Setting CMA in armbian
Go to solution Solved by ajellisuk,
Hello
I need to increase the size of the CMA on my armbian set up. But I've not found a way to do it.
Is there a kernel command line option I need to pass to increase the CMA size, or is this done in the kernel configuration before building?
Thanks in advance
Andrew
  • Solution
Thank you for the link.
For the benefit of anyone else who may come accross this post:
I added the following line to "/boot/boot.cmd/"
setenv bootargs "${bootargs} cma=xM"
where x is the size of RAM allocated to CMA.
I then compiled the file with:
mkimage -C none -A arm -T script -d /boot/boot.cmd /boot/boot.scr
Hopefully this will help anyone else who runs into this issue.
Andrew
