FRANK333 Posted November 7, 2021 Posted November 7, 2021 good evening, on orange pzero+ with debian10 i tried to install docker with the procedure of the armbian manual, but the installation fails. do you know how to solve? apt-get remove docker docker-engine docker.io containerd runc apt-get install apt-transport-https ca-certificates curl gnupg-agent software-properties-common curl -fsSL https://download.docker.com/linux/debian/gpg | apt-key add - add-apt-repository "deb [arch=arm64] https://download.docker.com/linux/debian $(lsb_release -cs) stable" apt update apt-get install docker-ce docker-ce-cli containerd.io result: ● docker.service - Docker Application Container Engine Loaded: loaded (/lib/systemd/system/docker.service; enabled; vendor preset: enabled) Drop-In: /etc/systemd/system/docker.service.d └─override.conf Active: activating (auto-restart) (Result: exit-code) since Sun 2021-11-07 19:36:34 CET; 54ms ago Docs: https://docs.docker.com Process: 10722 ExecStart=/usr/bin/dockerd -H fd:// -H tcp://0.0.0.0:2736 (code=exited, status=1/FAILURE) Main PID: 10722 (code=exited, status=1/FAILURE) dpkg: error processing package docker-ce (--configure): installed docker-ce package post-installation script subprocess returned error exit status 1 Processing triggers for man-db (2.8.5-2) ... Processing triggers for systemd (241-7~deb10u8) ... Errors were encountered while processing: docker-ce E: Sub-process /usr/bin/dpkg returned an error code (1) root@server:~# service docker status ● docker.service - Docker Application Container Engine Loaded: loaded (/lib/systemd/system/docker.service; enabled; vendor preset: enabled) Drop-In: /etc/systemd/system/docker.service.d └─override.conf Active: failed (Result: exit-code) since Sun 2021-11-07 19:38:39 CET; 9min ago Docs: https://docs.docker.com Process: 11195 ExecStart=/usr/bin/dockerd -H fd:// -H tcp://0.0.0.0:2736 (code=exited, status=1/FAILURE) Main PID: 11195 (code=exited, status=1/FAILURE) Nov 07 19:38:39 server systemd[1]: docker.service: Service RestartSec=2s expired, scheduling restart. Nov 07 19:38:39 server systemd[1]: docker.service: Scheduled restart job, restart counter is at 7. Nov 07 19:38:39 server systemd[1]: Stopped Docker Application Container Engine. Nov 07 19:38:39 server systemd[1]: docker.service: Start request repeated too quickly. Nov 07 19:38:39 server systemd[1]: docker.service: Failed with result 'exit-code'. Nov 07 19:38:39 server systemd[1]: Failed to start Docker Application Container Engine.
