jcyr Posted November 16, 2021 Posted November 16, 2021 Armbianmonitor: http://ix.io/3FaS Got this error this morning doing apt upgrade! Not sure what the issue is, there seems to be plenty of space. _ _ ____ _ __ __ _ ___ ______ | \ | | _ \(_) | \/ | || \ \ / /___ \ | \| | |_) | | | |\/| | || |\ \ / / __) | | |\ | __/| | | | | |__ _\ V / / __/ |_| \_|_| |_| |_| |_| |_| \_/ |_____| Welcome to Armbian 21.08.5 Focal with Linux 5.10.63-rockchip64 Calculating upgrade... Done The following packages will be upgraded: armbian-bsp-cli-nanopim4v2 armbian-config armbian-firmware linux-libc-dev 4 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. Need to get 9,657 kB of archives. After this operation, 126 kB of additional disk space will be used. Do you want to continue? [Y/n] y Get:1 http://armbian.tnahosting.net/apt focal/focal-utils arm64 armbian-bsp-cli-nanopim4v2 arm64 21.08.5 [419 kB] Get:3 http://mirror.12z.eu/pub/linux/armbian/apt focal/main arm64 armbian-firmware all 21.08.5 [7,933 kB] Get:2 http://armbian.tnahosting.net/apt focal/main arm64 armbian-config all 21.08.5 [126 kB] Get:4 http://mirror.12z.eu/pub/linux/armbian/apt focal/main arm64 linux-libc-dev arm64 21.08.4 [1,179 kB] Fetched 9,657 kB in 3s (3,863 kB/s) (Reading database ... 84278 files and directories currently installed.) Preparing to unpack .../armbian-bsp-cli-nanopim4v2_21.08.5_arm64.deb ... Unpacking armbian-bsp-cli-nanopim4v2 (21.08.5) over (21.08.3) ... Preparing to unpack .../armbian-config_21.08.5_all.deb ... Unpacking armbian-config (21.08.5) over (21.08.3) ... Preparing to unpack .../armbian-firmware_21.08.5_all.deb ... Unpacking armbian-firmware (21.08.5) over (21.08.3) ... Preparing to unpack .../linux-libc-dev_21.08.4_arm64.deb ... Unpacking linux-libc-dev:arm64 (21.08.4) over (21.08.2) ... Setting up linux-libc-dev:arm64 (21.08.4) ... Setting up armbian-bsp-cli-nanopim4v2 (21.08.5) ... Setting up armbian-config (21.08.5) ... Setting up armbian-firmware (21.08.5) ... Processing triggers for initramfs-tools (0.136ubuntu6.6) ... update-initramfs: Generating /boot/initrd.img-5.10.63-rockchip64 update-initramfs: Converting to u-boot format E: Write error - ~LZMAFILE (28: No space left on device) Reading package lists... Done Building dependency tree Reading state information... Done 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. pi@data:~$ df /tmp -h Filesystem Size Used Avail Use% Mounted on tmpfs 1.9G 4.0K 1.9G 1% /tmp pi@data:~$ df / -h Filesystem Size Used Avail Use% Mounted on /dev/mmcblk2p1 15G 4.1G 9.5G 30% /
