mhel Posted November 19, 2021 Posted November 19, 2021 Hello, I'm attempting to port an unknown rk3399 board to Linux from Android with kernerl 4.4. I managed to extract the devicetree and it's slowly coming along with poking arround and mixing and matching and comparing devicetrees (it's not easy but I got time ;-) ) The board uses a tc358775 converter for the lvds display since the rk3399 doesn't have one built in. With patch from here: https://forum.armbian.com/topic/16747-orange-pi-4-kernel-510y-mipi-dsi-panel-sucessful/ it started to show some signs of life. The screen is lighting up seems to have activities but it's just showing bars. I'm not sure if it's a timing issues, but I used the exact values from extracted dtb, another I'm not sure are the dsi/panel properties from old dtb if useable on my reconstructed devicetree. I'm testing this on mainline 5.14, I tried on 5.10.y but I can't get it to show activities only flashing RGB colours. Now, there's actually a driver for the converter, but I can't figure out how to use it yet, so I'm sticking with the simple panel. If anyone could point me in the right direction that would be great. Here's my dsi tree: &mipi_dsi { status = "okay"; ports { #address-cells = <1>; #size-cells = <0>; mipi_out: port@1 { reg = <1>; mipi_out_panel: endpoint { remote-endpoint = <&panel_in_mipi>; }; }; }; lcd_panel: panel@0 { compatible = "panel-dsi-simple"; reg = <0>; backlight = <&backlight>; power-supply = <&vcc_lcd>; enable-delay-ms = <100>; enable-gpios = <&gpio1 RK_PC2 GPIO_ACTIVE_HIGH>; reset-gpios = <&gpio1 RK_PD0 GPIO_ACTIVE_HIGH>; /* prepare-delay-ms = <100>; reset-delay-ms = <20>; */ dsi,flags = <0xa03>; dsi,format = <0>; dsi,lanes = <4>; rockchip,lane-rate = <890>; panel-init-sequence = [ 29 02 06 14 01 07 00 00 00 29 02 06 3c 01 0b 00 08 00 29 02 06 64 01 0e 00 00 00 29 02 06 68 01 0e 00 00 00 29 02 06 6c 01 0e 00 00 00 29 02 06 70 01 0e 00 00 00 29 02 06 34 01 1f 00 00 00 29 02 06 10 02 1f 00 00 00 29 02 06 04 01 01 00 00 00 29 02 06 04 02 01 00 00 00 29 02 06 50 04 30 01 f0 03 29 02 06 54 04 14 00 50 00 // hsync-len, hback-porch // 04 54 00 50 00 14 29 02 06 58 04 80 07 c8 00 // hfront-porch, hactive // 04 58 00 c8 07 80 29 02 06 5c 04 02 00 08 00 // 04 5c 00 08 00 02 // vback-porch, vsync-len 29 02 06 60 04 38 04 28 00 // 04 60 00 28 04 38 // vfront-porch, vactive 29 02 06 64 04 01 00 00 00 29 02 06 a0 04 06 80 44 00 29 02 06 a0 04 06 80 04 00 29 02 06 04 05 04 00 00 00 29 02 06 80 04 00 02 02 03 29 02 06 84 04 04 07 05 08 29 02 06 88 04 09 0a 0e 0f 29 02 06 8c 04 0b 0c 0d 10 29 02 06 90 04 16 17 11 12 29 02 06 94 04 13 14 15 1b 29 02 06 98 04 18 19 1a 06 29 78 06 9c 04 33 04 00 00 ]; panel-exit-sequence = [05 05 01 28 05 78 01 10]; display-timings { native-mode = <&timing3>; timing3: timing3 { clock-frequency = <148000000>; hactive = <1920>; vactive = <1080>; hback-porch = <80>; hsync-len = <20>; hfront-porch = <200>; vback-porch = <8>; vfront-porch = <40>; vsync-len = <2>; hsync-active = <0>; vsync-active = <0>; de-active = <0>; pixelclk-active = <0>; }; }; port { panel_in_mipi: endpoint { remote-endpoint = <&mipi_out_panel>; }; }; }; }; and here's what I get poking some register, that seem to look correct :
