ZTE ZXV10 B860H RAM 1GB (error running after install_aml.sh)
dear,
please help me, my trouble is can't run after running install_aml.sh.
i am use image from  :https://disk.yandex.ru/d/_rQgn_FosYuW0g/20.10/20201014 version Armbian_20.10_Arm-64_buster_current_5.9.0.img.xz
hardware used STB ZTE ZXV10 B860H RAM 1GB,
detail log version dtb
-----board_version[9]
      unified board, board id adc = 9
Fiberhome GPIOAO_4 power on!!!!!      Multi dtb tool version: v2 .
      Support 3 dtbs.
        aml_dt soc: gxl platform: p212 variant: 1g
        dtb 0 soc: gxl   plat: p212   vari: 1g
        dtb 1 soc: gxl   plat: p212   vari: 2g
        dtb 2 soc: gxl   plat: p215   vari: 1g
      Find match dtb: 0
detail after run Sdcard and install_aml.sh status success
Start script create MBR and filesystem
/dev/mmcblk1
Start backup u-boot default
4+0 records in
4+0 records out
4194304 bytes (4.2 MB, 4.0 MiB) copied, 0.244996 s, 17.1 MB/s
Start create MBR and partittion
Start restore u-boot
442+0 records in
442+0 records out
442 bytes copied, 0.00461932 s, 95.7 kB/s
8191+0 records in
8191+0 records out
4193792 bytes (4.2 MB, 4.0 MiB) copied, 0.216712 s, 19.4 MB/s
Done
Start copy system for eMMC.
Formatting BOOT partition...mkfs.fat 4.1 (2017-01-24)
done.
Cppying BOOT...done.
Edit init config...done.
done.
Formatting ROOT partition...
e2fsck 1.44.5 (15-Dec-2018)
ROOT_EMMC: clean, 11/385024 files, 46572/1539584 blocks
done.
Copying ROOTFS.
Copy BIN
Create DEV
Copy ETC
Copy HOME
Copy LIB
Copy LIB64
Create MEDIA
Create MNT
Copy OPT
Create PROC
Copy ROOT
Create RUN
Copy SBIN
Copy SELINUX
Copy SRV
Create SYS
Create TMP
Copy USR
Copy VAR
Copy fstab
Complete copy OS to eMMC
after i am halt and unplug sdcard, armbian not running.
U-Boot 2015.01 (Aug 15 2018 - 12:27:30)
DRAM:  1 GiB
Relocation Offset is: 36ec9000
gpio: pin GPIOAO_6 (gpio 106) value is 0
gpio: pin GPIOH_8 (gpio 57) value is 1
gpio: pin GPIOH_9 (gpio 58) value is 0
gpio: pin GPIOAO_9 (gpio 109) value is 0
gpio: pin GPIOAO_5 (gpio 105) value is 1
register usb cfg[0][1] = 0000000037f5f9d8
vpu: error: vpu: check dts: FDT_ERR_BADMAGIC, load default parameters
vpu: clk_level = 7
vpu: set clk: 666667000Hz, readback: 666660000Hz(0x300)
vpp: vpp_init
boot_device_flag : 1
Nand PHY Ver:1.01.001.0006 (c) 2013 Amlogic Inc.
init bus_cycle=6, bus_timing=7, system=5.0ns
reset failed
get_chip_type and ret:fffffffe
chip detect failed and ret:fffffffe
nandphy_init failed and ret=0xfffffff1
MMC:   aml_priv->desc_buf = 0x0000000033ec9dd0
aml_priv->desc_buf = 0x0000000033ecc0f0
SDIO Port B: 0, SDIO Port C: 1
emmc/sd response timeout, cmd8, status=0x1ff2800
emmc/sd response timeout, cmd55, status=0x1ff2800
[mmc_init] mmc init success
mmc read lba=0x14000, blocks=0x400
      Amlogic multi-dtb tool
      Multi dtb detected
GPIOAO_4 value board_id_gpio = 1
saradc: check dts: FDT_ERR_BADMAGIC, load default parameters
      Support 3 dtbs.
      Find match dtb: 0
start dts,buffer=0000000033ece970,dt_addr=0000000033ecf170
parts: 11
00:      logo    0000000001000000 1
01:  recovery    0000000001800000 1
02:       rsv    0000000000800000 1
03:       tee    0000000000800000 1
04:     crypt    0000000002000000 1
05:      misc    0000000000400000 1
06:      conf    0000000000400000 1
07:      boot    0000000001000000 1
08:     cache    0000000037a00000 2
09:    system    000000006cc00000 1
10:      data    ffffffffffffffff 4
get_dtb_struct: Get emmc dtb OK!
overide_emmc_partition_table: overide cache
[mmc_get_partition_table] skip partition cache.
Partition table get from SPL is :
        name                        offset              size              flag
   0: bootloader                         0            400000                  0
   1: reserved                     2400000           4000000                  0
   2: cache                        6c00000          37a00000                  2
   3: env                         3ee00000            800000                  0
   4: logo                        3fe00000           1000000                  1
   5: recovery                    41600000           1800000                  1
   6: rsv                         43600000            800000                  1
   7: tee                         44600000            800000                  1
   8: crypt                       45600000           2000000                  1
   9: misc                        47e00000            400000                  1
  10: conf                        48a00000            400000                  1
  11: boot                        49600000           1000000                  1
  12: system                      4ae00000          6cc00000                  1
  13: data                        b8200000         119fd0000                  4
mmc read lba=0x12000, blocks=0x2
mmc read lba=0x12002, blocks=0x2
mmc_read_partition_tbl: mmc read partition OK!
eMMC/TSD partition table have been checked OK!
mmc env offset: 0x3ee00000
In:    serial
Out:   serial
Err:   serial
reboot_mode=cold_boot
board_late_init,defenv!
hpd_state=0
cvbs performance type = 6, table = 1
[store]To run cmd[emmc dtb_read 0x1000000 0x40000]
read emmc dtb
      Multi dtb detected
      Support 3 dtbs.
      Find match dtb: 0
Net:   dwmac.c9410000
wipe_data=successful
wipe_cache=successful
upgrade_step=2
[OSD]load fb addr from dts
[OSD]fb_addr for logo: 0x3f400000
[CANVAS]canvas init
[CANVAS]addr=0x3f400000 width=3840, height=2160
Err imgread(L340):Logo header err.
There is no valid bmp file at the given address
amlkey_init() enter!
[EFUSE_MSG]keynum is 4
[KM]Error:f[key_manage_query_size]L507:key[usid] not programed yet
[KM]Error:f[key_manage_query_size]L507:key[mac] not programed yet
[KM]Error:f[key_manage_query_size]L507:key[deviceid] not programed yet
gpio: pin GPIOAO_2 (gpio 102) value is 1
InUsbBurn
noSof
Hit Enter or space or Ctrl+C key to stop autoboot -- :  1 0
card out
emmc/sd response timeout, cmd1, status=0x1ff2800
(Re)start USB...
USB0:   USB3.0 XHCI init start
Register 2000140 NbrPorts 2
Starting the controller
USB XHCI 1.00
scanning bus 0 for devices... 1 USB Device(s) found
** Bad device usb 0 **
** Bad device usb 1 **
** Bad device usb 2 **
** Bad device usb 3 **
reading emmc_autoscript
174 bytes read in 10 ms (16.6 KiB/s)
## Executing script at 01020000
## Error: "bootfromsd" not defined
reading u-boot.emmc
650183 bytes read in 29 ms (21.4 MiB/s)
## Starting application at 0x01000000 ...
sincelery yours,
yunus
I have more STB and i am try to STB2, log look different with a hardware.
STB ZTE ZXV10 B860H RAM 2GB, but log result detected 1Gb
set vddee to 1070 mv
U-Boot 2015.01-ge1b7b3f-dirty (Aug 24 2017 - 23:11:22)
DRAM:  1 GiB
Relocation Offset is: 3eeaf000
after i'm used uboot (activate multi boot, MMC and Sdcard.uboot_HG860H, the result log is looping)
dd if=uboot_HG680P.bin of=/dev/block/bootloader
8192+0 records in
8192+0 records out
4194304 bytes transferred in 0.445 secs (9425402 bytes/sec)
root@pulpstone_b860h:/sdcard/Download # reboot update
SysRq : Emergency Remount R/O
reboot: Restarting systå~~~~....................................................................set vcck to 1120 mv
set vddee to 1000 mv
Full LOG
DRAM:  1 GiB
Starting uboot
-----board_version[8]
gpio: pin GPIOAO_6 (gpio 106) value is 1
gpio: pin GPIOCLK_1 (gpio 99) value is 1
gpio: pin GPIOAO_4 (gpio 104) value is 1
gpio: pin GPIOX_15 (gpio 15) value is 1
register usb cfg[0][1] = 000000003ff59d60
[CANVAS]canvas init
vpu: clk_level = 7
vpp: vpp_init
reset failed
MMC:   aml_priv->desc_buf = 0x000000003beafdb0
aml_priv->desc_buf = 0x000000003beb20d0
[mmc_startup] mmc refix success
      Multi dtb detected
checkhw: g_board_type = 0x8
      Support 3 dtbs.
      Find match dtb: 0
start dts,buffer=000000003beb4eb0,dt_addr=000000003beb56b0
parts: 11
   2: env                          6500000            800000                  0
   3: logo                         6e00000           1000000                  1
   4: recovery                     7f00000           1800000                  1
   5: rsv                          9800000            800000                  1
   6: tee                          a100000            800000                  1
   7: crypt                        aa00000           2000000                  1
   8: misc                         cb00000            400000                  1
   9: conf                         d000000            400000                  1
  10: boot                         d500000           1000000                  1
  11: cache                        e600000          37a00000                  2
  12: system                      46100000          6cc00000                  1
  13: data                        b2e00000         11f200000                  4
mmc env offset: 0x6500000
In:    serial
Out:   serial
Err:   serial
------reboot_mode(0xc810023c)=0x0
hpd_state=0
cvbs performance type = 6, table = 0
read emmc dtb
      Multi dtb detected
      Support 3 dtbs.
      Find match dtb: 0
card in
Device: SDIO Port B
Manufacturer ID: 12
OEM: 3456
Name: SDTran Speed: 50000000
Rd Block Len: 512
SD version 2.0
High Capacity: Yes
Capacity: 3.7 GiB
mmc clock: 40000000
Bus Width: 4-bit
Net:   dwmac.c9410000
zteDbg: original preboot=run init_display;run storeargs;run irremote_update;run upgrade_key;run switch_bootmode;
zteDbg: current preboot=run init_display;run storeargs;run irremote_update;run upgrade_key;run switch_bootmode;
[CANVAS]addr=0x3f400000 width=5760, height=2160
## Error: "irremote_update" not defined
gpio: pin GPIOAO_2 (gpio 102) value is 0
detect upgrade key
ztebsp: bootcmd=jpeg ${outputmode};bootsys
 0
Starting logo
[Logo_disp]: ====== Logo_disp ======
[draw_logo] size=0x15e48, ntohl(imgheader.len)=0x15de8, ntohs(imgheader.offset)=0x60
[draw_logo] after ALIGN, size=0x16000
[draw_logo]: before read_logo_data
[draw_logo]: draw_logo 1482
[draw_logo]: draw_logo 1484
[set_logoParam]: enter the set_logoParam
[set_logoParam]:  Id        FileName        Type        No         Addr            Size
[set_logoParam]: before the get_logo_source PAL_LOGO_PICTURE
### get_logo_source: material.type=0, material.No=1
[set_logoParam]:  <0>        LogoPic(480i)        0        1        0x110000f0        25466
### get_logo_source: material.type=0, material.No=2
[set_logoParam]:  <1>        LogoPic(576i)        0        2        0x1100646c        19222
### get_logo_source: material.type=0, material.No=3
[set_logoParam]:  <2>        LogoPic(720p)        0        3        0x1100af84        19222
### get_logo_source: material.type=0, material.No=4
[set_logoParam]:  <3>        LogoPic(1080i_p)    0        2        0x1100fa9c        25466
[draw_logo]: draw_logo 1527
before the  decompressToRGB
Start to decode the LOGO jpeg ...
[decompressToRGB]: before the decompress_jpeg_rgb
[decompressToRGB]: Call decompress_pic_rgb565(id=3,addr=1100fa9c,size=25466,maxw=1920,maxh=1080,Bpp=3) ...
[decompressToRGB]: after the decompress_jpeg_rgb
[draw_logo]: Success in decoding LOGO src file:    (w=1920,h=1080,Bpp=3,data=0x3c52f0e0)
[deinit_Logo]: all LOGO's resource (Exc. logoThread) are released
Logo_disp ret: 0
ztebsp:boot_revision = V811005,23:11:25
read boot-recovery from misc failed.
ztebsp: ethaddr=04:95:73:EE:32:2A
[setup_bootenv] ScreenMode=>   value[7]=2, val=2
Saving Environment to aml-storage...
Writing to MMC(1)... done
not found mac in efuse
bootmode:NORM
ztebsp: head magic=55667788
ztebsp: cmdT = imgread kernel boot ${loadaddr}; store dtb read ${dtb_mem_addr}; bootm ${loadaddr}
bootargs=rootfstype=ramfs init=/init console=ttyS0,115200 no_console_suspend earlyprintk=aml-uart,0xc81004c0 ramoops.pstore_en=1 ramoops.record_size=0x8000 ramoops.console_size=0x4000 androidboot.selinux=permissive logo=osd1,loaded,0x3d800000,576cvbs maxcpus=4 vout=576cvbs,enable hdmimode=1080p60hz cvbsmode=576cvbs hdmitx= rxsen1 cvbsdrv=0 androidboot.firstboot=0 jtag=apee androidboot.hardware=amlogic mac=04:95:73:EE:32:2A system=norm runlevel=0 boot_revision=V811005 boardtype=8 loglevel=1 uimode=1080p CTSEnable=0 market=3601,1 hdcp_process=0 ProductID=88100499007037000000049573EE322A
[imgread]szTimeStamp[2018081520461378]
[imgread]secureKernelImgSz=0x94f000
read emmc dtb
      Multi dtb detected
      Support 3 dtbs.
      Find match dtb: 0
ee_gate_off ...
## Booting Android Image at 0x01080000 ...
reloc_addr =3bf35080
copy done
use dts in boot.img/recovery.img instead of dts partition.
      Multi dtb detected
      Support 3 dtbs.
      Find match dtb: 0
L258:
L260:
L266:load dtb from 0x1000000 ......
   Uncompressing Kernel Image ... OK
   kernel loaded at 0x01080000, end = 0x0201b670
   Loading Ramdisk to 3bc3b000, end 3be9d000 ... OK
   Loading Device Tree to 000000001fff3000, end 000000001ffff4b7 ... OK
fdt_instaboot: no instaboot image
Starting kernel ...
uboot time: 4641429 us
Initializing cgroup subsys cpu
Initializing cgroup subsys cpuacct
Linux version 3.14.29-g0184957 (stb-android@ubuntu-129) (gcc version 4.9.2 20140904 (prerelease) (crosstool-NG linaro-1.13.1-4.9-2014.09 - Linaro GCC 4.9-2014.09) ) #1 SMP PREEMPT Wed Aug 15 20:38:06 HKT 2018
CPU: AArch64 Processor [410fd034] revision 4
no prop version_code
bootconsole [earlycon0] enabled
Initramfs unpacking failed: junk in compressed archive
root@pulpstone_b860h:/ # Hello Jten!!!
This Device Root by Pulpstone
root@pulpstone_b860h:/ # cp  ls -la
drwxr-xr-x root     root              2015-01-01 07:00 acct
drwxr-xr-x root     root              1970-01-01 07:00 boot
drwxrwx--- system   cache             2015-01-01 07:00 cache
lrwxrwxrwx root     root              1970-01-01 07:00 charger -> /sbin/healthd
dr-x------ root     root              2015-01-01 07:00 config
lrwxrwxrwx root     root              2015-01-01 07:00 d -> /sys/kernel/debug
drwxrwx--x system   system            2015-01-01 07:02 data
-rw-r--r-- root     root          600 1970-01-01 07:00 default.prop
drwxr-xr-x root     root              2015-01-01 07:00 dev
lrwxrwxrwx root     root              2015-01-01 07:00 etc -> /system/etc
drwxr-xr-x root     root              2015-01-01 07:00 factory
-rw-r--r-- root     root        20175 1970-01-01 07:00 file_contexts
-rw-r----- root     root         1613 1970-01-01 07:00 fstab.amlogic
-rwxr-x--- root     root       665104 1970-01-01 07:00 init
-rwxr-x--- root     root         4195 1970-01-01 07:00 init.amlogic.board.rc
-rwxr-x--- root     root        19848 1970-01-01 07:00 init.amlogic.rc
-rwxr-x--- root     root         4226 1970-01-01 07:00 init.amlogic.usb.rc
-rwxr-x--- root     root         1284 1970-01-01 07:00 init.amlogic.wifi.rc
-rwxr-x--- root     root         1263 1970-01-01 07:00 init.environ.rc
-rwxr-x--- root     root        27078 1970-01-01 07:00 init.rc
-rwxr-x--- root     root         2091 1970-01-01 07:00 init.trace.rc
-rwxr-x--- root     root         9283 1970-01-01 07:00 init.usb.configfs.rc
-rwxr-x--- root     root         5339 1970-01-01 07:00 init.usb.rc
-rwxr-x--- root     root          342 1970-01-01 07:00 init.zygote32.rc
drwxr-xr-x root     system            2015-01-01 07:00 mnt
drwxr-xr-x root     root              1970-01-01 07:00 oem
dr-xr-xr-x root     root              1970-01-01 07:00 proc
-rw-r--r-- root     root         4381 1970-01-01 07:00 property_contexts
drwx------ root     root              2018-08-15 19:37 root
drwxr-x--- root     root              1970-01-01 07:00 sbin
lrwxrwxrwx root     root              2015-01-01 07:00 sdcard -> /storage/self/primary
-rw-r--r-- root     root          647 1970-01-01 07:00 seapp_contexts
-rw-r--r-- root     root           73 1970-01-01 07:00 selinux_version
-rw-r--r-- root     root       170705 1970-01-01 07:00 sepolicy
-rw-r--r-- root     root        10545 1970-01-01 07:00 service_contexts
drwxr-xr-x root     root              2015-01-01 07:00 storage
drwxr-xr-x root     root              1970-01-01 07:00 swap_zram0
dr-xr-xr-x root     root              2015-01-01 07:00 sys
drwxr-xr-x root     root              2015-01-01 07:00 system
drwxrwxr-x root     system            2015-01-01 07:00 tmp
drwxr-xr-x root     root              2015-01-01 07:00 tmp-mksh
-rw-r--r-- root     root         3369 1970-01-01 07:00 ueventd.amlogic.rc
-rw-r--r-- root     root         5083 1970-01-01 07:00 ueventd.rc
drwxrwxr-x root     system            2015-01-01 07:00 var
lrwxrwxrwx root     root              2015-01-01 07:00 vendor -> /system/vendor
-rw-r--r-- root     root          297 1970-01-01 07:00 zte_init.rc
-rw-r--r-- root     root         1982 1970-01-01 07:00 zte_middleware.rc
root@pulpstone_b860h:/ # cd /stor
root@pulpstone_b860h:/ # cd /storage/
root@pulpstone_b860h:/storage # cd 8
root@pulpstone_b860h:/storage # cd 8005-D9A5/
root@pulpstone_b860h:/storage/8005-D9A5 # ls -la
drwxrwx--x root     sdcard_rw          2015-01-01 00:13 Android
drwxrwx--x root     sdcard_rw          2015-01-01 07:03 LOST.DIR
drwxrwx--x root     sdcard_rw          2021-12-13 22:19 System Volume Information
-rwxrwx--x root     sdcard_rw 16777216 2019-08-02 18:30 boot.img
-rwxrwx--x root     sdcard_rw  4194304 2019-07-31 23:56 bootloader.img
-rwxrwx--x root     sdcard_rw      345 2021-12-19 21:39 password
-rwxrwx--x root     sdcard_rw   650183 2021-12-15 16:59 u-boot-s905x-s912.bin
-rwxrwx--x root     sdcard_rw  1229408 2018-08-05 23:28 u-boot.bin
-rwxrwx--x root     sdcard_rw   709768 2021-03-05 19:31 u-boot.sd
-rwxrwx--x root     sdcard_rw   709768 2021-03-05 19:31 u-boot.usb
-rwxrwx--x root     sdcard_rw  1229408 2019-03-06 03:25 uboot_B860H.bin
-rwxrwx--x root     sdcard_rw  4194304 2018-11-11 07:07 uboot_HG680P.bin
root@pulpstone_b860h:/storage/8005-D9A5 # cp ub
uboot_B860H.bin     uboot_HG680P.bin
root@pulpstone_b860h:/storage/8005-D9A5 # cp uboot_                            _ HG
p uboot_HG680P.bin                                                            <   /sdc
p uboot_HG680P.bin /sdcard/                                                   <Dow
p uboot_HG680P.bin /sdcard/Download/                                          <
root@pulpstone_b860h:/storage/8005-D9A5 # cd /sd
root@pulpstone_b860h:/storage/8005-D9A5 # cd /sdcard/                          doiw  wn
/system/bin/sh: cd: /sdcard/down: No such file or directory
2|root@pulpstone_b860h:/storage/8005-D9A5 # cd /sdcar
d /sdcard/        <Do
d /sdcard/Download/                                                           <
root@pulpstone_b860h:/sdcard/Download # ls- la
/system/bin/sh: ls-: not found
127|root@pulpstone_b860h:/sdcard/Download # ls
uboot_HG680P.bin
root@pulpstone_b860h:/sdcard/Download # dd if=u
d if=uboot_HG680P.bin                                                         < of=/dev/bloc
d if=uboot_HG680P.bin of=/dev/block/                                          <bootlo
d if=uboot_HG680P.bin of=/dev/block/bootloader                                <
8192+0 records in
8192+0 records out
hai... @yunus, got the same board. how do you manage to boot armbian? i've try many ways but no luck to boot armbian.
board number 1 or number 2?
i am not running board number 2
but board number 1 running on sdcard, not for emmc.
Edited by yunus
wrong number
7 minutes ago, d4l170 said:
my board is number 2, product of PT HEXING
same i'm not runing to but my board provided by PT.Star Global Indonesia.
