wuhanstudio Posted January 27, 2022 Posted January 27, 2022 (edited) Armbianmonitor: http://ix.io/3NF9 Hi, I was trying to use OrangePi One to add a filter to my USB camera, so that I can apply some image processing to the original input image. The original project uses raspberrypi: https://github.com/likeablob/rpi-wfh-webcam It captures the image from a USB Camera, then applys some image processing on Raspberry Pi. Lastly, it creates a virtual camera that sends the output image to the PC. I would like to achieve the same effect using OrangePi One (Armbian), and the only problem left is to simulate a virtual camera using the USB Gadget. What I tried: $ sudo modprobe g_webcam musb-hdrc.4.auto: failed to start g_webcam: -22 According to this post, a more preferred way to do this is to use configfs: I followed instructions here: https://developer.ridgerun.com/wiki/index.php?title=How_to_use_the_UVC_gadget_driver_in_Linux But unfortunately, it returned with the same error: Invalid Argument: sudo modprobe libcomposite dwc2 usb_f_uvc mkdir -p /sys/kernel/config/usb_gadget/g1 cd /sys/kernel/config/usb_gadget/g1 echo 0x0525 > idVendor echo 0x0102 > idProduct mkdir -p strings/0x409 echo 0123456789 > strings/0x409/serialnumber echo $(hostname) > strings/0x409/manufacturer echo "UVC Gadget" > strings/0x409/product mkdir configs/c.1 mkdir configs/c.1/strings/0x409 mkdir functions/uvc.0 mkdir -p functions/uvc.0/streaming/uncompressed/u/360p cat <<EOF > functions/uvc.0/streaming/uncompressed/u/360p/dwFrameInterval 666666 1000000 5000000 EOF mkdir functions/uvc.0/streaming/header/h cd functions/uvc.0/streaming/header/h ln -s ../../uncompressed/u cd ../../class/fs ln -s ../../header/h cd ../../class/hs ln -s ../../header/h cd ../../class/ss ln -s ../../header/h cd ../../../control mkdir -p header/h ln -s header/h class/fs ln -s header/h class/ss cd ../../../ echo 2048 > functions/uvc.0/streaming_maxpacket ln -s functions/uvc.0 configs/c.1 ls /sys/class/udc > UDC Does this mean the Allwinner H2/H3 USB IP Core does not support g_webcam / usb_f_uvc ? (Both g_serial and g_eth works, but not g_webcam) Edited January 27, 2022 by wuhanstudio
