Chris4arm Posted February 6, 2022 Posted February 6, 2022 Hi, I run Armbian 20.10 with kernel 5.9.0-arm-64 on a S905x TV box and ~20 times a day the following lines appear in the logs : 525418.166366] WARNING: CPU: 2 PID: 1966008 at kernel/time/hrtimer.c:932 hrtimer_forward+0x88/0xc0 [525418.166372] Modules linked in: nfnetlink bnep 8192eu zram nls_ascii rtl8xxxu mac80211 cfg80211 crct10dif_ce hci_uart btqca meson_vdec(C) btrtl btbcm v4l2_mem2mem btintel videobuf2_dma_contig lima bluetooth videobuf2_memops videobuf2_v4l2 gpu_sched meson_ir videobuf2_common rc_core ecdh_generic videodev dw_hdmi_cec ecc rfkill mc ao_cec display_connector fuse ip_tables x_tables ipv6 [525418.166505] CPU: 2 PID: 1966008 Comm: kworker/u8:3 Tainted: G WC 5.9.0-arm-64 #20.10 [525418.166512] Hardware name: Amlogic Meson GXL (S905X) P212 Development Board (DT) [525418.166534] Workqueue: events_freezable_power_ thermal_zone_device_check [525418.166550] pstate: 20000085 (nzCv daIf -PAN -UAO BTYPE=--) [525418.166561] pc : hrtimer_forward+0x88/0xc0 [525418.166573] lr : txdone_hrtimer+0xf4/0x110 [525418.166579] sp : ffff800010013e20 [525418.166585] x29: ffff800010013e20 x28: ffff800011e14dd0 [525418.166596] x27: ffff00003fc22240 x26: 0000000000000006 [525418.166606] x25: 0000000000000001 x24: 0000000000000001 [525418.166616] x23: ffff00003f16cbe8 x22: 00000000000000f8 [525418.166626] x21: ffff00003f16cbb8 x20: ffff00003f16cac0 [525418.166636] x19: 00000000000f4240 x18: 0000000000001800 [525418.166646] x17: 0000000000001400 x16: 0000000000001c00 [525418.166656] x15: 0000000000000000 x14: 0000000000000052 [525418.166666] x13: 0000000000000000 x12: 0000000000000000 [525418.166676] x11: 0000000000000040 x10: ffff800012a37ef8 [525418.166686] x9 : ffff800012a37ef0 x8 : ffff00003f4026f0 [525418.166696] x7 : 0000000000000000 x6 : 00000b78184130b1 [525418.166706] x5 : 0001ddd97b207643 x4 : ffff00003f16cbe8 [525418.166716] x3 : 0000000000000001 x2 : 00000000000f4240 [525418.166726] x1 : 0001ddd97b2079ae x0 : 000000000000036b [525418.166737] Call trace: [525418.166751] hrtimer_forward+0x88/0xc0 [525418.166764] __hrtimer_run_queues+0x114/0x1b8 [525418.166776] hrtimer_interrupt+0xe8/0x248 [525418.166789] arch_timer_handler_phys+0x34/0x48 [525418.166802] handle_percpu_devid_irq+0x84/0x148 [525418.166816] generic_handle_irq+0x30/0x48 [525418.166824] __handle_domain_irq+0x64/0xc0 [525418.166836] gic_handle_irq+0x54/0xa8 [525418.166847] el1_irq+0xcc/0x180 [525418.166860] _raw_spin_unlock_irqrestore+0xc/0x68 [525418.166874] wait_for_completion_timeout+0x84/0x100 [525418.166883] mbox_send_message+0xa0/0x120 [525418.166894] scpi_send_message+0x178/0x288 [525418.166904] scpi_sensor_get_value+0x40/0x90 [525418.166915] scpi_read_temp+0x58/0xc8 [525418.166924] of_thermal_get_temp+0x24/0x38 [525418.166936] thermal_zone_get_temp+0x70/0x158 [525418.166947] thermal_zone_device_update+0x78/0x128 [525418.166958] thermal_zone_device_check+0x18/0x28 [525418.166972] process_one_work+0x1a0/0x328 [525418.166981] worker_thread+0x4c/0x420 [525418.166993] kthread+0x140/0x160 [525418.167005] ret_from_fork+0x10/0x34 [525418.167012] ---[ end trace 3c3a4049aa377f8f ]--- Is the origin known ? Is there a fix ? Thanks
