Hello.
First, I have an LTS board that provides only 3.05 on the 3.3 pins. Is it normal ?
Anyway, in case this was the issue, I have built a new voltage regulator, and now supply the DHT22 and pullup resistor with 3.60V
My issue is simple: when plugged on normal 1W bus, the DHT22 kills the bus, and makes other devices non working. I have moved all other devices on a new bus, leaving the DHT on a bus I know works fine. Some people mentionned the DHT is not compliant with official 1W libraries, and can not be recognised with normal timings, so, special libs are required. I have removed param_w1_pin=PA06 for the hysical pin 7, and installed new software.
I have a very bad experience with python, and I have never been able to make any python lib/project, on any board of any brand; I always get some error at some point.
The only non python lib/app for DHT22 I have found is
https://github.com/pilkch/climbatize
but after heavily patching it (to fix various bugs), the app still seems unable to communicate with the probe.
I have checked more than 12 times the sensor is connected to the so called pin 7 (PA06), pin 2 in WiringPi, and changed the physical sensor (paid for  a new item).
Who can help reading this probe ? I am just running out of ideas.
The only issue that bothers me is that I am not physically 100% certain that Climbatize manipulates pin7. I have entered the loop that manipulates some pin, but at some point it's calling wiringPi, and my multimeter always shows 3.6V on the pin; I don't have a scope to check the pin goes down, and applying a LED on a pulledup pin will not produce a perceptible OFF time. I would need to solder an inverted gate to transform the logic, but even then, the light pulses may be too short for my eyes.
I really dont think 3.60V could burn the oPi board; and 3.05 could be a huge reason  for the DHT22 to refuse to work. I could plug a lab regulated supply, but I think it would be overkill.
I do have spare/new/unused boards; but all my LTS boards deliver 3.05. (yes I have some boards left in 2022; I had bought *MANY* spare ones years ago).
WORKS FOR ME
It was my VERY LAST try before giving up completely:
https://www.uugear.com/portfolio/read-dht1122-temperature-humidity-sensor-from-raspberry-pi/
fix the ping to 7 (instead of 3 in the source), compile with
cc -Wall dht.c -o dht -lwiringPi -pthread
and it does the job:
./dht
Raspberry Pi DHT11/DHT22 temperature/humidity test
Humidity = 46.0 % Temperature = 23.5 *C (74.3 *F)
Humidity = 37.9 % Temperature = 27.4 *C (81.3 *F)
Data not good, skip
Data not good, skip
Data not good, skip
Data not good, skip
Humidity = 37.5 % Temperature = 27.2 *C (81.0 *F)
Data not good, skip
Data not good, skip
Humidity = 37.7 % Temperature = 27.2 *C (81.0 *F)
Data not good, skip
Humidity = 37.6 % Temperature = 27.2 *C (81.0 *F)
Data not good, skip
Data not good, skip
Data not good, skip
Data not good, skip
Data not good, skip
Humidity = 37.6 % Temperature = 27.3 *C (81.1 *F)
Data not good, skip
Humidity = 37.7 % Temperature = 27.3 *C (81.1 *F)
Data not good, skip
Data not good, skip
Data not good, skip
Data not good, skip
Data not good, skip
Data not good, skip
Data not good, skip
According to other forums, 60% misses is ordinary for this probe.
Note that the very first value is completely wrong; I did not read anything about this, but I am not surprised. CO2 probes need 15 pre heat; and this is the very first successfull read of the probe, so some miss-configuration or badly initialised variable are likely. So, on production line, I will take care to ignore the first 3 values after service start/reboot.
In case the other website goes down, I will duplicate their original code here. Don't forget to fix your PIN number.
My WiringPi lib is probably https://github.com/zhaolei/WiringOP (not 100% certain).
 *  dht.c:
 *    read temperature and humidity from DHT11 or DHT22 sensor
#include <wiringPi.h>
#include <stdio.h>
#include <stdlib.h>
#include <stdint.h>
#define MAX_TIMINGS    85
#define DHT_PIN        3    /* GPIO-22 */
int data[5] = { 0, 0, 0, 0, 0 };
void read_dht_data()
    uint8_t laststate    = HIGH;
    uint8_t counter        = 0;
    uint8_t j            = 0, i;
    data[0] = data[1] = data[2] = data[3] = data[4] = 0;
    /* pull pin down for 18 milliseconds */
    pinMode( DHT_PIN, OUTPUT );
    digitalWrite( DHT_PIN, LOW );
    delay( 18 );
    /* prepare to read the pin */
    pinMode( DHT_PIN, INPUT );
    /* detect change and read data */
    for ( i = 0; i < MAX_TIMINGS; i++ )
        counter = 0;
        while ( digitalRead( DHT_PIN ) == laststate )
            counter++;
            delayMicroseconds( 1 );
            if ( counter == 255 )
                break;
        laststate = digitalRead( DHT_PIN );
            break;
        /* ignore first 3 transitions */
        if ( (i >= 4) && (i % 2 == 0) )
            /* shove each bit into the storage bytes */
            data[j / 8] <<= 1;
            if ( counter > 16 )
                data[j / 8] |= 1;
            j++;
     * check we read 40 bits (8bit x 5 ) + verify checksum in the last byte
     * print it out if data is good
    if ( (j >= 40) &&
         (data[4] == ( (data[0] + data[1] + data[2] + data[3]) & 0xFF) ) )
        float h = (float)((data[0] << 8) + data[1]) / 10;
        if ( h > 100 )
            h = data[0];    // for DHT11
        float c = (float)(((data[2] & 0x7F) << 8) + data[3]) / 10;
        if ( c > 125 )
            c = data[2];    // for DHT11
        if ( data[2] & 0x80 )
            c = -c;
        float f = c * 1.8f + 32;
        printf( "Humidity = %.1f %% Temperature = %.1f *C (%.1f *F)\n", h, c, f );
    }else  {
        printf( "Data not good, skip\n" );
int main( void )
    printf( "Raspberry Pi DHT11/DHT22 temperature/humidity test\n" );
    if ( wiringPiSetup() == -1 )
        exit( 1 );
    while ( 1 )
        read_dht_data();
        delay( 2000 ); /* wait 2 seconds before next read */
    return(0);
Thank you for sharing this! I have a DHT22 that i've been trying to get working with an OrangePi Lite and I've had terrible results with all of the python-based libraries i've tried. I'm getting about 25-30% of the readings with this every 2s, which is good enough for my purposes.
FWIW, my opi lite is showing about 5.2 and 3.8v for the 5V and 3.3V pins
