AliAhmadi Posted April 30, 2022 Posted April 30, 2022 Hello all. I have a Nanopi due2 with Armbian. I've enabled my SPI in armbianEnv.txt file and with: overlays=spi-add-cs1 spi-spidev usbhost0 usbhost2 usbhost3 param_spidev_spi_bus=1 param_spidev_spi_cs=1 but when I try to use "/dev/spidev1.1", CS pin is active high by default not active low. how can I change it to active low.
