I tried building current@4c54309b7b1c6
for opi+2e, dev, jessie, console, and saw those:
[ warn ] ... scripts-dtc-Update-to-version-with-overlays.patch [ failed ]
scripts/kconfig/conf  --olddefconfig Kconfig
.config:1440:warning: symbol value 'm' invalid for RXKAD
.config:5691:warning: symbol value 'm' invalid for ASYMMETRIC_KEY_TYPE
Are they known ? harmless ?
EDIT: trying to fix, will PR if it works OK:
https://github.com/igorpecovnik/lib/pull/468
For the first "[ warn ] ... scripts-dtc-Update-to-version-with-overlays.patch [ failed ]", it is the DTC version that changed between 4.6.x and 4.7.x.
I will do some fix for that :
--- a/scripts/dtc/version_gen.h
+++ b/scripts/dtc/version_gen.h
@@ -1 +1 @@
-#define DTC_VERSION "DTC 1.4.1-g53bf130b"
+#define DTC_VERSION "DTC 1.4.1-g4273dca2"
@zador-blood-stained: thanks for the merge
@martinayotte: thanks for taking care of the other piece
During my skimming over the build process scripts (found some small glitches in text UI, PR'ed),
my editor found a lot of space@EOL, and I had to revert them not to pollute my PR, would a full
scripted sweep be acceptable ?
