Eberhard61 Posted May 6, 2022 Posted May 6, 2022 Hallo, ich habe ein Tinkerboard S und habe per SD Karte Armbian installiert. Dann per ssh root@ip-adresse . Bei der Passowort 1234 eingegeben. Aber das passwort wird nicht anerkannt. Gibt es inzwischen ein neues Passwort? Gruß Eberhard61 Translation: Hello, I have a Tinkerboard S and installed Armbian via SD card. Then via ssh root@ip-address . Entered the password 1234. But the password is not recognized. Is there a new password now? greeting Eberhard61
Myron Posted May 6, 2022 Posted May 6, 2022 This discussion thread may be of use to you. The initial user name and password from a fresh install has not changed.
