inos Posted September 20, 2016 Posted September 20, 2016 First of all, thank you very much for the great work! On cubietruck after upgrade to 5.20, I have some trouble with network bonding. /etc/network/interfaces: auto eth0 iface eth0 inet manual bond-master bond0 bond-primary eth0 bond-mode active-backup auto wlan0 iface wlan0 inet manual wpa-ssid xxxx.xxx wpa-psk xxxxxxxxx bond-master bond0 bond-primary eth0 bond-mode active-backup # Define master auto bond0 iface bond0 inet static address xxx.xxx.xxx.xxx netmask xxx.xxx.xxx.xxx gateway xxx.xxx.xxx.xxx hwaddress ether xx:xx:xx:xx:xx bond-slaves none bond-primary eth0 bond-mode active-backup bond-miimon 100 After booting, the device is not reachable via the LAN unless the wlan0 is down the corresponding log: <6>bonding: bond0: setting mode to active-backup (1). <6>ADDRCONF(NETDEV_UP): bond0: link is not ready <6>bonding: bond0: Adding slave eth0. <6>sunxi_gmac: probed <6>eth0: PHY ID 001cc915 at 0 IRQ 0 (sunxi_gmac-0:00) active <6>eth0: PHY ID 001cc915 at 1 IRQ 0 (sunxi_gmac-0:01) <6>bonding: bond0: making interface eth0 the new active one. <6>bonding: bond0: first active interface up! <6>bonding: bond0: enslaving eth0 as an active interface with an up link. <6>ADDRCONF(NETDEV_CHANGE): bond0: link becomes ready <6>bonding: bond0: Setting eth0 as primary slave. <3>bonding: unable to update mode of bond0 because interface is up. <6>bonding: bond0: Adding slave wlan0. <3>[ap6210] Dongle Host Driver, version 1.28.23.3 (r). <3>[ap6210] Compiled in drivers/net/wireless/ap6210 on Sep 14 2016 at 19:40:55. <3>[ap6210] WLAN going back to live sdio_reset_comm(): <3>[ap6210] dhd_bus_devreset: WLAN ON <3>[ap6210] Final fw_path=/lib/firmware/ap6210/fw_bcm40181a2.bin <3>[ap6210] Final nv_path=/lib/firmware/ap6210/nvram_ap6210.txt <3>[ap6210] download firmware /lib/firmware/ap6210/fw_bcm40181a2.bin <3>[ap6210] Dongle ready, protocol version 4 <3>[ap6210] Dongle ready, protocol version 4 <3>[ap6210] Firmware up: op_mode=0x0005, Broadcom Dongle Host Driver mac=6c:fa:a7:16:12:19 <3>[ap6210] Firmware version = wl0: Mar 10 2014 14:59:50 version 5.90.195.89.18 FWID 01-b13c09c7 <3>[ap6210] Chip: a962 Rev 1 Pkg 9<3>[ap6210] p2p0: p2p_dev_addr=6e:fa:a7:16:12:19 <6>bonding: bond0: enslaving wlan0 as a backup interface with an up link. <6>bonding: bond0: Setting eth0 as primary slave. <6>bonding: bond0: Setting MII monitoring interval to 100. <3>bonding: unable to update mode of bond0 because interface is up. <6>bonding: bond0: Setting eth0 as primary slave. <6>bonding: bond0: link status definitely down for interface eth0, disabling it <6>bonding: bond0: making interface wlan0 the new active one. <6>Installing knfsd (copyright (C) 1996 okir@monad.swb.de). <6>PHY: sunxi_gmac-0:00 - Link is Up<c> - 1000/Full<c> <6>bonding: bond0: link status definitely up for interface eth0, 1000 Mbps full duplex. <6>bonding: bond0: making interface eth0 the new active one. Forgot to mention the WLAN itself (without bonding) works fine. On shutdown or reboot, the device hangs with the following message: <3>[ap6210] wl_event_handler was terminated <6>bonding: bond0: Removing slave wlan0. <6>bonding: bond0: releasing backup interface wlan0 <3>[ap6210] Reason 3 <3>[ap6210] error (-5) <3>[ap6210] dhd_check_hang: Event HANG send up due to re=2 te=0 e=-110 s=2 <3>[ap6210] 'wl bss -C 0' failed: -110 <3>[ap6210] NOTE: this ioctl error is normal when the BSS has not been created yet. <3>[ap6210] dhd_prot_ioctl : bus is down. we have nothing to do <3>[ap6210] wlan0:error(-1) <3>[ap6210] Reason 3 <3>[ap6210] dhd_prot_ioctl : bus is down. we have nothing to do <3>[ap6210] bcmsdh_set_irq Flag = 0 <3>[ap6210] dhd_bus_devreset: WLAN OFF DONE <3>[ap6210] WLAN placed in RESET <3>[ap6210] In : chip crash eventing So shutdown or reboot is possible only after ifconfig wlan0 down Thanks for your help! Martin
