Giuseppe1990 Posted May 30, 2022 Posted May 30, 2022 Hello, I would like to know more informations about this test made with the Asus XG-C100C Network Adapter or, generally, how to optimize the speed from a 10GbE PCIe Network Adapter in the RockPro64. Which version to use of Armbian and how to get that version to have so good performances? Which version of the Adapter driver to use? Were the drivers included in the Kernel or did you use the Asus driver recompiled? I would be very grateful if you will help me. Thank you. 0 Quote
Tauro Posted January 21, 2023 Posted January 21, 2023 I'm currently using a StarTech PEX10GSFP with a 1310nm single-mode fiber SFP+ module. It has an Aquantia chipset. It worked out of the box without issue. Small form factor cards are pricey, but I wanted something that could fit in the NAS case which has about 127mm of clearance. There's a bottleneck I haven't quite figured out. I'm averaging about 4 to 6 GB/s with a 10GB link using iperf3. 0 Quote
