yannick Posted September 25, 2016 Posted September 25, 2016 Hi everyone, I have recently buy a Orange Pi plus 2e. I installed Armbian legacy/server on it. When I plug a 3.5 HDD (in self-powered USB box), I have this message in log (dmesg) : [ 13.654305] ehci_irq: highspeed device connect [ 13.920099] usb 3-1: new high-speed USB device number 2 using sunxi-ehci [ 14.074826] scsi0 : usb-storage 3-1:1.0 [ 15.070939] scsi 0:0:0:0: Direct-Access WDC WD30 EFRX-68EUZN0 PQ: 0 ANSI: 5 [ 15.073286] sd 0:0:0:0: [sda] Very big device. Trying to use READ CAPACITY(16). [ 15.073771] sd 0:0:0:0: [sda] 5860533168 512-byte logical blocks: (3.00 TB/2.72 TiB) [ 15.074679] sd 0:0:0:0: [sda] Write Protect is off [ 15.074695] sd 0:0:0:0: [sda] Mode Sense: 28 00 00 00 [ 15.076537] sd 0:0:0:0: [sda] No Caching mode page found [ 15.076555] sd 0:0:0:0: [sda] Assuming drive cache: write through [ 15.077900] sd 0:0:0:0: [sda] Very big device. Trying to use READ CAPACITY(16). [ 15.080310] sd 0:0:0:0: [sda] No Caching mode page found [ 15.080329] sd 0:0:0:0: [sda] Assuming drive cache: write through [ 15.210047] usb 3-1: reset high-speed USB device number 2 using sunxi-ehci [ 15.510084] usb 3-1: reset high-speed USB device number 2 using sunxi-ehci [ 15.810092] usb 3-1: reset high-speed USB device number 2 using sunxi-ehci [ 16.110081] usb 3-1: reset high-speed USB device number 2 using sunxi-ehci [ 16.410087] usb 3-1: reset high-speed USB device number 2 using sunxi-ehci [ 16.710055] usb 3-1: reset high-speed USB device number 2 using sunxi-ehci [ 16.860581] sd 0:0:0:0: [sda] Unhandled error code [ 16.860593] sd 0:0:0:0: [sda] Result: hostbyte=0x07 driverbyte=0x00 [ 16.860606] sd 0:0:0:0: [sda] CDB: cdb[0]=0x28: 28 00 00 00 00 00 00 00 08 00 [ 16.860637] end_request: I/O error, dev sda, sector 0 [ 16.860649] Buffer I/O error on device sda, logical block 0 [ 16.990052] usb 3-1: reset high-speed USB device number 2 using sunxi-ehci [ 17.290047] usb 3-1: reset high-speed USB device number 2 using sunxi-ehci [ 17.590051] usb 3-1: reset high-speed USB device number 2 using sunxi-ehci [ 17.890049] usb 3-1: reset high-speed USB device number 2 using sunxi-ehci [ 18.190098] usb 3-1: reset high-speed USB device number 2 using sunxi-ehci [ 18.490133] usb 3-1: reset high-speed USB device number 2 using sunxi-ehci [ 18.640766] sd 0:0:0:0: [sda] Unhandled error code [ 18.640780] sd 0:0:0:0: [sda] Result: hostbyte=0x07 driverbyte=0x00 [ 18.640793] sd 0:0:0:0: [sda] CDB: cdb[0]=0x28: 28 00 00 00 00 00 00 00 08 00 [ 18.640823] end_request: I/O error, dev sda, sector 0 [ 18.640836] Buffer I/O error on device sda, logical block 0 I don't have this kind of message if : - I plug a 2.5 HDD (no self-powered) on the same board. - I plug this 3.5 HDD on a Raspberry Pi 2 Anyone can help me ? Yannick
zador.blood.stained Posted September 25, 2016 Posted September 25, 2016 Most likely this is caused by your HDD adapter/enclosure incompatibility with older kernel version. Please provide output of "lsusb" command when this drive is connected.
yannick Posted September 25, 2016 Author Posted September 25, 2016 Thanks a lots for the quick reply ! Here, the result of "lsusb -v" for the device : Bus 002 Device 002: ID 152d:2338 JMicron Technology Corp. / JMicron USA Technology Corp. JM20337 Hi-Speed USB to SATA & PATA Combo Bridge Device Descriptor: bLength 18 bDescriptorType 1 bcdUSB 2.00 bDeviceClass 0 (Defined at Interface level) bDeviceSubClass 0 bDeviceProtocol 0 bMaxPacketSize0 64 idVendor 0x152d JMicron Technology Corp. / JMicron USA Technology Corp. idProduct 0x2338 JM20337 Hi-Speed USB to SATA & PATA Combo Bridge bcdDevice 1.00 iManufacturer 1 JMicron iProduct 2 USB to ATA/ATAPI bridge iSerial 5 000001D91CC4 bNumConfigurations 1 Configuration Descriptor: bLength 9 bDescriptorType 2 wTotalLength 32 bNumInterfaces 1 bConfigurationValue 1 iConfiguration 4 USB Mass Storage bmAttributes 0xc0 Self Powered MaxPower 2mA Interface Descriptor: bLength 9 bDescriptorType 4 bInterfaceNumber 0 bAlternateSetting 0 bNumEndpoints 2 bInterfaceClass 8 Mass Storage bInterfaceSubClass 6 SCSI bInterfaceProtocol 80 Bulk-Only iInterface 6 MSC Bulk-Only Transfer Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x81 EP 1 IN bmAttributes 2 Transfer Type Bulk Synch Type None Usage Type Data wMaxPacketSize 0x0200 1x 512 bytes bInterval 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x02 EP 2 OUT bmAttributes 2 Transfer Type Bulk Synch Type None Usage Type Data wMaxPacketSize 0x0200 1x 512 bytes bInterval 0 Device Qualifier (for other device speed): bLength 10 bDescriptorType 6 bcdUSB 2.00 bDeviceClass 0 (Defined at Interface level) bDeviceSubClass 0 bDeviceProtocol 0 bMaxPacketSize0 64 bNumConfigurations 1 Device Status: 0x0001 Self Powered
zador.blood.stained Posted September 25, 2016 Posted September 25, 2016 I don't see any quirks for this specific device (0x152d 0x2338) in mainline kernel, but some JMicron devices are known as ones that may need additional workarounds in kernel
yannick Posted September 27, 2016 Author Posted September 27, 2016 Thanks for you response. It seems like I need to wait after a newer kernel...
yannick Posted September 28, 2016 Author Posted September 28, 2016 After more investigations on internet, and some tests, the size of the HDD is important. With a 500Go : no problems, with a 3To : unreadable. As I understand, the length of USB commands depends of HDD size (12bits vs 16bits). Recent Linux kernels have been fixed.
