dkebler Posted June 16, 2022 Posted June 16, 2022 I've got jammy running but I have a dsi display for the board and I'd like that to work (well the tp port too) with jammy. Looking at armbian config I see no setting for it. I know the display works fine as if I load an aryufan android image it works as it is set to use DSI by default. Does this kernel know about the DSI port? Do I have to build a custom kernel? If not then what boot env line will get it going? 0 Quote
dkebler Posted August 20, 2022 Author Posted August 20, 2022 (edited) Still trying to get this to work. I did see that the kernel config has enabled it. So apparently that kernel module is loaded. `CONFIG_DRM_MIPI_DSI=y` but `CONFIG_DRM_PANEL_DSI_CM=m` is a loadable module The two DSI modules that that be loaded are apparently `cat /lib/modules/$(uname -r)/modules.builtin | grep dsi` kernel/drivers/gpu/drm/drm_mipi_dsi.ko kernel/drivers/gpu/drm/bridge/synopsys/dw-mipi-dsi.ko ` so I added those to /etc/modules dw_mipi_dsi drm_mipi_dsi but on reboot they are not listed by lsmod.| grep dsi So am I barking up the right tree? How come these built-in modules won't load in this way? Edited August 20, 2022 by dkebler 0 Quote
dkebler Posted August 20, 2022 Author Posted August 20, 2022 ok so I try to load the module manually and get modprobe --first-time drm_mipi_dsi modprobe: ERROR: could not insert 'drm_mipi_dsi': Module already in kernel so it's already in the kernel so WHY is the DSI device not recognized and loaded (its not listed with lsmod) IF it's auto detected in order to load well the cable to the lcd is connected and it was working with android. 0 Quote
iamdrq Posted December 23, 2022 Posted December 23, 2022 A bit little trouble. in fact dsi lcd and touch pannel need dts mark device,pin, then driver matched, then load init... 0 Quote
dkebler Posted December 31, 2022 Author Posted December 31, 2022 @iamdrq can you provide more details of what you did. I don't understand what you mean by Quote need dts mark device,pin, Thx 0 Quote
iamdrq Posted January 1, 2023 Posted January 1, 2023 Are you have a worked linux image or you said a android ? Could you show me detail source code adreess you uesed ? And which you uesed dsi/ tp board detail model ? 0 Quote
iamdrq Posted January 1, 2023 Posted January 1, 2023 Actually, this easy. Because I found main line kernel support this display panel since linux 6.0,touch https://github.com/torvalds/linux/blob/4fe89d07dcc2804c8b562f6c7896a45643d34b2f/arch/arm64/boot/dts/rockchip/rk3399-rockpro64.dtsi#L582,lcd https://github.com/torvalds/linux/blob/4fe89d07dcc2804c8b562f6c7896a45643d34b2f/arch/arm64/boot/dts/rockchip/rk3399-rockpro64.dtsi#L629 If use linux 5.15, you need copy upper 2 section dts and enable touch,lcd as overlay. If use linux 6.0 and latter,you just enable touch,lcd as overlay. 0 Quote
dkebler Posted January 2, 2023 Author Posted January 2, 2023 Thx for info. I haven't had a chance to try yet but I'll report back when I do 0 Quote
dkebler Posted January 5, 2023 Author Posted January 5, 2023 For 5.15 Kernel. There are no dtsi files in the image in order to insert and compile. Can I just compile the entire 6.0 dtsi you pointed to and replace that dtb completely or will that break things? Otherwise i guess I have to go grab the dtsi for 5.15 and edit as you say and then compile. Alternatively I could upgrade the entire kernel to 6.0 but again don't know if that will break things. What did you do? 0 Quote
dkebler Posted January 5, 2023 Author Posted January 5, 2023 ok can grab the kernel source via armbian-config. I'll try editing and compiling the 5.15 dtsi first. 0 Quote
dkebler Posted January 6, 2023 Author Posted January 6, 2023 I wrote up a little script to deal with includes before running dtc per https://stackoverflow.com/a/36298460/4695378 First I tried just remaking the dtb file with the unchanged rk3399-rockpro64.dtsi but throws an error in the rk3399.dtsi dependency file Error: rk3399.dtsi:15.1-2 syntax error FATAL ERROR: Unable to parse input tree I did nothing but copy that file so not understanding why there is a syntax error in a file that was NOT changed. Anyway, stuck at this point with idea of making a new rk3399-rockpro64.dtb I see some armbian images are now shipping the 6 kernel but not the rock64pro ones :(. Even if they did I think I still have to make the dtb file as the dtsi file has those as status "disabled" instead of "okay" So how does one compile a one off dtb file from dtsi that has dtsi dependencies cause I seem to be missing something here. Quote SRC=/usr/src/linux-source-5.15.80-rockchip64 ARCH=arm64 DIR=$SRC/arch/$ARCH/boot/dts SOC=rockchip INCLUDE=$SRC/include CHIP=rk3399 DEV=$CHIP-rockpro64 DEP1=$CHIP DEP2=$CHIP-opp DST=$DEV.dtb cp $DIR/$SOC/$DEP1.dtsi $DEP1.dtsi.tmp cp $DIR/$SOC/$DEP2.dtsi $DEP2.dtsi.tmp cp $DIR/$SOC/$DEV.dtsi $DEV.dtsi.tmp cpp -nostdinc -I $INCLUDE -undef -x assembler-with-cpp $DEP1.dtsi.tmp > $DEP1.dtsi cpp -nostdinc -I $INCLUDE -undef -x assembler-with-cpp $DEP2.dtsi.tmp > $DEP2.dtsi cpp -nostdinc -I $INCLUDE -undef -x assembler-with-cpp $DEV.dtsi.tmp > $DEV.dtsi dtc -O dtb -b 0 -o $DST $DEV.dtsi 0 Quote
dkebler Posted January 6, 2023 Author Posted January 6, 2023 OKE I got my script issue resolved needed to use the dts file and only need to precompile it not the other files. My new version of the script is below Was able to compile with the changes you suggested but had to add also the backlight and avdd stanzas. Not sure if they are needed? So I booted and the hdmi goes blank but then the panel does not come up (super sad). So I went back and removed the avdd-supply and backlight but that did not help. So definitely suck now. Hopefully the hardware if functioning. I have no way to tell. I guess I should try the 6.0 kernel but all the current armbian images for rockpro64 are using 5.15 and I have no experience compiling a kernel and I don't think armbian-config will upgrade across major releases. mipi_panel: panel@0 { compatible = "feiyang,fy07024di26a30d"; reg = <0>; avdd-supply = <&avdd>; backlight = <&backlight>; dvdd-supply = <&vcc3v3_s0>; ports { #address-cells = <1>; #size-cells = <0>; port@0 { reg = <0>; mipi_in_panel: endpoint { remote-endpoint = <&mipi_out_panel>; }; }; }; }; #!/bin/bash SRC=/usr/src/linux-source-5.15.80-rockchip64 ARCH=arm64 DIR=$SRC/arch/$ARCH/boot/dts SOC=rockchip INCLUDE=$SRC/include CHIP=rk3399 DEV=$CHIP-rockpro64 DEP1=$CHIP DEP2=$CHIP-opp DST=$DEV.dtb cp $DIR/$SOC/$DEP1.dtsi . cp $DIR/$SOC/$DEP2.dtsi . # cp $DIR/$SOC/$DEV.dtsi . cp $DEV.dtsi.edits $DEV.dtsi cp $DIR/$SOC/$DEV.dts $DEV.dts.tmp cpp -nostdinc -I $INCLUDE -undef -x assembler-with-cpp $DEV.dts.tmp > $DEV.dts dtc -O dtb -b 0 -o $DST $DEV.dts 0 Quote
iamdrq Posted January 7, 2023 Posted January 7, 2023 If you need help @ me please else I don't recive notify and my time zone is GMT+8. https://www.armbian.com/rockpro64/ at the bottom Rolling weekly releases has linux 6.1 image . Of course,I suggest you use a sdcard as test first if you use emmc now. I don't have a rockpro64, only have nanopct4 and orangepi4 as rk3399 board. But I guess it has same way that they also use rk3399. 1. I suppose you use linux kernel 6.x at rockpro64 and swtich user to root, create pine64-lcd.dts and put below content: /dts-v1/; /plugin/; / { compatible = "rockchip,rk3399"; fragment@0 { target=<&backlight>; __overlay__ { status = "okay"; }; }; fragment@1 { target=<&touch>; __overlay__ { status = "okay"; }; }; fragment@2 { target=<&mipi_dsi>; __overlay__ { status = "okay"; }; }; fragment@3 { target=<&vopl>; __overlay__ { status = "okay"; }; }; fragment@4 { target=<&vopl_mmu>; __overlay__ { status = "okay"; }; }; fragment@5 { target=<&vopb>; __overlay__ { status = "okay"; }; }; fragment@6 { target=<&vopb_mmu>; __overlay__ { status = "okay"; }; }; }; 2. exec below command, then reboot. armbian-add-overlay pine64-lcd.dts 0 Quote
dkebler Posted January 7, 2023 Author Posted January 7, 2023 @iamdrq [SOLVED] That worked including touch! I downloaded the sid image and added the dts file. I didn't know that armbian had a overlay add command. Plus I don't know enough about kernels and overlays to come up with that dts file so THX! As I look at that code I now see that's a way to enable (okay) a stanza/device in an existing dtb module without having to recompile it. So I have learned something! My goal was to set up home assistant on this board but since I had the touch screen I bought originally for running android (now images of that are way old) I wanted to also set up a minimal X and load a browser in kiosk mode pointing to the home assistant page. Now with your help I can do that! Eventually when 6 kernel ends up in stable release I can switch to that. again THX. 0 Quote
