[Pull Request] - rockchip64: reworked PWM patch due to breakage in existing pwm dtbs
Description
A recent rk356x patch changed part of pwm-rockchip.c file; in particular it adds a mandatory "active" pinctrl state, which is not expected for existing PWM users for all rockchip64 family chips (notably px30, rk3328 and rk3399) where PWM is in use and "active" pinctrl name is not provided.
In case PWM is used as modulator for some voltage regulation, may break opp and devfreq framework (in my particular case, a tv box, made cpu unable to do frequency scaling and prevented lima driver to be correctly setup).
This patch makes the "active" pinctrl state optional on v5.18 edge kernel for rockchip64.
How Has This Been Tested?
  • [x] Built kernel deb packages successfully, installed on existing rk3318 (rk3328 sibling) installation
Checklist:
  • [x] I have commented my code, particularly in hard-to-understand areas
  • [x] I have made corresponding changes to the documentation
  • [x] Any dependent changes have been merged and published in downstream modules
View the full article
