compile.sh fails with ERROR in function create_rootfs_cache [ debootstrap-ng.sh:157 ]
Sorry I missed it because my attention was focused on the bottom of the screen here is the error:
E: Failed getting release file http://localhost:3142/httpredir.debian.org/debian/dists/wheezy/Release
This is the contents of
output/debug/output.log
Contents:
Displaying message: Command line: setting KERNEL_CONFIGURE to yes info
Displaying message: Preparing host info
Displaying message: Build host OS release jessie info
Displaying message: Host system support was not tested jessie wrn
## BUILD SCRIPT ENVIRONMENT
Version: 5fad0a2f605cc88d8ac2759a4eb1c424a221e9c7
## BUILD CONFIGURATION
Build target:
Board: cubieboard2
Branch: default
Kernel configuration:
Repository: https://github.com/linux-sunxi/linux-sunxi
Branch: branch:sunxi-3.4
Config file: linux-sun7i-default
U-boot configuration:
Repository: git://git.denx.de/u-boot.git
Branch: tag:v2015.10
Offset: 1
CPU configuration:
480000 - 1010000 with interactive
Displaying message: Starting Armbian build script @host info
Displaying message: Syncing clock host info
Displaying message: Downloading sources  info
Displaying message: Checking git sources u-boot v2015.10 info
Displaying message: Checking out
Displaying message: Checking git sources linux-sunxi sunxi-3.4 info
Displaying message: Checking git sources sunxi-display-changer master info
Displaying message: Up to date
Displaying message: Checking git sources sunxi-tools master info
Displaying message: Cleaning u-boot/v2015.10 info
Displaying message: Cleaning linux-sunxi/sunxi-3.4 info
Displaying message: Cleaning output/debs for cubieboard2 default info
Displaying message: Started patching process for u-boot u-boot-default info
Displaying message: Looking for user patches in userpatches/u-boot/u-boot-default info
Displaying message: ... add-awsom-uboot.patch succeeded info
Displaying message: ... add-cubieboard4.patch succeeded info
Displaying message: ... add-lime2-emmc.patch succeeded info
Displaying message: ... add-missing-h3-boards.patch failed wrn
Displaying message: ... adjust-h3-dram-frequency.patch failed wrn
Displaying message: ... cubieboard1.patch succeeded info
Displaying message: ... disable-usb-keyboards.patch failed wrn
Displaying message: ... fix-h3-rev3-dram-calibration.patch failed wrn
Displaying message: ... h3-enable-power-led.patch failed wrn
Displaying message: Compiling uboot 2015.10 info
Displaying message: Compiler version arm-linux-gnueabihf-gcc 4.9.2 info
Displaying message: Building deb linux-u-boot-cubieboard2_5.20_armhf.deb info
Displaying message: Started patching process for kernel sun7i-default info
Displaying message: Looking for user patches in userpatches/kernel/sun7i-default info
Displaying message: ... 0001-arm-sunxi-disp-Fix-division-by-zero.patch succeeded info
Displaying message: ... 0001-arm-sunxi-disp-Fix-typo-in-get_src_window.patch succeeded info
Displaying message: ... 0002-arm-sunxi-g2d-Fix-handle-noop-blits.patch succeeded info
Displaying message: ... 0002-arm-sunxi-ir-Enable-IR-autorepeat.patch succeeded info
Displaying message: ... 0003-arm-sunxi-disp-Fix-csc-calculations.patch succeeded info
Displaying message: ... 0004-ax88179_178a-USB-3.0-Ethernet.patch succeeded info
Displaying message: ... 0008-Fix-zram-and-zcache-to-compile-on-non-x86-architectu.patch succeeded info
Displaying message: ... 0009-Added-new-backend-based-on-CMA-for-the-Mali-UMP-memo.patch succeeded info
Displaying message: ... 0010-patch-3.4.104-105.patch succeeded info
Displaying message: ... 0011-patch-3.4.105-106.patch succeeded info
Displaying message: ... 0012-Add-rc-core-driver-for-A20-in-tree.patch succeeded info
Displaying message: ... 0012-patch-3.4.106-107.patch succeeded info
Displaying message: ... 0013-patch-3.4.107-108.patch succeeded info
Displaying message: ... 0014-modified-pwm-sunxi.h.patch succeeded info
Displaying message: ... 0015-linux-sunxi-3.4.108-overlayfs.patch succeeded info
Displaying message: ... 0015-rewrite-function-bestprescale.patch succeeded info
Displaying message: ... 0016-patch-3.4.108-109.patch succeeded info
Displaying message: ... 0017-patch-3.4.109-110.patch succeeded info
Displaying message: ... 0018-patch-3.4.110-111.patch succeeded info
Displaying message: ... 0018-patch-3.4.111-112.patch succeeded info
Displaying message: ... 0020-clustering-patch-3.4-ja1.patch succeeded info
Displaying message: ... 0020-dev-bananapi-r1.patch succeeded info
Displaying message: ... 0021-IDE-led-trigger-to-generic-disk-activity.patch succeeded info
Displaying message: ... 0022-a20-temp.patch succeeded info
Displaying message: ... 0024-dev-chip-id-and-gmac-fixing-mac.patch succeeded info
Displaying message: ... 0025-gpio.patch succeeded info
Displaying message: ... 0026-rt8192cu-missing-case.patch succeeded info
Displaying message: ... 0027-banana_touch_screen.patch succeeded info
Displaying message: ... 0028-nikkov-i2s-spdif-2.0.patch succeeded info
Displaying message: ... 0029-HDMI-8ch-and-alsa-fix-2.0.patch succeeded info
Displaying message: ... 0029-dev-spi-sun7i.patch succeeded info
Displaying message: ... 0030-ap6210_module-cubietruck.patch succeeded info
Displaying message: ... 0031-ap6211_module-bananapro.patch succeeded info
Displaying message: ... 0050-lircgpio_and_raw.patch succeeded info
Displaying message: ... 0061-w1-fix.patch succeeded info
Displaying message: ... 1017-SPDIF-experiments.patch succeeded info
Displaying message: ... 1018-Some-magic.patch succeeded info
Displaying message: ... bash_to_afterinstall.patch succeeded info
Displaying message: ... cedar-remove-insecure-code.patch succeeded info
Displaying message: ... enable_watchdog_a20.patch succeeded info
Displaying message: ... fbtft_for_older.patch succeeded info
Displaying message: ... fix-gcc5.patch succeeded info
Displaying message: ... packaging-3.4.x-DEFAULT-with-postinstall-scripts.patch succeeded info
Displaying message: ... rtl2832.patch succeeded info
Displaying message: ... tbs5520.patch succeeded info
Displaying message: Compiling default kernel 3.4.112 info
Displaying message: Using kernel config file lib/config/kernel/linux-sun7i-default.config info
Displaying message: Creating board support package cubieboard2 default info
Displaying message: Fingerprinting
Displaying message: Building package linux-wheezy-root-cubieboard2 info
Displaying message: Starting build process for cubieboard2 wheezy info
Displaying message: Creating new rootfs for wheezy info
Displaying message: Installing base system Stage 1/2 info
Displaying message: ERROR in function create_rootfs_cache debootstrap-ng.sh:157 err
Displaying message: Debootstrap base system first stage failed  err
Displaying message: Process terminated  info
Displaying message: ERROR in function unmount_on_exit debootstrap-ng.sh:576 err
Displaying message: debootstrap-ng was interrupted  err
Please try adding NO_APT_CACHER=yes to compile.sh, if this doesn't help, please try setting another Debian mirror in userpatches/lib.config like this:
DEBIAN_MIRROR='ftp.si.debian.org/debian/'
but in any case build script is designed to work on Xenial (mainly) and Trusty (not recommended but should still work), so there may be other issues
