[Device specific] Odroid XU4 part3 / Armbian Next / Single partition boot for SD & eMMC
I have pushed some changes for XU4 with the help of so many internet sources (thanks!)
- uboot 2016.05
- vanilla kernel (4.7.6 as of now)
- single partition (using the LABEL=rootfs for booting)
- SD & eMMC
for eMMC, burn the image on both a SD card & eMMC first, boot with SD card to write files on mmcblk0boot0 partition, then
cd /usr/lib/linux-u-boot-next-odroidxu4_5.21-GRO_armhf (probably remove -GRO)
-rw-r--r-- 1 root root  15616 oct.   1 01:58 bl1.bin.hardkernel
-rw-r--r-- 1 root root  14592 oct.   1 01:58 bl2.bin.hardkernel.1mb_uboot
-rw-r--r-- 1 root root   1807 oct.   1 01:58 sd_fusing.sh
-rw-r--r-- 1 root root 262144 oct.   1 01:58 tzsw.bin.hardkernel
-rw-r--r-- 1 root root 548159 oct.   1 01:58 u-boot-dtb.bin
then
sudo bash ./sd_fusing.sh /dev/mmcblk0
eventually, remove the SD card, power-off, boot from eMMC
Please, I would need help to check the changes, probably testing with Xenial (as I am using CLI Jessie so far)
you can fetch the source here
https://github.com/golfromeo-fr/lib/tree/gro_master
or later in the master branch https://github.com/igorpecovnik/lib/issues/482
thanks!
some config I am using
[gr@server1604:~/gro_armbian] $ cat helper_compile_xu4.sh
#!/bin/bash
function do_clean_up()
        # update all "lib" files to logname user (for forked "lib" and github RSA public key)
        chown -R $(/usr/bin/logname):$(/usr/bin/id -g $(/usr/bin/logname)) $SRC
trap '{ echo "Hey, you pressed Ctrl-C.  Time to quit." ; do_clean_up; exit 1; }' INT
# uncomment if you want the Armbian "lib" to be managed with logname user (login name)
# instead of root
PREFIX_GIT_LIB='sudo -u $(/usr/bin/logname)'
NO_APT_CACHER="no"
PRIVATE_CCACHE="yes"
EXTERNAL="no"
USE_CCACHE="yes"
EXPERIMENTAL_DEBOOTSTRAP="yes"
EXTENDED_DEBOOTSTRAP="yes"
COMPRESS_OUTPUTIMAGE="yes"
SEVENZIP="yes"
BUILD_DESKTOP="no"
#RELEASE="xenial"
RELEASE="jessie"
SUBREVISION="-GRO"
BOARD="odroidxu4"
BRANCH="next"
PROGRESS_DISPLAY="plain"
PROGRESS_LOG_TO_FILE="yes"
KERNEL_ONLY="no"
KERNEL_CONFIGURE="no"
DEST_LANG="fr_FR.UTF-8"
note: zador.blood.stain is making the framework so well, it's getting quite easy to achieve this. So nice!
xenial: still the old issue eth0 is enx001e06301503
this xenial thing gave me the opportunity to test the HDMI console and figure out the usb2 port is working
so the XU4 is working with vanilla software, even with eMMC, I cannot believe this.
Samsung Opensource Group team is just great.
Edited by goldfish_paris
some editing
