tom-c2 Posted October 2, 2016 Posted October 2, 2016 Hello Forum, i am using a vdr headless server with 3 Technisat Skystar USB tuners for satellite television streaming. Before i used a raspberry pi 2 but because of limitations with its ethernet bandwith i went to odroid c2. System is now armbian with self compiled vdr with vnsi plugin, both out of git repo. System runs fine but after some hours (8h) a sporadic failure occurs and (USB?) system becomes unusable, To get the 3 dvb-s2 tuners running i increased the urb pool (USB request block) with kernel parameter "coherent_pool=6M" in boot.ini. I calculated that every of all 3 instances of driver needs about 512kB of USB buffer memory, without the option the first instance fails with error -12 (ENOMEM). At first i put an option "coherent_pool=32M" to test but it seemed that this was ignored without any message. I found a hint in another forum and tried 6M and that seemed to be taken and to be enough for my 3 tuner devices. My first questions is: what are the limits for this parameter coherent_pool and what is the default value ? Second: what can i do to increase stability of USB ? Here the syslog after some hours: WARN::urb_dequeue:780: urb->hcpriv == NULL; urb = ffffffc07a0c9000 status=-2 and then lots of driver and application errors because of usb action errors: dvb-usb2: i2c-error: out failed 68 = -110
tom-c2 Posted October 4, 2016 Author Posted October 4, 2016 Hello, is there someone in this forum who can tell about this "coherent_pool" ? Is there some adjustment needed in uboot to reseve some DRAM for this pool ? Until now i only found that default size is 256kB and this is much too small for some multimedia devices. If i take "coherent_pool=8M" the system not even runs until video chip initialization, hdmi stays black. If set it to 1M system boots. What are the limits, is there something to adjust in uboot ? Thanks Thomas
