As I have quite unpopular mobo,
I am playing with armbian alone with sbc like in topic
I am on macos, I created a docker container with ubuntu,
I cloned armbian project there and I was able to run ./compile.sh
I had some errors but I was able to fix them but now I really stuck
after some options selection (depending which way I choose) I am always ending in same place:
[ .... ] Extension being added [ sunxi-tools :: added by main.sh:381 -> configuration.sh:178 -> config/sources/families/sun7i.conf:1 -> config/sources/families/include/sunxi_common.inc:1 ]
[ o.k. ] Extension manager [ processed 3 Extension Methods calls and 3 Extension Method implementations ]
[ o.k. ] Preparing [ host ]
[ warn ] Package manager is running in the background. [ Please wait! Retrying in 30 sec ]
I tried to remove
/var/lib/dpkg/lock-frontend
/var/lib/dpkg/lock
but it changes nothing
ps command also shows that nothing runs in background
root@7df16688df5e:/armbian/build# ps -AF
UID        PID  PPID  C    SZ   RSS PSR STIME TTY          TIME CMD
root         1     0  0  1123  1192   0 09:56 pts/0    00:00:00 /bin/bash
root         8     0  0  1157  2588   0 09:57 pts/1    00:00:00 /bin/bash
root     20882     8  0  1552  3480   0 10:33 pts/1    00:00:00 su
root     20883 20882  0  1156  3824   0 10:33 pts/1    00:00:00 bash
root     24744     0  0  1156  3672   0 11:28 pts/2    00:00:00 bash
root     32299 20883  0  2081  7524   0 12:22 pts/1    00:00:00 /bin/bash ./compile.sh
root     33470 32299  0   697  1000   0 12:42 pts/1    00:00:00 sleep 30
root     33471 24744  0  1765  1552   0 12:42 pts/2    00:00:00 ps -AF
Any thoughts?
Thanks
@luk23 i have have just received an AD-B03 V1.5 myself. I am very interested in your findings - were you able to get Armbian running on it?  If so, how.. ? Was there Android preinstalled on it or not? Did you install it on the SD card or on emmc? If not Armbian - did something else work? :-)
Thank you so much for the feedback!
