Good afternoon dear experts. I have a problem on my Orange pi plus 2. My hard drive(WD Red WD10JFCX, 1Тб, HDD, SATA III, 2.5") is periodically switched-off (/dev/sda1). in ravines I have:
Sep 28 10:48:37 PM dvr kernel: [1678371.474389] ehci_irq: highspeed device disconnect
Sep 28 10:48:37 PM dvr kernel: [1678371.474593] usb 3-1: USB disconnect, device number 2
Sep 28 10:48:37 PM dvr kernel: [1678371.479539] Buffer I/O error on device sda1, logical block 76682192
Sep 28 10:48:37 PM dvr kernel: [1678371.479581] Buffer I/O error on device sda1, logical block 76682193
Sep 28 10:48:37 PM dvr kernel: [1678371.479609] Buffer I/O error on device sda1, logical block 76682194
Sep 28 10:48:37 PM dvr kernel: [1678371.479636] Buffer I/O error on device sda1, logical block 76682195
Sep 28 10:48:37 PM dvr kernel: [1678371.479663] Buffer I/O error on device sda1, logical block 76682196
Sep 28 10:48:37 PM dvr kernel: [1678371.479690] Buffer I/O error on device sda1, logical block 76682197
Sep 28 10:48:37 PM dvr kernel: [1678371.479716] Buffer I/O error on device sda1, logical block 76682198
and
Sep 28 22:48:37 dvr kernel: [1678371.474593] usb 3-1: USB disconnect, device number 2
Sep 28 22:48:37 dvr kernel: [1678371.480406] EXT4-fs warning (device sda1): ext4_end_bio:249: I/O error writing to inode 55368747 (offset 1900544 size 126976 starting block 76682478)
Sep 28 22:48:37 dvr kernel: [1678371.481086] EXT4-fs warning (device sda1): ext4_end_bio:249: I/O error writing to inode 55368747 (offset 2023424 size 73728 starting block 76682496)
Sep 28 22:48:37 dvr kernel: [1678371.482205] EXT4-fs warning (device sda1): ext4_end_bio:249: I/O error writing to inode 55368747 (offset 2097152 size 126976 starting block 76683038)
Sep 28 22:48:37 dvr kernel: [1678371.483168] EXT4-fs warning (device sda1): ext4_end_bio:249: I/O error writing to inode 55368747 (offset 2220032 size 126976 starting block 76683068)
Sep 28 22:48:37 dvr kernel: [1678371.484271] EXT4-fs warning (device sda1): ext4_end_bio:249: I/O error writing to inode 55368747 (offset 2342912 size 126976 starting block 76683098)
Sep 28 22:48:37 dvr kernel: [1678371.485228] EXT4-fs warning (device sda1): ext4_end_bio:249: I/O error writing to inode 55368747 (offset 2465792 size 126976 starting block 76683128)
Sep 28 22:48:37 dvr kernel: [1678371.485968] EXT4-fs warning (device sda1): ext4_end_bio:249: I/O error writing to inode 55368747 (offset 2588672 size 126976 starting block 76683158)
Sep 28 22:48:37 dvr kernel: [1678371.485968] EXT4-fs warning (device sda1): ext4_end_bio:249: I/O error writing to inode 55368747 (offset 2711552 size 126976 starting block 76683188)
Sep 28 22:48:37 dvr kernel: [1678371.485968] EXT4-fs warning (device sda1): ext4_end_bio:249: I/O error writing to inode 55368747 (offset 2834432 size 126976 starting block 76683218)
Sep 28 22:48:37 dvr kernel: [1678371.485968] EXT4-fs warning (device sda1): ext4_end_bio:249: I/O error writing to inode 55368747 (offset 2957312 size 61440 starting block 76683233)
Sep 28 22:48:37 dvr kernel: [1678371.492144] EXT4-fs warning (device sda1): ext4_end_bio:249: I/O error writing to inode 55368748 (offset 860160 size 110592 starting block 76681453)
Sep 28 22:48:37 dvr kernel: [1678371.493059] EXT4-fs warning (device sda1): ext4_end_bio:249: I/O error writing to inode 55368748 (offset 737280 size 126976 starting block 76681426)
Sep 28 22:48:37 dvr kernel: [1678371.493944] EXT4-fs warning (device sda1): ext4_end_bio:249: I/O error writing to inode 55368748 (offset 614400 size 126976 starting block 76681396)
Sep 28 22:48:37 dvr kernel: [1678371.494826] EXT4-fs warning (device sda1): ext4_end_bio:249: I/O error writing to inode 55368748 (offset 491520 size 126976 starting block 76681366)
Sep 28 22:48:37 dvr kernel: [1678371.495733] EXT4-fs warning (device sda1): ext4_end_bio:249: I/O error writing to inode 55368748 (offset 368640 size 126976 starting block 76681336)
Sep 28 22:48:37 dvr kernel: [1678371.496700] EXT4-fs warning (device sda1): ext4_end_bio:249: I/O error writing to inode 55368748 (offset 245760 size 126976 starting block 76681306)
Sep 28 22:48:37 dvr kernel: [1678371.497596] EXT4-fs warning (device sda1): ext4_end_bio:249: I/O error writing to inode 55368748 (offset 122880 size 126976 starting block 76681276)
Sep 28 22:48:37 dvr kernel: [1678371.498622] EXT4-fs warning (device sda1): ext4_end_bio:249: I/O error writing to inode 55368748 (offset 0 size 126976 starting block 76681246)
Sep 28 22:48:37 dvr kernel: [1678371.499036] JBD2: Detected IO errors while flushing file data on sda1-8
Sep 28 22:48:40 dvr kernel: [1678373.960205] usb 3-1: new high-speed USB device number 3 using sunxi-ehci
Sep 28 22:48:40 dvr kernel: [1678374.114545] scsi1 : usb-storage 3-1:1.0
Sep 28 22:48:40 dvr mtp-probe: checking bus 3, device 3: "/sys/devices/platform/sunxi-ehci.4/usb3/3-1"
Sep 28 22:48:40 dvr mtp-probe: bus: 3, device: 3 was not an MTP device
Sep 28 22:48:41 dvr kernel: [1678375.112846] scsi 1:0:0:0: Direct-Access     WDC WD10 JFCX-68N6GN0     0009 PQ: 0 ANSI: 0
Sep 28 22:48:41 dvr kernel: [1678375.115159] sd 1:0:0:0: [sdb] 1953525164 512-byte logical blocks: (1.00 TB/931 GiB)
Sep 28 22:48:41 dvr kernel: [1678375.116283] sd 1:0:0:0: [sdb] Write Protect is off
Sep 28 22:48:41 dvr kernel: [1678375.155871]  sdb: sdb1
Sep 28 22:48:41 dvr kernel: [1678375.160752] sd 1:0:0:0: [sdb] Attached SCSI disk
Sep 29 06:42:28 dvr rsyslogd: [origin software="rsyslogd" swVersion="8.4.2" x-pid="1415" x-info="http://www.rsyslog.com"] rsyslogd was HUPed
Sep 29 06:42:29 dvr rsyslogd: [origin software="rsyslogd" swVersion="8.4.2" x-pid="1415" x-info="http://www.rsyslog.com"] rsyslogd was HUPed
Sep 29 22:50:02 dvr kernel: [1764856.800097] EXT4-fs (sda1): error count since last fsck: 5
Sep 29 22:50:02 dvr kernel: [1764856.800132] EXT4-fs (sda1): initial error at time 1475092117: ext4_journal_start_sb:328
Sep 29 22:50:02 dvr kernel: [1764856.800164] EXT4-fs (sda1): last error at time 1475125069: ext4_find_entry:941: inode 55312385
Orange pi plus 2 works 24 hours a day, 7 days a week, on the hard drive constant record of small videos of files has to be made. Help to solve a problem please.
I had something similar, when I used several brands/types of 5 and 12V wall socket adapters combinations,
I experienced disconnecting sda and attaching as sdb, then sdc etc, ending up with sdx after a week or so.
After changing to an old 400W PC power supply, problem never came back in the past half year.
So you may want to try a better power supply ?
