I have just updated the latest kernel available on my sbc orangepi+2e with the armbian-config tool and after that it no longer boots. After plugging in the serial port it complains
"## Executing script at 44000000
Wrong Ramdisk Image Format Ramdisk image is corrupt or invalid".
How can I fix it without having to reinstall everything? I run home-assistant and all the data is on emmc.
U-Boot 2019.04-armbian (Jul 15 2019 - 18:03:30 +0200) Allwinner Technology
CPU:   Allwinner H3 (SUN8I 1680)
Model: Xunlong Orange Pi Plus 2E
DRAM:  2 GiB
MMC:   Device 'mmc@1c11000': seq 1 is in use by 'mmc@1c10000'
mmc@1c0f000: 0, mmc@1c10000: 2, mmc@1c11000: 1
Loading Environment from EXT4... MMC: no card present
In:    serial
Out:   serial
Err:   serial
Net:   phy interface7
eth0: ethernet@1c30000
starting USB...
USB0:   USB EHCI 1.00
USB1:   USB OHCI 1.0
USB2:   USB EHCI 1.00
USB3:   USB OHCI 1.0
USB4:   USB EHCI 1.00
USB5:   USB OHCI 1.0
USB6:   USB EHCI 1.00
USB7:   USB OHCI 1.0
scanning bus 0 for devices... 1 USB Device(s) found
scanning bus 1 for devices... 1 USB Device(s) found
scanning bus 2 for devices... 1 USB Device(s) found
scanning bus 3 for devices... 1 USB Device(s) found
scanning bus 4 for devices... 1 USB Device(s) found
scanning bus 5 for devices... 1 USB Device(s) found
scanning bus 6 for devices... 1 USB Device(s) found
scanning bus 7 for devices... 1 USB Device(s) found
Autoboot in 1 seconds, press <Space> to stop
switch to partitions #0, OK
mmc1(part 0) is current device
Scanning mmc 1:1...
3798 bytes read in 2 ms (1.8 MiB/s)
U-boot loaded from eMMC or secondary SD
Boot script loaded from mmc
283 bytes read in 0 ms
8378512 bytes read in 403 ms (19.8 MiB/s)
33059 bytes read in 7 ms (4.5 MiB/s)
804 bytes read in 3 ms (261.7 KiB/s)
Applying kernel provided DT overlay sun8i-h3-spi-spidev.dtbo
4185 bytes read in 2 ms (2 MiB/s)
Applying kernel provided DT fixup script (sun8i-h3-fixup.scr)
SCRIPT FAILED: continuing...
Scanning mmc 1:1...
3798 bytes read in 1 ms (3.6 MiB/s)
283 bytes read in 1 ms (276.4 KiB/s)
Edited by Manel
add
There is ls -l of /boot partition:
-rw-r--r-- 1 root root     283 31 août  19:08 armbianEnv.txt
-rw-r--r-- 1 root root    1536  7 sept.  2019 armbian_first_run.txt.template
-rw-r--r-- 1 root root    3726  7 sept.  2019 boot.cmd
-rw-r--r-- 1 root root    3798  7 sept.  2019 boot.scr
-rw-r--r-- 1 root root  200877 22 juin  09:35 config-5.15.48-sunxi
lrwxrwxrwx 1 root root      17 31 août  19:33 dtb -> dtb-5.15.48-sunxi
drwxr-xr-x 3 root root   12288 31 août  19:32 dtb-5.15.48-sunxi
lrwxrwxrwx 1 root root      17  7 sept.  2019 dtb.old -> dtb-4.19.59-sunxi
-rw-r--r-- 1 root root 9777425 31 août  19:33 initrd.img-5.15.48-sunxi
drwxr-xr-x 2 root root    4096  7 sept.  2019 overlay-user
-rw-r--r-- 1 root root 4449753 22 juin  09:35 System.map-5.15.48-sunxi
lrwxrwxrwx 1 root root      21 31 août  12:05 uInitrd -> uInitrd-4.19.62-sunxi
-rwxr-xr-x 1 root root 8378512 22 juin  09:35 vmlinuz-5.15.48-sunxi
lrwxrwxrwx 1 root root      21 31 août  19:33 zImage -> vmlinuz-5.15.48-sunxi
I can see uInitrd have no link...what happened ?
After removing bad link uInitrd-4.19.62-sunxi, adding new uInitrd-5.15.48-sunxi and relinking uInitrd I bring back my system. Is armbian-config  or me the culprit ? 😅
