[Armbian build PR] - Use hex type codes in `sfdisk` for compatibility
Description
The type names will cause build problem in focal (use sfdisk v2.34) and bullseye (use sfdisk v2.36)
The partition type is given in hex for MBR (DOS) where 0x prefix is optional; a GUID string for GPT; a shortcut or an alias. It’s recommended to use two letters for MBR hex codes to avoid collision between deprecated shortcut 'E' and '0E' MBR hex code. For backward compatibility sfdisk tries to interpret type as a shortcut as a first possibility in partitioning scripts although on other places (e.g. --part-type command) it tries shortcuts as the last possibility.
Since v2.36 libfdisk supports partition type aliases as extension to shortcuts. The alias is a simple human readable word (e.g. "linux").
Since v2.37 libfdisk supports partition type names on input, ignoring the case of the characters and all non-alphanumeric and non-digit characters in the name (e.g. "Linux /usr x86" is the same as "linux usr-x86").
How Has This Been Tested?
  • [X] Build
Checklist:
  • [ ] My code follows the style guidelines of this project
  • [X] I have performed a self-review of my own code
  • [ ] I have made corresponding changes to the documentation
  • [X] My changes generate no new warnings
View the full article
