Add packages to Armbian image for my Orange Pi One (face_recognition python)
Hi there!
Issue:
Installing required package for Python face_recognition takes almost 15-20 hours to install using my Orange Pi One.
These are the commands I manually ran to my Orange Pi one:
https://gist.github.com/jmcausing/d89d659ae43dff8f5ea8feea95fe2de3
Goal:
I need a custom armbian image that has those package installed already.
I tried:
- Building armbian image using Virtual Box with ubuntu-22.04.1-live-server-amd64
- 30GB of Disk , 4GB of RAM and 6 CPUs
- Edited the /build/config/templates/customize-image.sh and added those commands (see gist link above) to install the required packages
- Run the command:
./compile.sh \
BOARD=orangepione \
BRANCH=current \
RELEASE=focal \
BUILD_MINIMAL=yes \
BUILD_DESKTOP=no \
KERNEL_ONLY=no \
KERNEL_CONFIGURE=no \
CARD_DEVICE="/dev/sda"
- Failed (sorry I didn't get the error) most likely I'm doing it wrong.
I also tried the Automated Build System:
- Fork the repo
- Edited the customize-image.sh and inserted my bash commands to install packages
- Created pull request (it was closed I was doing it wrong :( https://github.com/armbian/build/pull/4229#issuecomment-1257176031
May I ask for your guidance how can I achieve my goal, please?
7 часов назад, jmcausing сказал:
30 GB is not enough for a virtual machine. You may run out of free space at the very end of the process.
https://github.com/armbian/build/blob/d57777caade0e3751d759b75239c5a66c3b28728/lib/debootstrap.sh#L78-L80
	# stage: user customization script
	# NOTE: installing too many packages may fill tmpfs mount
	customize_image
That's the first thing that came to mind. I have a 45 GB virtual machine image.
This script is a template for the user and is copied to the userpatches folder.
After that, in this folder, you can change it at your discretion. It is only your property and you can write whatever you want there.
Add debugging code there something like this:
apt-get install -y build-essential cmake gfortran |& tee -a $DEST/${LOG_SUBPATH}/custom.log
pip3 install dlib |& tee -a $DEST/${LOG_SUBPATH}/custom.log
See output/debug/custom.log
