I had to reapply u-boot image. So, I did it by armbian-config and later by "dd" command. In both situations this is failing (please see u-boot messages printed by serial). I was restoring the image (I have backup images of my SD card) and trying again. What may be the problem? I had linux-u-boot-orangepi*-current 22.08.6 installed.
As below - please note Verifying Checksum ... Bad Data CRC
BTW. I tried the same on Orange Pi PC and Orange Pi Zero - the same result (fail to boot).
=> version
U-Boot 2022.07-armbian (Oct 18 2022 - 07:35:20 +0000) Allwinner Technology
arm-none-linux-gnueabihf-gcc (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 9.2.1 20191025
GNU ld (GNU Toolchain for the A-profile Architecture 9.2-2019.12 (arm-9.10)) 2.33.1.20191209
=> reset
resetting ...
U-Boot SPL 2022.07-armbian (Oct 18 2022 - 07:35:20 +0000)
DRAM: 1024 MiB
Trying to boot from MMC1
CPU:   Allwinner H3 (SUN8I 1680)
Model: Xunlong Orange Pi PC
DRAM:  1 GiB
Core:  65 devices, 18 uclasses, devicetree: separate
WDT:   Not starting watchdog@1c20ca0
MMC:   mmc@1c0f000: 0
Loading Environment from FAT... Unable to use mmc 0:1...
In:    serial@1c28000
Out:   serial@1c28000
Err:   serial@1c28000
Net:   phy interface1
eth0: ethernet@1c30000
starting USB...
Bus usb@1c1a000: USB EHCI 1.00
Bus usb@1c1a400: USB OHCI 1.0
Bus usb@1c1b000: USB EHCI 1.00
Bus usb@1c1b400: USB OHCI 1.0
Bus usb@1c1c000: USB EHCI 1.00
Bus usb@1c1c400: USB OHCI 1.0
Bus usb@1c1d000: USB EHCI 1.00
Bus usb@1c1d400: USB OHCI 1.0
scanning bus usb@1c1a000 for devices... 1 USB Device(s) found
scanning bus usb@1c1a400 for devices... 1 USB Device(s) found
scanning bus usb@1c1b000 for devices... 1 USB Device(s) found
scanning bus usb@1c1b400 for devices... 1 USB Device(s) found
scanning bus usb@1c1c000 for devices... 1 USB Device(s) found
scanning bus usb@1c1c400 for devices... 1 USB Device(s) found
scanning bus usb@1c1d000 for devices... 1 USB Device(s) found
scanning bus usb@1c1d400 for devices... 1 USB Device(s) found
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
3708 bytes read in 5 ms (723.6 KiB/s)
U-boot loaded from SD
Boot script loaded from mmc
212 bytes read in 4 ms (51.8 KiB/s)
13021622 bytes read in 549 ms (22.6 MiB/s)
8387760 bytes read in 356 ms (22.5 MiB/s)
32077 bytes read in 13 ms (2.4 MiB/s)
374 bytes read in 10 ms (36.1 KiB/s)
Applying kernel provided DT overlay sun8i-h3-i2c0.dtbo
393 bytes read in 5 ms (76.2 KiB/s)
Applying user provided DT overlay ds1307.dtbo
4185 bytes read in 9 ms (454.1 KiB/s)
Applying kernel provided DT fixup script (sun8i-h3-fixup.scr)
## Executing script at 44000000
Kernel image @ 0x42000000 [ 0x000000 - 0x7ffcb0 ]
## Loading init Ramdisk from Legacy Image at 43400000 ...
   Image Name:   uInitrd
   Data Size:    13021558 Bytes = 12.4 MiB
   Load Address: 00000000
   Entry Point:  00000000
Ramdisk image is corrupt or invalid
SCRIPT FAILED: continuing...
No EFI system partition
BootOrder not defined
EFI boot manager: Cannot load any image
Device 0: unknown device
ethernet@1c30000 Waiting for PHY auto negotiation to complete. done
BOOTP broadcast 1
DHCP client bound to address 192.168.10.136 (3 ms)
*** ERROR: `serverip' not set
Cannot autoload with TFTPGET
Retrieving file: pxelinux.cfg/01-02-81-a9-fc-f7-d9
Retrieving file: pxelinux.cfg/C0A80A88
Retrieving file: pxelinux.cfg/default-arm-sunxi-sunxi
Config file not found
BOOTP broadcast 1
BOOTP broadcast 1
DHCP client bound to address 192.168.10.136 (2 ms)
