Rockpro64 not booting anymore after latest apt upgrade / init not found
Dear Armbian community,
Yesterday morning, after apt upgrade my Rockpro64 not boot (the white and red led stayed lit).
After some tries I managed to get a boot again but I now have a "init not found" error, as you can see on the screenshot.
What have been done so far :
- Install an Ubuntu as "debug" platform
- Follow the recovery steps from Armbian website
- Put on eMMC storage a 5.15.63 by copying the files from Armbian
- Check if UUID was consistent between partition, boot config, ... ==> this is the case
- Made a fsck : no errors found
==> I would like to try this : https://askubuntu.com/questions/910218/sbin-init-no-such-file-or-directory-not-able-to-boot-ubuntu-desktop, but need to have a boot prompt (how to get it ?)
If somebody has any other hint... I would take it :)
I have spent hours on the setup of my Rockpro64, I would avoid to reinstall it.
Regards.
I finally found the issue :
For an unknown reason the /lib->/usr/lib symlink in rootdir disappeared. It becamed a directory with "firmware" and "modules" subdirs.
I then copied the actual lib content to /usr/lib, then delete /lib and made again the symlink. This solved the problem.
