ABF023 Posted November 9, 2022 Posted November 9, 2022 (edited) I flashed my espressobin v7 with bubt flash-image-DDR4-1g_1cs_5-1000_800.bin spi usb and set u-boot prompt: printenv ethaddr env default -a saveenv After the boot printenv: TIM-1.0 mv_ddr-devel-g251bc63 DDR4 16b 1GB 1CS WTMI-devel-18.12.1-1d97715 WTMI: system early-init CPU VDD voltage default value: 1.155V Setting clocks: CPU 1000 MHz, DDR 800 MHz CZ.NIC's Armada 3720 Secure Firmware 0b68a33-dirty (May 16 2022 17:51:06) Running on ESPRESSObin NOTICE: Booting Trusted Firmware NOTICE: BL1: v2.6(release):a921da5e NOTICE: BL1: Built : 17:54:27, May 16 2022 NOTICE: BL1: Booting BL2 NOTICE: BL2: v2.6(release):a921da5e NOTICE: BL2: Built : 17:54:27, May 16 2022 NOTICE: BL1: Booting BL31 NOTICE: BL31: v2.6(release):a921da5e NOTICE: BL31: Built : 17:54:27, May 16 2022 U-Boot 2022.04-armbian (May 16 2022 - 17:50:52 +0000) DRAM: 1 GiB Core: 38 devices, 20 uclasses, devicetree: fit WDT: Not starting watchdog@8300 Comphy chip #0: Comphy-0: USB3_HOST0 5 Gbps Comphy-1: PEX0 5 Gbps Comphy-2: SATA0 6 Gbps SATA link 0 timeout. AHCI 0001.0300 32 slots 1 ports 6 Gbps 0x1 impl SATA mode flags: ncq led only pmp fbss pio slum part sxs PCIe: Link down MMC: sdhci@d0000: 0, sdhci@d8000: 1 Loading Environment from SPIFlash... SF: Detected w25q32dw with page size 256 Bytes, erase size 4 KiB, total 4 MiB OK Model: Globalscale Marvell ESPRESSOBin Board Net: eth0: ethernet@30000 Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc1(part 0) is current device Scanning mmc 1:1... libfdt fdt_check_header(): FDT_ERR_BADMAGIC Scanning disk sdhci@d0000.blk... Scanning disk sdhci@d8000.blk... Found 4 disks No EFI system partition ERROR: invalid device tree switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr load - load binary file from a filesystem Usage: load <interface> [<dev[:part]> [<addr> [<filename> [bytes [pos]]]]] - Load binary file 'filename' from partition 'part' on device type 'interface' instance 'dev' to address 'addr' in memory. 'bytes' gives the size to load in bytes. If 'bytes' is 0 or omitted, the file is read until the end. 'pos' gives the file byte position to start reading from. If 'pos' is 0 or omitted, the file is read from the start. ## Executing script at 06000000 Wrong image format for "source" command SCRIPT FAILED: continuing... libfdt fdt_check_header(): FDT_ERR_BADMAGIC ERROR: invalid device tree starting USB... Bus usb@58000: Register 2000104 NbrPorts 2 Starting the controller USB XHCI 1.00 Bus usb@5e000: USB EHCI 1.00 scanning bus usb@58000 for devices... 1 USB Device(s) found scanning bus usb@5e000 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Device 0: unknown device scanning bus for devices... Device 0: unknown device (NULL udevice *): mvneta_setup_txqs: can't create txq=0 BOOTP broadcast 1 timeout: packet not sent BOOTP broadcast 2 timeout: packet not sent BOOTP broadcast 3 timeout: packet not sent BOOTP broadcast 4 timeout: packet not sent .................. .............. Edited November 9, 2022 by armbianfans023 0 Quote
ManoftheSea Posted November 30, 2022 Posted November 30, 2022 I'm guessing you don't have a "scriptaddr" variable after the env update. Pali helped me track down a bug in u-boot, for which I've submitted a patch. Then, we'll need to build a new u-boot for ebins, to really resolve the issue. In the meantime, add env set scriptaddr 0x6d00000 0 Quote
ABF023 Posted December 2, 2022 Author Posted December 2, 2022 OK, yes. After adding scriptaddr, it starts normally 0 Quote
