espresso v7 doesn't boot from sdcard, please help....
Posted (edited)
I flashed my espressobin v7 with
bubt flash-image-DDR4-1g_1cs_5-1000_800.bin spi usb
and set u-boot prompt:
printenv ethaddr
env default -a
saveenv
After the boot
printenv:
TIM-1.0
mv_ddr-devel-g251bc63 DDR4 16b 1GB 1CS
WTMI-devel-18.12.1-1d97715
WTMI: system early-init
CPU VDD voltage default value: 1.155V
Setting clocks: CPU 1000 MHz, DDR 800 MHz
CZ.NIC's Armada 3720 Secure Firmware 0b68a33-dirty (May 16 2022 17:51:06)
Running on ESPRESSObin
NOTICE:  Booting Trusted Firmware
NOTICE:  BL1: v2.6(release):a921da5e
NOTICE:  BL1: Built : 17:54:27, May 16 2022
NOTICE:  BL1: Booting BL2
NOTICE:  BL2: v2.6(release):a921da5e
NOTICE:  BL2: Built : 17:54:27, May 16 2022
NOTICE:  BL1: Booting BL31
NOTICE:  BL31: v2.6(release):a921da5e
NOTICE:  BL31: Built : 17:54:27, May 16 2022
U-Boot 2022.04-armbian (May 16 2022 - 17:50:52 +0000)
DRAM:  1 GiB
Core:  38 devices, 20 uclasses, devicetree: fit
WDT:   Not starting watchdog@8300
Comphy chip #0:
Comphy-0: USB3_HOST0    5 Gbps
Comphy-1: PEX0          5 Gbps
Comphy-2: SATA0         6 Gbps
SATA link 0 timeout.
AHCI 0001.0300 32 slots 1 ports 6 Gbps 0x1 impl SATA mode
flags: ncq led only pmp fbss pio slum part sxs
PCIe: Link down
MMC:   sdhci@d0000: 0, sdhci@d8000: 1
Loading Environment from SPIFlash... SF: Detected w25q32dw with page size 256 Bytes, erase size 4 KiB, total 4 MiB
OK
Model: Globalscale Marvell ESPRESSOBin Board
Net:   eth0: ethernet@30000
switch to partitions #0, OK
mmc1(part 0) is current device
Scanning mmc 1:1...
libfdt fdt_check_header(): FDT_ERR_BADMAGIC
Scanning disk sdhci@d0000.blk...
Scanning disk sdhci@d8000.blk...
Found 4 disks
No EFI system partition
ERROR: invalid device tree
mmc0 is current device
Scanning mmc 0:1...
load - load binary file from a filesystem
Usage:
load <interface> [<dev[:part]> [<addr> [<filename> [bytes [pos]]]]]
    - Load binary file 'filename' from partition 'part' on device
       type 'interface' instance 'dev' to address 'addr' in memory.
      'bytes' gives the size to load in bytes.
      If 'bytes' is 0 or omitted, the file is read until the end.
      'pos' gives the file byte position to start reading from.
      If 'pos' is 0 or omitted, the file is read from the start.
## Executing script at 06000000
Wrong image format for "source" command
SCRIPT FAILED: continuing...
starting USB...
Bus usb@58000: Register 2000104 NbrPorts 2
Starting the controller
USB XHCI 1.00
Bus usb@5e000: USB EHCI 1.00
scanning bus usb@58000 for devices... 1 USB Device(s) found
scanning bus usb@5e000 for devices... 1 USB Device(s) found
Device 0: unknown device
scanning bus for devices...
(NULL udevice *): mvneta_setup_txqs: can't create txq=0
BOOTP broadcast 1
timeout: packet not sent
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
Edited by armbianfans023
  • ABF023 changed the title to espresso v7 doesn't boot from sdcard, please help....
I'm guessing you don't have a "scriptaddr" variable after the env update.  Pali helped me track down a bug in u-boot, for which I've submitted a patch.  Then, we'll need to build a new u-boot for ebins, to really resolve the issue.  In the meantime, add
env set scriptaddr 0x6d00000
