Is there some instructions on how to get opencl with gpu working on the C4 with armbian ?
I found https://wiki.odroid.com/odroid-c4/os_images/ubuntu/minimal/20200526#opencl_configuration but the package mali-fbdev isn't available on armbian.
Closest I've got is :
$ curl -L http://deb.odroid.in/c4/pool/main/m/mali-midgard-driver/mali-fbdev_0.1-2ubuntu4_arm64.deb -o mali-fbdev_0.1-2ubuntu4_arm64.deb
$ ar -xv mali-fbdev_*
$ tar --use-compress-program=unzstd -xvf data.tar.zst
$ sudo cp -r usr/* /usr/
$ mkdir -p /etc/OpenCL/vendors/
$ echo /usr/share/mali-odroid-c4/libmali.so | sudo tee /etc/OpenCL/vendors/mali.icd
But then clinfo fails with :
$ clinfo
Number of platforms                               1
  Platform Name                                   ARM Platform
  Platform Vendor                                 ARM
  Platform Version                                OpenCL 2.0 git.c8adbf9.ad00b04c1b60847de257177231dc1a53
  Platform Profile                                FULL_PROFILE
  Platform Extensions                             cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_byte_addressable_store cl_khr_3d_image_writes cl_khr_int64_base_atomics cl_khr_int64_extended_atomics cl_khr_fp16 cl_khr_icd cl_khr_egl_image cl_khr_image2d_from_buffer cl_khr_depth_images cl_khr_create_command_queue cl_arm_core_id cl_arm_printf cl_arm_thread_limit_hint cl_arm_non_uniform_work_group_size cl_arm_import_memory cl_arm_shared_virtual_memory
  Platform Extensions function suffix             ARM
Number of devices                                 1
Failed creating base context during opening of kernel driver.
So, presumably, there is a kernel module to be installed as well.
I also found https://developer.arm.com/downloads/-/mali-drivers/user-space ... but doesn't indicate support for the C4.
Any hints to get further ?  Thanks.
Hi @plord
have you come any further since then? I have found some how-tos very similar to what you did. But I just ended up at the very same point as you...
Cheers
Edited by Jojo
@usual user
Well, that doesn't look that bad, I would say. But I personally am stuck where clinfo tells me that the GPU has not been found and that the kernel driver module seems not to be loaded.
I tried a lot of thing like the default panfrost driver, self-compiled ARM driver, ARM userspace driver... Sure, I might have screwed some things up by myself. But I wouldn't have started tinkering around with that if it had worked from the beginning on :) .
I haven't tried any of that. I only used the distribution of my choice. It is in no way designed specifically for a specific device. The only requirement to use it is a firmware that is capable of booting the system. But since there's mainline firmware support for many devices, and I've learned to build it from the sources according to my needs, the same OS image works the same way for me for every device.
To create the previously attached log file, I only had to use an environment variable to reveal the backend to be used with rusticl and was ready to go. The user space doesn't use anything device-specific, but is only built from current mainline releases. That's what the OS developers did for me, and they don't even know what devices I'm using it on.
@usual user
Thank you very much for taking the time for the description!
Honestly I must confess that I am not that deep in all this kernel build stuff that I would dare to build my own distro 🙈.
I followed another guide and now my clinfo looks different but still not good. It seems that it has detected three OpenCL profiles, but still no entire GPU (driver):
Number of platforms                               3
  Platform Vendor                                 ARM
  Platform Version                                OpenCL 2.0 git.c8adbf9.122c9daed32dbba4b3056f41a2f23c58
  Platform Extensions                             cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_byte_addressable_store cl_khr_3d_image_writes cl_khr_int64_base_atomics cl_khr_int64_extended_atomics cl_khr_fp16 cl_khr_icd cl_khr_egl_image cl_khr_image2d_from_buffer cl_khr_depth_images cl_khr_subgroups cl_khr_create_command_queue cl_arm_core_id cl_arm_printf cl_arm_thread_limit_hint cl_arm_non_uniform_work_group_size cl_arm_import_memory cl_arm_shared_virtual_memory
  Platform Name                                   rusticl
  Platform Vendor                                 Mesa/X.org
  Platform Version                                OpenCL 3.0
  Platform Extensions                             cl_khr_icd
  Platform Extensions with Version                cl_khr_icd                                                       0x400000 (1.0.0)
  Platform Numeric Version                        0xc00000 (3.0.0)
  Platform Extensions function suffix             MESA
  Platform Host timer resolution                  0ns
  Platform Name                                   Clover
  Platform Version                                OpenCL 1.1 Mesa 22.3.6
Number of devices                                 1
Kernel module may not have been loaded
  Device Name                                     <printDeviceInfo:0: get CL_DEVICE_NAME size : error -6>
  Device Vendor                                   ARM
  Device Vendor ID                                <printDeviceInfo:2: get CL_DEVICE_VENDOR_ID : error -6>
  Device Version                                  OpenCL 2.0 git.c8adbf9.122c9daed32dbba4b3056f41a2f23c58
  Driver Version                                  2.0
  Device OpenCL C Version                         OpenCL C 2.0 git.c8adbf9.122c9daed32dbba4b3056f41a2f23c58
  Device Type                                     GPU
  Device Profile                                  FULL_PROFILE
  Device Available                                Yes
  Compiler Available                              Yes
  Linker Available                                Yes
  Max compute units                               <printDeviceInfo:32: get CL_DEVICE_MAX_COMPUTE_UNITS : error -6>
  Available core IDs (ARM)                        <printDeviceInfo:33: get CL_DEVICE_COMPUTE_UNITS_BITFIELD_ARM : error -30>
  Max clock frequency                             <printDeviceInfo:40: get CL_DEVICE_MAX_CLOCK_FREQUENCY : error -6>
  Device Partition                                (core)
    Max number of sub-devices                     0
    Supported partition types                     None
    Supported affinity domains                    (n/a)
  Max work item dimensions                        3
  Max work item sizes                             <printDeviceInfo:62: get number of CL_DEVICE_MAX_WORK_ITEM_SIZES : error -6>
  Max work group size                             <printDeviceInfo:63: get CL_DEVICE_MAX_WORK_GROUP_SIZE : error -6>
  Preferred work group size multiple (kernel)     <getWGsizes:1950: create context : error -6>
  Preferred / native vector sizes
    char                                                16 / 4
    short                                                8 / 2
    int                                                  4 / 1
    long                                                 2 / 1
    half                                                 8 / 2        (cl_khr_fp16)
    float                                                4 / 1
    double                                               0 / 0        (n/a)
  Half-precision Floating-point support           (cl_khr_fp16)
    Denormals                                     Yes
    Infinity and NANs                             Yes
    Round to nearest                              Yes
    Round to zero                                 Yes
    Round to infinity                             Yes
    IEEE754-2008 fused multiply-add               Yes
    Support is emulated in software               No
  Single-precision Floating-point support         (core)
    Denormals                                     Yes
    Round to zero                                 Yes
    Correctly-rounded divide and sqrt operations  No
  Double-precision Floating-point support         (n/a)
  Address bits                                    64, Little-Endian
  Global memory size                              <printDeviceInfo:108: get CL_DEVICE_GLOBAL_MEM_SIZE : error -6>
  Error Correction support                        No
  Max memory allocation                           <printDeviceInfo:114: get CL_DEVICE_MAX_MEM_ALLOC_SIZE : error -6>
  Unified memory for Host and Device              Yes
  Shared Virtual Memory (SVM) capabilities        <printDeviceInfo:117: get CL_DEVICE_SVM_CAPABILITIES : error -6>
  Shared Virtual Memory (SVM) capabilities (ARM)  <printDeviceInfo:118: get CL_DEVICE_SVM_CAPABILITIES_ARM : error -6>
  Minimum alignment for any data type             128 bytes
  Alignment of base address                       1024 bits (128 bytes)
  Preferred alignment for atomics
    SVM                                           0 bytes
    Global                                        0 bytes
    Local                                         0 bytes
  Max size for global variable                    65536 (64KiB)
  Preferred total size of global vars             0
  Global Memory cache type                        Read/Write
  Global Memory cache size                        <printDeviceInfo:139: get CL_DEVICE_GLOBAL_MEM_CACHE_SIZE : error -6>
  Global Memory cache line size                   <printDeviceInfo:140: get CL_DEVICE_GLOBAL_MEM_CACHELINE_SIZE : error -6>
  Image support                                   Yes
    Max number of samplers per kernel             16
    Max size for 1D images from buffer            65536 pixels
    Max 1D or 2D image array size                 2048 images
    Base address alignment for 2D image buffers   32 bytes
    Pitch alignment for 2D image buffers          64 pixels
    Max 2D image size                             65536x65536 pixels
    Max 3D image size                             65536x65536x65536 pixels
    Max number of read image args                 128
    Max number of write image args                64
    Max number of read/write image args           64
  Max number of pipe args                         16
  Max active pipe reservations                    1
  Max pipe packet size                            1024
  Local memory type                               Global
  Local memory size                               32768 (32KiB)
  Max number of constant args                     8
  Max constant buffer size                        65536 (64KiB)
  Max size of kernel argument                     1024
  Queue properties (on host)
    Out-of-order execution                        Yes
    Profiling                                     Yes
  Queue properties (on device)
    Profiling                                     Yes
    Preferred size                                2097152 (2MiB)
    Max size                                      16777216 (16MiB)
  Max queues on device                            1
  Max events on device                            1024
  Prefer user sync for interop                    No
  Profiling timer resolution                      <printDeviceInfo:195: get CL_DEVICE_PROFILING_TIMER_RESOLUTION : error -6>
  Execution capabilities
    Run OpenCL kernels                            Yes
    Run native kernels                            No
  printf() buffer size                            1048576 (1024KiB)
  Built-in kernels                                (n/a)
  Device Extensions                               cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_byte_addressable_store cl_khr_3d_image_writes cl_khr_int64_base_atomics cl_khr_int64_extended_atomics cl_khr_fp16 cl_khr_icd cl_khr_egl_image cl_khr_image2d_from_buffer cl_khr_depth_images cl_khr_subgroups cl_khr_create_command_queue cl_arm_core_id cl_arm_printf cl_arm_thread_limit_hint cl_arm_non_uniform_work_group_size cl_arm_import_memory cl_arm_shared_virtual_memory
Number of devices                                 0
Number of devices                                 0
NULL platform behavior
  clGetPlatformInfo(NULL, CL_PLATFORM_NAME, ...)  ARM Platform
  clGetDeviceIDs(NULL, CL_DEVICE_TYPE_ALL, ...)   Success [ARM]
  clCreateContext(NULL, ...) [default]            <checkNullCtx:4108: create context with device from default platform : error -6>
  clCreateContext(NULL, ...) [other]              <error: no devices in non-default plaforms>
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_DEFAULT)  <checkNullCtxFromType:4160: create context from type CL_DEVICE_TYPE_DEFAULT : error -6>
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_CPU)  No devices found in platform
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_GPU)  <checkNullCtxFromType:4160: create context from type CL_DEVICE_TYPE_GPU : error -6>
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_ACCELERATOR)  No devices found in platform
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_CUSTOM)  No devices found in platform
  clCreateContextFromType(NULL, CL_DEVICE_TYPE_ALL)  <checkNullCtxFromType:4160: create context from type CL_DEVICE_TYPE_ALL : error -6>
ICD loader properties
  ICD loader Name                                 OpenCL ICD Loader
  ICD loader Vendor                               OCL Icd free software
  ICD loader Version                              2.2.14
  ICD loader Profile                              OpenCL 3.0
My system is Armbian bookworm on an ODROID N2+ (Mali-G52).
Do you have any idea about a workflow how to get OpenCL running properly? What driver (ARM, HK...), what to copy, what to compile, where to copy...
Thank you!
I'm currently running this:
since Debian based systems are for my taste way to stable - outdated.
At times, I grab a nightly image, rearrange it to my liking, drop in my personal configuration preferences and use it till the cycle restarts.
Nothing special, the key is current mainline releases.
Panfrost has been very mature for a long time, so the kernel version may be a bit older.
But of course, the latest version comes with the latest fixes and improvements.
The same goes for Mesa, and that's where the current release is important, as the development of Rusticl is still quite vivid.
To use a version that is more than a year old, and thus to forego any improvements that have taken place during this time, is quite courageous.
But nevertheless, I would be interested in the output result of this command:
RUSTICL_ENABLE=panfrost clinfo
okay, your workflow regarding creating an own OS image is definitely beyond my knowledge 😅. Maybe I will give it a try to create an image for the N2 via the Armbian build system. That looks quite straight forward. Maybe I just screwed up something on my system when I can not get clinfo to detect my GPU, so there is a chance that it works OOTB after fresh install...
Here is the output of the command you requested:
$ sudo RUSTICL_ENABLE=panfrost clinfo
  Platform Vendor                                 ARM
Number of devices                                 1
  Device Vendor                                   ARM
  Driver Version                                  2.0
  Device Type                                     GPU
    char                                                16 / 4
    short                                                8 / 2
    int                                                  4 / 1
    long                                                 2 / 1
    float                                                4 / 1
    double                                               0 / 0        (n/a)
    Denormals                                     Yes
    Round to zero                                 Yes
    Denormals                                     Yes
    Round to zero                                 Yes
    SVM                                           0 bytes
    Global                                        0 bytes
    Local                                         0 bytes
  Image support                                   Yes
    Profiling                                     Yes
    Profiling                                     Yes
Number of devices                                 0
Number of devices                                 0
Normally, I would have said: "With suitable firmware in SPI flash, a raw image  on any storage device is sufficient". This is still true for FC38, but further development of the kernel has revealed a flaw in the support of the S922X SoC. This results in a kernel exception for operation with an ODROID N2/N2+. Of course, this means that it no longer works out-of-the-box for newer releases.
As far as I know, no one has yet provided a mainline acceptable solution, it is just a revert of the advancement. Of course, this is not a long-term solution and is not accepted in mainline.
Rusticl doesn't seem to be able to use the Mali GPU in your setup. I can't tell if the kernel doesn't make it available via the panfrost driver or if Mesa 22.3.6 doesn't even provide rusticl panfrost driver support yet.
For a quick test, I started FC38 again:
As you can see from the clinfo-02.log, Mesa 23.1.9 still lacks basic extensions for rusticl. So it's quite possible that mesa 22.3.6 isn't enough.
But it may also be that it is messed up by your additionally installed CL platforms.
