on orange_pi pc plus i run nand-sata-install
and after progress is 100% i see this error
cp: error writing '/mnt/nand-sata-install.Qdjq7T/bootfs/boot/initrd.img-5.15.74-sunxi': No space left on device
cp: error writing '/mnt/nand-sata-install.Qdjq7T/bootfs/boot/armbianEnv.txt': No space left on device
cp: error writing '/mnt/nand-sata-install.Qdjq7T/bootfs/boot/armbianEnv.txt~': No space left on device
cp: error writing '/mnt/nand-sata-install.Qdjq7T/bootfs/boot/boot.bmp': No space left on device
cp: error writing '/mnt/nand-sata-install.Qdjq7T/bootfs/boot/boot.cmd': No space left on device
cp: error writing '/mnt/nand-sata-install.Qdjq7T/bootfs/boot/boot.scr': No space left on deviceqqqqqqqqqqqqqqqeMMC installqqqqqqqqqqqqqqqqqqqqqqqqk
cp: error writing '/mnt/nand-sata-install.Qdjq7T/bootfs/boot/armbian_first_run.txt.template': No space left on device                             x
cp: cannot create directory '/mnt/nand-sata-install.Qdjq7T/bootfs/boot/overlay-user': No space left on deviceing up ... Almost done.              x
cp: error writing '/mnt/nand-sata-install.Qdjq7T/bootfs/boot/armbianEnv.txz~': No space left on device                                            x
cp: cannot create directory '/mnt/nand-sata-install.Qdjq7T/bootfs/boot/dtb-5.15.74-sunxi': No space left on deviceqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqj
/usr/sbin/nand-sata-install: line 284: echo: write error: No space left on device
Error while creating U-Boot loader image with mkimage
/usr/sbin/nand-sata-install: line 306: echo: write error: No space left on device
cat: write error: No space left on device
and i cant boot from emmc
from SD card i can boot and it works well but cant write to emmc
if i run ls /dev/mm* i can see
SD CARD: /dev/mmcblk0  /dev/mmcblk0p1
EMMC:
 /dev/mmcblk2       /dev/mmcblk2boot1     /dev/mmcblk2boot0      /dev/mmcblk2p1
P.s in sd card i have installed "u-boot-sunxi-with-spl.bin"  this way:
dd if=/dev/zero of=/dev/sda bs=1k count=1023 seek=1
dd if=u-boot-sunxi-with-spl.bin of=/dev/sda bs=1024 seek=8
maybe i need to do something to install u-boot-sunxi-with-spl.bin manually on emmc
Edited by ari1234
