So, i managed to boot from ssd, run docker ... after issues with usb port connection i desided to apt-get upgrade.... then stuff happends that i do not really understand.
As i try to run docker afterwards there seems to be an issue with the storage-driver overlay2.
I tried a- lot of fixes... but do not want to lose the containers and images that i used in docker. A lot of time has gone in to configuring ( :) and figureing? out)
I cannot solve how to get the issue solved.
:) Help! this man is desperate.
How do i start?
armbianmonitor -U
     1
     2  ### Activated 1 lzo-rle zram swap devices with 994MB each.
     3  ### Activated Armbian ramlog partition with zstd compression
     4
     5  Fri Dec  9 06:53:53 PM CET 2022 | Pine64 | 22.05.3 | arm64 | aarch64 | 5.15.48-sunxi64
     6
     7  ### dmesg:
     8
     9  [    1.295379] sun8i-ce 1c15000.crypto: DEBUG: Algo of sha512 not supported
    10  [    1.295388] sun8i-ce 1c15000.crypto: Register stdrng
    11  [    1.295556] sun8i-ce 1c15000.crypto: TRNG not supported
    12  [    1.295565] sun8i-ce 1c15000.crypto: CryptoEngine Die ID 0
    13  [    1.296170] hid: raw HID events driver (C) Jiri Kosina
    14  [    1.296320] usbcore: registered new interface driver usbhid
    15  [    1.296327] usbhid: USB HID core driver
    16  [    1.302464] NET: Registered PF_INET6 protocol family
    17  [    1.955883] Freeing initrd memory: 12684K
    18  [    1.989691] Segment Routing with IPv6
    19  [    1.989807] In-situ OAM (IOAM) with IPv6
    20  [    1.989917] NET: Registered PF_PACKET protocol family
    21  [    1.990072] 8021q: 802.1Q VLAN Support v1.8
    22  [    1.990245] 9pnet: Installing 9P2000 support
    23  [    1.990335] Key type dns_resolver registered
    24  [    1.990873] registered taskstats version 1
    25  [    1.990891] Loading compiled-in X.509 certificates
    26  [    1.995134] Loaded X.509 cert 'Build time autogenerated kernel key: 32330adefd2da02e444296fafd37464380789679'
    27  [    1.999519] zswap: loaded using pool zstd/z3fold
    28  [    2.000278] Key type ._fscrypt registered
    29  [    2.000287] Key type .fscrypt registered
    30  [    2.000293] Key type fscrypt-provisioning registered
    31  [    2.001478] Btrfs loaded, crc32c=crc32c-generic, zoned=yes, fsverity=no
    32  [    2.017261] Key type encrypted registered
    33  [    2.017301] AppArmor: AppArmor sha1 policy hashing enabled
    34  [    2.017348] ima: No TPM chip found, activating TPM-bypass!
    35  [    2.017386] ima: Allocated hash algorithm: sha1
    36  [    2.017458] ima: No architecture policies found
    37  [    2.017515] evm: Initialising EVM extended attributes:
    38  [    2.017520] evm: security.selinux
    39  [    2.017526] evm: security.SMACK64
    40  [    2.017530] evm: security.SMACK64EXEC
    41  [    2.017535] evm: security.SMACK64TRANSMUTE
    42  [    2.017539] evm: security.SMACK64MMAP
    43  [    2.017544] evm: security.apparmor
    44  [    2.017549] evm: security.ima
    45  [    2.017554] evm: security.capability
    46  [    2.017558] evm: HMAC attrs: 0x1
    47  [    2.030401] platform 1100000.mixer: Fixing up cyclic dependency with 1c0d000.lcd-controller
    48  [    2.030490] platform 1100000.mixer: Fixing up cyclic dependency with 1c0c000.lcd-controller
    49  [    2.031240] platform 1200000.mixer: Fixing up cyclic dependency with 1c0d000.lcd-controller
    50  [    2.031307] platform 1200000.mixer: Fixing up cyclic dependency with 1c0c000.lcd-controller
    51  [    2.032165] sunxi-rsb 1f03400.rsb: RSB running at 3000000 Hz
    52  [    2.032550] axp20x-rsb sunxi-rsb-3a3: AXP20x variant AXP803 found
    53  [    2.034692] input: axp20x-pek as /devices/platform/soc/1f03400.rsb/sunxi-rsb-3a3/axp221-pek/input/input0
    54  [    2.037741] vcc-3v3: supplied by regulator-dummy
    55  [    2.038237] vdd-cpux: supplied by regulator-dummy
    56  [    2.038910] dcdc4: supplied by regulator-dummy
    57  [    2.039103] vcc-dram: supplied by regulator-dummy
    58  [    2.039531] vdd-sys: supplied by regulator-dummy
    59  [    2.040092] vcc-phy: supplied by regulator-dummy
    60  [    2.040434] aldo1: supplied by regulator-dummy
    61  [    2.040616] vcc-pl: supplied by regulator-dummy
    62  [    2.041085] vcc-pll-avcc: supplied by regulator-dummy
    63  [    2.041722] vcc-hdmi: supplied by regulator-dummy
    64  [    2.042088] vcc-mipi: supplied by regulator-dummy
    65  [    2.042472] dldo3: supplied by regulator-dummy
    66  [    2.042833] vcc-wifi: supplied by regulator-dummy
    67  [    2.043218] cpvdd: supplied by regulator-dummy
    68  [    2.043582] eldo2: supplied by regulator-dummy
    69  [    2.043950] eldo3: supplied by regulator-dummy
    70  [    2.044339] vcc-1v2-hsic: supplied by regulator-dummy
    71  [    2.044531] vdd-cpus: supplied by regulator-dummy
    72  [    2.044935] vcc-rtc: supplied by regulator-dummy
    73  [    2.045380] ldo-io0: supplied by regulator-dummy
    74  [    2.045759] ldo-io1: supplied by regulator-dummy
    75  [    2.045885] axp20x-rsb sunxi-rsb-3a3: AXP20X driver loaded
    76  [    2.050826] sun50i-a64-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
    77  [    2.051233] sun50i-a64-pinctrl 1c20800.pinctrl: supply vcc-pb not found, using dummy regulator
    78  [    2.051785] printk: console [ttyS0] disabled
    79  [    2.051872] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 41, base_baud = 1500000) is a 16550A
    80  [    2.052086] printk: console [ttyS0] enabled
    81  [    2.052806] sun50i-a64-pinctrl 1c20800.pinctrl: supply vcc-pg not found, using dummy regulator
    82  [    2.053260] 1c28400.serial: ttyS1 at MMIO 0x1c28400 (irq = 42, base_baud = 1500000) is a 16550A
    83  [    2.053451] serial serial0: tty port ttyS1 registered
    84  [    2.083968] sun4i-drm display-engine: bound 1100000.mixer (ops 0xffff800008e16990)
    85  [    2.085749] sun4i-drm display-engine: bound 1200000.mixer (ops 0xffff800008e16990)
    86  [    2.086246] sun4i-drm display-engine: No panel or bridge found... RGB output disabled
    87  [    2.086263] sun4i-drm display-engine: bound 1c0c000.lcd-controller (ops 0xffff800008e11ba0)
    88  [    2.086501] sun4i-drm display-engine: bound 1c0d000.lcd-controller (ops 0xffff800008e11ba0)
    89  [    2.087655] sun8i-dw-hdmi 1ee0000.hdmi: Detected HDMI TX controller v1.32a with HDCP (sun8i_dw_hdmi_phy)
    90  [    2.088290] sun8i-dw-hdmi 1ee0000.hdmi: registered DesignWare HDMI I2C bus driver
    91  [    2.088666] sun4i-drm display-engine: bound 1ee0000.hdmi (ops 0xffff800008e15cc8)
    92  [    2.089340] [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on minor 0
    93  [    2.089450] sun4i-drm display-engine: [drm] Cannot find any crtc or sizes
    94  [    2.090166] sun50i-a64-pinctrl 1c20800.pinctrl: supply vcc-pc not found, using dummy regulator
    95  [    2.090763] sun4i-drm display-engine: [drm] Cannot find any crtc or sizes
    96  [    2.091508] ehci-platform 1c1a000.usb: EHCI Host Controller
    97  [    2.091546] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
    98  [    2.091676] ehci-platform 1c1a000.usb: irq 28, io mem 0x01c1a000
    99  [    2.105429] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
   100  [    2.105873] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
   101  [    2.105889] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
   102  [    2.105901] usb usb1: Product: EHCI Host Controller
   103  [    2.105910] usb usb1: Manufacturer: Linux 5.15.48-sunxi64 ehci_hcd
   104  [    2.105920] usb usb1: SerialNumber: 1c1a000.usb
   105  [    2.106467] hub 1-0:1.0: USB hub found
   106  [    2.106516] hub 1-0:1.0: 1 port detected
   107  [    2.107527] ehci-platform 1c1b000.usb: EHCI Host Controller
   108  [    2.107553] ehci-platform 1c1b000.usb: new USB bus registered, assigned bus number 2
   109  [    2.107679] ehci-platform 1c1b000.usb: irq 30, io mem 0x01c1b000
   110  [    2.121430] ehci-platform 1c1b000.usb: USB 2.0 started, EHCI 1.00
   111  [    2.121720] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
   112  [    2.121735] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
   113  [    2.121747] usb usb2: Product: EHCI Host Controller
   114  [    2.121756] usb usb2: Manufacturer: Linux 5.15.48-sunxi64 ehci_hcd
   115  [    2.121765] usb usb2: SerialNumber: 1c1b000.usb
   116  [    2.122246] hub 2-0:1.0: USB hub found
   117  [    2.122289] hub 2-0:1.0: 1 port detected
   118  [    2.301512] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
   119  [    2.301552] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 3
   120  [    2.301731] ohci-platform 1c1a400.usb: irq 29, io mem 0x01c1a400
   121  [    2.365483] usb 1-1: new high-speed USB device number 2 using ehci-platform
   122  [    2.365752] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.15
   123  [    2.365768] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
   124  [    2.365780] usb usb3: Product: Generic Platform OHCI controller
   125  [    2.365789] usb usb3: Manufacturer: Linux 5.15.48-sunxi64 ohci_hcd
   126  [    2.365799] usb usb3: SerialNumber: 1c1a400.usb
   127  [    2.366359] hub 3-0:1.0: USB hub found
   128  [    2.366410] hub 3-0:1.0: 1 port detected
   129  [    2.367435] ohci-platform 1c1b400.usb: Generic Platform OHCI controller
   130  [    2.367463] ohci-platform 1c1b400.usb: new USB bus registered, assigned bus number 4
   131  [    2.367603] ohci-platform 1c1b400.usb: irq 31, io mem 0x01c1b400
   132  [    2.377431] usb 2-1: new high-speed USB device number 2 using ehci-platform
   133  [    2.433690] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.15
   134  [    2.433705] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
   135  [    2.433717] usb usb4: Product: Generic Platform OHCI controller
   136  [    2.433726] usb usb4: Manufacturer: Linux 5.15.48-sunxi64 ohci_hcd
   137  [    2.433736] usb usb4: SerialNumber: 1c1b400.usb
   138  [    2.434255] hub 4-0:1.0: USB hub found
   139  [    2.434301] hub 4-0:1.0: 1 port detected
   140  [    2.435343] usb_phy_generic usb_phy_generic.3.auto: supply vcc not found, using dummy regulator
   141  [    2.435505] usb_phy_generic usb_phy_generic.3.auto: dummy supplies not allowed for exclusive requests
   142  [    2.509674] musb-hdrc musb-hdrc.4.auto: MUSB HDRC host driver
   143  [    2.509706] musb-hdrc musb-hdrc.4.auto: new USB bus registered, assigned bus number 5
   144  [    2.509990] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
   145  [    2.510006] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
   146  [    2.510018] usb usb5: Product: MUSB HDRC host driver
   147  [    2.510027] usb usb5: Manufacturer: Linux 5.15.48-sunxi64 musb-hcd
   148  [    2.510036] usb usb5: SerialNumber: musb-hdrc.4.auto
   149  [    2.510603] hub 5-0:1.0: USB hub found
   150  [    2.510653] hub 5-0:1.0: 1 port detected
   151  [    2.514069] sun50i-a64-pinctrl 1c20800.pinctrl: supply vcc-pf not found, using dummy regulator
   152  [    2.514140] scpi_protocol scpi: SCP Protocol 0.0 Firmware 0.0.0 version
   153  [    2.515161] sunxi-mmc 1c0f000.mmc: Got CD GPIO
   154  [    2.515161] sunxi-mmc 1c10000.mmc: allocated mmc-pwrseq
   155  [    2.515306] of_cfs_init
   156  [    2.515433] of_cfs_init: OK
   157  [    2.515791] ALSA device list:
   158  [    2.515798]   No soundcards found.
   159  [    2.531360] usb 1-1: New USB device found, idVendor=1f75, idProduct=0621, bcdDevice= 0.36
   160  [    2.531379] usb 1-1: New USB device strings: Mfr=4, Product=5, SerialNumber=6
   161  [    2.531391] usb 1-1: SerialNumber: 20181120
   162  [    2.532355] usb-storage 1-1:1.0: USB Mass Storage device detected
   163  [    2.532902] scsi host0: usb-storage 1-1:1.0
   164  [    2.536597] usb 2-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice= 6.54
   165  [    2.536613] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
   166  [    2.536624] usb 2-1: Product: USB2.1 Hub
   167  [    2.536634] usb 2-1: Manufacturer: GenesysLogic
   168  [    2.537226] hub 2-1:1.0: USB hub found
   169  [    2.537598] hub 2-1:1.0: 4 ports detected
   170  [    2.540602] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB, uses new timings mode
   171  [    2.540829] sunxi-mmc 1c10000.mmc: initialized, max. request size: 16384 KB, uses new timings mode
   172  [    2.542490] Freeing unused kernel memory: 2496K
   173  [    2.542625] Run /init as init process
   174  [    2.542633]   with arguments:
   175  [    2.542639]     /init
   176  [    2.542645]   with environment:
   177  [    2.542650]     HOME=/
   178  [    2.542655]     TERM=linux
   179  [    2.542661]     ubootpart=ea5e158f-01
   180  [    2.542667]     cgroup_enable=memory
   181  [    2.577256] mmc0: new high speed SDHC card at address 0001
   182  [    2.578372] mmcblk0: mmc0:0001 EB1QT 29.8 GiB
   183  [    2.580778]  mmcblk0: p1
   184  [    2.853458] usb 2-1.1: new high-speed USB device number 3 using ehci-platform
   185  [    3.038364] usbcore: registered new interface driver uas
   186  [    3.053676] sun50i-a64-pinctrl 1c20800.pinctrl: supply vcc-ph not found, using dummy regulator
   187  [    3.080577] axp20x-gpio axp20x-gpio: DMA mask not set
   188  [    3.088676] axp20x-gpio axp20x-gpio: AXP209 pinctrl and GPIO driver loaded
   189  [    3.098900] sun50i-a64-pinctrl 1c20800.pinctrl: supply vcc-pd not found, using dummy regulator
   190  [    3.099216] dwmac-sun8i 1c30000.ethernet: IRQ eth_wake_irq not found
   191  [    3.099233] dwmac-sun8i 1c30000.ethernet: IRQ eth_lpi not found
   192  [    3.099565] dwmac-sun8i 1c30000.ethernet: supply phy-io not found, using dummy regulator
   193  [    3.099821] dwmac-sun8i 1c30000.ethernet: PTP uses main clock
   194  [    3.099870] dwmac-sun8i 1c30000.ethernet: Current syscon value is not the default 6 (expect 0)
   195  [    3.100314] dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported
   196  [    3.100337] dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported
   197  [    3.100344] dwmac-sun8i 1c30000.ethernet: COE Type 2
   198  [    3.100355] dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported
   199  [    3.100363] dwmac-sun8i 1c30000.ethernet: Normal descriptors
   200  [    3.100371] dwmac-sun8i 1c30000.ethernet: Chain mode enabled
   201  [    3.205277] usb 2-1.1: New USB device found, idVendor=046d, idProduct=081b, bcdDevice= 0.12
   202  [    3.205312] usb 2-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=2
   203  [    3.205324] usb 2-1.1: SerialNumber: AA5FCF90
   204  [    3.313433] usb 2-1.2: new full-speed USB device number 4 using ehci-platform
   205  [    3.456351] usb 2-1.2: New USB device found, idVendor=0403, idProduct=6001, bcdDevice= 6.00
   206  [    3.456368] usb 2-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
   207  [    3.456379] usb 2-1.2: Product: FT232R USB UART
   208  [    3.456388] usb 2-1.2: Manufacturer: FTDI
   209  [    3.456397] usb 2-1.2: SerialNumber: AR0K4JEL
   210  [    3.558452] scsi 0:0:0:0: Direct-Access     OCZ-VERT EX2                   PQ: 0 ANSI: 6
   211  [    3.559075] sd 0:0:0:0: Attached scsi generic sg0 type 0
   212  [    3.560300] sd 0:0:0:0: [sda] 234441648 512-byte logical blocks: (120 GB/112 GiB)
   213  [    3.561562] sd 0:0:0:0: [sda] Write Protect is off
   214  [    3.561591] sd 0:0:0:0: [sda] Mode Sense: 3b 00 00 00
   215  [    3.562830] sd 0:0:0:0: [sda] No Caching mode page found
   216  [    3.562870] sd 0:0:0:0: [sda] Assuming drive cache: write through
   217  [    3.568912]  sda: sda1
   218  [    3.572400] sd 0:0:0:0: [sda] Attached SCSI disk
   219  [    3.938137] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
   220  [    4.530698] systemd[1]: systemd 249.11-0ubuntu3.4 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP -LIBFDISK +PCRE2 -PWQUALITY -P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
   221  [    4.531436] systemd[1]: Detected architecture arm64.
   222  [    4.534489] systemd[1]: Hostname set to <pine64>.
   223  [    4.658087] dw-apb-uart 1c28000.serial: forbid DMA for kernel console
   224  [    5.479982] systemd[1]: Queued start job for default target Graphical Interface.
   225  [    5.482130] random: systemd: uninitialized urandom read (16 bytes read)
   226  [    5.526010] systemd[1]: Created slice Slice /system/modprobe.
   227  [    5.526743] random: systemd: uninitialized urandom read (16 bytes read)
   228  [    5.529798] systemd[1]: Created slice Slice /system/serial-getty.
   229  [    5.530230] random: systemd: uninitialized urandom read (16 bytes read)
   230  [    5.532549] systemd[1]: Created slice User and Session Slice.
   231  [    5.533035] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped.
   232  [    5.533611] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
   233  [    5.535113] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
   234  [    5.535657] systemd[1]: Reached target Local Encrypted Volumes.
   235  [    5.536358] systemd[1]: Reached target Slice Units.
   236  [    5.536692] systemd[1]: Reached target Swaps.
   237  [    5.537002] systemd[1]: Reached target System Time Set.
   238  [    5.537587] systemd[1]: Reached target Local Verity Protected Volumes.
   239  [    5.559907] systemd[1]: Listening on RPCbind Server Activation Socket.
   240  [    5.561333] systemd[1]: Listening on Syslog Socket.
   241  [    5.562492] systemd[1]: Listening on fsck to fsckd communication Socket.
   242  [    5.563140] systemd[1]: Listening on initctl Compatibility Named Pipe.
   243  [    5.564650] systemd[1]: Listening on Journal Audit Socket.
   244  [    5.565663] systemd[1]: Listening on Journal Socket (/dev/log).
   245  [    5.566774] systemd[1]: Listening on Journal Socket.
   246  [    5.568082] systemd[1]: Listening on udev Control Socket.
   247  [    5.569057] systemd[1]: Listening on udev Kernel Socket.
   248  [    5.574683] systemd[1]: Mounting Huge Pages File System...
   249  [    5.581617] systemd[1]: Mounting POSIX Message Queue File System...
   250  [    5.587786] systemd[1]: Mounting NFSD configuration filesystem...
   251  [    5.594595] systemd[1]: Mounting Kernel Debug File System...
   252  [    5.595712] systemd[1]: Condition check resulted in Kernel Trace File System being skipped.
   253  [    5.596689] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
   254  [    5.605920] systemd[1]: Starting Restore / save the current clock...
   255  [    5.614353] systemd[1]: Starting Set the console keyboard layout...
   256  [    5.623063] systemd[1]: Starting Create List of Static Device Nodes...
   257  [    5.632107] systemd[1]: Starting Load Kernel Module chromeos_pstore...
   258  [    5.640267] systemd[1]: Starting Load Kernel Module configfs...
   259  [    5.648421] systemd[1]: Starting Load Kernel Module drm...
   260  [    5.656519] systemd[1]: Starting Load Kernel Module efi_pstore...
   261  [    5.667005] systemd[1]: Starting Load Kernel Module fuse...
   262  [    5.674704] systemd[1]: Starting Load Kernel Module mtdpstore...
   263  [    5.682795] systemd[1]: Starting Load Kernel Module pstore_blk...
   264  [    5.686006] RPC: Registered named UNIX socket transport module.
   265  [    5.686039] RPC: Registered udp transport module.
   266  [    5.686044] RPC: Registered tcp transport module.
   267  [    5.686049] RPC: Registered tcp NFSv4.1 backchannel transport module.
   268  [    5.691248] systemd[1]: Starting Load Kernel Module pstore_zone...
   269  [    5.699238] systemd[1]: Starting Load Kernel Module ramoops...
   270  [    5.710800] systemd[1]: Started Nameserver information manager.
   271  [    5.712507] systemd[1]: Reached target Preparation for Network.
   272  [    5.714142] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
   273  [    5.728169] fuse: init (API version 7.34)
   274  [    5.746976] systemd[1]: Starting Load Kernel Modules...
   275  [    5.755503] systemd[1]: Starting Remount Root and Kernel File Systems...
   276  [    5.766561] systemd[1]: Starting Coldplug All udev Devices...
   277  [    5.798255] systemd[1]: Mounted Huge Pages File System.
   278  [    5.799407] systemd[1]: Mounted POSIX Message Queue File System.
   279  [    5.800453] systemd[1]: Mounted Kernel Debug File System.
   280  [    5.802887] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
   281  [    5.804360] systemd[1]: Finished Restore / save the current clock.
   282  [    5.809337] systemd[1]: Finished Create List of Static Device Nodes.
   283  [    5.812287] EXT4-fs (sda1): re-mounted. Opts: commit=600,errors=remount-ro. Quota mode: none.
   284  [    5.819178] systemd[1]: Mounted NFSD configuration filesystem.
   285  [    5.821039] systemd[1]: modprobe@chromeos_pstore.service: Deactivated successfully.
   286  [    5.822516] systemd[1]: Finished Load Kernel Module chromeos_pstore.
   287  [    5.824627] systemd[1]: modprobe@configfs.service: Deactivated successfully.
   288  [    5.846741] systemd[1]: Finished Load Kernel Module configfs.
   289  [    5.848800] systemd[1]: modprobe@drm.service: Deactivated successfully.
   290  [    5.850260] systemd[1]: Finished Load Kernel Module drm.
   291  [    5.852292] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
   292  [    5.854781] systemd[1]: Finished Load Kernel Module efi_pstore.
   293  [    5.856829] systemd[1]: modprobe@fuse.service: Deactivated successfully.
   294  [    5.858307] systemd[1]: Finished Load Kernel Module fuse.
   295  [    5.860388] systemd[1]: modprobe@mtdpstore.service: Deactivated successfully.
   296  [    5.861980] systemd[1]: Finished Load Kernel Module mtdpstore.
   297  [    5.864011] systemd[1]: modprobe@pstore_blk.service: Deactivated successfully.
   298  [    5.865608] systemd[1]: Finished Load Kernel Module pstore_blk.
   299  [    5.867642] systemd[1]: modprobe@pstore_zone.service: Deactivated successfully.
   300  [    5.869070] systemd[1]: Finished Load Kernel Module pstore_zone.
   301  [    5.871303] systemd[1]: modprobe@ramoops.service: Deactivated successfully.
   302  [    5.872731] systemd[1]: Finished Load Kernel Module ramoops.
   303  [    5.878987] systemd[1]: Finished Load Kernel Modules.
   304  [    5.882737] systemd[1]: Finished Remount Root and Kernel File Systems.
   305  [    5.910247] systemd[1]: Mounting FUSE Control File System...
   306  [    5.921067] systemd[1]: Mounting Kernel Configuration File System...
   307  [    5.921836] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
   308  [    5.928548] systemd[1]: Starting Load/Save Random Seed...
   309  [    5.935441] systemd[1]: Starting Apply Kernel Variables...
   310  [    5.946632] systemd[1]: Starting Create System Users...
   311  [    5.964986] systemd[1]: Mounted FUSE Control File System.
   312  [    5.966445] systemd[1]: Mounted Kernel Configuration File System.
   313  [    6.006390] systemd[1]: Finished Create System Users.
   314  [    6.078730] systemd[1]: Starting Create Static Device Nodes in /dev...
   315  [    6.082512] systemd[1]: Finished Set the console keyboard layout.
   316  [    6.085782] systemd[1]: Finished Apply Kernel Variables.
   317  [    6.134253] systemd[1]: Finished Create Static Device Nodes in /dev.
   318  [    6.135343] systemd[1]: Reached target Preparation for Local File Systems.
   319  [    6.166200] systemd[1]: Mounting /tmp...
   320  [    6.176511] systemd[1]: Starting Rule-based Manager for Device Events and Files...
   321  [    6.181692] systemd[1]: Mounted /tmp.
   322  [    6.183036] systemd[1]: Reached target Local File Systems.
   323  [    6.191937] systemd[1]: Starting Armbian leds state...
   324  [    6.206231] systemd[1]: Starting Armbian ZRAM config...
   325  [    6.214844] systemd[1]: Starting Set console font and keymap...
   326  [    6.215844] systemd[1]: Condition check resulted in RPC security service for NFS server being skipped.
   327  [    6.216334] systemd[1]: Condition check resulted in Mark the need to relabel after reboot being skipped.
   328  [    6.221977] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
   329  [    6.248638] systemd[1]: Finished Set console font and keymap.
   330  [    6.298156] systemd[1]: armbian-led-state.service: Main process exited, code=exited, status=1/FAILURE
   331  [    6.299141] systemd[1]: armbian-led-state.service: Failed with result 'exit-code'.
   332  [    6.300999] systemd[1]: Failed to start Armbian leds state.
   333  [    6.310527] systemd[1]: Finished Coldplug All udev Devices.
   334  [    6.322224] systemd[1]: Starting Helper to synchronize boot up for ifupdown...
   335  [    6.441891] systemd[1]: Started Rule-based Manager for Device Events and Files.
   336  [    6.570005] zram: Added device: zram0
   337  [    6.570788] zram: Added device: zram1
   338  [    6.571532] zram: Added device: zram2
   339  [    6.659205] urandom_read_iter: 54 callbacks suppressed
   340  [    6.659234] random: systemd: uninitialized urandom read (16 bytes read)
   341  [    6.679091] zram0: detected capacity change from 0 to 2037280
   342  [    6.757626] random: systemd: uninitialized urandom read (16 bytes read)
   343  [    6.757774] random: systemd: uninitialized urandom read (16 bytes read)
   344  [    6.841466] random: crng init done
   345  [    6.841488] random: 6 urandom warning(s) missed due to ratelimiting
   346  [    6.851333] systemd[1]: Finished Load/Save Random Seed.
   347  [    6.852488] systemd[1]: Condition check resulted in First Boot Complete being skipped.
   348  [    6.852618] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
   349  [    6.852764] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
   350  [    6.961299] mc: Linux media interface: v0.10
   351  [    6.976285] Adding 1018636k swap on /dev/zram0.  Priority:5 extents:1 across:1018636k SSFS
   352  [    7.036741] systemd[1]: Found device /dev/ttyS0.
   353  [    7.047314] videodev: Linux video capture interface: v2.00
   354  [    7.274657] zram1: detected capacity change from 0 to 102400
   355  [    7.290084] lima 1c40000.gpu: gp - mali400 version major 1 minor 1
   356  [    7.290221] lima 1c40000.gpu: pp0 - mali400 version major 1 minor 1
   357  [    7.290277] lima 1c40000.gpu: pp1 - mali400 version major 1 minor 1
   358  [    7.290336] lima 1c40000.gpu: l2 cache 64K, 4-way, 64byte cache line, 64bit external bus
   359  [    7.292006] lima 1c40000.gpu: bus rate = 200000000
   360  [    7.292092] lima 1c40000.gpu: mod rate = 432000000
   361  [    7.317277] sunxi_cedrus: module is from the staging directory, the quality is unknown, you have been warned.
   362  [    7.344557] [drm] Initialized lima 1.2.0 20200215 for 1c40000.gpu on minor 1
   363  [    7.418277] cedrus 1c0e000.video-codec: Device registered as /dev/video0
   364  [    7.455716] systemd[1]: Finished Armbian ZRAM config.
   365  [    7.475341] axp20x-battery-power-supply axp20x-battery-power-supply: DMA mask not set
   366  [    7.480922] axp20x-ac-power-supply axp20x-ac-power-supply: DMA mask not set
   367  [    7.483821] Bluetooth: Core ver 2.22
   368  [    7.484187] NET: Registered PF_BLUETOOTH protocol family
   369  [    7.484205] Bluetooth: HCI device and connection manager initialized
   370  [    7.484264] Bluetooth: HCI socket layer initialized
   371  [    7.484282] Bluetooth: L2CAP socket layer initialized
   372  [    7.484327] Bluetooth: SCO socket layer initialized
   373  [    7.589325] systemd[1]: Starting Armbian memory supported logging...
   374  [    7.598740] axp20x-adc axp813-adc: DMA mask not set
   375  [    7.612201] usbcore: registered new interface driver usbserial_generic
   376  [    7.612315] usbserial: USB Serial support registered for generic
   377  [    7.622639] hwmon hwmon4: temp1_input not attached to any thermal zone
   378  [    7.657205] usbcore: registered new interface driver ftdi_sio
   379  [    7.657375] usbserial: USB Serial support registered for FTDI USB Serial Device
   380  [    7.676661] usb 2-1.1: Found UVC 1.00 device <unnamed> (046d:081b)
   381  [    7.678801] ftdi_sio 2-1.2:1.0: FTDI USB Serial Device converter detected
   382  [    7.684383] usb 2-1.2: Detected FT232RL
   383  [    7.703921] systemd[1]: Found device /sys/subsystem/net/devices/eth0.
   384  [    7.738461] input: UVC Camera (046d:081b) as /devices/platform/soc/1c1b000.usb/usb2/2-1/2-1.1/2-1.1:1.0/input/input1
   385  [    7.752488] usb 2-1.2: FTDI USB Serial Device converter now attached to ttyUSB0
   386  [    7.782744] Bluetooth: HCI UART driver ver 2.3
   387  [    7.782841] Bluetooth: HCI UART protocol H4 registered
   388  [    7.782850] Bluetooth: HCI UART protocol BCSP registered
   389  [    7.786686] systemd[1]: Started ifup for eth0.
   390  [    7.792020] usbcore: registered new interface driver uvcvideo
   391  [    7.809997] Bluetooth: HCI UART protocol LL registered
   392  [    7.810071] Bluetooth: HCI UART protocol ATH3K registered
   393  [    7.810347] Bluetooth: HCI UART protocol Three-wire (H5) registered
   394  [    7.810958] Bluetooth: HCI UART protocol Intel registered
   395  [    7.811175] dw-apb-uart 1c28400.serial: failed to request DMA
   396  [    7.811268] Bluetooth: HCI UART protocol Broadcom registered
   397  [    7.811332] Bluetooth: HCI UART protocol QCA registered
   398  [    7.811340] Bluetooth: HCI UART protocol AG6XX registered
   399  [    7.811389] Bluetooth: HCI UART protocol Marvell registered
   400  [    7.846757] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard. Quota mode: none.
   401  [    7.917124] systemd[1]: ifup@eth0.service: Main process exited, code=exited, status=1/FAILURE
   402  [    7.918479] systemd[1]: ifup@eth0.service: Failed with result 'exit-code'.
   403  [    8.319754] systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
   404  [    8.478418] jack: irq plug-in
   405  [    8.482104] input: sun50i-a64-audio Headset Jack as /devices/platform/sound/sound/card2/input2
   406  [    8.689482] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped.
   407  [    8.690039] systemd[1]: Condition check resulted in Kernel Trace File System being skipped.
   408  [    8.714465] systemd[1]: Starting Load Kernel Module chromeos_pstore...
   409  [    8.721368] systemd[1]: Starting Load Kernel Module efi_pstore...
   410  [    8.732748] systemd[1]: Starting Load Kernel Module mtdpstore...
   411  [    8.739423] systemd[1]: Starting Load Kernel Module pstore_blk...
   412  [    8.747849] systemd[1]: Starting Load Kernel Module pstore_zone...
   413  [    8.755291] systemd[1]: Starting Load Kernel Module ramoops...
   414  [    8.756221] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
   415  [    8.756466] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
   416  [    8.756695] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
   417  [    8.759961] systemd[1]: modprobe@chromeos_pstore.service: Deactivated successfully.
   418  [    8.761898] systemd[1]: Finished Load Kernel Module chromeos_pstore.
   419  [    8.764356] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
   420  [    8.765893] systemd[1]: Finished Load Kernel Module efi_pstore.
   421  [    8.768350] systemd[1]: modprobe@mtdpstore.service: Deactivated successfully.
   422  [    8.769339] systemd[1]: Finished Load Kernel Module mtdpstore.
   423  [    8.771060] systemd[1]: modprobe@pstore_blk.service: Deactivated successfully.
   424  [    8.772028] systemd[1]: Finished Load Kernel Module pstore_blk.
   425  [    8.774069] systemd[1]: modprobe@pstore_zone.service: Deactivated successfully.
   426  [    8.775053] systemd[1]: Finished Load Kernel Module pstore_zone.
   427  [    8.781672] systemd[1]: modprobe@ramoops.service: Deactivated successfully.
   428  [    8.782910] systemd[1]: Finished Load Kernel Module ramoops.
   429  [    8.784391] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
   430  [    9.163505] usb 2-1.1: set resolution quirk: cval->res = 384
   431  [    9.164160] usbcore: registered new interface driver snd-usb-audio
   432  [    9.229632] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped.
   433  [    9.230142] systemd[1]: Condition check resulted in Kernel Trace File System being skipped.
   434  [    9.266220] systemd[1]: Starting Load Kernel Module chromeos_pstore...
   435  [    9.273877] systemd[1]: Starting Load Kernel Module efi_pstore...
   436  [    9.279738] systemd[1]: Starting Load Kernel Module mtdpstore...
   437  [    9.285950] systemd[1]: Starting Load Kernel Module pstore_blk...
   438  [    9.292133] systemd[1]: Starting Load Kernel Module pstore_zone...
   439  [    9.298483] systemd[1]: Starting Load Kernel Module ramoops...
   440  [    9.299431] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
   441  [    9.299693] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
   442  [    9.299879] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
   443  [    9.302560] systemd[1]: modprobe@chromeos_pstore.service: Deactivated successfully.
   444  [    9.304024] systemd[1]: Finished Load Kernel Module chromeos_pstore.
   445  [    9.306167] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
   446  [    9.307249] systemd[1]: Finished Load Kernel Module efi_pstore.
   447  [    9.309320] systemd[1]: modprobe@mtdpstore.service: Deactivated successfully.
   448  [    9.310390] systemd[1]: Finished Load Kernel Module mtdpstore.
   449  [    9.312050] systemd[1]: modprobe@pstore_blk.service: Deactivated successfully.
   450  [    9.312975] systemd[1]: Finished Load Kernel Module pstore_blk.
   451  [    9.314656] systemd[1]: modprobe@pstore_zone.service: Deactivated successfully.
   452  [    9.315585] systemd[1]: Finished Load Kernel Module pstore_zone.
   453  [    9.317200] systemd[1]: modprobe@ramoops.service: Deactivated successfully.
   454  [    9.318222] systemd[1]: Finished Load Kernel Module ramoops.
   455  [    9.319228] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
   456  [    9.599031] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped.
   457  [    9.599538] systemd[1]: Condition check resulted in Kernel Trace File System being skipped.
   458  [    9.630260] systemd[1]: Starting Load Kernel Module chromeos_pstore...
   459  [    9.636198] systemd[1]: Starting Load Kernel Module efi_pstore...
   460  [    9.642285] systemd[1]: Starting Load Kernel Module mtdpstore...
   461  [    9.648507] systemd[1]: Starting Load Kernel Module pstore_blk...
   462  [    9.654783] systemd[1]: Starting Load Kernel Module pstore_zone...
   463  [    9.661018] systemd[1]: Starting Load Kernel Module ramoops...
   464  [    9.661938] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
   465  [    9.662180] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
   466  [    9.662379] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
   467  [    9.666196] systemd[1]: Finished Helper to synchronize boot up for ifupdown.
   468  [    9.668105] systemd[1]: modprobe@chromeos_pstore.service: Deactivated successfully.
   469  [    9.669272] systemd[1]: Finished Load Kernel Module chromeos_pstore.
   470  [    9.671364] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
   471  [    9.672277] systemd[1]: Finished Load Kernel Module efi_pstore.
   472  [    9.674113] systemd[1]: modprobe@mtdpstore.service: Deactivated successfully.
   473  [    9.675048] systemd[1]: Finished Load Kernel Module mtdpstore.
   474  [    9.676820] systemd[1]: modprobe@pstore_blk.service: Deactivated successfully.
   475  [    9.677871] systemd[1]: Finished Load Kernel Module pstore_blk.
   476  [    9.679532] systemd[1]: modprobe@pstore_zone.service: Deactivated successfully.
   477  [    9.680430] systemd[1]: Finished Load Kernel Module pstore_zone.
   478  [    9.682259] systemd[1]: modprobe@ramoops.service: Deactivated successfully.
   479  [    9.683210] systemd[1]: Finished Load Kernel Module ramoops.
   480  [    9.689068] systemd[1]: Starting Raise network interfaces...
   481  [    9.689706] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
   482  [   10.079326] systemd[1]: networking.service: Main process exited, code=exited, status=1/FAILURE
   483  [   10.079976] systemd[1]: networking.service: Failed with result 'exit-code'.
   484  [   10.081243] systemd[1]: Failed to start Raise network interfaces.
   485  [   11.214316] systemd[1]: Finished Armbian memory supported logging.
   486  [   11.261900] systemd[1]: Starting Journal Service...
   487  [   11.475047] systemd[1]: Started Journal Service.
   488  [   11.544421] systemd-journald[658]: Received client request to flush runtime journal.
   489
   490  ### armbian-release:
   491
   492  # PLEASE DO NOT EDIT THIS FILE
   493  BOARD=pine64
   494  BOARD_NAME="Pine64"
   495  BOARDFAMILY=sun50iw1
   496  BUILD_REPOSITORY_URL=https://github.com/armbian/build
   497  BUILD_REPOSITORY_COMMIT=13f5fba13c1
   498  VERSION=22.05.3
   499  LINUXFAMILY=sunxi64
   500  ARCH=arm64
   501  IMAGE_TYPE=stable
   502  BOARD_TYPE=conf
   503  INITRD_ARCH=arm64
   504  KERNEL_IMAGE_TYPE=stable
   505  BRANCH=current
   506
   507  ### boot environment:
   508
   509  verbosity=1
   510  bootlogo=false
   511  console=both
   512  disp_mode=1920x1080p60
   513  overlay_prefix=sun50i-a64
   514  rootdev=UUID=1a07fccf-6922-49b1-ace2-e12d87fdb297
   515  rootfstype=ext4
   516  usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
   517
   518  ### lsusb:
   519
   520  Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
   521  Bus 002 Device 004: ID 0403:6001 Future Technology Devices International, Ltd FT232 Serial (UART) IC
   522  Bus 002 Device 003: ID 046d:081b Logitech, Inc. Webcam C310
   523  Bus 002 Device 002: ID 05e3:0610 Genesys Logic, Inc. Hub
   524  Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
   525  Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
   526  Bus 001 Device 002: ID 1f75:0621 Innostor Technology Corporation IS621 SATA Storage Controller
   527  Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
   528  Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
   529
   530  ### lscpu:
   531
   532  Architecture:                    aarch64
   533  CPU op-mode(s):                  32-bit, 64-bit
   534  Byte Order:                      Little Endian
   535  CPU(s):                          4
   536  On-line CPU(s) list:             0-3
   537  Vendor ID:                       ARM
   538  Model name:                      Cortex-A53
   539  Model:                           4
   540  Thread(s) per core:              1
   541  Core(s) per cluster:             4
   542  Socket(s):                       -
   543  Cluster(s):                      1
   544  Stepping:                        r0p4
   545  CPU max MHz:                     1152.0000
   546  CPU min MHz:                     648.0000
   547  BogoMIPS:                        48.00
   548  Flags:                           fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
   549  NUMA node(s):                    1
   550  NUMA node0 CPU(s):               0-3
   551  Vulnerability Itlb multihit:     Not affected
   552  Vulnerability L1tf:              Not affected
   553  Vulnerability Mds:               Not affected
   554  Vulnerability Meltdown:          Not affected
   555  Vulnerability Mmio stale data:   Not affected
   556  Vulnerability Spec store bypass: Not affected
   557  Vulnerability Spectre v1:        Mitigation; __user pointer sanitization
   558  Vulnerability Spectre v2:        Not affected
   559  Vulnerability Srbds:             Not affected
   560  Vulnerability Tsx async abort:   Not affected
   561
   562  ### cpuinfo:
   563
   564  processor       : 0
   565  BogoMIPS        : 48.00
   566  Features        : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
   567  CPU implementer : 0x41
   568  CPU architecture: 8
   569  CPU variant     : 0x0
   570  CPU part        : 0xd03
   571  CPU revision    : 4
   572
   573  processor       : 1
   574  BogoMIPS        : 48.00
   575  Features        : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
   576  CPU implementer : 0x41
   577  CPU architecture: 8
   578  CPU variant     : 0x0
   579  CPU part        : 0xd03
   580  CPU revision    : 4
   581
   582  processor       : 2
   583  BogoMIPS        : 48.00
   584  Features        : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
   585  CPU implementer : 0x41
   586  CPU architecture: 8
   587  CPU variant     : 0x0
   588  CPU part        : 0xd03
   589  CPU revision    : 4
   590
   591  processor       : 3
   592  BogoMIPS        : 48.00
   593  Features        : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
   594  CPU implementer : 0x41
   595  CPU architecture: 8
   596  CPU variant     : 0x0
   597  CPU part        : 0xd03
   598  CPU revision    : 4
   599
   600
   601  ### meminfo:
   602
   603  MemTotal:        2037276 kB
   604  MemFree:         1863420 kB
   605  MemAvailable:    1876548 kB
   606  Buffers:           11652 kB
   607  Cached:            61360 kB
   608  SwapCached:            0 kB
   609  Active:            27756 kB
   610  Inactive:          63724 kB
   611  Active(anon):        348 kB
   612  Inactive(anon):    21196 kB
   613  Active(file):      27408 kB
   614  Inactive(file):    42528 kB
   615  Unevictable:           0 kB
   616  Mlocked:               0 kB
   617  SwapTotal:       1018636 kB
   618  SwapFree:        1018636 kB
   619  Dirty:             12512 kB
   620  Writeback:             0 kB
   621  AnonPages:         18340 kB
   622  Mapped:            16968 kB
   623  Shmem:              3252 kB
   624  KReclaimable:      10284 kB
   625  Slab:              34276 kB
   626  SReclaimable:      10284 kB
   627  SUnreclaim:        23992 kB
   628  KernelStack:        2272 kB
   629  PageTables:         1452 kB
   630  NFS_Unstable:          0 kB
   631  Bounce:                0 kB
   632  WritebackTmp:          0 kB
   633  CommitLimit:     2037272 kB
   634  Committed_AS:      40296 kB
   635  VmallocTotal:   133143592960 kB
   636  VmallocUsed:       24140 kB
   637  VmallocChunk:          0 kB
   638  Percpu:             1264 kB
   639  AnonHugePages:         0 kB
   640  ShmemHugePages:        0 kB
   641  ShmemPmdMapped:        0 kB
   642  FileHugePages:         0 kB
   643  FilePmdMapped:         0 kB
   644  CmaTotal:         131072 kB
   645  CmaFree:          128768 kB
   646  HugePages_Total:       0
   647  HugePages_Free:        0
   648  HugePages_Rsvd:        0
   649  HugePages_Surp:        0
   650  Hugepagesize:       2048 kB
   651  Hugetlb:               0 kB
   652
   653  ### virtual memory:
   654
   655  vm.admin_reserve_kbytes = 8192
   656  vm.compaction_proactiveness = 20
   657  vm.compact_unevictable_allowed = 1
   658  vm.dirty_background_bytes = 0
   659  vm.dirty_background_ratio = 10
   660  vm.dirty_bytes = 0
   661  vm.dirty_expire_centisecs = 3000
   662  vm.dirty_ratio = 20
   663  vm.dirtytime_expire_seconds = 43200
   664  vm.dirty_writeback_centisecs = 500
   665  vm.extfrag_threshold = 500
   666  vm.hugetlb_shm_group = 0
   667  vm.laptop_mode = 0
   668  vm.legacy_va_layout = 0
   669  vm.lowmem_reserve_ratio = 256   256     32      0
   670  vm.max_map_count = 65530
   671  vm.min_free_kbytes = 22528
   672  vm.min_slab_ratio = 5
   673  vm.min_unmapped_ratio = 1
   674  vm.mmap_min_addr = 32768
   675  vm.mmap_rnd_bits = 18
   676  vm.mmap_rnd_compat_bits = 11
   677  vm.nr_hugepages = 0
   678  vm.nr_hugepages_mempolicy = 0
   679  vm.nr_overcommit_hugepages = 0
   680  vm.numa_stat = 1
   681  vm.numa_zonelist_order = Node
   682  vm.oom_dump_tasks = 1
   683  vm.oom_kill_allocating_task = 0
   684  vm.overcommit_kbytes = 0
   685  vm.overcommit_memory = 0
   686  vm.overcommit_ratio = 50
   687  vm.page-cluster = 0
   688  vm.page_lock_unfairness = 5
   689  vm.panic_on_oom = 0
   690  vm.percpu_pagelist_high_fraction = 0
   691  vm.stat_interval = 1
   692  vm.swappiness = 100
   693  vm.user_reserve_kbytes = 63007
   694  vm.vfs_cache_pressure = 100
   695  vm.watermark_boost_factor = 15000
   696  vm.watermark_scale_factor = 10
   697  vm.zone_reclaim_mode = 0
   698
   699  ### ip addr:
   700
   701  1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
   702      link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
   703      inet XXX.XXX.0.1/8 scope host lo
   704         valid_lft forever preferred_lft forever
   705      inet6 ::1/128 scope host
   706         valid_lft forever preferred_lft forever
   707  2: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
   708      link/ether 02:ba:85:77:17:e9 brd ff:ff:ff:ff:ff:ff
   709
   710  ### partitions:
   711
   712  major minor  #blocks  name
   713
   714   179        0   31260672 mmcblk0
   715   179        1   30928896 mmcblk0p1
   716     8        0  117220824 sda
   717     8        1  117218304 sda1
   718   252        0    1018640 zram0
   719   252        1      51200 zram1
   720
   721  ### df:
   722
   723  tmpfs           199M  3.2M  196M   2% /run
   724  /dev/sda1       110G   19G   86G  19% /
   725  tmpfs           995M     0  995M   0% /dev/shm
   726  tmpfs           5.0M  4.0K  5.0M   1% /run/lock
   727  tmpfs           995M     0  995M   0% /tmp
   728  /dev/zram1       47M   13M   32M  29% /var/log
   729
   730  ### lsblk:
   731
   732  NAME        FSTYPE   SIZE MOUNTPOINT UUID
   733  sda                111.8G
   734  └─sda1      ext4   111.8G /          933d6d44-0352-46aa-8100-fd703056ae3d
   735  mmcblk0             29.8G
   736  └─mmcblk0p1 ext4    29.5G            1a07fccf-6922-49b1-ace2-e12d87fdb297
   737  zram1                 50M /var/log
   738  zram2                  0B
   739
   740  ### zramctl:
   741
   742  NAME       ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT
   743  /dev/zram1 zstd           50M  68K  732B   44K       4 /var/log
   744  /dev/zram0 lzo-rle     994.8M   4K   74B   12K       4 [SWAP]
   745
   746  ### mtab:
   747
   748  /dev/sda1 / ext4 rw,noatime,errors=remount-ro,commit=600 0 0
   749  /dev/sda1 /var/log.hdd ext4 rw,noatime,errors=remount-ro,commit=600 0 0
   750  /dev/zram1 /var/log ext4 rw,relatime,discard 0 0
   751
   752  ### mmc0:0001 info:
   753
   754                 fwrev: 0x0
   755                uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=EB1QT MODALIAS=mmc:block
   756                   cid: 1b534d454231515430bc836120012941
   757                   rca: 0x0001
   758                   csd: 400e00325b590000ee7f7f800a404055
   759                manfid: 0x00001b
   760                   ocr: 0x00200000
   761  preferred_erase_size: 4194304
   762                  type: SD
   763                 hwrev: 0x3
   764                  date: 09/2018
   765                   dsr: 0x404
   766            erase_size: 512
   767                 oemid: 0x534d
   768                serial: 0xbc836120
   769                   ssr: 0000000005000000040090000f051c00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
   770                   scr: 02b5800200000000
   771                  name: EB1QT
   772
   773  ### Boot system health:
   774
   775  Time        CPU    load %cpu %sys %usr %nice %io %irq   CPU  C.St.
   776  18:53:54: 1152MHz  0.23  52%  30%  17%   0%   3%   0% 40.7°C  0/7
   777  18:53:55: 1056MHz  0.23  54%  24%  28%   0%   0%   0% 41.2°C  0/7
   778  18:53:55: 1152MHz  0.23  35%  19%  14%   0%   0%   1% 41.2°C  0/7
   779  18:53:55: 1056MHz  0.23  36%  18%  15%   1%   0%   1% 36.1°C  0/7
   780  18:53:56: 1008MHz  0.23  35%  17%  15%   1%   0%   0% 36.1°C  0/7
   781
   782  ### No more available zram devices ()
   783
   784  Fri Dec  9 09:02:35 PM CET 2022 | Pine64 | 22.11.1 | arm64 | aarch64 | 5.15.48-sunxi64
   785
   786  ### dmesg:
   787
   788  [    0.003390] rcu: Hierarchical SRCU implementation.
   789  [    0.004905] smp: Bringing up secondary CPUs ...
   790  [    0.006156] Detected VIPT I-cache on CPU1
   791  [    0.006225] arch_timer: CPU1: Trapping CNTVCT access
   792  [    0.006242] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
   793  [    0.007054] Detected VIPT I-cache on CPU2
   794  [    0.007090] arch_timer: CPU2: Trapping CNTVCT access
   795  [    0.007101] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
   796  [    0.007832] Detected VIPT I-cache on CPU3
   797  [    0.007866] arch_timer: CPU3: Trapping CNTVCT access
   798  [    0.007876] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
   799  [    0.008000] smp: Brought up 1 node, 4 CPUs
   800  [    0.008017] SMP: Total of 4 processors activated.
   801  [    0.008024] CPU features: detected: 32-bit EL0 Support
   802  [    0.008030] CPU features: detected: CRC32 instructions
   803  [    0.022878] CPU: All CPU(s) started at EL2
   804  [    0.022912] alternatives: patching kernel code
   805  [    0.024731] devtmpfs: initialized
   806  [    0.032773] Registered cp15_barrier emulation handler
   807  [    0.032807] Registered setend emulation handler
   808  [    0.032990] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
   809  [    0.033014] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
   810  [    0.038461] pinctrl core: initialized pinctrl subsystem
   811  [    0.040135] NET: Registered PF_NETLINK/PF_ROUTE protocol family
   812  [    0.041986] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
   813  [    0.042165] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
   814  [    0.042365] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
   815  [    0.042476] audit: initializing netlink subsys (disabled)
   816  [    0.042691] audit: type=2000 audit(0.040:1): state=initialized audit_enabled=0 res=1
   817  [    0.043293] thermal_sys: Registered thermal governor 'fair_share'
   818  [    0.043301] thermal_sys: Registered thermal governor 'bang_bang'
   819  [    0.043307] thermal_sys: Registered thermal governor 'step_wise'
   820  [    0.043312] thermal_sys: Registered thermal governor 'user_space'
   821  [    0.043749] cpuidle: using governor menu
   822  [    0.044007] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
   823  [    0.044119] ASID allocator initialised with 65536 entries
   824  [    0.044315] Serial: AMBA PL011 UART driver
   825  [    0.060307] platform 1ee0000.hdmi: Fixing up cyclic dependency with 1c0d000.lcd-controller
   826  [    0.061835] platform hdmi-connector: Fixing up cyclic dependency with 1ee0000.hdmi
   827  [    0.069915] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
   828  [    0.069939] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
   829  [    0.069948] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
   830  [    0.069956] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
   831  [    0.072137] cryptd: max_cpu_qlen set to 1000
   832  [    0.140260] raid6: neonx8   gen()  1456 MB/s
   833  [    0.208333] raid6: neonx8   xor()  1091 MB/s
   834  [    0.276415] raid6: neonx4   gen()  1495 MB/s
   835  [    0.344481] raid6: neonx4   xor()  1081 MB/s
   836  [    0.412575] raid6: neonx2   gen()  1411 MB/s
   837  [    0.480651] raid6: neonx2   xor()   991 MB/s
   838  [    0.548725] raid6: neonx1   gen()  1229 MB/s
   839  [    0.616797] raid6: neonx1   xor()   848 MB/s
   840  [    0.684870] raid6: int64x8  gen()  1019 MB/s
   841  [    0.752945] raid6: int64x8  xor()   533 MB/s
   842  [    0.821018] raid6: int64x4  gen()  1126 MB/s
   843  [    0.889081] raid6: int64x4  xor()   573 MB/s
   844  [    0.957167] raid6: int64x2  gen()   962 MB/s
   845  [    1.025230] raid6: int64x2  xor()   509 MB/s
   846  [    1.093311] raid6: int64x1  gen()   716 MB/s
   847  [    1.161376] raid6: int64x1  xor()   372 MB/s
   848  [    1.161383] raid6: using algorithm neonx4 gen() 1495 MB/s
   849  [    1.161389] raid6: .... xor() 1081 MB/s, rmw enabled
   850  [    1.161395] raid6: using neon recovery algorithm
   851  [    1.162072] iommu: Default domain type: Translated
   852  [    1.162081] iommu: DMA domain TLB invalidation policy: strict mode
   853  [    1.162408] SCSI subsystem initialized
   854  [    1.162634] usbcore: registered new interface driver usbfs
   855  [    1.162684] usbcore: registered new interface driver hub
   856  [    1.162720] usbcore: registered new device driver usb
   857  [    1.163047] pps_core: LinuxPPS API ver. 1 registered
   858  [    1.163054] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
   859  [    1.163073] PTP clock support registered
   860  [    1.163583] ARM FF-A: FFA_VERSION returned not supported
   861  [    1.163979] Advanced Linux Sound Architecture Driver Initialized.
   862  [    1.164722] NetLabel: Initializing
   863  [    1.164728] NetLabel:  domain hash size = 128
   864  [    1.164734] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
   865  [    1.164818] NetLabel:  unlabeled traffic allowed by default
   866  [    1.165322] clocksource: Switched to clocksource arch_sys_counter
   867  [    1.165555] VFS: Disk quotas dquot_6.6.0
   868  [    1.165617] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
   869  [    1.166276] AppArmor: AppArmor Filesystem Enabled
   870  [    1.173500] NET: Registered PF_INET protocol family
   871  [    1.173779] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
   872  [    1.175152] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
   873  [    1.175196] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
   874  [    1.175214] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
   875  [    1.175374] TCP bind hash table entries: 16384 (order: 6, 262144 bytes, linear)
   876  [    1.175700] TCP: Hash tables configured (established 16384 bind 16384)
   877  [    1.175864] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
   878  [    1.175932] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
   879  [    1.176154] NET: Registered PF_UNIX/PF_LOCAL protocol family
   880  [    1.176746] Trying to unpack rootfs image as initramfs...
   881  [    1.186754] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
   882  [    1.193921] Initialise system trusted keyrings
   883  [    1.194017] Key type blacklist registered
   884  [    1.194270] workingset: timestamp_bits=44 max_order=19 bucket_order=0
   885  [    1.200671] zbud: loaded
   886  [    1.202448] squashfs: version 4.0 (2009/01/31) Phillip Lougher
   887  [    1.205034] integrity: Platform Keyring initialized
   888  [    1.258464] xor: automatically using best checksumming function   32regs
   889  [    1.258493] async_tx: api initialized (async)
   890  [    1.258505] Key type asymmetric registered
   891  [    1.258512] Asymmetric key parser 'x509' registered
   892  [    1.258656] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
   893  [    1.258833] io scheduler mq-deadline registered
   894  [    1.258842] io scheduler kyber registered
   895  [    1.259058] io scheduler bfq registered
   896  [    1.263135] sun50i-a64-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver
   897  [    1.273197] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
   898  [    1.285222] loop: module loaded
   899  [    1.287819] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
   900  [    1.287855] ehci-platform: EHCI generic platform driver
   901  [    1.288013] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
   902  [    1.288028] ohci-platform: OHCI generic platform driver
   903  [    1.288523] usbcore: registered new interface driver usb-storage
   904  [    1.289104] mousedev: PS/2 mouse device common for all mice
   905  [    1.290282] sun6i-rtc 1f00000.rtc: registered as rtc0
   906  [    1.290323] sun6i-rtc 1f00000.rtc: setting system clock to 2022-12-09T20:02:25 UTC (1670616145)
   907  [    1.290445] sun6i-rtc 1f00000.rtc: RTC enabled
   908  [    1.290557] i2c_dev: i2c /dev entries driver
   909  [    1.291379] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
   910  [    1.293519] sun50i-a64-r-pinctrl 1f02c00.pinctrl: supply vcc-pl not found, using dummy regulator
   911  [    1.294045] sdhci: Secure Digital Host Controller Interface driver
   912  [    1.294054] sdhci: Copyright(c) Pierre Ossman
   913  [    1.294083] Synopsys Designware Multimedia Card Interface Driver
   914  [    1.294845] sdhci-pltfm: SDHCI platform and OF driver helper
   915  [    1.295969] ledtrig-cpu: registered to indicate activity on CPUs
   916  [    1.296474] SMCCC: SOC_ID: ID = jep106:091e:1689 Revision = 0x00000001
   917  [    1.296794] sun8i-ce 1c15000.crypto: Set mod clock to 300000000 (300 Mhz) from 24000000 (24 Mhz)
   918  [    1.297091] sun8i-ce 1c15000.crypto: will run requests pump with realtime priority
   919  [    1.297277] sun8i-ce 1c15000.crypto: will run requests pump with realtime priority
   920  [    1.297523] sun8i-ce 1c15000.crypto: will run requests pump with realtime priority
   921  [    1.297645] sun8i-ce 1c15000.crypto: will run requests pump with realtime priority
   922  [    1.297746] sun8i-ce 1c15000.crypto: Register cbc(aes)
   923  [    1.297935] sun8i-ce 1c15000.crypto: Register ecb(aes)
   924  [    1.298075] sun8i-ce 1c15000.crypto: Register cbc(des3_ede)
   925  [    1.298216] sun8i-ce 1c15000.crypto: Register ecb(des3_ede)
   926  [    1.298350] sun8i-ce 1c15000.crypto: Register md5
   927  [    1.298490] sun8i-ce 1c15000.crypto: Register sha1
   928  [    1.298623] sun8i-ce 1c15000.crypto: Register sha224
   929  [    1.298763] sun8i-ce 1c15000.crypto: Register sha256
   930  [    1.298897] sun8i-ce 1c15000.crypto: DEBUG: Algo of sha384 not supported
   931  [    1.298908] sun8i-ce 1c15000.crypto: DEBUG: Algo of sha512 not supported
   932  [    1.298916] sun8i-ce 1c15000.crypto: Register stdrng
   933  [    1.299072] sun8i-ce 1c15000.crypto: TRNG not supported
   934  [    1.299083] sun8i-ce 1c15000.crypto: CryptoEngine Die ID 0
   935  [    1.299677] hid: raw HID events driver (C) Jiri Kosina
   936  [    1.299825] usbcore: registered new interface driver usbhid
   937  [    1.299833] usbhid: USB HID core driver
   938  [    1.305971] NET: Registered PF_INET6 protocol family
   939  [    1.956399] Freeing initrd memory: 12684K
   940  [    1.989933] Segment Routing with IPv6
   941  [    1.990034] In-situ OAM (IOAM) with IPv6
   942  [    1.990136] NET: Registered PF_PACKET protocol family
   943  [    1.990283] 8021q: 802.1Q VLAN Support v1.8
   944  [    1.990452] 9pnet: Installing 9P2000 support
   945  [    1.990566] Key type dns_resolver registered
   946  [    1.991114] registered taskstats version 1
   947  [    1.991132] Loading compiled-in X.509 certificates
   948  [    1.995427] Loaded X.509 cert 'Build time autogenerated kernel key: 32330adefd2da02e444296fafd37464380789679'
   949  [    1.999778] zswap: loaded using pool zstd/z3fold
   950  [    2.000511] Key type ._fscrypt registered
   951  [    2.000519] Key type .fscrypt registered
   952  [    2.000525] Key type fscrypt-provisioning registered
   953  [    2.001703] Btrfs loaded, crc32c=crc32c-generic, zoned=yes, fsverity=no
   954  [    2.017536] Key type encrypted registered
   955  [    2.017572] AppArmor: AppArmor sha1 policy hashing enabled
   956  [    2.017617] ima: No TPM chip found, activating TPM-bypass!
   957  [    2.017661] ima: Allocated hash algorithm: sha1
   958  [    2.017704] ima: No architecture policies found
   959  [    2.017759] evm: Initialising EVM extended attributes:
   960  [    2.017764] evm: security.selinux
   961  [    2.017770] evm: security.SMACK64
   962  [    2.017774] evm: security.SMACK64EXEC
   963  [    2.017779] evm: security.SMACK64TRANSMUTE
   964  [    2.017783] evm: security.SMACK64MMAP
   965  [    2.017788] evm: security.apparmor
   966  [    2.017793] evm: security.ima
   967  [    2.017797] evm: security.capability
   968  [    2.017802] evm: HMAC attrs: 0x1
   969  [    2.030714] platform 1100000.mixer: Fixing up cyclic dependency with 1c0d000.lcd-controller
   970  [    2.030811] platform 1100000.mixer: Fixing up cyclic dependency with 1c0c000.lcd-controller
   971  [    2.031564] platform 1200000.mixer: Fixing up cyclic dependency with 1c0d000.lcd-controller
   972  [    2.031633] platform 1200000.mixer: Fixing up cyclic dependency with 1c0c000.lcd-controller
   973  [    2.032492] sunxi-rsb 1f03400.rsb: RSB running at 3000000 Hz
   974  [    2.032926] axp20x-rsb sunxi-rsb-3a3: AXP20x variant AXP803 found
   975  [    2.035103] input: axp20x-pek as /devices/platform/soc/1f03400.rsb/sunxi-rsb-3a3/axp221-pek/input/input0
   976  [    2.038141] vcc-3v3: supplied by regulator-dummy
   977  [    2.038637] vdd-cpux: supplied by regulator-dummy
   978  [    2.039288] dcdc4: supplied by regulator-dummy
   979  [    2.039504] vcc-dram: supplied by regulator-dummy
   980  [    2.039949] vdd-sys: supplied by regulator-dummy
   981  [    2.040463] vcc-phy: supplied by regulator-dummy
   982  [    2.040836] aldo1: supplied by regulator-dummy
   983  [    2.041013] vcc-pl: supplied by regulator-dummy
   984  [    2.041491] vcc-pll-avcc: supplied by regulator-dummy
   985  [    2.042113] vcc-hdmi: supplied by regulator-dummy
   986  [    2.042474] vcc-mipi: supplied by regulator-dummy
   987  [    2.042859] dldo3: supplied by regulator-dummy
   988  [    2.043225] vcc-wifi: supplied by regulator-dummy
   989  [    2.043589] cpvdd: supplied by regulator-dummy
   990  [    2.043978] eldo2: supplied by regulator-dummy
   991  [    2.044351] eldo3: supplied by regulator-dummy
   992  [    2.044717] vcc-1v2-hsic: supplied by regulator-dummy
   993  [    2.044938] vdd-cpus: supplied by regulator-dummy
   994  [    2.045386] vcc-rtc: supplied by regulator-dummy
   995  [    2.045840] ldo-io0: supplied by regulator-dummy
   996  [    2.046176] ldo-io1: supplied by regulator-dummy
   997  [    2.046296] axp20x-rsb sunxi-rsb-3a3: AXP20X driver loaded
   998  [    2.051157] sun50i-a64-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
   999  [    2.051588] sun50i-a64-pinctrl 1c20800.pinctrl: supply vcc-pb not found, using dummy regulator
  1000  [    2.052176] printk: console [ttyS0] disabled
  1001  [    2.052263] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 41, base_baud = 1500000) is a 16550A
  1002  [    2.052473] printk: console [ttyS0] enabled
  1003  [    2.053167] sun50i-a64-pinctrl 1c20800.pinctrl: supply vcc-pg not found, using dummy regulator
  1004  [    2.053687] 1c28400.serial: ttyS1 at MMIO 0x1c28400 (irq = 42, base_baud = 1500000) is a 16550A
  1005  [    2.053845] serial serial0: tty port ttyS1 registered
  1006  [    2.084440] sun4i-drm display-engine: bound 1100000.mixer (ops 0xffff800008e16990)
  1007  [    2.086282] sun4i-drm display-engine: bound 1200000.mixer (ops 0xffff800008e16990)
  1008  [    2.086798] sun4i-drm display-engine: No panel or bridge found... RGB output disabled
  1009  [    2.086818] sun4i-drm display-engine: bound 1c0c000.lcd-controller (ops 0xffff800008e11ba0)
  1010  [    2.087052] sun4i-drm display-engine: bound 1c0d000.lcd-controller (ops 0xffff800008e11ba0)
  1011  [    2.088217] sun8i-dw-hdmi 1ee0000.hdmi: Detected HDMI TX controller v1.32a with HDCP (sun8i_dw_hdmi_phy)
  1012  [    2.088848] sun8i-dw-hdmi 1ee0000.hdmi: registered DesignWare HDMI I2C bus driver
  1013  [    2.089229] sun4i-drm display-engine: bound 1ee0000.hdmi (ops 0xffff800008e15cc8)
  1014  [    2.089992] [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on minor 0
  1015  [    2.090079] sun4i-drm display-engine: [drm] Cannot find any crtc or sizes
  1016  [    2.090792] sun50i-a64-pinctrl 1c20800.pinctrl: supply vcc-pc not found, using dummy regulator
  1017  [    2.091360] sun4i-drm display-engine: [drm] Cannot find any crtc or sizes
  1018  [    2.092081] ehci-platform 1c1a000.usb: EHCI Host Controller
  1019  [    2.092115] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
  1020  [    2.092247] ehci-platform 1c1a000.usb: irq 28, io mem 0x01c1a000
  1021  [    2.105340] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
  1022  [    2.105712] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
  1023  [    2.105728] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  1024  [    2.105740] usb usb1: Product: EHCI Host Controller
  1025  [    2.105749] usb usb1: Manufacturer: Linux 5.15.48-sunxi64 ehci_hcd
  1026  [    2.105759] usb usb1: SerialNumber: 1c1a000.usb
  1027  [    2.106319] hub 1-0:1.0: USB hub found
  1028  [    2.106378] hub 1-0:1.0: 1 port detected
  1029  [    2.107445] ehci-platform 1c1b000.usb: EHCI Host Controller
  1030  [    2.107471] ehci-platform 1c1b000.usb: new USB bus registered, assigned bus number 2
  1031  [    2.107612] ehci-platform 1c1b000.usb: irq 30, io mem 0x01c1b000
  1032  [    2.121326] ehci-platform 1c1b000.usb: USB 2.0 started, EHCI 1.00
  1033  [    2.121651] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
  1034  [    2.121667] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  1035  [    2.121678] usb usb2: Product: EHCI Host Controller
  1036  [    2.121687] usb usb2: Manufacturer: Linux 5.15.48-sunxi64 ehci_hcd
  1037  [    2.121697] usb usb2: SerialNumber: 1c1b000.usb
  1038  [    2.122190] hub 2-0:1.0: USB hub found
  1039  [    2.122240] hub 2-0:1.0: 1 port detected
  1040  [    2.297431] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
  1041  [    2.297470] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 3
  1042  [    2.297607] ohci-platform 1c1a400.usb: irq 29, io mem 0x01c1a400
  1043  [    2.361386] usb 1-1: new high-speed USB device number 2 using ehci-platform
  1044  [    2.361675] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.15
  1045  [    2.361690] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  1046  [    2.361702] usb usb3: Product: Generic Platform OHCI controller
  1047  [    2.361712] usb usb3: Manufacturer: Linux 5.15.48-sunxi64 ohci_hcd
  1048  [    2.361721] usb usb3: SerialNumber: 1c1a400.usb
  1049  [    2.362233] hub 3-0:1.0: USB hub found
  1050  [    2.362281] hub 3-0:1.0: 1 port detected
  1051  [    2.363296] ohci-platform 1c1b400.usb: Generic Platform OHCI controller
  1052  [    2.363323] ohci-platform 1c1b400.usb: new USB bus registered, assigned bus number 4
  1053  [    2.363492] ohci-platform 1c1b400.usb: irq 31, io mem 0x01c1b400
  1054  [    2.377341] usb 2-1: new high-speed USB device number 2 using ehci-platform
  1055  [    2.425592] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.15
  1056  [    2.425607] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  1057  [    2.425619] usb usb4: Product: Generic Platform OHCI controller
  1058  [    2.425629] usb usb4: Manufacturer: Linux 5.15.48-sunxi64 ohci_hcd
  1059  [    2.425638] usb usb4: SerialNumber: 1c1b400.usb
  1060  [    2.426151] hub 4-0:1.0: USB hub found
  1061  [    2.426205] hub 4-0:1.0: 1 port detected
  1062  [    2.427269] usb_phy_generic usb_phy_generic.3.auto: supply vcc not found, using dummy regulator
  1063  [    2.427419] usb_phy_generic usb_phy_generic.3.auto: dummy supplies not allowed for exclusive requests
  1064  [    2.505603] musb-hdrc musb-hdrc.4.auto: MUSB HDRC host driver
  1065  [    2.505635] musb-hdrc musb-hdrc.4.auto: new USB bus registered, assigned bus number 5
  1066  [    2.505915] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
  1067  [    2.505931] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  1068  [    2.505943] usb usb5: Product: MUSB HDRC host driver
  1069  [    2.505952] usb usb5: Manufacturer: Linux 5.15.48-sunxi64 musb-hcd
  1070  [    2.505962] usb usb5: SerialNumber: musb-hdrc.4.auto
  1071  [    2.506486] hub 5-0:1.0: USB hub found
  1072  [    2.506535] hub 5-0:1.0: 1 port detected
  1073  [    2.509992] sun50i-a64-pinctrl 1c20800.pinctrl: supply vcc-pf not found, using dummy regulator
  1074  [    2.510054] scpi_protocol scpi: SCP Protocol 0.0 Firmware 0.0.0 version
  1075  [    2.511089] sunxi-mmc 1c10000.mmc: allocated mmc-pwrseq
  1076  [    2.511096] sunxi-mmc 1c0f000.mmc: Got CD GPIO
  1077  [    2.511224] of_cfs_init
  1078  [    2.511388] of_cfs_init: OK
  1079  [    2.511811] ALSA device list:
  1080  [    2.511819]   No soundcards found.
  1081  [    2.519310] usb 1-1: New USB device found, idVendor=1f75, idProduct=0621, bcdDevice= 0.36
  1082  [    2.519327] usb 1-1: New USB device strings: Mfr=4, Product=5, SerialNumber=6
  1083  [    2.519338] usb 1-1: SerialNumber: 20181120
  1084  [    2.520305] usb-storage 1-1:1.0: USB Mass Storage device detected
  1085  [    2.520835] scsi host0: usb-storage 1-1:1.0
  1086  [    2.536408] usb 2-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice= 6.54
  1087  [    2.536425] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
  1088  [    2.536437] usb 2-1: Product: USB2.1 Hub
  1089  [    2.536446] usb 2-1: Manufacturer: GenesysLogic
  1090  [    2.536559] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB, uses new timings mode
  1091  [    2.536788] sunxi-mmc 1c10000.mmc: initialized, max. request size: 16384 KB, uses new timings mode
  1092  [    2.538570] Freeing unused kernel memory: 2496K
  1093  [    2.538798] hub 2-1:1.0: USB hub found
  1094  [    2.538952] Run /init as init process
  1095  [    2.538960]   with arguments:
  1096  [    2.538966]     /init
  1097  [    2.538973]   with environment:
  1098  [    2.538978]     HOME=/
  1099  [    2.538983]     TERM=linux
  1100  [    2.538988]     ubootpart=ea5e158f-01
  1101  [    2.538994]     cgroup_enable=memory
  1102  [    2.539224] hub 2-1:1.0: 4 ports detected
  1103  [    2.573398] mmc0: new high speed SDHC card at address 0001
  1104  [    2.574518] mmcblk0: mmc0:0001 EB1QT 29.8 GiB
  1105  [    2.576949]  mmcblk0: p1
  1106  [    2.853398] usb 2-1.1: new high-speed USB device number 3 using ehci-platform
  1107  [    3.043430] usbcore: registered new interface driver uas
  1108  [    3.058898] sun50i-a64-pinctrl 1c20800.pinctrl: supply vcc-ph not found, using dummy regulator
  1109  [    3.067368] sun50i-a64-pinctrl 1c20800.pinctrl: supply vcc-pd not found, using dummy regulator
  1110  [    3.067643] dwmac-sun8i 1c30000.ethernet: IRQ eth_wake_irq not found
  1111  [    3.067658] dwmac-sun8i 1c30000.ethernet: IRQ eth_lpi not found
  1112  [    3.067986] dwmac-sun8i 1c30000.ethernet: supply phy-io not found, using dummy regulator
  1113  [    3.069558] dwmac-sun8i 1c30000.ethernet: PTP uses main clock
  1114  [    3.069621] dwmac-sun8i 1c30000.ethernet: Current syscon value is not the default 6 (expect 0)
  1115  [    3.071253] dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported
  1116  [    3.071280] dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported
  1117  [    3.071288] dwmac-sun8i 1c30000.ethernet: COE Type 2
  1118  [    3.071298] dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported
  1119  [    3.071307] dwmac-sun8i 1c30000.ethernet: Normal descriptors
  1120  [    3.071315] dwmac-sun8i 1c30000.ethernet: Chain mode enabled
  1121  [    3.093587] axp20x-gpio axp20x-gpio: DMA mask not set
  1122  [    3.094580] axp20x-gpio axp20x-gpio: AXP209 pinctrl and GPIO driver loaded
  1123  [    3.206728] usb 2-1.1: New USB device found, idVendor=046d, idProduct=081b, bcdDevice= 0.12
  1124  [    3.206766] usb 2-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=2
  1125  [    3.206779] usb 2-1.1: SerialNumber: AA5FCF90
  1126  [    3.313376] usb 2-1.2: new full-speed USB device number 4 using ehci-platform
  1127  [    3.452285] usb 2-1.2: New USB device found, idVendor=0403, idProduct=6001, bcdDevice= 6.00
  1128  [    3.452301] usb 2-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
  1129  [    3.452313] usb 2-1.2: Product: FT232R USB UART
  1130  [    3.452323] usb 2-1.2: Manufacturer: FTDI
  1131  [    3.452332] usb 2-1.2: SerialNumber: AR0K4JEL
  1132  [    3.526365] scsi 0:0:0:0: Direct-Access     OCZ-VERT EX2                   PQ: 0 ANSI: 6
  1133  [    3.527753] sd 0:0:0:0: [sda] 234441648 512-byte logical blocks: (120 GB/112 GiB)
  1134  [    3.528870] sd 0:0:0:0: [sda] Write Protect is off
  1135  [    3.528902] sd 0:0:0:0: [sda] Mode Sense: 3b 00 00 00
  1136  [    3.529262] sd 0:0:0:0: Attached scsi generic sg0 type 0
  1137  [    3.530692] sd 0:0:0:0: [sda] No Caching mode page found
  1138  [    3.530722] sd 0:0:0:0: [sda] Assuming drive cache: write through
  1139  [    3.536985]  sda: sda1
  1140  [    3.540595] sd 0:0:0:0: [sda] Attached SCSI disk
  1141  [    3.931963] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
  1142  [    4.528269] systemd[1]: systemd 249.11-0ubuntu3.6 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY -P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
  1143  [    4.528991] systemd[1]: Detected architecture arm64.
  1144  [    4.531890] systemd[1]: Hostname set to <pine64>.
  1145  [    4.621537] dw-apb-uart 1c28000.serial: forbid DMA for kernel console
  1146  [    5.500464] systemd[1]: Queued start job for default target Graphical Interface.
  1147  [    5.502727] random: systemd: uninitialized urandom read (16 bytes read)
  1148  [    5.537903] systemd[1]: Created slice Slice /system/modprobe.
  1149  [    5.538624] random: systemd: uninitialized urandom read (16 bytes read)
  1150  [    5.541663] systemd[1]: Created slice Slice /system/serial-getty.
  1151  [    5.542122] random: systemd: uninitialized urandom read (16 bytes read)
  1152  [    5.544480] systemd[1]: Created slice User and Session Slice.
  1153  [    5.544953] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped.
  1154  [    5.545514] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
  1155  [    5.546961] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
  1156  [    5.547503] systemd[1]: Reached target Local Encrypted Volumes.
  1157  [    5.548232] systemd[1]: Reached target Slice Units.
  1158  [    5.548589] systemd[1]: Reached target Swaps.
  1159  [    5.548895] systemd[1]: Reached target System Time Set.
  1160  [    5.549405] systemd[1]: Reached target Local Verity Protected Volumes.
  1161  [    5.572118] systemd[1]: Listening on RPCbind Server Activation Socket.
  1162  [    5.574322] systemd[1]: Listening on Syslog Socket.
  1163  [    5.575558] systemd[1]: Listening on fsck to fsckd communication Socket.
  1164  [    5.576233] systemd[1]: Listening on initctl Compatibility Named Pipe.
  1165  [    5.577886] systemd[1]: Listening on Journal Audit Socket.
  1166  [    5.578920] systemd[1]: Listening on Journal Socket (/dev/log).
  1167  [    5.580016] systemd[1]: Listening on Journal Socket.
  1168  [    5.581504] systemd[1]: Listening on udev Control Socket.
  1169  [    5.582525] systemd[1]: Listening on udev Kernel Socket.
  1170  [    5.588297] systemd[1]: Mounting Huge Pages File System...
  1171  [    5.595231] systemd[1]: Mounting POSIX Message Queue File System...
  1172  [    5.601550] systemd[1]: Mounting NFSD configuration filesystem...
  1173  [    5.608288] systemd[1]: Mounting Kernel Debug File System...
  1174  [    5.609832] systemd[1]: Condition check resulted in Kernel Trace File System being skipped.
  1175  [    5.610770] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
  1176  [    5.619686] systemd[1]: Starting Restore / save the current clock...
  1177  [    5.628104] systemd[1]: Starting Set the console keyboard layout...
  1178  [    5.628788] systemd[1]: Condition check resulted in Create List of Static Device Nodes being skipped.
  1179  [    5.635996] systemd[1]: Starting Load Kernel Module chromeos_pstore...
  1180  [    5.643611] systemd[1]: Starting Load Kernel Module configfs...
  1181  [    5.651538] systemd[1]: Starting Load Kernel Module drm...
  1182  [    5.659669] systemd[1]: Starting Load Kernel Module efi_pstore...
  1183  [    5.667830] systemd[1]: Starting Load Kernel Module fuse...
  1184  [    5.675761] systemd[1]: Starting Load Kernel Module pstore_blk...
  1185  [    5.683701] systemd[1]: Starting Load Kernel Module pstore_zone...
  1186  [    5.691618] systemd[1]: Starting Load Kernel Module ramoops...
  1187  [    5.699936] systemd[1]: Started Nameserver information manager.
  1188  [    5.701621] systemd[1]: Reached target Preparation for Network.
  1189  [    5.702869] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
  1190  [    5.716634] systemd[1]: Starting Load Kernel Modules...
  1191  [    5.725472] systemd[1]: Starting Remount Root and Kernel File Systems...
  1192  [    5.734296] systemd[1]: Starting Coldplug All udev Devices...
  1193  [    5.750420] systemd[1]: Mounted Huge Pages File System.
  1194  [    5.751616] systemd[1]: Mounted POSIX Message Queue File System.
  1195  [    5.753049] systemd[1]: proc-fs-nfsd.mount: Mount process exited, code=exited, status=32/n/a
  1196  [    5.753100] systemd[1]: proc-fs-nfsd.mount: Failed with result 'exit-code'.
  1197  [    5.755299] systemd[1]: Failed to mount NFSD configuration filesystem.
  1198  [    5.755680] systemd[1]: Dependency failed for NFS server and services.
  1199  [    5.755833] systemd[1]: Dependency failed for NFSv4 ID-name mapping service.
  1200  [    5.755984] systemd[1]: nfs-idmapd.service: Job nfs-idmapd.service/start failed with result 'dependency'.
  1201  [    5.756053] systemd[1]: Dependency failed for NFS Mount Daemon.
  1202  [    5.756189] systemd[1]: nfs-mountd.service: Job nfs-mountd.service/start failed with result 'dependency'.
  1203  [    5.756240] systemd[1]: nfs-server.service: Job nfs-server.service/start failed with result 'dependency'.
  1204  [    5.756380] systemd[1]: Dependency failed for NFSv4 Client Tracking Daemon.
  1205  [    5.756562] systemd[1]: nfsdcld.service: Job nfsdcld.service/start failed with result 'dependency'.
  1206  [    5.758112] systemd[1]: Mounted Kernel Debug File System.
  1207  [    5.761151] systemd[1]: Finished Restore / save the current clock.
  1208  [    5.763553] systemd[1]: modprobe@chromeos_pstore.service: Deactivated successfully.
  1209  [    5.764878] systemd[1]: Finished Load Kernel Module chromeos_pstore.
  1210  [    5.767379] systemd[1]: modprobe@configfs.service: Deactivated successfully.
  1211  [    5.767574] EXT4-fs (sda1): re-mounted. Opts: commit=600,errors=remount-ro. Quota mode: none.
  1212  [    5.768874] systemd[1]: Finished Load Kernel Module configfs.
  1213  [    5.776591] systemd[1]: modprobe@drm.service: Deactivated successfully.
  1214  [    5.778255] systemd[1]: Finished Load Kernel Module drm.
  1215  [    5.780632] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
  1216  [    5.782253] systemd[1]: Finished Load Kernel Module efi_pstore.
  1217  [    5.784523] systemd[1]: modprobe@fuse.service: Deactivated successfully.
  1218  [    5.798648] systemd[1]: Finished Load Kernel Module fuse.
  1219  [    5.800762] systemd[1]: modprobe@pstore_blk.service: Deactivated successfully.
  1220  [    5.802373] systemd[1]: Finished Load Kernel Module pstore_blk.
  1221  [    5.804429] systemd[1]: modprobe@pstore_zone.service: Deactivated successfully.
  1222  [    5.805902] systemd[1]: Finished Load Kernel Module pstore_zone.
  1223  [    5.807916] systemd[1]: modprobe@ramoops.service: Deactivated successfully.
  1224  [    5.809433] systemd[1]: Finished Load Kernel Module ramoops.
  1225  [    5.814710] systemd[1]: Finished Load Kernel Modules.
  1226  [    5.817646] systemd[1]: Finished Remount Root and Kernel File Systems.
  1227  [    5.819844] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
  1228  [    5.826540] systemd[1]: Mounting Kernel Configuration File System...
  1229  [    5.827387] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
  1230  [    5.835049] systemd[1]: Starting Load/Save Random Seed...
  1231  [    5.844291] systemd[1]: Starting Apply Kernel Variables...
  1232  [    5.854674] systemd[1]: Starting Create System Users...
  1233  [    5.869265] systemd[1]: Mounted Kernel Configuration File System.
  1234  [    5.928348] systemd[1]: Finished Create System Users.
  1235  [    5.936531] systemd[1]: Starting Create Static Device Nodes in /dev...
  1236  [    5.942985] systemd[1]: Finished Apply Kernel Variables.
  1237  [    5.996023] systemd[1]: Finished Create Static Device Nodes in /dev.
  1238  [    6.009955] systemd[1]: Starting Rule-based Manager for Device Events and Files...
  1239  [    6.044327] systemd[1]: Finished Set the console keyboard layout.
  1240  [    6.045700] systemd[1]: Reached target Preparation for Local File Systems.
  1241  [    6.057748] systemd[1]: Mounting /tmp...
  1242  [    6.069732] systemd[1]: Mounted /tmp.
  1243  [    6.070790] systemd[1]: Reached target Local File Systems.
  1244  [    6.077945] systemd[1]: Starting Armbian leds state...
  1245  [    6.090143] systemd[1]: Starting Armbian ZRAM config...
  1246  [    6.107098] systemd[1]: Starting Set console font and keymap...
  1247  [    6.108139] systemd[1]: Condition check resulted in RPC security service for NFS server being skipped.
  1248  [    6.108566] systemd[1]: Condition check resulted in Mark the need to relabel after reboot being skipped.
  1249  [    6.115447] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
  1250  [    6.138860] systemd[1]: Finished Set console font and keymap.
  1251  [    6.165497] systemd[1]: armbian-led-state.service: Main process exited, code=exited, status=1/FAILURE
  1252  [    6.166483] systemd[1]: armbian-led-state.service: Failed with result 'exit-code'.
  1253  [    6.170132] systemd[1]: Failed to start Armbian leds state.
  1254  [    6.284623] systemd[1]: Finished Coldplug All udev Devices.
  1255  [    6.312456] systemd[1]: Starting Helper to synchronize boot up for ifupdown...
  1256  [    6.343224] systemd[1]: Started Rule-based Manager for Device Events and Files.
  1257  [    6.431848] systemd[1]: armbian-zram-config.service: Main process exited, code=exited, status=1/FAILURE
  1258  [    6.432784] systemd[1]: armbian-zram-config.service: Failed with result 'exit-code'.
  1259  [    6.434739] systemd[1]: Failed to start Armbian ZRAM config.
  1260  [    6.469719] systemd[1]: Starting Armbian memory supported logging...
  1261  [    6.555476] urandom_read_iter: 51 callbacks suppressed
  1262  [    6.555506] random: systemd: uninitialized urandom read (16 bytes read)
  1263  [    6.652261] random: systemd: uninitialized urandom read (16 bytes read)
  1264  [    6.652371] random: systemd: uninitialized urandom read (16 bytes read)
  1265  [    6.785166] random: crng init done
  1266  [    6.785195] random: 8 urandom warning(s) missed due to ratelimiting
  1267  [    6.807855] systemd[1]: Finished Load/Save Random Seed.
  1268  [    6.809714] systemd[1]: Condition check resulted in First Boot Complete being skipped.
  1269  [    6.809986] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
  1270  [    6.810286] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
  1271  [    6.872276] systemd[1]: Found device /dev/ttyS0.
  1272  [    7.432756] systemd[1]: Found device /sys/subsystem/net/devices/eth0.
  1273  [    7.475372] systemd[1]: Started ifup for eth0.
  1274  [    7.479618] systemd[1]: Finished Helper to synchronize boot up for ifupdown.
  1275  [    7.487385] systemd[1]: Starting Raise network interfaces...
  1276  [    7.492546] systemd[1]: ifup@eth0.service: Main process exited, code=exited, status=1/FAILURE
  1277  [    7.493724] systemd[1]: ifup@eth0.service: Failed with result 'exit-code'.
  1278  [    8.020551] systemd[1]: networking.service: Main process exited, code=exited, status=1/FAILURE
  1279  [    8.021493] systemd[1]: networking.service: Failed with result 'exit-code'.
  1280  [    8.023165] systemd[1]: Failed to start Raise network interfaces.
  1281  [   10.555645] systemd[1]: Finished Armbian memory supported logging.
  1282  [   10.593602] systemd[1]: Starting Journal Service...
  1283  [   10.855401] systemd[1]: Started Journal Service.
  1284  [   10.906967] systemd-journald[587]: Received client request to flush runtime journal.
  1285
  1286  ### armbian-release:
  1287
  1288  # PLEASE DO NOT EDIT THIS FILE
  1289  BOARD=pine64
  1290  BOARD_NAME="Pine64"
  1291  BOARDFAMILY=sun50iw1
  1292  BUILD_REPOSITORY_URL=https://github.com/armbian/build
  1293  BUILD_REPOSITORY_COMMIT=84940abb
  1294  VERSION=22.11.1
  1295  LINUXFAMILY=sunxi64
  1296  ARCH=arm64
  1297  IMAGE_TYPE=stable
  1298  BOARD_TYPE=conf
  1299  INITRD_ARCH=arm64
  1300  KERNEL_IMAGE_TYPE=Image
  1301
  1302  ### boot environment:
  1303
  1304  verbosity=1
  1305  bootlogo=false
  1306  console=both
  1307  disp_mode=1920x1080p60
  1308  overlay_prefix=sun50i-a64
  1309  rootdev=UUID=1a07fccf-6922-49b1-ace2-e12d87fdb297
  1310  rootfstype=ext4
  1311  usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
  1312
  1313
  1314  ### lsusb:
  1315
  1316  Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  1317  Bus 002 Device 004: ID 0403:6001 Future Technology Devices International, Ltd FT232 Serial (UART) IC
  1318  Bus 002 Device 003: ID 046d:081b Logitech, Inc. Webcam C310
  1319  Bus 002 Device 002: ID 05e3:0610 Genesys Logic, Inc. Hub
  1320  Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  1321  Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  1322  Bus 001 Device 002: ID 1f75:0621 Innostor Technology Corporation IS621 SATA Storage Controller
  1323  Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  1324  Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  1325
  1326  ### lscpu:
  1327
  1328  Architecture:                    aarch64
  1329  CPU op-mode(s):                  32-bit, 64-bit
  1330  Byte Order:                      Little Endian
  1331  CPU(s):                          4
  1332  On-line CPU(s) list:             0-3
  1333  Vendor ID:                       ARM
  1334  Model name:                      Cortex-A53
  1335  Model:                           4
  1336  Thread(s) per core:              1
  1337  Core(s) per cluster:             4
  1338  Socket(s):                       -
  1339  Cluster(s):                      1
  1340  Stepping:                        r0p4
  1341  BogoMIPS:                        48.00
  1342  Flags:                           fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  1343  NUMA node(s):                    1
  1344  NUMA node0 CPU(s):               0-3
  1345  Vulnerability Itlb multihit:     Not affected
  1346  Vulnerability L1tf:              Not affected
  1347  Vulnerability Mds:               Not affected
  1348  Vulnerability Meltdown:          Not affected
  1349  Vulnerability Mmio stale data:   Not affected
  1350  Vulnerability Spec store bypass: Not affected
  1351  Vulnerability Spectre v1:        Mitigation; __user pointer sanitization
  1352  Vulnerability Spectre v2:        Not affected
  1353  Vulnerability Srbds:             Not affected
  1354  Vulnerability Tsx async abort:   Not affected
  1355
  1356  ### cpuinfo:
  1357
  1358  processor       : 0
  1359  BogoMIPS        : 48.00
  1360  Features        : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  1361  CPU implementer : 0x41
  1362  CPU architecture: 8
  1363  CPU variant     : 0x0
  1364  CPU part        : 0xd03
  1365  CPU revision    : 4
  1366
  1367  processor       : 1
  1368  BogoMIPS        : 48.00
  1369  Features        : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  1370  CPU implementer : 0x41
  1371  CPU architecture: 8
  1372  CPU variant     : 0x0
  1373  CPU part        : 0xd03
  1374  CPU revision    : 4
  1375
  1376  processor       : 2
  1377  BogoMIPS        : 48.00
  1378  Features        : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  1379  CPU implementer : 0x41
  1380  CPU architecture: 8
  1381  CPU variant     : 0x0
  1382  CPU part        : 0xd03
  1383  CPU revision    : 4
  1384
  1385  processor       : 3
  1386  BogoMIPS        : 48.00
  1387  Features        : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  1388  CPU implementer : 0x41
  1389  CPU architecture: 8
  1390  CPU variant     : 0x0
  1391  CPU part        : 0xd03
  1392  CPU revision    : 4
  1393
  1394
  1395  ### meminfo:
  1396
  1397  MemTotal:        2037276 kB
  1398  MemFree:         1893432 kB
  1399  MemAvailable:    1887720 kB
  1400  Buffers:           11348 kB
  1401  Cached:            52144 kB
  1402  SwapCached:            0 kB
  1403  Active:            27656 kB
  1404  Inactive:          52880 kB
  1405  Active(anon):        288 kB
  1406  Inactive(anon):    33144 kB
  1407  Active(file):      27368 kB
  1408  Inactive(file):    19736 kB
  1409  Unevictable:           0 kB
  1410  Mlocked:               0 kB
  1411  SwapTotal:             0 kB
  1412  SwapFree:              0 kB
  1413  Dirty:                16 kB
  1414  Writeback:             0 kB
  1415  AnonPages:         17496 kB
  1416  Mapped:            14724 kB
  1417  Shmem:             16136 kB
  1418  KReclaimable:       9056 kB
  1419  Slab:              31508 kB
  1420  SReclaimable:       9056 kB
  1421  SUnreclaim:        22452 kB
  1422  KernelStack:        2256 kB
  1423  PageTables:         1528 kB
  1424  NFS_Unstable:          0 kB
  1425  Bounce:                0 kB
  1426  WritebackTmp:          0 kB
  1427  CommitLimit:     1018636 kB
  1428  Committed_AS:      57456 kB
  1429  VmallocTotal:   133143592960 kB
  1430  VmallocUsed:       10308 kB
  1431  VmallocChunk:          0 kB
  1432  Percpu:             1024 kB
  1433  AnonHugePages:         0 kB
  1434  ShmemHugePages:        0 kB
  1435  ShmemPmdMapped:        0 kB
  1436  FileHugePages:         0 kB
  1437  FilePmdMapped:         0 kB
  1438  CmaTotal:         131072 kB
  1439  CmaFree:          130304 kB
  1440  HugePages_Total:       0
  1441  HugePages_Free:        0
  1442  HugePages_Rsvd:        0
  1443  HugePages_Surp:        0
  1444  Hugepagesize:       2048 kB
  1445  Hugetlb:               0 kB
  1446
  1447  ### virtual memory:
  1448
  1449  vm.admin_reserve_kbytes = 8192
  1450  vm.compaction_proactiveness = 20
  1451  vm.compact_unevictable_allowed = 1
  1452  vm.dirty_background_bytes = 0
  1453  vm.dirty_background_ratio = 10
  1454  vm.dirty_bytes = 0
  1455  vm.dirty_expire_centisecs = 3000
  1456  vm.dirty_ratio = 20
  1457  vm.dirtytime_expire_seconds = 43200
  1458  vm.dirty_writeback_centisecs = 500
  1459  vm.extfrag_threshold = 500
  1460  vm.hugetlb_shm_group = 0
  1461  vm.laptop_mode = 0
  1462  vm.legacy_va_layout = 0
  1463  vm.lowmem_reserve_ratio = 256   256     32      0
  1464  vm.max_map_count = 65530
  1465  vm.min_free_kbytes = 22528
  1466  vm.min_slab_ratio = 5
  1467  vm.min_unmapped_ratio = 1
  1468  vm.mmap_min_addr = 32768
  1469  vm.mmap_rnd_bits = 18
  1470  vm.mmap_rnd_compat_bits = 11
  1471  vm.nr_hugepages = 0
  1472  vm.nr_hugepages_mempolicy = 0
  1473  vm.nr_overcommit_hugepages = 0
  1474  vm.numa_stat = 1
  1475  vm.numa_zonelist_order = Node
  1476  vm.oom_dump_tasks = 1
  1477  vm.oom_kill_allocating_task = 0
  1478  vm.overcommit_kbytes = 0
  1479  vm.overcommit_memory = 0
  1480  vm.overcommit_ratio = 50
  1481  vm.page-cluster = 3
  1482  vm.page_lock_unfairness = 5
  1483  vm.panic_on_oom = 0
  1484  vm.percpu_pagelist_high_fraction = 0
  1485  vm.stat_interval = 1
  1486  vm.swappiness = 100
  1487  vm.user_reserve_kbytes = 63003
  1488  vm.vfs_cache_pressure = 100
  1489  vm.watermark_boost_factor = 15000
  1490  vm.watermark_scale_factor = 10
  1491  vm.zone_reclaim_mode = 0
  1492
  1493  ### ip addr:
  1494
  1495  1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
  1496      link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
  1497      inet XXX.XXX.0.1/8 scope host lo
  1498         valid_lft forever preferred_lft forever
  1499      inet6 ::1/128 scope host
  1500         valid_lft forever preferred_lft forever
  1501  2: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
  1502      link/ether 02:ba:85:77:17:e9 brd ff:ff:ff:ff:ff:ff
  1503
  1504  ### partitions:
  1505
  1506  major minor  #blocks  name
  1507
  1508   179        0   31260672 mmcblk0
  1509   179        1   30928896 mmcblk0p1
  1510     8        0  117220824 sda
  1511     8        1  117218304 sda1
  1512
  1513  ### df:
  1514
  1515  tmpfs           199M  3.1M  196M   2% /run
  1516  /dev/sda1       110G   20G   85G  19% /
  1517  tmpfs           995M     0  995M   0% /dev/shm
  1518  tmpfs           5.0M     0  5.0M   0% /run/lock
  1519  tmpfs           995M  4.0K  995M   1% /tmp
  1520
  1521  ### lsblk:
  1522
  1523  NAME        FSTYPE   SIZE MOUNTPOINT UUID
  1524  sda                111.8G
  1525  └─sda1      ext4   111.8G /          933d6d44-0352-46aa-8100-fd703056ae3d
  1526  mmcblk0             29.8G
  1527  └─mmcblk0p1 ext4    29.5G            1a07fccf-6922-49b1-ace2-e12d87fdb297
  1528
  1529  ### zramctl:
  1530
  1531
  1532
  1533  ### mtab:
  1534
  1535  /dev/sda1 / ext4 rw,noatime,errors=remount-ro,commit=600 0 0
  1536  /dev/sda1 /var/log.hdd ext4 rw,noatime,errors=remount-ro,commit=600 0 0
  1537
  1538  ### mmc0:0001 info:
  1539
  1540                 fwrev: 0x0
  1541                uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=EB1QT MODALIAS=mmc:block
  1542                   cid: 1b534d454231515430bc836120012941
  1543                   rca: 0x0001
  1544                   csd: 400e00325b590000ee7f7f800a404055
  1545                manfid: 0x00001b
  1546                   ocr: 0x00200000
  1547  preferred_erase_size: 4194304
  1548                  type: SD
  1549                 hwrev: 0x3
  1550                  date: 09/2018
  1551                   dsr: 0x404
  1552            erase_size: 512
  1553                 oemid: 0x534d
  1554                serial: 0xbc836120
  1555                   ssr: 0000000005000000040090000f051c00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
  1556                   scr: 02b5800200000000
  1557                  name: EB1QT
  1558
  1559  ### Boot system health:
  1560
  1561  Time      CPU n/a    load %cpu %sys %usr %nice %io %irq   CPU
  1562  21:02:38:   ---      0.15  54%  29%  20%   0%   3%   0% 37.1 °C
  1563  21:02:39:   ---      0.15  84%  20%  23%   1%  34%   5% 37.1 °C
  1564  21:02:39:   ---      0.46  79%  16%  24%   0%  35%   2% 34.4 °C
  1565  21:02:39:   ---      0.46  35%  10%   8%   1%  14%   0% 34.4 °C
  1566  21:02:40:   ---      0.46  21%   6%   2%   0%  12%   0% 34.4 °C
  1567
  1568  ### No more available zram devices ()
  1569
  1570  Fri Dec  9 10:03:41 PM CET 2022 | Pine64 | 22.11.1 | arm64 | aarch64 | 5.15.48-sunxi64
  1571
  1572  ### dmesg:
  1573
  1574  [    0.000967] pid_max: default: 32768 minimum: 301
  1575  [    0.001055] LSM: Security Framework initializing
  1576  [    0.001085] Yama: becoming mindful.
  1577  [    0.001182] AppArmor: AppArmor initialized
  1578  [    0.001295] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
  1579  [    0.001324] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
  1580  [    0.003393] rcu: Hierarchical SRCU implementation.
  1581  [    0.004901] smp: Bringing up secondary CPUs ...
  1582  [    0.006140] Detected VIPT I-cache on CPU1
  1583  [    0.006207] arch_timer: CPU1: Trapping CNTVCT access
  1584  [    0.006225] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
  1585  [    0.007049] Detected VIPT I-cache on CPU2
  1586  [    0.007084] arch_timer: CPU2: Trapping CNTVCT access
  1587  [    0.007095] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
  1588  [    0.007824] Detected VIPT I-cache on CPU3
  1589  [    0.007858] arch_timer: CPU3: Trapping CNTVCT access
  1590  [    0.007868] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
  1591  [    0.007963] smp: Brought up 1 node, 4 CPUs
  1592  [    0.007980] SMP: Total of 4 processors activated.
  1593  [    0.007987] CPU features: detected: 32-bit EL0 Support
  1594  [    0.007993] CPU features: detected: CRC32 instructions
  1595  [    0.022850] CPU: All CPU(s) started at EL2
  1596  [    0.022883] alternatives: patching kernel code
  1597  [    0.024714] devtmpfs: initialized
  1598  [    0.032755] Registered cp15_barrier emulation handler
  1599  [    0.032789] Registered setend emulation handler
  1600  [    0.032969] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
  1601  [    0.032992] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
  1602  [    0.038452] pinctrl core: initialized pinctrl subsystem
  1603  [    0.040122] NET: Registered PF_NETLINK/PF_ROUTE protocol family
  1604  [    0.041916] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
  1605  [    0.042094] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
  1606  [    0.042271] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
  1607  [    0.042379] audit: initializing netlink subsys (disabled)
  1608  [    0.042599] audit: type=2000 audit(0.040:1): state=initialized audit_enabled=0 res=1
  1609  [    0.043211] thermal_sys: Registered thermal governor 'fair_share'
  1610  [    0.043218] thermal_sys: Registered thermal governor 'bang_bang'
  1611  [    0.043224] thermal_sys: Registered thermal governor 'step_wise'
  1612  [    0.043230] thermal_sys: Registered thermal governor 'user_space'
  1613  [    0.043694] cpuidle: using governor menu
  1614  [    0.043952] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
  1615  [    0.044060] ASID allocator initialised with 65536 entries
  1616  [    0.044260] Serial: AMBA PL011 UART driver
  1617  [    0.060255] platform 1ee0000.hdmi: Fixing up cyclic dependency with 1c0d000.lcd-controller
  1618  [    0.061792] platform hdmi-connector: Fixing up cyclic dependency with 1ee0000.hdmi
  1619  [    0.069877] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
  1620  [    0.069900] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
  1621  [    0.069909] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
  1622  [    0.069917] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
  1623  [    0.072108] cryptd: max_cpu_qlen set to 1000
  1624  [    0.140242] raid6: neonx8   gen()  1460 MB/s
  1625  [    0.208328] raid6: neonx8   xor()  1090 MB/s
  1626  [    0.276399] raid6: neonx4   gen()  1492 MB/s
  1627  [    0.344486] raid6: neonx4   xor()  1081 MB/s
  1628  [    0.412556] raid6: neonx2   gen()  1411 MB/s
  1629  [    0.480640] raid6: neonx2   xor()   995 MB/s
  1630  [    0.548723] raid6: neonx1   gen()  1232 MB/s
  1631  [    0.616795] raid6: neonx1   xor()   848 MB/s
  1632  [    0.684888] raid6: int64x8  gen()  1017 MB/s
  1633  [    0.752959] raid6: int64x8  xor()   533 MB/s
  1634  [    0.821043] raid6: int64x4  gen()  1127 MB/s
  1635  [    0.889126] raid6: int64x4  xor()   572 MB/s
  1636  [    0.957212] raid6: int64x2  gen()   962 MB/s
  1637  [    1.025290] raid6: int64x2  xor()   509 MB/s
  1638  [    1.093395] raid6: int64x1  gen()   717 MB/s
  1639  [    1.161484] raid6: int64x1  xor()   373 MB/s
  1640  [    1.161491] raid6: using algorithm neonx4 gen() 1492 MB/s
  1641  [    1.161497] raid6: .... xor() 1081 MB/s, rmw enabled
  1642  [    1.161503] raid6: using neon recovery algorithm
  1643  [    1.162148] iommu: Default domain type: Translated
  1644  [    1.162158] iommu: DMA domain TLB invalidation policy: strict mode
  1645  [    1.162483] SCSI subsystem initialized
  1646  [    1.162711] usbcore: registered new interface driver usbfs
  1647  [    1.162761] usbcore: registered new interface driver hub
  1648  [    1.162797] usbcore: registered new device driver usb
  1649  [    1.163127] pps_core: LinuxPPS API ver. 1 registered
  1650  [    1.163134] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
  1651  [    1.163153] PTP clock support registered
  1652  [    1.163617] ARM FF-A: FFA_VERSION returned not supported
  1653  [    1.164013] Advanced Linux Sound Architecture Driver Initialized.
  1654  [    1.164787] NetLabel: Initializing
  1655  [    1.164793] NetLabel:  domain hash size = 128
  1656  [    1.164799] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
  1657  [    1.164877] NetLabel:  unlabeled traffic allowed by default
  1658  [    1.165371] clocksource: Switched to clocksource arch_sys_counter
  1659  [    1.165601] VFS: Disk quotas dquot_6.6.0
  1660  [    1.165666] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
  1661  [    1.166323] AppArmor: AppArmor Filesystem Enabled
  1662  [    1.173624] NET: Registered PF_INET protocol family
  1663  [    1.173909] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
  1664  [    1.175290] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
  1665  [    1.175335] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
  1666  [    1.175353] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
  1667  [    1.175513] TCP bind hash table entries: 16384 (order: 6, 262144 bytes, linear)
  1668  [    1.175838] TCP: Hash tables configured (established 16384 bind 16384)
  1669  [    1.176006] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
  1670  [    1.176075] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
  1671  [    1.176295] NET: Registered PF_UNIX/PF_LOCAL protocol family
  1672  [    1.176892] Trying to unpack rootfs image as initramfs...
  1673  [    1.191958] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
  1674  [    1.199069] Initialise system trusted keyrings
  1675  [    1.199153] Key type blacklist registered
  1676  [    1.199362] workingset: timestamp_bits=44 max_order=19 bucket_order=0
  1677  [    1.205839] zbud: loaded
  1678  [    1.207583] squashfs: version 4.0 (2009/01/31) Phillip Lougher
  1679  [    1.210115] integrity: Platform Keyring initialized
  1680  [    1.264129] xor: automatically using best checksumming function   32regs
  1681  [    1.264158] async_tx: api initialized (async)
  1682  [    1.264189] Key type asymmetric registered
  1683  [    1.264196] Asymmetric key parser 'x509' registered
  1684  [    1.264327] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
  1685  [    1.264505] io scheduler mq-deadline registered
  1686  [    1.264514] io scheduler kyber registered
  1687  [    1.264740] io scheduler bfq registered
  1688  [    1.268751] sun50i-a64-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver
  1689  [    1.278783] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
  1690  [    1.290999] loop: module loaded
  1691  [    1.293557] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
  1692  [    1.293594] ehci-platform: EHCI generic platform driver
  1693  [    1.293755] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
  1694  [    1.293771] ohci-platform: OHCI generic platform driver
  1695  [    1.294264] usbcore: registered new interface driver usb-storage
  1696  [    1.294812] mousedev: PS/2 mouse device common for all mice
  1697  [    1.295921] sun6i-rtc 1f00000.rtc: registered as rtc0
  1698  [    1.295960] sun6i-rtc 1f00000.rtc: setting system clock to 2022-12-09T21:03:31 UTC (1670619811)
  1699  [    1.296086] sun6i-rtc 1f00000.rtc: RTC enabled
  1700  [    1.296193] i2c_dev: i2c /dev entries driver
  1701  [    1.297011] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
  1702  [    1.299211] sun50i-a64-r-pinctrl 1f02c00.pinctrl: supply vcc-pl not found, using dummy regulator
  1703  [    1.299675] sdhci: Secure Digital Host Controller Interface driver
  1704  [    1.299684] sdhci: Copyright(c) Pierre Ossman
  1705  [    1.299713] Synopsys Designware Multimedia Card Interface Driver
  1706  [    1.300482] sdhci-pltfm: SDHCI platform and OF driver helper
  1707  [    1.301340] ledtrig-cpu: registered to indicate activity on CPUs
  1708  [    1.301915] SMCCC: SOC_ID: ID = jep106:091e:1689 Revision = 0x00000001
  1709  [    1.302228] sun8i-ce 1c15000.crypto: Set mod clock to 300000000 (300 Mhz) from 24000000 (24 Mhz)
  1710  [    1.302536] sun8i-ce 1c15000.crypto: will run requests pump with realtime priority
  1711  [    1.302718] sun8i-ce 1c15000.crypto: will run requests pump with realtime priority
  1712  [    1.302835] sun8i-ce 1c15000.crypto: will run requests pump with realtime priority
  1713  [    1.302962] sun8i-ce 1c15000.crypto: will run requests pump with realtime priority
  1714  [    1.303055] sun8i-ce 1c15000.crypto: Register cbc(aes)
  1715  [    1.303247] sun8i-ce 1c15000.crypto: Register ecb(aes)
  1716  [    1.303387] sun8i-ce 1c15000.crypto: Register cbc(des3_ede)
  1717  [    1.303522] sun8i-ce 1c15000.crypto: Register ecb(des3_ede)
  1718  [    1.303662] sun8i-ce 1c15000.crypto: Register md5
  1719  [    1.303797] sun8i-ce 1c15000.crypto: Register sha1
  1720  [    1.303929] sun8i-ce 1c15000.crypto: Register sha224
  1721  [    1.304063] sun8i-ce 1c15000.crypto: Register sha256
  1722  [    1.304196] sun8i-ce 1c15000.crypto: DEBUG: Algo of sha384 not supported
  1723  [    1.304207] sun8i-ce 1c15000.crypto: DEBUG: Algo of sha512 not supported
  1724  [    1.304216] sun8i-ce 1c15000.crypto: Register stdrng
  1725  [    1.304372] sun8i-ce 1c15000.crypto: TRNG not supported
  1726  [    1.304382] sun8i-ce 1c15000.crypto: CryptoEngine Die ID 0
  1727  [    1.304972] hid: raw HID events driver (C) Jiri Kosina
  1728  [    1.305156] usbcore: registered new interface driver usbhid
  1729  [    1.305164] usbhid: USB HID core driver
  1730  [    1.311428] NET: Registered PF_INET6 protocol family
  1731  [    1.956426] Freeing initrd memory: 12684K
  1732  [    1.989708] Segment Routing with IPv6
  1733  [    1.989802] In-situ OAM (IOAM) with IPv6
  1734  [    1.989900] NET: Registered PF_PACKET protocol family
  1735  [    1.990047] 8021q: 802.1Q VLAN Support v1.8
  1736  [    1.990233] 9pnet: Installing 9P2000 support
  1737  [    1.990359] Key type dns_resolver registered
  1738  [    1.990929] registered taskstats version 1
  1739  [    1.990947] Loading compiled-in X.509 certificates
  1740  [    1.995257] Loaded X.509 cert 'Build time autogenerated kernel key: 32330adefd2da02e444296fafd37464380789679'
  1741  [    1.999607] zswap: loaded using pool zstd/z3fold
  1742  [    2.000376] Key type ._fscrypt registered
  1743  [    2.000386] Key type .fscrypt registered
  1744  [    2.000391] Key type fscrypt-provisioning registered
  1745  [    2.001590] Btrfs loaded, crc32c=crc32c-generic, zoned=yes, fsverity=no
  1746  [    2.017330] Key type encrypted registered
  1747  [    2.017399] AppArmor: AppArmor sha1 policy hashing enabled
  1748  [    2.017445] ima: No TPM chip found, activating TPM-bypass!
  1749  [    2.017482] ima: Allocated hash algorithm: sha1
  1750  [    2.017519] ima: No architecture policies found
  1751  [    2.017575] evm: Initialising EVM extended attributes:
  1752  [    2.017580] evm: security.selinux
  1753  [    2.017585] evm: security.SMACK64
  1754  [    2.017590] evm: security.SMACK64EXEC
  1755  [    2.017594] evm: security.SMACK64TRANSMUTE
  1756  [    2.017599] evm: security.SMACK64MMAP
  1757  [    2.017603] evm: security.apparmor
  1758  [    2.017608] evm: security.ima
  1759  [    2.017613] evm: security.capability
  1760  [    2.017617] evm: HMAC attrs: 0x1
  1761  [    2.030404] platform 1100000.mixer: Fixing up cyclic dependency with 1c0d000.lcd-controller
  1762  [    2.030497] platform 1100000.mixer: Fixing up cyclic dependency with 1c0c000.lcd-controller
  1763  [    2.031269] platform 1200000.mixer: Fixing up cyclic dependency with 1c0d000.lcd-controller
  1764  [    2.031335] platform 1200000.mixer: Fixing up cyclic dependency with 1c0c000.lcd-controller
  1765  [    2.032191] sunxi-rsb 1f03400.rsb: RSB running at 3000000 Hz
  1766  [    2.032600] axp20x-rsb sunxi-rsb-3a3: AXP20x variant AXP803 found
  1767  [    2.034719] input: axp20x-pek as /devices/platform/soc/1f03400.rsb/sunxi-rsb-3a3/axp221-pek/input/input0
  1768  [    2.037837] vcc-3v3: supplied by regulator-dummy
  1769  [    2.038345] vdd-cpux: supplied by regulator-dummy
  1770  [    2.038994] dcdc4: supplied by regulator-dummy
  1771  [    2.039210] vcc-dram: supplied by regulator-dummy
  1772  [    2.039639] vdd-sys: supplied by regulator-dummy
  1773  [    2.040194] vcc-phy: supplied by regulator-dummy
  1774  [    2.040537] aldo1: supplied by regulator-dummy
  1775  [    2.040712] vcc-pl: supplied by regulator-dummy
  1776  [    2.041158] vcc-pll-avcc: supplied by regulator-dummy
  1777  [    2.041802] vcc-hdmi: supplied by regulator-dummy
  1778  [    2.042175] vcc-mipi: supplied by regulator-dummy
  1779  [    2.042556] dldo3: supplied by regulator-dummy
  1780  [    2.042918] vcc-wifi: supplied by regulator-dummy
  1781  [    2.043290] cpvdd: supplied by regulator-dummy
  1782  [    2.043671] eldo2: supplied by regulator-dummy
  1783  [    2.044042] eldo3: supplied by regulator-dummy
  1784  [    2.044409] vcc-1v2-hsic: supplied by regulator-dummy
  1785  [    2.044629] vdd-cpus: supplied by regulator-dummy
  1786  [    2.045036] vcc-rtc: supplied by regulator-dummy
  1787  [    2.045496] ldo-io0: supplied by regulator-dummy
  1788  [    2.045830] ldo-io1: supplied by regulator-dummy
  1789  [    2.045949] axp20x-rsb sunxi-rsb-3a3: AXP20X driver loaded
  1790  [    2.050823] sun50i-a64-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
  1791  [    2.051230] sun50i-a64-pinctrl 1c20800.pinctrl: supply vcc-pb not found, using dummy regulator
  1792  [    2.051810] printk: console [ttyS0] disabled
  1793  [    2.051897] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 41, base_baud = 1500000) is a 16550A
  1794  [    2.052104] printk: console [ttyS0] enabled
  1795  [    2.052795] sun50i-a64-pinctrl 1c20800.pinctrl: supply vcc-pg not found, using dummy regulator
  1796  [    2.053242] 1c28400.serial: ttyS1 at MMIO 0x1c28400 (irq = 42, base_baud = 1500000) is a 16550A
  1797  [    2.053440] serial serial0: tty port ttyS1 registered
  1798  [    2.084008] sun4i-drm display-engine: bound 1100000.mixer (ops 0xffff800008e16990)
  1799  [    2.085840] sun4i-drm display-engine: bound 1200000.mixer (ops 0xffff800008e16990)
  1800  [    2.086356] sun4i-drm display-engine: No panel or bridge found... RGB output disabled
  1801  [    2.086375] sun4i-drm display-engine: bound 1c0c000.lcd-controller (ops 0xffff800008e11ba0)
  1802  [    2.086605] sun4i-drm display-engine: bound 1c0d000.lcd-controller (ops 0xffff800008e11ba0)
  1803  [    2.087770] sun8i-dw-hdmi 1ee0000.hdmi: Detected HDMI TX controller v1.32a with HDCP (sun8i_dw_hdmi_phy)
  1804  [    2.088379] sun8i-dw-hdmi 1ee0000.hdmi: registered DesignWare HDMI I2C bus driver
  1805  [    2.088759] sun4i-drm display-engine: bound 1ee0000.hdmi (ops 0xffff800008e15cc8)
  1806  [    2.089438] [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on minor 0
  1807  [    2.089524] sun4i-drm display-engine: [drm] Cannot find any crtc or sizes
  1808  [    2.090247] sun50i-a64-pinctrl 1c20800.pinctrl: supply vcc-pc not found, using dummy regulator
  1809  [    2.090854] sun4i-drm display-engine: [drm] Cannot find any crtc or sizes
  1810  [    2.091619] ehci-platform 1c1a000.usb: EHCI Host Controller
  1811  [    2.091652] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
  1812  [    2.091798] ehci-platform 1c1a000.usb: irq 28, io mem 0x01c1a000
  1813  [    2.105381] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
  1814  [    2.105771] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
  1815  [    2.105787] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  1816  [    2.105798] usb usb1: Product: EHCI Host Controller
  1817  [    2.105807] usb usb1: Manufacturer: Linux 5.15.48-sunxi64 ehci_hcd
  1818  [    2.105817] usb usb1: SerialNumber: 1c1a000.usb
  1819  [    2.106357] hub 1-0:1.0: USB hub found
  1820  [    2.106409] hub 1-0:1.0: 1 port detected
  1821  [    2.107444] ehci-platform 1c1b000.usb: EHCI Host Controller
  1822  [    2.107471] ehci-platform 1c1b000.usb: new USB bus registered, assigned bus number 2
  1823  [    2.107603] ehci-platform 1c1b000.usb: irq 30, io mem 0x01c1b000
  1824  [    2.121373] ehci-platform 1c1b000.usb: USB 2.0 started, EHCI 1.00
  1825  [    2.121684] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
  1826  [    2.121699] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  1827  [    2.121710] usb usb2: Product: EHCI Host Controller
  1828  [    2.121720] usb usb2: Manufacturer: Linux 5.15.48-sunxi64 ehci_hcd
  1829  [    2.121730] usb usb2: SerialNumber: 1c1b000.usb
  1830  [    2.122209] hub 2-0:1.0: USB hub found
  1831  [    2.122265] hub 2-0:1.0: 1 port detected
  1832  [    2.297464] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
  1833  [    2.297502] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 3
  1834  [    2.297644] ohci-platform 1c1a400.usb: irq 29, io mem 0x01c1a400
  1835  [    2.365416] usb 1-1: new high-speed USB device number 2 using ehci-platform
  1836  [    2.365743] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.15
  1837  [    2.365759] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  1838  [    2.365771] usb usb3: Product: Generic Platform OHCI controller
  1839  [    2.365780] usb usb3: Manufacturer: Linux 5.15.48-sunxi64 ohci_hcd
  1840  [    2.365789] usb usb3: SerialNumber: 1c1a400.usb
  1841  [    2.366313] hub 3-0:1.0: USB hub found
  1842  [    2.366362] hub 3-0:1.0: 1 port detected
  1843  [    2.367356] ohci-platform 1c1b400.usb: Generic Platform OHCI controller
  1844  [    2.367382] ohci-platform 1c1b400.usb: new USB bus registered, assigned bus number 4
  1845  [    2.367514] ohci-platform 1c1b400.usb: irq 31, io mem 0x01c1b400
  1846  [    2.377379] usb 2-1: new high-speed USB device number 2 using ehci-platform
  1847  [    2.429643] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.15
  1848  [    2.429658] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  1849  [    2.429670] usb usb4: Product: Generic Platform OHCI controller
  1850  [    2.429679] usb usb4: Manufacturer: Linux 5.15.48-sunxi64 ohci_hcd
  1851  [    2.429688] usb usb4: SerialNumber: 1c1b400.usb
  1852  [    2.430199] hub 4-0:1.0: USB hub found
  1853  [    2.430248] hub 4-0:1.0: 1 port detected
  1854  [    2.431312] usb_phy_generic usb_phy_generic.3.auto: supply vcc not found, using dummy regulator
  1855  [    2.431458] usb_phy_generic usb_phy_generic.3.auto: dummy supplies not allowed for exclusive requests
  1856  [    2.505659] musb-hdrc musb-hdrc.4.auto: MUSB HDRC host driver
  1857  [    2.505693] musb-hdrc musb-hdrc.4.auto: new USB bus registered, assigned bus number 5
  1858  [    2.505982] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
  1859  [    2.505998] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  1860  [    2.506010] usb usb5: Product: MUSB HDRC host driver
  1861  [    2.506020] usb usb5: Manufacturer: Linux 5.15.48-sunxi64 musb-hcd
  1862  [    2.506029] usb usb5: SerialNumber: musb-hdrc.4.auto
  1863  [    2.506585] hub 5-0:1.0: USB hub found
  1864  [    2.506643] hub 5-0:1.0: 1 port detected
  1865  [    2.510109] sun50i-a64-pinctrl 1c20800.pinctrl: supply vcc-pf not found, using dummy regulator
  1866  [    2.510177] scpi_protocol scpi: SCP Protocol 0.0 Firmware 0.0.0 version
  1867  [    2.511239] sunxi-mmc 1c0f000.mmc: Got CD GPIO
  1868  [    2.511243] sunxi-mmc 1c10000.mmc: allocated mmc-pwrseq
  1869  [    2.511491] of_cfs_init
  1870  [    2.511626] of_cfs_init: OK
  1871  [    2.511987] ALSA device list:
  1872  [    2.511995]   No soundcards found.
  1873  [    2.527348] usb 1-1: New USB device found, idVendor=1f75, idProduct=0621, bcdDevice= 0.36
  1874  [    2.527367] usb 1-1: New USB device strings: Mfr=4, Product=5, SerialNumber=6
  1875  [    2.527379] usb 1-1: SerialNumber: 20181120
  1876  [    2.528345] usb-storage 1-1:1.0: USB Mass Storage device detected
  1877  [    2.528919] scsi host0: usb-storage 1-1:1.0
  1878  [    2.536523] usb 2-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice= 6.54
  1879  [    2.536540] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
  1880  [    2.536552] usb 2-1: Product: USB2.1 Hub
  1881  [    2.536561] usb 2-1: Manufacturer: GenesysLogic
  1882  [    2.536687] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB, uses new timings mode
  1883  [    2.536885] sunxi-mmc 1c10000.mmc: initialized, max. request size: 16384 KB, uses new timings mode
  1884  [    2.537343] hub 2-1:1.0: USB hub found
  1885  [    2.537789] hub 2-1:1.0: 4 ports detected
  1886  [    2.538693] Freeing unused kernel memory: 2496K
  1887  [    2.538829] Run /init as init process
  1888  [    2.538836]   with arguments:
  1889  [    2.538843]     /init
  1890  [    2.538849]   with environment:
  1891  [    2.538854]     HOME=/
  1892  [    2.538859]     TERM=linux
  1893  [    2.538865]     ubootpart=ea5e158f-01
  1894  [    2.538871]     cgroup_enable=memory
  1895  [    2.572947] mmc0: new high speed SDHC card at address 0001
  1896  [    2.574020] mmcblk0: mmc0:0001 EB1QT 29.8 GiB
  1897  [    2.576356]  mmcblk0: p1
  1898  [    2.853435] usb 2-1.1: new high-speed USB device number 3 using ehci-platform
  1899  [    3.041625] usbcore: registered new interface driver uas
  1900  [    3.079672] axp20x-gpio axp20x-gpio: DMA mask not set
  1901  [    3.080548] axp20x-gpio axp20x-gpio: AXP209 pinctrl and GPIO driver loaded
  1902  [    3.086177] sun50i-a64-pinctrl 1c20800.pinctrl: supply vcc-ph not found, using dummy regulator
  1903  [    3.088064] sun50i-a64-pinctrl 1c20800.pinctrl: supply vcc-pd not found, using dummy regulator
  1904  [    3.088347] dwmac-sun8i 1c30000.ethernet: IRQ eth_wake_irq not found
  1905  [    3.088361] dwmac-sun8i 1c30000.ethernet: IRQ eth_lpi not found
  1906  [    3.090157] dwmac-sun8i 1c30000.ethernet: supply phy-io not found, using dummy regulator
  1907  [    3.090515] dwmac-sun8i 1c30000.ethernet: PTP uses main clock
  1908  [    3.090575] dwmac-sun8i 1c30000.ethernet: Current syscon value is not the default 6 (expect 0)
  1909  [    3.092685] dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported
  1910  [    3.092717] dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported
  1911  [    3.092725] dwmac-sun8i 1c30000.ethernet: COE Type 2
  1912  [    3.092734] dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported
  1913  [    3.092743] dwmac-sun8i 1c30000.ethernet: Normal descriptors
  1914  [    3.092751] dwmac-sun8i 1c30000.ethernet: Chain mode enabled
  1915  [    3.203500] usb 2-1.1: New USB device found, idVendor=046d, idProduct=081b, bcdDevice= 0.12
  1916  [    3.203541] usb 2-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=2
  1917  [    3.203553] usb 2-1.1: SerialNumber: AA5FCF90
  1918  [    3.562431] scsi 0:0:0:0: Direct-Access     OCZ-VERT EX2                   PQ: 0 ANSI: 6
  1919  [    3.563045] sd 0:0:0:0: Attached scsi generic sg0 type 0
  1920  [    3.564037] sd 0:0:0:0: [sda] 234441648 512-byte logical blocks: (120 GB/112 GiB)
  1921  [    3.565167] sd 0:0:0:0: [sda] Write Protect is off
  1922  [    3.565193] sd 0:0:0:0: [sda] Mode Sense: 3b 00 00 00
  1923  [    3.566442] sd 0:0:0:0: [sda] No Caching mode page found
  1924  [    3.566474] sd 0:0:0:0: [sda] Assuming drive cache: write through
  1925  [    3.602406]  sda: sda1
  1926  [    3.606021] sd 0:0:0:0: [sda] Attached SCSI disk
  1927  [    3.971956] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
  1928  [    4.568206] systemd[1]: systemd 249.11-0ubuntu3.6 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY -P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
  1929  [    4.568949] systemd[1]: Detected architecture arm64.
  1930  [    4.571925] systemd[1]: Hostname set to <pine64>.
  1931  [    4.693665] dw-apb-uart 1c28000.serial: forbid DMA for kernel console
  1932  [    5.509269] systemd[1]: Queued start job for default target Graphical Interface.
  1933  [    5.511390] random: systemd: uninitialized urandom read (16 bytes read)
  1934  [    5.554045] systemd[1]: Created slice Slice /system/modprobe.
  1935  [    5.554785] random: systemd: uninitialized urandom read (16 bytes read)
  1936  [    5.557809] systemd[1]: Created slice Slice /system/serial-getty.
  1937  [    5.558252] random: systemd: uninitialized urandom read (16 bytes read)
  1938  [    5.560597] systemd[1]: Created slice User and Session Slice.
  1939  [    5.561082] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped.
  1940  [    5.561662] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
  1941  [    5.563104] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
  1942  [    5.563653] systemd[1]: Reached target Local Encrypted Volumes.
  1943  [    5.564435] systemd[1]: Reached target Slice Units.
  1944  [    5.564764] systemd[1]: Reached target Swaps.
  1945  [    5.565071] systemd[1]: Reached target System Time Set.
  1946  [    5.565631] systemd[1]: Reached target Local Verity Protected Volumes.
  1947  [    5.587985] systemd[1]: Listening on RPCbind Server Activation Socket.
  1948  [    5.590149] systemd[1]: Listening on Syslog Socket.
  1949  [    5.591328] systemd[1]: Listening on fsck to fsckd communication Socket.
  1950  [    5.591968] systemd[1]: Listening on initctl Compatibility Named Pipe.
  1951  [    5.593623] systemd[1]: Listening on Journal Audit Socket.
  1952  [    5.594654] systemd[1]: Listening on Journal Socket (/dev/log).
  1953  [    5.595693] systemd[1]: Listening on Journal Socket.
  1954  [    5.597030] systemd[1]: Listening on udev Control Socket.
  1955  [    5.598188] systemd[1]: Listening on udev Kernel Socket.
  1956  [    5.603925] systemd[1]: Mounting Huge Pages File System...
  1957  [    5.610880] systemd[1]: Mounting POSIX Message Queue File System...
  1958  [    5.617185] systemd[1]: Mounting NFSD configuration filesystem...
  1959  [    5.624267] systemd[1]: Mounting Kernel Debug File System...
  1960  [    5.625550] systemd[1]: Condition check resulted in Kernel Trace File System being skipped.
  1961  [    5.626478] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
  1962  [    5.635416] systemd[1]: Starting Restore / save the current clock...
  1963  [    5.643601] systemd[1]: Starting Set the console keyboard layout...
  1964  [    5.644258] systemd[1]: Condition check resulted in Create List of Static Device Nodes being skipped.
  1965  [    5.651346] systemd[1]: Starting Load Kernel Module chromeos_pstore...
  1966  [    5.659042] systemd[1]: Starting Load Kernel Module configfs...
  1967  [    5.666509] systemd[1]: Starting Load Kernel Module drm...
  1968  [    5.674892] systemd[1]: Starting Load Kernel Module efi_pstore...
  1969  [    5.683147] systemd[1]: Starting Load Kernel Module fuse...
  1970  [    5.691079] systemd[1]: Starting Load Kernel Module pstore_blk...
  1971  [    5.699079] systemd[1]: Starting Load Kernel Module pstore_zone...
  1972  [    5.706715] systemd[1]: Starting Load Kernel Module ramoops...
  1973  [    5.714880] systemd[1]: Started Nameserver information manager.
  1974  [    5.716525] systemd[1]: Reached target Preparation for Network.
  1975  [    5.717918] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
  1976  [    5.733004] systemd[1]: Starting Load Kernel Modules...
  1977  [    5.742850] systemd[1]: Starting Remount Root and Kernel File Systems...
  1978  [    5.750843] systemd[1]: Starting Coldplug All udev Devices...
  1979  [    5.766147] systemd[1]: Mounted Huge Pages File System.
  1980  [    5.767223] systemd[1]: Mounted POSIX Message Queue File System.
  1981  [    5.768269] systemd[1]: proc-fs-nfsd.mount: Mount process exited, code=exited, status=32/n/a
  1982  [    5.768318] systemd[1]: proc-fs-nfsd.mount: Failed with result 'exit-code'.
  1983  [    5.770692] systemd[1]: Failed to mount NFSD configuration filesystem.
  1984  [    5.771070] systemd[1]: Dependency failed for NFSv4 Client Tracking Daemon.
  1985  [    5.771217] systemd[1]: nfsdcld.service: Job nfsdcld.service/start failed with result 'dependency'.
  1986  [    5.771277] systemd[1]: Dependency failed for NFS server and services.
  1987  [    5.771404] systemd[1]: Dependency failed for NFSv4 ID-name mapping service.
  1988  [    5.771534] systemd[1]: nfs-idmapd.service: Job nfs-idmapd.service/start failed with result 'dependency'.
  1989  [    5.771578] systemd[1]: Dependency failed for NFS Mount Daemon.
  1990  [    5.771699] systemd[1]: nfs-mountd.service: Job nfs-mountd.service/start failed with result 'dependency'.
  1991  [    5.771748] systemd[1]: nfs-server.service: Job nfs-server.service/start failed with result 'dependency'.
  1992  [    5.772818] systemd[1]: Mounted Kernel Debug File System.
  1993  [    5.776040] systemd[1]: Finished Restore / save the current clock.
  1994  [    5.778317] systemd[1]: modprobe@chromeos_pstore.service: Deactivated successfully.
  1995  [    5.779560] EXT4-fs (sda1): re-mounted. Opts: commit=600,errors=remount-ro. Quota mode: none.
  1996  [    5.779726] systemd[1]: Finished Load Kernel Module chromeos_pstore.
  1997  [    5.786543] systemd[1]: modprobe@configfs.service: Deactivated successfully.
  1998  [    5.787893] systemd[1]: Finished Load Kernel Module configfs.
  1999  [    5.790160] systemd[1]: modprobe@drm.service: Deactivated successfully.
  2000  [    5.791531] systemd[1]: Finished Load Kernel Module drm.
  2001  [    5.793850] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
  2002  [    5.795314] systemd[1]: Finished Load Kernel Module efi_pstore.
  2003  [    5.797555] systemd[1]: modprobe@fuse.service: Deactivated successfully.
  2004  [    5.798916] systemd[1]: Finished Load Kernel Module fuse.
  2005  [    5.800986] systemd[1]: modprobe@pstore_blk.service: Deactivated successfully.
  2006  [    5.802635] systemd[1]: Finished Load Kernel Module pstore_blk.
  2007  [    5.804723] systemd[1]: modprobe@pstore_zone.service: Deactivated successfully.
  2008  [    5.806254] systemd[1]: Finished Load Kernel Module pstore_zone.
  2009  [    5.808329] systemd[1]: modprobe@ramoops.service: Deactivated successfully.
  2010  [    5.810094] systemd[1]: Finished Load Kernel Module ramoops.
  2011  [    5.815380] systemd[1]: Finished Load Kernel Modules.
  2012  [    5.854561] systemd[1]: Finished Remount Root and Kernel File Systems.
  2013  [    5.856825] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
  2014  [    5.862500] systemd[1]: Mounting Kernel Configuration File System...
  2015  [    5.863300] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
  2016  [    5.873290] systemd[1]: Starting Load/Save Random Seed...
  2017  [    5.883239] systemd[1]: Starting Apply Kernel Variables...
  2018  [    5.894766] systemd[1]: Starting Create System Users...
  2019  [    5.917140] systemd[1]: Mounted Kernel Configuration File System.
  2020  [    5.952052] systemd[1]: Finished Apply Kernel Variables.
  2021  [    5.954898] systemd[1]: Finished Create System Users.
  2022  [    5.964573] systemd[1]: Starting Create Static Device Nodes in /dev...
  2023  [    6.017161] systemd[1]: Finished Create Static Device Nodes in /dev.
  2024  [    6.030235] systemd[1]: Starting Rule-based Manager for Device Events and Files...
  2025  [    6.069109] systemd[1]: Finished Set the console keyboard layout.
  2026  [    6.070546] systemd[1]: Reached target Preparation for Local File Systems.
  2027  [    6.102206] systemd[1]: Mounting /tmp...
  2028  [    6.113906] systemd[1]: Mounted /tmp.
  2029  [    6.114971] systemd[1]: Reached target Local File Systems.
  2030  [    6.124947] systemd[1]: Starting Armbian leds state...
  2031  [    6.134640] systemd[1]: Starting Armbian ZRAM config...
  2032  [    6.148623] systemd[1]: Starting Set console font and keymap...
  2033  [    6.149965] systemd[1]: Condition check resulted in RPC security service for NFS server being skipped.
  2034  [    6.150279] systemd[1]: Condition check resulted in Mark the need to relabel after reboot being skipped.
  2035  [    6.162450] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
  2036  [    6.181233] systemd[1]: Finished Set console font and keymap.
  2037  [    6.226719] systemd[1]: armbian-led-state.service: Main process exited, code=exited, status=1/FAILURE
  2038  [    6.227647] systemd[1]: armbian-led-state.service: Failed with result 'exit-code'.
  2039  [    6.229527] systemd[1]: Failed to start Armbian leds state.
  2040  [    6.303669] systemd[1]: Finished Coldplug All udev Devices.
  2041  [    6.312090] systemd[1]: Starting Helper to synchronize boot up for ifupdown...
  2042  [    6.349680] systemd[1]: Started Rule-based Manager for Device Events and Files.
  2043  [    6.479572] systemd[1]: armbian-zram-config.service: Main process exited, code=exited, status=1/FAILURE
  2044  [    6.480546] systemd[1]: armbian-zram-config.service: Failed with result 'exit-code'.
  2045  [    6.484262] systemd[1]: Failed to start Armbian ZRAM config.
  2046  [    6.524337] systemd[1]: Starting Armbian memory supported logging...
  2047  [    6.568364] urandom_read_iter: 51 callbacks suppressed
  2048  [    6.568396] random: systemd: uninitialized urandom read (16 bytes read)
  2049  [    6.655463] random: systemd: uninitialized urandom read (16 bytes read)
  2050  [    6.655580] random: systemd: uninitialized urandom read (16 bytes read)
  2051  [    6.781953] random: crng init done
  2052  [    6.781985] random: 8 urandom warning(s) missed due to ratelimiting
  2053  [    6.799828] systemd[1]: Finished Load/Save Random Seed.
  2054  [    6.801862] systemd[1]: Condition check resulted in First Boot Complete being skipped.
  2055  [    6.802097] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
  2056  [    6.802346] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
  2057  [    6.850157] systemd[1]: Found device /dev/ttyS0.
  2058  [    7.402721] systemd[1]: Found device /sys/subsystem/net/devices/eth0.
  2059  [    7.430601] systemd[1]: Started ifup for eth0.
  2060  [    7.435878] systemd[1]: Finished Helper to synchronize boot up for ifupdown.
  2061  [    7.444614] systemd[1]: Starting Raise network interfaces...
  2062  [    7.448556] systemd[1]: ifup@eth0.service: Main process exited, code=exited, status=1/FAILURE
  2063  [    7.449736] systemd[1]: ifup@eth0.service: Failed with result 'exit-code'.
  2064  [    8.011502] systemd[1]: networking.service: Main process exited, code=exited, status=1/FAILURE
  2065  [    8.012392] systemd[1]: networking.service: Failed with result 'exit-code'.
  2066  [    8.014158] systemd[1]: Failed to start Raise network interfaces.
  2067  [   10.585634] systemd[1]: Finished Armbian memory supported logging.
  2068  [   10.625744] systemd[1]: Starting Journal Service...
  2069  [   10.887291] systemd[1]: Started Journal Service.
  2070  [   10.944202] systemd-journald[590]: Received client request to flush runtime journal.
  2071
  2072  ### armbian-release:
  2073
  2074  # PLEASE DO NOT EDIT THIS FILE
  2075  BOARD=pine64
  2076  BOARD_NAME="Pine64"
  2077  BOARDFAMILY=sun50iw1
  2078  BUILD_REPOSITORY_URL=https://github.com/armbian/build
  2079  BUILD_REPOSITORY_COMMIT=84940abb
  2080  VERSION=22.11.1
  2081  LINUXFAMILY=sunxi64
  2082  ARCH=arm64
  2083  IMAGE_TYPE=stable
  2084  BOARD_TYPE=conf
  2085  INITRD_ARCH=arm64
  2086  KERNEL_IMAGE_TYPE=Image
  2087  BRANCH=current
  2088
  2089  ### boot environment:
  2090
  2091  verbosity=1
  2092  bootlogo=false
  2093  console=both
  2094  disp_mode=1920x1080p60
  2095  overlay_prefix=sunxi64
  2096  rootdev=UUID=1a07fccf-6922-49b1-ace2-e12d87fdb297
  2097  rootfstype=ext4
  2098  usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
  2099
  2100  ### lsusb:
  2101
  2102  Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  2103  Bus 002 Device 003: ID 046d:081b Logitech, Inc. Webcam C310
  2104  Bus 002 Device 002: ID 05e3:0610 Genesys Logic, Inc. Hub
  2105  Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  2106  Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  2107  Bus 001 Device 002: ID 1f75:0621 Innostor Technology Corporation IS621 SATA Storage Controller
  2108  Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  2109  Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  2110
  2111  ### lscpu:
  2112
  2113  Architecture:                    aarch64
  2114  CPU op-mode(s):                  32-bit, 64-bit
  2115  Byte Order:                      Little Endian
  2116  CPU(s):                          4
  2117  On-line CPU(s) list:             0-3
  2118  Vendor ID:                       ARM
  2119  Model name:                      Cortex-A53
  2120  Model:                           4
  2121  Thread(s) per core:              1
  2122  Core(s) per cluster:             4
  2123  Socket(s):                       -
  2124  Cluster(s):                      1
  2125  Stepping:                        r0p4
  2126  BogoMIPS:                        48.00
  2127  Flags:                           fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  2128  NUMA node(s):                    1
  2129  NUMA node0 CPU(s):               0-3
  2130  Vulnerability Itlb multihit:     Not affected
  2131  Vulnerability L1tf:              Not affected
  2132  Vulnerability Mds:               Not affected
  2133  Vulnerability Meltdown:          Not affected
  2134  Vulnerability Mmio stale data:   Not affected
  2135  Vulnerability Spec store bypass: Not affected
  2136  Vulnerability Spectre v1:        Mitigation; __user pointer sanitization
  2137  Vulnerability Spectre v2:        Not affected
  2138  Vulnerability Srbds:             Not affected
  2139  Vulnerability Tsx async abort:   Not affected
  2140
  2141  ### cpuinfo:
  2142
  2143  processor       : 0
  2144  BogoMIPS        : 48.00
  2145  Features        : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  2146  CPU implementer : 0x41
  2147  CPU architecture: 8
  2148  CPU variant     : 0x0
  2149  CPU part        : 0xd03
  2150  CPU revision    : 4
  2151
  2152  processor       : 1
  2153  BogoMIPS        : 48.00
  2154  Features        : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  2155  CPU implementer : 0x41
  2156  CPU architecture: 8
  2157  CPU variant     : 0x0
  2158  CPU part        : 0xd03
  2159  CPU revision    : 4
  2160
  2161  processor       : 2
  2162  BogoMIPS        : 48.00
  2163  Features        : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  2164  CPU implementer : 0x41
  2165  CPU architecture: 8
  2166  CPU variant     : 0x0
  2167  CPU part        : 0xd03
  2168  CPU revision    : 4
  2169
  2170  processor       : 3
  2171  BogoMIPS        : 48.00
  2172  Features        : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  2173  CPU implementer : 0x41
  2174  CPU architecture: 8
  2175  CPU variant     : 0x0
  2176  CPU part        : 0xd03
  2177  CPU revision    : 4
  2178
  2179
  2180  ### meminfo:
  2181
  2182  MemTotal:        2037276 kB
  2183  MemFree:         1888184 kB
  2184  MemAvailable:    1882516 kB
  2185  Buffers:           11376 kB
  2186  Cached:            52504 kB
  2187  SwapCached:            0 kB
  2188  Active:            27956 kB
  2189  Inactive:          53844 kB
  2190  Active(anon):        408 kB
  2191  Inactive(anon):    34116 kB
  2192  Active(file):      27548 kB
  2193  Inactive(file):    19728 kB
  2194  Unevictable:           0 kB
  2195  Mlocked:               0 kB
  2196  SwapTotal:             0 kB
  2197  SwapFree:              0 kB
  2198  Dirty:                20 kB
  2199  Writeback:             0 kB
  2200  AnonPages:         18204 kB
  2201  Mapped:            14816 kB
  2202  Shmem:             16356 kB
  2203  KReclaimable:       8964 kB
  2204  Slab:              31468 kB
  2205  SReclaimable:       8964 kB
  2206  SUnreclaim:        22504 kB
  2207  KernelStack:        2384 kB
  2208  PageTables:         1636 kB
  2209  NFS_Unstable:          0 kB
  2210  Bounce:                0 kB
  2211  WritebackTmp:          0 kB
  2212  CommitLimit:     1018636 kB
  2213  Committed_AS:      66116 kB
  2214  VmallocTotal:   133143592960 kB
  2215  VmallocUsed:       10284 kB
  2216  VmallocChunk:          0 kB
  2217  Percpu:             1072 kB
  2218  AnonHugePages:         0 kB
  2219  ShmemHugePages:        0 kB
  2220  ShmemPmdMapped:        0 kB
  2221  FileHugePages:         0 kB
  2222  FilePmdMapped:         0 kB
  2223  CmaTotal:         131072 kB
  2224  CmaFree:          130304 kB
  2225  HugePages_Total:       0
  2226  HugePages_Free:        0
  2227  HugePages_Rsvd:        0
  2228  HugePages_Surp:        0
  2229  Hugepagesize:       2048 kB
  2230  Hugetlb:               0 kB
  2231
  2232  ### virtual memory:
  2233
  2234  vm.admin_reserve_kbytes = 8192
  2235  vm.compaction_proactiveness = 20
  2236  vm.compact_unevictable_allowed = 1
  2237  vm.dirty_background_bytes = 0
  2238  vm.dirty_background_ratio = 10
  2239  vm.dirty_bytes = 0
  2240  vm.dirty_expire_centisecs = 3000
  2241  vm.dirty_ratio = 20
  2242  vm.dirtytime_expire_seconds = 43200
  2243  vm.dirty_writeback_centisecs = 500
  2244  vm.extfrag_threshold = 500
  2245  vm.hugetlb_shm_group = 0
  2246  vm.laptop_mode = 0
  2247  vm.legacy_va_layout = 0
  2248  vm.lowmem_reserve_ratio = 256   256     32      0
  2249  vm.max_map_count = 65530
  2250  vm.min_free_kbytes = 22528
  2251  vm.min_slab_ratio = 5
  2252  vm.min_unmapped_ratio = 1
  2253  vm.mmap_min_addr = 32768
  2254  vm.mmap_rnd_bits = 18
  2255  vm.mmap_rnd_compat_bits = 11
  2256  vm.nr_hugepages = 0
  2257  vm.nr_hugepages_mempolicy = 0
  2258  vm.nr_overcommit_hugepages = 0
  2259  vm.numa_stat = 1
  2260  vm.numa_zonelist_order = Node
  2261  vm.oom_dump_tasks = 1
  2262  vm.oom_kill_allocating_task = 0
  2263  vm.overcommit_kbytes = 0
  2264  vm.overcommit_memory = 0
  2265  vm.overcommit_ratio = 50
  2266  vm.page-cluster = 3
  2267  vm.page_lock_unfairness = 5
  2268  vm.panic_on_oom = 0
  2269  vm.percpu_pagelist_high_fraction = 0
  2270  vm.stat_interval = 1
  2271  vm.swappiness = 100
  2272  vm.user_reserve_kbytes = 63000
  2273  vm.vfs_cache_pressure = 100
  2274  vm.watermark_boost_factor = 15000
  2275  vm.watermark_scale_factor = 10
  2276  vm.zone_reclaim_mode = 0
  2277
  2278  ### ip addr:
  2279
  2280  1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
  2281      link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
  2282      inet XXX.XXX.0.1/8 scope host lo
  2283         valid_lft forever preferred_lft forever
  2284      inet6 ::1/128 scope host
  2285         valid_lft forever preferred_lft forever
  2286  2: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
  2287      link/ether 02:ba:85:77:17:e9 brd ff:ff:ff:ff:ff:ff
  2288
  2289  ### partitions:
  2290
  2291  major minor  #blocks  name
  2292
  2293   179        0   31260672 mmcblk0
  2294   179        1   30928896 mmcblk0p1
  2295     8        0  117220824 sda
  2296     8        1  117218304 sda1
  2297
  2298  ### df:
  2299
  2300  tmpfs           199M  3.1M  196M   2% /run
  2301  /dev/sda1       110G   20G   85G  19% /
  2302  tmpfs           995M     0  995M   0% /dev/shm
  2303  tmpfs           5.0M     0  5.0M   0% /run/lock
  2304  tmpfs           995M  4.0K  995M   1% /tmp
  2305
  2306  ### lsblk:
  2307
  2308  NAME        FSTYPE   SIZE MOUNTPOINT UUID
  2309  sda                111.8G
  2310  └─sda1      ext4   111.8G /          933d6d44-0352-46aa-8100-fd703056ae3d
  2311  mmcblk0             29.8G
  2312  └─mmcblk0p1 ext4    29.5G            1a07fccf-6922-49b1-ace2-e12d87fdb297
  2313
  2314  ### zramctl:
  2315
  2316
  2317
  2318  ### mtab:
  2319
  2320  /dev/sda1 / ext4 rw,noatime,errors=remount-ro,commit=600 0 0
  2321  /dev/sda1 /var/log.hdd ext4 rw,noatime,errors=remount-ro,commit=600 0 0
  2322
  2323  ### mmc0:0001 info:
  2324
  2325                 fwrev: 0x0
  2326                uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=EB1QT MODALIAS=mmc:block
  2327                   cid: 1b534d454231515430bc836120012941
  2328                   rca: 0x0001
  2329                   csd: 400e00325b590000ee7f7f800a404055
  2330                manfid: 0x00001b
  2331                   ocr: 0x00200000
  2332  preferred_erase_size: 4194304
  2333                  type: SD
  2334                 hwrev: 0x3
  2335                  date: 09/2018
  2336                   dsr: 0x404
  2337            erase_size: 512
  2338                 oemid: 0x534d
  2339                serial: 0xbc836120
  2340                   ssr: 0000000005000000040090000f051c00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
  2341                   scr: 02b5800200000000
  2342                  name: EB1QT
  2343
  2344  ### Boot system health:
  2345
  2346  Time      CPU n/a    load %cpu %sys %usr %nice %io %irq   CPU
  2347  22:03:44:   ---      0.15  53%  29%  19%   0%   3%   0% 39.8 °C
  2348  22:03:45:   ---      0.15  91%  15%  38%   0%  33%   2% 39.8 °C
  2349  22:03:45:   ---      0.62  84%  20%  18%   0%  42%   2% 37.2 °C
  2350  22:03:45:   ---      0.62  67%  12%  17%   1%  35%   0% 37.2 °C
  2351  22:03:46:   ---      0.62  25%   4%   3%   0%  15%   1% 37.2 °C
  2352
  2353  ### No more available zram devices ()
  2354
  2355  Fri Dec  9 10:41:36 PM CET 2022 | Pine64 | 22.11.1 | arm64 | aarch64 | 5.15.48-sunxi64
  2356
  2357  ### dmesg:
  2358
  2359  [    0.000966] pid_max: default: 32768 minimum: 301
  2360  [    0.001053] LSM: Security Framework initializing
  2361  [    0.001082] Yama: becoming mindful.
  2362  [    0.001177] AppArmor: AppArmor initialized
  2363  [    0.001290] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
  2364  [    0.001319] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
  2365  [    0.003384] rcu: Hierarchical SRCU implementation.
  2366  [    0.004894] smp: Bringing up secondary CPUs ...
  2367  [    0.006138] Detected VIPT I-cache on CPU1
  2368  [    0.006206] arch_timer: CPU1: Trapping CNTVCT access
  2369  [    0.006224] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
  2370  [    0.007051] Detected VIPT I-cache on CPU2
  2371  [    0.007088] arch_timer: CPU2: Trapping CNTVCT access
  2372  [    0.007098] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
  2373  [    0.007836] Detected VIPT I-cache on CPU3
  2374  [    0.007870] arch_timer: CPU3: Trapping CNTVCT access
  2375  [    0.007881] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
  2376  [    0.008001] smp: Brought up 1 node, 4 CPUs
  2377  [    0.008017] SMP: Total of 4 processors activated.
  2378  [    0.008025] CPU features: detected: 32-bit EL0 Support
  2379  [    0.008031] CPU features: detected: CRC32 instructions
  2380  [    0.022887] CPU: All CPU(s) started at EL2
  2381  [    0.022921] alternatives: patching kernel code
  2382  [    0.024757] devtmpfs: initialized
  2383  [    0.032795] Registered cp15_barrier emulation handler
  2384  [    0.032829] Registered setend emulation handler
  2385  [    0.033012] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
  2386  [    0.033037] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
  2387  [    0.038493] pinctrl core: initialized pinctrl subsystem
  2388  [    0.040177] NET: Registered PF_NETLINK/PF_ROUTE protocol family
  2389  [    0.041966] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
  2390  [    0.042142] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
  2391  [    0.042319] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
  2392  [    0.042425] audit: initializing netlink subsys (disabled)
  2393  [    0.042643] audit: type=2000 audit(0.040:1): state=initialized audit_enabled=0 res=1
  2394  [    0.043252] thermal_sys: Registered thermal governor 'fair_share'
  2395  [    0.043259] thermal_sys: Registered thermal governor 'bang_bang'
  2396  [    0.043265] thermal_sys: Registered thermal governor 'step_wise'
  2397  [    0.043270] thermal_sys: Registered thermal governor 'user_space'
  2398  [    0.043734] cpuidle: using governor menu
  2399  [    0.043991] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
  2400  [    0.044102] ASID allocator initialised with 65536 entries
  2401  [    0.044296] Serial: AMBA PL011 UART driver
  2402  [    0.060271] platform 1ee0000.hdmi: Fixing up cyclic dependency with 1c0d000.lcd-controller
  2403  [    0.061807] platform hdmi-connector: Fixing up cyclic dependency with 1ee0000.hdmi
  2404  [    0.069882] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
  2405  [    0.069905] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
  2406  [    0.069914] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
  2407  [    0.069922] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
  2408  [    0.072138] cryptd: max_cpu_qlen set to 1000
  2409  [    0.140231] raid6: neonx8   gen()  1460 MB/s
  2410  [    0.208291] raid6: neonx8   xor()  1091 MB/s
  2411  [    0.276370] raid6: neonx4   gen()  1492 MB/s
  2412  [    0.344434] raid6: neonx4   xor()  1081 MB/s
  2413  [    0.412501] raid6: neonx2   gen()  1411 MB/s
  2414  [    0.480568] raid6: neonx2   xor()   991 MB/s
  2415  [    0.548634] raid6: neonx1   gen()  1231 MB/s
  2416  [    0.616706] raid6: neonx1   xor()   848 MB/s
  2417  [    0.684778] raid6: int64x8  gen()  1023 MB/s
  2418  [    0.752845] raid6: int64x8  xor()   533 MB/s
  2419  [    0.820906] raid6: int64x4  gen()  1126 MB/s
  2420  [    0.888991] raid6: int64x4  xor()   572 MB/s
  2421  [    0.957064] raid6: int64x2  gen()   962 MB/s
  2422  [    1.025139] raid6: int64x2  xor()   509 MB/s
  2423  [    1.093217] raid6: int64x1  gen()   716 MB/s
  2424  [    1.161276] raid6: int64x1  xor()   372 MB/s
  2425  [    1.161284] raid6: using algorithm neonx4 gen() 1492 MB/s
  2426  [    1.161290] raid6: .... xor() 1081 MB/s, rmw enabled
  2427  [    1.161296] raid6: using neon recovery algorithm
  2428  [    1.161949] iommu: Default domain type: Translated
  2429  [    1.161959] iommu: DMA domain TLB invalidation policy: strict mode
  2430  [    1.162284] SCSI subsystem initialized
  2431  [    1.162509] usbcore: registered new interface driver usbfs
  2432  [    1.162559] usbcore: registered new interface driver hub
  2433  [    1.162594] usbcore: registered new device driver usb
  2434  [    1.162925] pps_core: LinuxPPS API ver. 1 registered
  2435  [    1.162932] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
  2436  [    1.162952] PTP clock support registered
  2437  [    1.163416] ARM FF-A: FFA_VERSION returned not supported
  2438  [    1.163814] Advanced Linux Sound Architecture Driver Initialized.
  2439  [    1.164560] NetLabel: Initializing
  2440  [    1.164601] NetLabel:  domain hash size = 128
  2441  [    1.164608] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
  2442  [    1.164688] NetLabel:  unlabeled traffic allowed by default
  2443  [    1.165188] clocksource: Switched to clocksource arch_sys_counter
  2444  [    1.165420] VFS: Disk quotas dquot_6.6.0
  2445  [    1.165486] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
  2446  [    1.166160] AppArmor: AppArmor Filesystem Enabled
  2447  [    1.173302] NET: Registered PF_INET protocol family
  2448  [    1.173586] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
  2449  [    1.174959] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
  2450  [    1.175004] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
  2451  [    1.175022] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
  2452  [    1.175181] TCP bind hash table entries: 16384 (order: 6, 262144 bytes, linear)
  2453  [    1.175511] TCP: Hash tables configured (established 16384 bind 16384)
  2454  [    1.175681] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
  2455  [    1.175750] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
  2456  [    1.175970] NET: Registered PF_UNIX/PF_LOCAL protocol family
  2457  [    1.176569] Trying to unpack rootfs image as initramfs...
  2458  [    1.186574] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
  2459  [    1.193922] Initialise system trusted keyrings
  2460  [    1.194032] Key type blacklist registered
  2461  [    1.194268] workingset: timestamp_bits=44 max_order=19 bucket_order=0
  2462  [    1.200682] zbud: loaded
  2463  [    1.202489] squashfs: version 4.0 (2009/01/31) Phillip Lougher
  2464  [    1.205065] integrity: Platform Keyring initialized
  2465  [    1.257974] xor: automatically using best checksumming function   32regs
  2466  [    1.258002] async_tx: api initialized (async)
  2467  [    1.258014] Key type asymmetric registered
  2468  [    1.258021] Asymmetric key parser 'x509' registered
  2469  [    1.258167] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
  2470  [    1.258340] io scheduler mq-deadline registered
  2471  [    1.258348] io scheduler kyber registered
  2472  [    1.258564] io scheduler bfq registered
  2473  [    1.262456] sun50i-a64-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver
  2474  [    1.272519] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
  2475  [    1.284812] loop: module loaded
  2476  [    1.287435] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
  2477  [    1.287469] ehci-platform: EHCI generic platform driver
  2478  [    1.287632] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
  2479  [    1.287647] ohci-platform: OHCI generic platform driver
  2480  [    1.288140] usbcore: registered new interface driver usb-storage
  2481  [    1.288737] mousedev: PS/2 mouse device common for all mice
  2482  [    1.289877] sun6i-rtc 1f00000.rtc: registered as rtc0
  2483  [    1.289916] sun6i-rtc 1f00000.rtc: setting system clock to 2022-12-09T21:41:26 UTC (1670622086)
  2484  [    1.290039] sun6i-rtc 1f00000.rtc: RTC enabled
  2485  [    1.290147] i2c_dev: i2c /dev entries driver
  2486  [    1.290958] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
  2487  [    1.293120] sun50i-a64-r-pinctrl 1f02c00.pinctrl: supply vcc-pl not found, using dummy regulator
  2488  [    1.293725] sdhci: Secure Digital Host Controller Interface driver
  2489  [    1.293736] sdhci: Copyright(c) Pierre Ossman
  2490  [    1.293764] Synopsys Designware Multimedia Card Interface Driver
  2491  [    1.294517] sdhci-pltfm: SDHCI platform and OF driver helper
  2492  [    1.295484] ledtrig-cpu: registered to indicate activity on CPUs
  2493  [    1.295997] SMCCC: SOC_ID: ID = jep106:091e:1689 Revision = 0x00000001
  2494  [    1.296307] sun8i-ce 1c15000.crypto: Set mod clock to 300000000 (300 Mhz) from 24000000 (24 Mhz)
  2495  [    1.296608] sun8i-ce 1c15000.crypto: will run requests pump with realtime priority
  2496  [    1.296760] sun8i-ce 1c15000.crypto: will run requests pump with realtime priority
  2497  [    1.296888] sun8i-ce 1c15000.crypto: will run requests pump with realtime priority
  2498  [    1.297000] sun8i-ce 1c15000.crypto: will run requests pump with realtime priority
  2499  [    1.297098] sun8i-ce 1c15000.crypto: Register cbc(aes)
  2500  [    1.297339] sun8i-ce 1c15000.crypto: Register ecb(aes)
  2501  [    1.297504] sun8i-ce 1c15000.crypto: Register cbc(des3_ede)
  2502  [    1.297644] sun8i-ce 1c15000.crypto: Register ecb(des3_ede)
  2503  [    1.297776] sun8i-ce 1c15000.crypto: Register md5
  2504  [    1.297917] sun8i-ce 1c15000.crypto: Register sha1
  2505  [    1.298048] sun8i-ce 1c15000.crypto: Register sha224
  2506  [    1.298177] sun8i-ce 1c15000.crypto: Register sha256
  2507  [    1.298308] sun8i-ce 1c15000.crypto: DEBUG: Algo of sha384 not supported
  2508  [    1.298318] sun8i-ce 1c15000.crypto: DEBUG: Algo of sha512 not supported
  2509  [    1.298327] sun8i-ce 1c15000.crypto: Register stdrng
  2510  [    1.298504] sun8i-ce 1c15000.crypto: TRNG not supported
  2511  [    1.298515] sun8i-ce 1c15000.crypto: CryptoEngine Die ID 0
  2512  [    1.299131] hid: raw HID events driver (C) Jiri Kosina
  2513  [    1.299282] usbcore: registered new interface driver usbhid
  2514  [    1.299291] usbhid: USB HID core driver
  2515  [    1.305618] NET: Registered PF_INET6 protocol family
  2516  [    1.956986] Freeing initrd memory: 12684K
  2517  [    1.990251] Segment Routing with IPv6
  2518  [    1.990345] In-situ OAM (IOAM) with IPv6
  2519  [    1.990444] NET: Registered PF_PACKET protocol family
  2520  [    1.990577] 8021q: 802.1Q VLAN Support v1.8
  2521  [    1.990741] 9pnet: Installing 9P2000 support
  2522  [    1.990844] Key type dns_resolver registered
  2523  [    1.991355] registered taskstats version 1
  2524  [    1.991379] Loading compiled-in X.509 certificates
  2525  [    1.995669] Loaded X.509 cert 'Build time autogenerated kernel key: 32330adefd2da02e444296fafd37464380789679'
  2526  [    2.000062] zswap: loaded using pool zstd/z3fold
  2527  [    2.000790] Key type ._fscrypt registered
  2528  [    2.000800] Key type .fscrypt registered
  2529  [    2.000805] Key type fscrypt-provisioning registered
  2530  [    2.002013] Btrfs loaded, crc32c=crc32c-generic, zoned=yes, fsverity=no
  2531  [    2.017908] Key type encrypted registered
  2532  [    2.017945] AppArmor: AppArmor sha1 policy hashing enabled
  2533  [    2.017990] ima: No TPM chip found, activating TPM-bypass!
  2534  [    2.018035] ima: Allocated hash algorithm: sha1
  2535  [    2.018072] ima: No architecture policies found
  2536  [    2.018167] evm: Initialising EVM extended attributes:
  2537  [    2.018172] evm: security.selinux
  2538  [    2.018178] evm: security.SMACK64
  2539  [    2.018182] evm: security.SMACK64EXEC
  2540  [    2.018187] evm: security.SMACK64TRANSMUTE
  2541  [    2.018191] evm: security.SMACK64MMAP
  2542  [    2.018196] evm: security.apparmor
  2543  [    2.018201] evm: security.ima
  2544  [    2.018206] evm: security.capability
  2545  [    2.018210] evm: HMAC attrs: 0x1
  2546  [    2.031144] platform 1100000.mixer: Fixing up cyclic dependency with 1c0d000.lcd-controller
  2547  [    2.031237] platform 1100000.mixer: Fixing up cyclic dependency with 1c0c000.lcd-controller
  2548  [    2.032003] platform 1200000.mixer: Fixing up cyclic dependency with 1c0d000.lcd-controller
  2549  [    2.032072] platform 1200000.mixer: Fixing up cyclic dependency with 1c0c000.lcd-controller
  2550  [    2.032946] sunxi-rsb 1f03400.rsb: RSB running at 3000000 Hz
  2551  [    2.033409] axp20x-rsb sunxi-rsb-3a3: AXP20x variant AXP803 found
  2552  [    2.035463] input: axp20x-pek as /devices/platform/soc/1f03400.rsb/sunxi-rsb-3a3/axp221-pek/input/input0
  2553  [    2.038624] vcc-3v3: supplied by regulator-dummy
  2554  [    2.039156] vdd-cpux: supplied by regulator-dummy
  2555  [    2.039819] dcdc4: supplied by regulator-dummy
  2556  [    2.040012] vcc-dram: supplied by regulator-dummy
  2557  [    2.040486] vdd-sys: supplied by regulator-dummy
  2558  [    2.041029] vcc-phy: supplied by regulator-dummy
  2559  [    2.041491] aldo1: supplied by regulator-dummy
  2560  [    2.041677] vcc-pl: supplied by regulator-dummy
  2561  [    2.042132] vcc-pll-avcc: supplied by regulator-dummy
  2562  [    2.042766] vcc-hdmi: supplied by regulator-dummy
  2563  [    2.043137] vcc-mipi: supplied by regulator-dummy
  2564  [    2.043506] dldo3: supplied by regulator-dummy
  2565  [    2.043905] vcc-wifi: supplied by regulator-dummy
  2566  [    2.044271] cpvdd: supplied by regulator-dummy
  2567  [    2.044643] eldo2: supplied by regulator-dummy
  2568  [    2.045041] eldo3: supplied by regulator-dummy
  2569  [    2.045467] vcc-1v2-hsic: supplied by regulator-dummy
  2570  [    2.045666] vdd-cpus: supplied by regulator-dummy
  2571  [    2.046100] vcc-rtc: supplied by regulator-dummy
  2572  [    2.046538] ldo-io0: supplied by regulator-dummy
  2573  [    2.046905] ldo-io1: supplied by regulator-dummy
  2574  [    2.047030] axp20x-rsb sunxi-rsb-3a3: AXP20X driver loaded
  2575  [    2.051973] sun50i-a64-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
  2576  [    2.052387] sun50i-a64-pinctrl 1c20800.pinctrl: supply vcc-pb not found, using dummy regulator
  2577  [    2.052963] printk: console [ttyS0] disabled
  2578  [    2.053053] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 41, base_baud = 1500000) is a 16550A
  2579  [    2.053306] printk: console [ttyS0] enabled
  2580  [    2.054031] sun50i-a64-pinctrl 1c20800.pinctrl: supply vcc-pg not found, using dummy regulator
  2581  [    2.054553] 1c28400.serial: ttyS1 at MMIO 0x1c28400 (irq = 42, base_baud = 1500000) is a 16550A
  2582  [    2.054710] serial serial0: tty port ttyS1 registered
  2583  [    2.085328] sun4i-drm display-engine: bound 1100000.mixer (ops 0xffff800008e16990)
  2584  [    2.087151] sun4i-drm display-engine: bound 1200000.mixer (ops 0xffff800008e16990)
  2585  [    2.087670] sun4i-drm display-engine: No panel or bridge found... RGB output disabled
  2586  [    2.087688] sun4i-drm display-engine: bound 1c0c000.lcd-controller (ops 0xffff800008e11ba0)
  2587  [    2.087911] sun4i-drm display-engine: bound 1c0d000.lcd-controller (ops 0xffff800008e11ba0)
  2588  [    2.089031] sun8i-dw-hdmi 1ee0000.hdmi: Detected HDMI TX controller v1.32a with HDCP (sun8i_dw_hdmi_phy)
  2589  [    2.089726] sun8i-dw-hdmi 1ee0000.hdmi: registered DesignWare HDMI I2C bus driver
  2590  [    2.090114] sun4i-drm display-engine: bound 1ee0000.hdmi (ops 0xffff800008e15cc8)
  2591  [    2.090804] [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on minor 0
  2592  [    2.090896] sun4i-drm display-engine: [drm] Cannot find any crtc or sizes
  2593  [    2.091602] sun50i-a64-pinctrl 1c20800.pinctrl: supply vcc-pc not found, using dummy regulator
  2594  [    2.092190] sun4i-drm display-engine: [drm] Cannot find any crtc or sizes
  2595  [    2.092943] ehci-platform 1c1a000.usb: EHCI Host Controller
  2596  [    2.092978] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
  2597  [    2.093124] ehci-platform 1c1a000.usb: irq 28, io mem 0x01c1a000
  2598  [    2.105194] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
  2599  [    2.105531] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
  2600  [    2.105547] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  2601  [    2.105559] usb usb1: Product: EHCI Host Controller
  2602  [    2.105568] usb usb1: Manufacturer: Linux 5.15.48-sunxi64 ehci_hcd
  2603  [    2.105577] usb usb1: SerialNumber: 1c1a000.usb
  2604  [    2.106127] hub 1-0:1.0: USB hub found
  2605  [    2.106175] hub 1-0:1.0: 1 port detected
  2606  [    2.107178] ehci-platform 1c1b000.usb: EHCI Host Controller
  2607  [    2.107204] ehci-platform 1c1b000.usb: new USB bus registered, assigned bus number 2
  2608  [    2.107330] ehci-platform 1c1b000.usb: irq 30, io mem 0x01c1b000
  2609  [    2.121193] ehci-platform 1c1b000.usb: USB 2.0 started, EHCI 1.00
  2610  [    2.121520] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
  2611  [    2.121536] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  2612  [    2.121547] usb usb2: Product: EHCI Host Controller
  2613  [    2.121556] usb usb2: Manufacturer: Linux 5.15.48-sunxi64 ehci_hcd
  2614  [    2.121566] usb usb2: SerialNumber: 1c1b000.usb
  2615  [    2.122074] hub 2-0:1.0: USB hub found
  2616  [    2.122126] hub 2-0:1.0: 1 port detected
  2617  [    2.301288] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
  2618  [    2.301321] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 3
  2619  [    2.301460] ohci-platform 1c1a400.usb: irq 29, io mem 0x01c1a400
  2620  [    2.365201] usb 1-1: new high-speed USB device number 2 using ehci-platform
  2621  [    2.369565] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.15
  2622  [    2.369581] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  2623  [    2.369593] usb usb3: Product: Generic Platform OHCI controller
  2624  [    2.369603] usb usb3: Manufacturer: Linux 5.15.48-sunxi64 ohci_hcd
  2625  [    2.369613] usb usb3: SerialNumber: 1c1a400.usb
  2626  [    2.370136] hub 3-0:1.0: USB hub found
  2627  [    2.370190] hub 3-0:1.0: 1 port detected
  2628  [    2.371218] ohci-platform 1c1b400.usb: Generic Platform OHCI controller
  2629  [    2.371246] ohci-platform 1c1b400.usb: new USB bus registered, assigned bus number 4
  2630  [    2.371376] ohci-platform 1c1b400.usb: irq 31, io mem 0x01c1b400
  2631  [    2.377231] usb 2-1: new high-speed USB device number 2 using ehci-platform
  2632  [    2.437518] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.15
  2633  [    2.437534] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  2634  [    2.437546] usb usb4: Product: Generic Platform OHCI controller
  2635  [    2.437555] usb usb4: Manufacturer: Linux 5.15.48-sunxi64 ohci_hcd
  2636  [    2.437565] usb usb4: SerialNumber: 1c1b400.usb
  2637  [    2.438096] hub 4-0:1.0: USB hub found
  2638  [    2.438145] hub 4-0:1.0: 1 port detected
  2639  [    2.439238] usb_phy_generic usb_phy_generic.3.auto: supply vcc not found, using dummy regulator
  2640  [    2.439381] usb_phy_generic usb_phy_generic.3.auto: dummy supplies not allowed for exclusive requests
  2641  [    2.509460] musb-hdrc musb-hdrc.4.auto: MUSB HDRC host driver
  2642  [    2.509492] musb-hdrc musb-hdrc.4.auto: new USB bus registered, assigned bus number 5
  2643  [    2.509762] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
  2644  [    2.509778] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  2645  [    2.509790] usb usb5: Product: MUSB HDRC host driver
  2646  [    2.509799] usb usb5: Manufacturer: Linux 5.15.48-sunxi64 musb-hcd
  2647  [    2.509809] usb usb5: SerialNumber: musb-hdrc.4.auto
  2648  [    2.510335] hub 5-0:1.0: USB hub found
  2649  [    2.510384] hub 5-0:1.0: 1 port detected
  2650  [    2.513812] sun50i-a64-pinctrl 1c20800.pinctrl: supply vcc-pf not found, using dummy regulator
  2651  [    2.513886] scpi_protocol scpi: SCP Protocol 0.0 Firmware 0.0.0 version
  2652  [    2.514907] sunxi-mmc 1c0f000.mmc: Got CD GPIO
  2653  [    2.514908] sunxi-mmc 1c10000.mmc: allocated mmc-pwrseq
  2654  [    2.515157] of_cfs_init
  2655  [    2.515301] of_cfs_init: OK
  2656  [    2.515659] ALSA device list:
  2657  [    2.515667]   No soundcards found.
  2658  [    2.531170] usb 1-1: New USB device found, idVendor=1f75, idProduct=0621, bcdDevice= 0.36
  2659  [    2.531189] usb 1-1: New USB device strings: Mfr=4, Product=5, SerialNumber=6
  2660  [    2.531200] usb 1-1: SerialNumber: 20181120
  2661  [    2.532159] usb-storage 1-1:1.0: USB Mass Storage device detected
  2662  [    2.532709] scsi host0: usb-storage 1-1:1.0
  2663  [    2.536502] usb 2-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice= 6.54
  2664  [    2.536519] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
  2665  [    2.536531] usb 2-1: Product: USB2.1 Hub
  2666  [    2.536540] usb 2-1: Manufacturer: GenesysLogic
  2667  [    2.537281] hub 2-1:1.0: USB hub found
  2668  [    2.537622] hub 2-1:1.0: 4 ports detected
  2669  [    2.540313] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB, uses new timings mode
  2670  [    2.540574] sunxi-mmc 1c10000.mmc: initialized, max. request size: 16384 KB, uses new timings mode
  2671  [    2.542395] Freeing unused kernel memory: 2496K
  2672  [    2.542532] Run /init as init process
  2673  [    2.542540]   with arguments:
  2674  [    2.542546]     /init
  2675  [    2.542552]   with environment:
  2676  [    2.542557]     HOME=/
  2677  [    2.542563]     TERM=linux
  2678  [    2.542568]     ubootpart=ea5e158f-01
  2679  [    2.542574]     cgroup_enable=memory
  2680  [    2.577098] mmc0: new high speed SDHC card at address 0001
  2681  [    2.578229] mmcblk0: mmc0:0001 EB1QT 29.8 GiB
  2682  [    2.580821]  mmcblk0: p1
  2683  [    2.853225] usb 2-1.1: new high-speed USB device number 3 using ehci-platform
  2684  [    3.043135] usbcore: registered new interface driver uas
  2685  [    3.071499] sun50i-a64-pinctrl 1c20800.pinctrl: supply vcc-pd not found, using dummy regulator
  2686  [    3.071803] dwmac-sun8i 1c30000.ethernet: IRQ eth_wake_irq not found
  2687  [    3.071819] dwmac-sun8i 1c30000.ethernet: IRQ eth_lpi not found
  2688  [    3.072121] dwmac-sun8i 1c30000.ethernet: supply phy-io not found, using dummy regulator
  2689  [    3.072335] dwmac-sun8i 1c30000.ethernet: PTP uses main clock
  2690  [    3.072377] dwmac-sun8i 1c30000.ethernet: Current syscon value is not the default 6 (expect 0)
  2691  [    3.072789] dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported
  2692  [    3.072801] dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported
  2693  [    3.072809] dwmac-sun8i 1c30000.ethernet: COE Type 2
  2694  [    3.072818] dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported
  2695  [    3.072827] dwmac-sun8i 1c30000.ethernet: Normal descriptors
  2696  [    3.072835] dwmac-sun8i 1c30000.ethernet: Chain mode enabled
  2697  [    3.074674] sun50i-a64-pinctrl 1c20800.pinctrl: supply vcc-ph not found, using dummy regulator
  2698  [    3.103692] axp20x-gpio axp20x-gpio: DMA mask not set
  2699  [    3.104370] axp20x-gpio axp20x-gpio: AXP209 pinctrl and GPIO driver loaded
  2700  [    3.202549] usb 2-1.1: New USB device found, idVendor=046d, idProduct=081b, bcdDevice= 0.12
  2701  [    3.202584] usb 2-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=2
  2702  [    3.202597] usb 2-1.1: SerialNumber: AA5FCF90
  2703  [    3.558252] scsi 0:0:0:0: Direct-Access     OCZ-VERT EX2                   PQ: 0 ANSI: 6
  2704  [    3.558876] sd 0:0:0:0: Attached scsi generic sg0 type 0
  2705  [    3.560234] sd 0:0:0:0: [sda] 234441648 512-byte logical blocks: (120 GB/112 GiB)
  2706  [    3.561480] sd 0:0:0:0: [sda] Write Protect is off
  2707  [    3.561510] sd 0:0:0:0: [sda] Mode Sense: 3b 00 00 00
  2708  [    3.562876] sd 0:0:0:0: [sda] No Caching mode page found
  2709  [    3.562906] sd 0:0:0:0: [sda] Assuming drive cache: write through
  2710  [    3.568847]  sda: sda1
  2711  [    3.572330] sd 0:0:0:0: [sda] Attached SCSI disk
  2712  [    3.937663] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
  2713  [    4.533416] systemd[1]: systemd 249.11-0ubuntu3.6 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY -P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
  2714  [    4.534138] systemd[1]: Detected architecture arm64.
  2715  [    4.537128] systemd[1]: Hostname set to <pine64>.
  2716  [    4.643661] dw-apb-uart 1c28000.serial: forbid DMA for kernel console
  2717  [    5.465445] systemd[1]: Queued start job for default target Graphical Interface.
  2718  [    5.467501] random: systemd: uninitialized urandom read (16 bytes read)
  2719  [    5.501798] systemd[1]: Created slice Slice /system/modprobe.
  2720  [    5.502609] random: systemd: uninitialized urandom read (16 bytes read)
  2721  [    5.505674] systemd[1]: Created slice Slice /system/serial-getty.
  2722  [    5.506158] random: systemd: uninitialized urandom read (16 bytes read)
  2723  [    5.508498] systemd[1]: Created slice User and Session Slice.
  2724  [    5.508980] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped.
  2725  [    5.509557] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
  2726  [    5.511026] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
  2727  [    5.511589] systemd[1]: Reached target Local Encrypted Volumes.
  2728  [    5.512336] systemd[1]: Reached target Slice Units.
  2729  [    5.512688] systemd[1]: Reached target Swaps.
  2730  [    5.512992] systemd[1]: Reached target System Time Set.
  2731  [    5.513493] systemd[1]: Reached target Local Verity Protected Volumes.
  2732  [    5.535773] systemd[1]: Listening on RPCbind Server Activation Socket.
  2733  [    5.537986] systemd[1]: Listening on Syslog Socket.
  2734  [    5.539145] systemd[1]: Listening on fsck to fsckd communication Socket.
  2735  [    5.539789] systemd[1]: Listening on initctl Compatibility Named Pipe.
  2736  [    5.541438] systemd[1]: Listening on Journal Audit Socket.
  2737  [    5.542435] systemd[1]: Listening on Journal Socket (/dev/log).
  2738  [    5.543551] systemd[1]: Listening on Journal Socket.
  2739  [    5.544909] systemd[1]: Listening on udev Control Socket.
  2740  [    5.545983] systemd[1]: Listening on udev Kernel Socket.
  2741  [    5.551869] systemd[1]: Mounting Huge Pages File System...
  2742  [    5.558599] systemd[1]: Mounting POSIX Message Queue File System...
  2743  [    5.564562] systemd[1]: Mounting NFSD configuration filesystem...
  2744  [    5.571494] systemd[1]: Mounting Kernel Debug File System...
  2745  [    5.572681] systemd[1]: Condition check resulted in Kernel Trace File System being skipped.
  2746  [    5.573820] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
  2747  [    5.582872] systemd[1]: Starting Restore / save the current clock...
  2748  [    5.591281] systemd[1]: Starting Set the console keyboard layout...
  2749  [    5.591942] systemd[1]: Condition check resulted in Create List of Static Device Nodes being skipped.
  2750  [    5.598892] systemd[1]: Starting Load Kernel Module chromeos_pstore...
  2751  [    5.606654] systemd[1]: Starting Load Kernel Module configfs...
  2752  [    5.614350] systemd[1]: Starting Load Kernel Module drm...
  2753  [    5.623111] systemd[1]: Starting Load Kernel Module efi_pstore...
  2754  [    5.631419] systemd[1]: Starting Load Kernel Module fuse...
  2755  [    5.639431] systemd[1]: Starting Load Kernel Module pstore_blk...
  2756  [    5.647085] systemd[1]: Starting Load Kernel Module pstore_zone...
  2757  [    5.654915] systemd[1]: Starting Load Kernel Module ramoops...
  2758  [    5.663254] systemd[1]: Started Nameserver information manager.
  2759  [    5.664770] systemd[1]: Reached target Preparation for Network.
  2760  [    5.666087] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
  2761  [    5.679719] systemd[1]: Starting Load Kernel Modules...
  2762  [    5.687988] systemd[1]: Starting Remount Root and Kernel File Systems...
  2763  [    5.696136] systemd[1]: Starting Coldplug All udev Devices...
  2764  [    5.711434] systemd[1]: Mounted Huge Pages File System.
  2765  [    5.712532] systemd[1]: Mounted POSIX Message Queue File System.
  2766  [    5.713822] systemd[1]: proc-fs-nfsd.mount: Mount process exited, code=exited, status=32/n/a
  2767  [    5.713874] systemd[1]: proc-fs-nfsd.mount: Failed with result 'exit-code'.
  2768  [    5.715963] systemd[1]: Failed to mount NFSD configuration filesystem.
  2769  [    5.716336] systemd[1]: Dependency failed for NFS Mount Daemon.
  2770  [    5.716464] systemd[1]: Dependency failed for NFS server and services.
  2771  [    5.716594] systemd[1]: Dependency failed for NFSv4 ID-name mapping service.
  2772  [    5.716733] systemd[1]: nfs-idmapd.service: Job nfs-idmapd.service/start failed with result 'dependency'.
  2773  [    5.716799] systemd[1]: nfs-server.service: Job nfs-server.service/start failed with result 'dependency'.
  2774  [    5.716861] systemd[1]: nfs-mountd.service: Job nfs-mountd.service/start failed with result 'dependency'.
  2775  [    5.716894] systemd[1]: Dependency failed for NFSv4 Client Tracking Daemon.
  2776  [    5.717037] systemd[1]: nfsdcld.service: Job nfsdcld.service/start failed with result 'dependency'.
  2777  [    5.718124] systemd[1]: Mounted Kernel Debug File System.
  2778  [    5.720789] systemd[1]: Finished Restore / save the current clock.
  2779  [    5.723322] systemd[1]: modprobe@chromeos_pstore.service: Deactivated successfully.
  2780  [    5.724584] systemd[1]: Finished Load Kernel Module chromeos_pstore.
  2781  [    5.726949] systemd[1]: modprobe@configfs.service: Deactivated successfully.
  2782  [    5.728465] systemd[1]: Finished Load Kernel Module configfs.
  2783  [    5.730739] systemd[1]: modprobe@drm.service: Deactivated successfully.
  2784  [    5.732189] systemd[1]: Finished Load Kernel Module drm.
  2785  [    5.734356] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
  2786  [    5.735248] EXT4-fs (sda1): re-mounted. Opts: commit=600,errors=remount-ro. Quota mode: none.
  2787  [    5.735950] systemd[1]: Finished Load Kernel Module efi_pstore.
  2788  [    5.743452] systemd[1]: modprobe@fuse.service: Deactivated successfully.
  2789  [    5.744772] systemd[1]: Finished Load Kernel Module fuse.
  2790  [    5.748151] systemd[1]: modprobe@pstore_blk.service: Deactivated successfully.
  2791  [    5.749943] systemd[1]: Finished Load Kernel Module pstore_blk.
  2792  [    5.752231] systemd[1]: modprobe@pstore_zone.service: Deactivated successfully.
  2793  [    5.754200] systemd[1]: Finished Load Kernel Module pstore_zone.
  2794  [    5.756520] systemd[1]: modprobe@ramoops.service: Deactivated successfully.
  2795  [    5.758095] systemd[1]: Finished Load Kernel Module ramoops.
  2796  [    5.763450] systemd[1]: Finished Load Kernel Modules.
  2797  [    5.766370] systemd[1]: Finished Remount Root and Kernel File Systems.
  2798  [    5.768589] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
  2799  [    5.774330] systemd[1]: Mounting Kernel Configuration File System...
  2800  [    5.775200] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
  2801  [    5.783620] systemd[1]: Starting Load/Save Random Seed...
  2802  [    5.791612] systemd[1]: Starting Apply Kernel Variables...
  2803  [    5.799215] systemd[1]: Starting Create System Users...
  2804  [    5.813047] systemd[1]: Mounted Kernel Configuration File System.
  2805  [    5.871513] systemd[1]: Finished Apply Kernel Variables.
  2806  [    5.900148] systemd[1]: Finished Create System Users.
  2807  [    5.909830] systemd[1]: Starting Create Static Device Nodes in /dev...
  2808  [    5.963331] systemd[1]: Finished Create Static Device Nodes in /dev.
  2809  [    6.004820] systemd[1]: Starting Rule-based Manager for Device Events and Files...
  2810  [    6.008640] systemd[1]: Finished Set the console keyboard layout.
  2811  [    6.010136] systemd[1]: Reached target Preparation for Local File Systems.
  2812  [    6.017941] systemd[1]: Mounting /tmp...
  2813  [    6.030336] systemd[1]: Mounted /tmp.
  2814  [    6.031404] systemd[1]: Reached target Local File Systems.
  2815  [    6.040860] systemd[1]: Starting Armbian leds state...
  2816  [    6.050947] systemd[1]: Starting Armbian ZRAM config...
  2817  [    6.062549] systemd[1]: Starting Set console font and keymap...
  2818  [    6.063435] systemd[1]: Condition check resulted in RPC security service for NFS server being skipped.
  2819  [    6.063757] systemd[1]: Condition check resulted in Mark the need to relabel after reboot being skipped.
  2820  [    6.068190] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
  2821  [    6.087450] systemd[1]: Finished Set console font and keymap.
  2822  [    6.134144] systemd[1]: armbian-led-state.service: Main process exited, code=exited, status=1/FAILURE
  2823  [    6.135531] systemd[1]: armbian-led-state.service: Failed with result 'exit-code'.
  2824  [    6.137662] systemd[1]: Failed to start Armbian leds state.
  2825  [    6.243271] systemd[1]: Finished Coldplug All udev Devices.
  2826  [    6.268275] systemd[1]: Starting Helper to synchronize boot up for ifupdown...
  2827  [    6.321451] systemd[1]: Started Rule-based Manager for Device Events and Files.
  2828  [    6.399318] systemd[1]: armbian-zram-config.service: Main process exited, code=exited, status=1/FAILURE
  2829  [    6.400319] systemd[1]: armbian-zram-config.service: Failed with result 'exit-code'.
  2830  [    6.402585] systemd[1]: Failed to start Armbian ZRAM config.
  2831  [    6.436958] systemd[1]: Starting Armbian memory supported logging...
  2832  [    6.525925] urandom_read_iter: 51 callbacks suppressed
  2833  [    6.525957] random: systemd: uninitialized urandom read (16 bytes read)
  2834  [    6.619367] random: systemd: uninitialized urandom read (16 bytes read)
  2835  [    6.619524] random: systemd: uninitialized urandom read (16 bytes read)
  2836  [    6.767198] random: crng init done
  2837  [    6.767233] random: 8 urandom warning(s) missed due to ratelimiting
  2838  [    6.798682] systemd[1]: Finished Load/Save Random Seed.
  2839  [    6.800108] systemd[1]: Condition check resulted in First Boot Complete being skipped.
  2840  [    6.800301] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
  2841  [    6.800484] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
  2842  [    6.820307] systemd[1]: Found device /dev/ttyS0.
  2843  [    7.415765] systemd[1]: Found device /sys/subsystem/net/devices/eth0.
  2844  [    7.451135] systemd[1]: Started ifup for eth0.
  2845  [    7.455837] systemd[1]: Finished Helper to synchronize boot up for ifupdown.
  2846  [    7.464084] systemd[1]: Starting Raise network interfaces...
  2847  [    7.467871] systemd[1]: ifup@eth0.service: Main process exited, code=exited, status=1/FAILURE
  2848  [    7.468865] systemd[1]: ifup@eth0.service: Failed with result 'exit-code'.
  2849  [    7.971765] systemd[1]: networking.service: Main process exited, code=exited, status=1/FAILURE
  2850  [    7.972653] systemd[1]: networking.service: Failed with result 'exit-code'.
  2851  [    7.974369] systemd[1]: Failed to start Raise network interfaces.
  2852  [   10.475090] systemd[1]: Finished Armbian memory supported logging.
  2853  [   10.497465] systemd[1]: Starting Journal Service...
  2854  [   10.752630] systemd[1]: Started Journal Service.
  2855  [   10.802840] systemd-journald[584]: Received client request to flush runtime journal.
  2856
  2857  ### armbian-release:
  2858
  2859  # PLEASE DO NOT EDIT THIS FILE
  2860  BOARD=pine64
  2861  BOARD_NAME="Pine64"
  2862  BOARDFAMILY=sun50iw1
  2863  BUILD_REPOSITORY_URL=https://github.com/armbian/build
  2864  BUILD_REPOSITORY_COMMIT=84940abb
  2865  VERSION=22.11.1
  2866  LINUXFAMILY=sunxi64
  2867  ARCH=arm64
  2868  IMAGE_TYPE=stable
  2869  BOARD_TYPE=conf
  2870  INITRD_ARCH=arm64
  2871  KERNEL_IMAGE_TYPE=Image
  2872  BRANCH=current
  2873
  2874  ### boot environment:
  2875
  2876  verbosity=1
  2877  bootlogo=false
  2878  console=both
  2879  disp_mode=1920x1080p60
  2880  overlay_prefix=sunxi64
  2881  rootdev=UUID=1a07fccf-6922-49b1-ace2-e12d87fdb297
  2882  rootfstype=ext4
  2883  usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
  2884
  2885
  2886  ### lsusb:
  2887
  2888  Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  2889  Bus 002 Device 003: ID 046d:081b Logitech, Inc. Webcam C310
  2890  Bus 002 Device 002: ID 05e3:0610 Genesys Logic, Inc. Hub
  2891  Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  2892  Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  2893  Bus 001 Device 002: ID 1f75:0621 Innostor Technology Corporation IS621 SATA Storage Controller
  2894  Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  2895  Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  2896
  2897  ### lscpu:
  2898
  2899  Architecture:                    aarch64
  2900  CPU op-mode(s):                  32-bit, 64-bit
  2901  Byte Order:                      Little Endian
  2902  CPU(s):                          4
  2903  On-line CPU(s) list:             0-3
  2904  Vendor ID:                       ARM
  2905  Model name:                      Cortex-A53
  2906  Model:                           4
  2907  Thread(s) per core:              1
  2908  Core(s) per cluster:             4
  2909  Socket(s):                       -
  2910  Cluster(s):                      1
  2911  Stepping:                        r0p4
  2912  BogoMIPS:                        48.00
  2913  Flags:                           fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  2914  NUMA node(s):                    1
  2915  NUMA node0 CPU(s):               0-3
  2916  Vulnerability Itlb multihit:     Not affected
  2917  Vulnerability L1tf:              Not affected
  2918  Vulnerability Mds:               Not affected
  2919  Vulnerability Meltdown:          Not affected
  2920  Vulnerability Mmio stale data:   Not affected
  2921  Vulnerability Spec store bypass: Not affected
  2922  Vulnerability Spectre v1:        Mitigation; __user pointer sanitization
  2923  Vulnerability Spectre v2:        Not affected
  2924  Vulnerability Srbds:             Not affected
  2925  Vulnerability Tsx async abort:   Not affected
  2926
  2927  ### cpuinfo:
  2928
  2929  processor       : 0
  2930  BogoMIPS        : 48.00
  2931  Features        : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  2932  CPU implementer : 0x41
  2933  CPU architecture: 8
  2934  CPU variant     : 0x0
  2935  CPU part        : 0xd03
  2936  CPU revision    : 4
  2937
  2938  processor       : 1
  2939  BogoMIPS        : 48.00
  2940  Features        : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  2941  CPU implementer : 0x41
  2942  CPU architecture: 8
  2943  CPU variant     : 0x0
  2944  CPU part        : 0xd03
  2945  CPU revision    : 4
  2946
  2947  processor       : 2
  2948  BogoMIPS        : 48.00
  2949  Features        : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  2950  CPU implementer : 0x41
  2951  CPU architecture: 8
  2952  CPU variant     : 0x0
  2953  CPU part        : 0xd03
  2954  CPU revision    : 4
  2955
  2956  processor       : 3
  2957  BogoMIPS        : 48.00
  2958  Features        : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  2959  CPU implementer : 0x41
  2960  CPU architecture: 8
  2961  CPU variant     : 0x0
  2962  CPU part        : 0xd03
  2963  CPU revision    : 4
  2964
  2965
  2966  ### meminfo:
  2967
  2968  MemTotal:        2037276 kB
  2969  MemFree:         1885780 kB
  2970  MemAvailable:    1881352 kB
  2971  Buffers:           11772 kB
  2972  Cached:            54292 kB
  2973  SwapCached:            0 kB
  2974  Active:            27796 kB
  2975  Inactive:          60192 kB
  2976  Active(anon):        412 kB
  2977  Inactive(anon):    38068 kB
  2978  Active(file):      27384 kB
  2979  Inactive(file):    22124 kB
  2980  Unevictable:           0 kB
  2981  Mlocked:               0 kB
  2982  SwapTotal:             0 kB
  2983  SwapFree:              0 kB
  2984  Dirty:                16 kB
  2985  Writeback:             0 kB
  2986  AnonPages:         21732 kB
  2987  Mapped:            16396 kB
  2988  Shmem:             16552 kB
  2989  KReclaimable:       9212 kB
  2990  Slab:              31852 kB
  2991  SReclaimable:       9212 kB
  2992  SUnreclaim:        22640 kB
  2993  KernelStack:        2384 kB
  2994  PageTables:         2032 kB
  2995  NFS_Unstable:          0 kB
  2996  Bounce:                0 kB
  2997  WritebackTmp:          0 kB
  2998  CommitLimit:     1018636 kB
  2999  Committed_AS:      69264 kB
  3000  VmallocTotal:   133143592960 kB
  3001  VmallocUsed:       10324 kB
  3002  VmallocChunk:          0 kB
  3003  Percpu:             1072 kB
  3004  AnonHugePages:         0 kB
  3005  ShmemHugePages:        0 kB
  3006  ShmemPmdMapped:        0 kB
  3007  FileHugePages:         0 kB
  3008  FilePmdMapped:         0 kB
  3009  CmaTotal:         131072 kB
  3010  CmaFree:          130304 kB
  3011  HugePages_Total:       0
  3012  HugePages_Free:        0
  3013  HugePages_Rsvd:        0
  3014  HugePages_Surp:        0
  3015  Hugepagesize:       2048 kB
  3016  Hugetlb:               0 kB
  3017
  3018  ### virtual memory:
  3019
  3020  vm.admin_reserve_kbytes = 8192
  3021  vm.compaction_proactiveness = 20
  3022  vm.compact_unevictable_allowed = 1
  3023  vm.dirty_background_bytes = 0
  3024  vm.dirty_background_ratio = 10
  3025  vm.dirty_bytes = 0
  3026  vm.dirty_expire_centisecs = 3000
  3027  vm.dirty_ratio = 20
  3028  vm.dirtytime_expire_seconds = 43200
  3029  vm.dirty_writeback_centisecs = 500
  3030  vm.extfrag_threshold = 500
  3031  vm.hugetlb_shm_group = 0
  3032  vm.laptop_mode = 0
  3033  vm.legacy_va_layout = 0
  3034  vm.lowmem_reserve_ratio = 256   256     32      0
  3035  vm.max_map_count = 65530
  3036  vm.min_free_kbytes = 22528
  3037  vm.min_slab_ratio = 5
  3038  vm.min_unmapped_ratio = 1
  3039  vm.mmap_min_addr = 32768
  3040  vm.mmap_rnd_bits = 18
  3041  vm.mmap_rnd_compat_bits = 11
  3042  vm.nr_hugepages = 0
  3043  vm.nr_hugepages_mempolicy = 0
  3044  vm.nr_overcommit_hugepages = 0
  3045  vm.numa_stat = 1
  3046  vm.numa_zonelist_order = Node
  3047  vm.oom_dump_tasks = 1
  3048  vm.oom_kill_allocating_task = 0
  3049  vm.overcommit_kbytes = 0
  3050  vm.overcommit_memory = 0
  3051  vm.overcommit_ratio = 50
  3052  vm.page-cluster = 3
  3053  vm.page_lock_unfairness = 5
  3054  vm.panic_on_oom = 0
  3055  vm.percpu_pagelist_high_fraction = 0
  3056  vm.stat_interval = 1
  3057  vm.swappiness = 100
  3058  vm.user_reserve_kbytes = 63000
  3059  vm.vfs_cache_pressure = 100
  3060  vm.watermark_boost_factor = 15000
  3061  vm.watermark_scale_factor = 10
  3062  vm.zone_reclaim_mode = 0
  3063
  3064  ### ip addr:
  3065
  3066  1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
  3067      link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
  3068      inet XXX.XXX.0.1/8 scope host lo
  3069         valid_lft forever preferred_lft forever
  3070      inet6 ::1/128 scope host
  3071         valid_lft forever preferred_lft forever
  3072  2: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
  3073      link/ether 02:ba:85:77:17:e9 brd ff:ff:ff:ff:ff:ff
  3074
  3075  ### partitions:
  3076
  3077  major minor  #blocks  name
  3078
  3079   179        0   31260672 mmcblk0
  3080   179        1   30928896 mmcblk0p1
  3081     8        0  117220824 sda
  3082     8        1  117218304 sda1
  3083
  3084  ### df:
  3085
  3086  tmpfs           199M  3.1M  196M   2% /run
  3087  /dev/sda1       110G   29G   76G  28% /
  3088  tmpfs           995M     0  995M   0% /dev/shm
  3089  tmpfs           5.0M     0  5.0M   0% /run/lock
  3090  tmpfs           995M  4.0K  995M   1% /tmp
  3091
  3092  ### lsblk:
  3093
  3094  NAME        FSTYPE   SIZE MOUNTPOINT UUID
  3095  sda                111.8G
  3096  └─sda1      ext4   111.8G /          933d6d44-0352-46aa-8100-fd703056ae3d
  3097  mmcblk0             29.8G
  3098  └─mmcblk0p1 ext4    29.5G            1a07fccf-6922-49b1-ace2-e12d87fdb297
  3099
  3100  ### zramctl:
  3101
  3102
  3103
  3104  ### mtab:
  3105
  3106  /dev/sda1 / ext4 rw,noatime,errors=remount-ro,commit=600 0 0
  3107  /dev/sda1 /var/log.hdd ext4 rw,noatime,errors=remount-ro,commit=600 0 0
  3108
  3109  ### mmc0:0001 info:
  3110
  3111                 fwrev: 0x0
  3112                uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=EB1QT MODALIAS=mmc:block
  3113                   cid: 1b534d454231515430bc836120012941
  3114                   rca: 0x0001
  3115                   csd: 400e00325b590000ee7f7f800a404055
  3116                manfid: 0x00001b
  3117                   ocr: 0x00200000
  3118  preferred_erase_size: 4194304
  3119                  type: SD
  3120                 hwrev: 0x3
  3121                  date: 09/2018
  3122                   dsr: 0x404
  3123            erase_size: 512
  3124                 oemid: 0x534d
  3125                serial: 0xbc836120
  3126                   ssr: 0000000005000000040090000f051c00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
  3127                   scr: 02b5800200000000
  3128                  name: EB1QT
  3129
  3130  ### Boot system health:
  3131
  3132  Time      CPU n/a    load %cpu %sys %usr %nice %io %irq   CPU
  3133  22:41:39:   ---      0.15  55%  28%  20%   0%   5%   0% 38.6 °C
  3134  22:41:40:   ---      0.15  82%  13%  16%   1%  48%   2% 38.6 °C
  3135  22:41:40:   ---      0.78  85%  16%  29%   0%  37%   1% 35.3 °C
  3136  22:41:40:   ---      0.78  35%  11%   5%   0%  17%   0% 35.3 °C
  3137  22:41:41:   ---      0.78  37%   7%   0%   0%  29%   0% 33.3 °C
  3138
  3139  ### No more available zram devices ()
  3140
  3141  Fri Dec  9 11:10:51 PM CET 2022 | Pine64 | 22.11.1 | arm64 | aarch64 | 5.15.48-sunxi64
  3142
  3143  ### dmesg:
  3144
  3145  [    0.000961] pid_max: default: 32768 minimum: 301
  3146  [    0.001049] LSM: Security Framework initializing
  3147  [    0.001078] Yama: becoming mindful.
  3148  [    0.001175] AppArmor: AppArmor initialized
  3149  [    0.001289] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
  3150  [    0.001319] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
  3151  [    0.003382] rcu: Hierarchical SRCU implementation.
  3152  [    0.004911] smp: Bringing up secondary CPUs ...
  3153  [    0.006154] Detected VIPT I-cache on CPU1
  3154  [    0.006223] arch_timer: CPU1: Trapping CNTVCT access
  3155  [    0.006241] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
  3156  [    0.007053] Detected VIPT I-cache on CPU2
  3157  [    0.007088] arch_timer: CPU2: Trapping CNTVCT access
  3158  [    0.007099] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
  3159  [    0.007827] Detected VIPT I-cache on CPU3
  3160  [    0.007861] arch_timer: CPU3: Trapping CNTVCT access
  3161  [    0.007872] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
  3162  [    0.007963] smp: Brought up 1 node, 4 CPUs
  3163  [    0.007979] SMP: Total of 4 processors activated.
  3164  [    0.007987] CPU features: detected: 32-bit EL0 Support
  3165  [    0.007992] CPU features: detected: CRC32 instructions
  3166  [    0.022846] CPU: All CPU(s) started at EL2
  3167  [    0.022879] alternatives: patching kernel code
  3168  [    0.024705] devtmpfs: initialized
  3169  [    0.032765] Registered cp15_barrier emulation handler
  3170  [    0.032799] Registered setend emulation handler
  3171  [    0.032982] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
  3172  [    0.033006] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
  3173  [    0.038448] pinctrl core: initialized pinctrl subsystem
  3174  [    0.040128] NET: Registered PF_NETLINK/PF_ROUTE protocol family
  3175  [    0.041913] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
  3176  [    0.042090] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
  3177  [    0.042269] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
  3178  [    0.042378] audit: initializing netlink subsys (disabled)
  3179  [    0.042595] audit: type=2000 audit(0.040:1): state=initialized audit_enabled=0 res=1
  3180  [    0.043204] thermal_sys: Registered thermal governor 'fair_share'
  3181  [    0.043212] thermal_sys: Registered thermal governor 'bang_bang'
  3182  [    0.043217] thermal_sys: Registered thermal governor 'step_wise'
  3183  [    0.043223] thermal_sys: Registered thermal governor 'user_space'
  3184  [    0.043686] cpuidle: using governor menu
  3185  [    0.043945] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
  3186  [    0.044054] ASID allocator initialised with 65536 entries
  3187  [    0.044251] Serial: AMBA PL011 UART driver
  3188  [    0.060244] platform 1ee0000.hdmi: Fixing up cyclic dependency with 1c0d000.lcd-controller
  3189  [    0.061780] platform hdmi-connector: Fixing up cyclic dependency with 1ee0000.hdmi
  3190  [    0.069851] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
  3191  [    0.069875] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
  3192  [    0.069883] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
  3193  [    0.069891] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
  3194  [    0.072097] cryptd: max_cpu_qlen set to 1000
  3195  [    0.140256] raid6: neonx8   gen()  1461 MB/s
  3196  [    0.208322] raid6: neonx8   xor()  1092 MB/s
  3197  [    0.276417] raid6: neonx4   gen()  1494 MB/s
  3198  [    0.344484] raid6: neonx4   xor()  1081 MB/s
  3199  [    0.412569] raid6: neonx2   gen()  1411 MB/s
  3200  [    0.480652] raid6: neonx2   xor()   993 MB/s
  3201  [    0.548727] raid6: neonx1   gen()  1232 MB/s
  3202  [    0.616803] raid6: neonx1   xor()   848 MB/s
  3203  [    0.684883] raid6: int64x8  gen()  1013 MB/s
  3204  [    0.752964] raid6: int64x8  xor()   533 MB/s
  3205  [    0.821043] raid6: int64x4  gen()  1126 MB/s
  3206  [    0.889139] raid6: int64x4  xor()   573 MB/s
  3207  [    0.957232] raid6: int64x2  gen()   962 MB/s
  3208  [    1.025317] raid6: int64x2  xor()   507 MB/s
  3209  [    1.093386] raid6: int64x1  gen()   716 MB/s
  3210  [    1.161495] raid6: int64x1  xor()   373 MB/s
  3211  [    1.161502] raid6: using algorithm neonx4 gen() 1494 MB/s
  3212  [    1.161508] raid6: .... xor() 1081 MB/s, rmw enabled
  3213  [    1.161514] raid6: using neon recovery algorithm
  3214  [    1.162165] iommu: Default domain type: Translated
  3215  [    1.162175] iommu: DMA domain TLB invalidation policy: strict mode
  3216  [    1.162498] SCSI subsystem initialized
  3217  [    1.162723] usbcore: registered new interface driver usbfs
  3218  [    1.162773] usbcore: registered new interface driver hub
  3219  [    1.162808] usbcore: registered new device driver usb
  3220  [    1.163144] pps_core: LinuxPPS API ver. 1 registered
  3221  [    1.163151] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
  3222  [    1.163171] PTP clock support registered
  3223  [    1.163645] ARM FF-A: FFA_VERSION returned not supported
  3224  [    1.164038] Advanced Linux Sound Architecture Driver Initialized.
  3225  [    1.164811] NetLabel: Initializing
  3226  [    1.164818] NetLabel:  domain hash size = 128
  3227  [    1.164824] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
  3228  [    1.164901] NetLabel:  unlabeled traffic allowed by default
  3229  [    1.165402] clocksource: Switched to clocksource arch_sys_counter
  3230  [    1.165636] VFS: Disk quotas dquot_6.6.0
  3231  [    1.165701] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
  3232  [    1.166360] AppArmor: AppArmor Filesystem Enabled
  3233  [    1.173672] NET: Registered PF_INET protocol family
  3234  [    1.173960] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
  3235  [    1.175335] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
  3236  [    1.175380] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
  3237  [    1.175398] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
  3238  [    1.175557] TCP bind hash table entries: 16384 (order: 6, 262144 bytes, linear)
  3239  [    1.175880] TCP: Hash tables configured (established 16384 bind 16384)
  3240  [    1.176046] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
  3241  [    1.176116] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
  3242  [    1.176335] NET: Registered PF_UNIX/PF_LOCAL protocol family
  3243  [    1.176930] Trying to unpack rootfs image as initramfs...
  3244  [    1.191944] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
  3245  [    1.199141] Initialise system trusted keyrings
  3246  [    1.199227] Key type blacklist registered
  3247  [    1.199443] workingset: timestamp_bits=44 max_order=19 bucket_order=0
  3248  [    1.205913] zbud: loaded
  3249  [    1.207637] squashfs: version 4.0 (2009/01/31) Phillip Lougher
  3250  [    1.210199] integrity: Platform Keyring initialized
  3251  [    1.263942] xor: automatically using best checksumming function   32regs
  3252  [    1.263971] async_tx: api initialized (async)
  3253  [    1.264004] Key type asymmetric registered
  3254  [    1.264012] Asymmetric key parser 'x509' registered
  3255  [    1.264144] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
  3256  [    1.264322] io scheduler mq-deadline registered
  3257  [    1.264331] io scheduler kyber registered
  3258  [    1.264554] io scheduler bfq registered
  3259  [    1.268255] sun50i-a64-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver
  3260  [    1.278295] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
  3261  [    1.290093] loop: module loaded
  3262  [    1.292585] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
  3263  [    1.292620] ehci-platform: EHCI generic platform driver
  3264  [    1.292776] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
  3265  [    1.292791] ohci-platform: OHCI generic platform driver
  3266  [    1.293287] usbcore: registered new interface driver usb-storage
  3267  [    1.293879] mousedev: PS/2 mouse device common for all mice
  3268  [    1.294991] sun6i-rtc 1f00000.rtc: registered as rtc0
  3269  [    1.295032] sun6i-rtc 1f00000.rtc: setting system clock to 2022-12-09T22:10:41 UTC (1670623841)
  3270  [    1.295156] sun6i-rtc 1f00000.rtc: RTC enabled
  3271  [    1.295261] i2c_dev: i2c /dev entries driver
  3272  [    1.296072] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
  3273  [    1.298213] sun50i-a64-r-pinctrl 1f02c00.pinctrl: supply vcc-pl not found, using dummy regulator
  3274  [    1.298742] sdhci: Secure Digital Host Controller Interface driver
  3275  [    1.298751] sdhci: Copyright(c) Pierre Ossman
  3276  [    1.298780] Synopsys Designware Multimedia Card Interface Driver
  3277  [    1.299548] sdhci-pltfm: SDHCI platform and OF driver helper
  3278  [    1.300748] ledtrig-cpu: registered to indicate activity on CPUs
  3279  [    1.301272] SMCCC: SOC_ID: ID = jep106:091e:1689 Revision = 0x00000001
  3280  [    1.301628] sun8i-ce 1c15000.crypto: Set mod clock to 300000000 (300 Mhz) from 24000000 (24 Mhz)
  3281  [    1.301942] sun8i-ce 1c15000.crypto: will run requests pump with realtime priority
  3282  [    1.302096] sun8i-ce 1c15000.crypto: will run requests pump with realtime priority
  3283  [    1.302212] sun8i-ce 1c15000.crypto: will run requests pump with realtime priority
  3284  [    1.302331] sun8i-ce 1c15000.crypto: will run requests pump with realtime priority
  3285  [    1.302430] sun8i-ce 1c15000.crypto: Register cbc(aes)
  3286  [    1.302622] sun8i-ce 1c15000.crypto: Register ecb(aes)
  3287  [    1.302765] sun8i-ce 1c15000.crypto: Register cbc(des3_ede)
  3288  [    1.302903] sun8i-ce 1c15000.crypto: Register ecb(des3_ede)
  3289  [    1.303035] sun8i-ce 1c15000.crypto: Register md5
  3290  [    1.303181] sun8i-ce 1c15000.crypto: Register sha1
  3291  [    1.303312] sun8i-ce 1c15000.crypto: Register sha224
  3292  [    1.303450] sun8i-ce 1c15000.crypto: Register sha256
  3293  [    1.303582] sun8i-ce 1c15000.crypto: DEBUG: Algo of sha384 not supported
  3294  [    1.303592] sun8i-ce 1c15000.crypto: DEBUG: Algo of sha512 not supported
  3295  [    1.303601] sun8i-ce 1c15000.crypto: Register stdrng
  3296  [    1.303762] sun8i-ce 1c15000.crypto: TRNG not supported
  3297  [    1.303772] sun8i-ce 1c15000.crypto: CryptoEngine Die ID 0
  3298  [    1.304346] hid: raw HID events driver (C) Jiri Kosina
  3299  [    1.304506] usbcore: registered new interface driver usbhid
  3300  [    1.304515] usbhid: USB HID core driver
  3301  [    1.310770] NET: Registered PF_INET6 protocol family
  3302  [    1.956025] Freeing initrd memory: 12684K
  3303  [    1.989310] Segment Routing with IPv6
  3304  [    1.989432] In-situ OAM (IOAM) with IPv6
  3305  [    1.989537] NET: Registered PF_PACKET protocol family
  3306  [    1.989671] 8021q: 802.1Q VLAN Support v1.8
  3307  [    1.989840] 9pnet: Installing 9P2000 support
  3308  [    1.989930] Key type dns_resolver registered
  3309  [    1.990452] registered taskstats version 1
  3310  [    1.990470] Loading compiled-in X.509 certificates
  3311  [    1.994776] Loaded X.509 cert 'Build time autogenerated kernel key: 32330adefd2da02e444296fafd37464380789679'
  3312  [    1.999127] zswap: loaded using pool zstd/z3fold
  3313  [    1.999894] Key type ._fscrypt registered
  3314  [    1.999903] Key type .fscrypt registered
  3315  [    1.999908] Key type fscrypt-provisioning registered
  3316  [    2.001080] Btrfs loaded, crc32c=crc32c-generic, zoned=yes, fsverity=no
  3317  [    2.017042] Key type encrypted registered
  3318  [    2.017078] AppArmor: AppArmor sha1 policy hashing enabled
  3319  [    2.017123] ima: No TPM chip found, activating TPM-bypass!
  3320  [    2.017162] ima: Allocated hash algorithm: sha1
  3321  [    2.017199] ima: No architecture policies found
  3322  [    2.017253] evm: Initialising EVM extended attributes:
  3323  [    2.017258] evm: security.selinux
  3324  [    2.017263] evm: security.SMACK64
  3325  [    2.017268] evm: security.SMACK64EXEC
  3326  [    2.017272] evm: security.SMACK64TRANSMUTE
  3327  [    2.017277] evm: security.SMACK64MMAP
  3328  [    2.017281] evm: security.apparmor
  3329  [    2.017286] evm: security.ima
  3330  [    2.017290] evm: security.capability
  3331  [    2.017295] evm: HMAC attrs: 0x1
  3332  [    2.030161] platform 1100000.mixer: Fixing up cyclic dependency with 1c0d000.lcd-controller
  3333  [    2.030249] platform 1100000.mixer: Fixing up cyclic dependency with 1c0c000.lcd-controller
  3334  [    2.031020] platform 1200000.mixer: Fixing up cyclic dependency with 1c0d000.lcd-controller
  3335  [    2.031108] platform 1200000.mixer: Fixing up cyclic dependency with 1c0c000.lcd-controller
  3336  [    2.031972] sunxi-rsb 1f03400.rsb: RSB running at 3000000 Hz
  3337  [    2.032376] axp20x-rsb sunxi-rsb-3a3: AXP20x variant AXP803 found
  3338  [    2.034453] input: axp20x-pek as /devices/platform/soc/1f03400.rsb/sunxi-rsb-3a3/axp221-pek/input/input0
  3339  [    2.037470] vcc-3v3: supplied by regulator-dummy
  3340  [    2.037986] vdd-cpux: supplied by regulator-dummy
  3341  [    2.038636] dcdc4: supplied by regulator-dummy
  3342  [    2.038825] vcc-dram: supplied by regulator-dummy
  3343  [    2.039282] vdd-sys: supplied by regulator-dummy
  3344  [    2.039806] vcc-phy: supplied by regulator-dummy
  3345  [    2.040176] aldo1: supplied by regulator-dummy
  3346  [    2.040354] vcc-pl: supplied by regulator-dummy
  3347  [    2.040794] vcc-pll-avcc: supplied by regulator-dummy
  3348  [    2.041439] vcc-hdmi: supplied by regulator-dummy
  3349  [    2.041809] vcc-mipi: supplied by regulator-dummy
  3350  [    2.042175] dldo3: supplied by regulator-dummy
  3351  [    2.042558] vcc-wifi: supplied by regulator-dummy
  3352  [    2.042930] cpvdd: supplied by regulator-dummy
  3353  [    2.043293] eldo2: supplied by regulator-dummy
  3354  [    2.043682] eldo3: supplied by regulator-dummy
  3355  [    2.044050] vcc-1v2-hsic: supplied by regulator-dummy
  3356  [    2.044245] vdd-cpus: supplied by regulator-dummy
  3357  [    2.044680] vcc-rtc: supplied by regulator-dummy
  3358  [    2.045100] ldo-io0: supplied by regulator-dummy
  3359  [    2.045541] ldo-io1: supplied by regulator-dummy
  3360  [    2.045666] axp20x-rsb sunxi-rsb-3a3: AXP20X driver loaded
  3361  [    2.050601] sun50i-a64-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
  3362  [    2.051007] sun50i-a64-pinctrl 1c20800.pinctrl: supply vcc-pb not found, using dummy regulator
  3363  [    2.051577] printk: console [ttyS0] disabled
  3364  [    2.051665] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 41, base_baud = 1500000) is a 16550A
  3365  [    2.051872] printk: console [ttyS0] enabled
  3366  [    2.052561] sun50i-a64-pinctrl 1c20800.pinctrl: supply vcc-pg not found, using dummy regulator
  3367  [    2.053041] 1c28400.serial: ttyS1 at MMIO 0x1c28400 (irq = 42, base_baud = 1500000) is a 16550A
  3368  [    2.053190] serial serial0: tty port ttyS1 registered
  3369  [    2.083829] sun4i-drm display-engine: bound 1100000.mixer (ops 0xffff800008e16990)
  3370  [    2.085658] sun4i-drm display-engine: bound 1200000.mixer (ops 0xffff800008e16990)
  3371  [    2.086184] sun4i-drm display-engine: No panel or bridge found... RGB output disabled
  3372  [    2.086203] sun4i-drm display-engine: bound 1c0c000.lcd-controller (ops 0xffff800008e11ba0)
  3373  [    2.086439] sun4i-drm display-engine: bound 1c0d000.lcd-controller (ops 0xffff800008e11ba0)
  3374  [    2.087576] sun8i-dw-hdmi 1ee0000.hdmi: Detected HDMI TX controller v1.32a with HDCP (sun8i_dw_hdmi_phy)
  3375  [    2.088225] sun8i-dw-hdmi 1ee0000.hdmi: registered DesignWare HDMI I2C bus driver
  3376  [    2.088595] sun4i-drm display-engine: bound 1ee0000.hdmi (ops 0xffff800008e15cc8)
  3377  [    2.089281] [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on minor 0
  3378  [    2.089363] sun4i-drm display-engine: [drm] Cannot find any crtc or sizes
  3379  [    2.090107] sun50i-a64-pinctrl 1c20800.pinctrl: supply vcc-pc not found, using dummy regulator
  3380  [    2.090746] sun4i-drm display-engine: [drm] Cannot find any crtc or sizes
  3381  [    2.091506] ehci-platform 1c1a000.usb: EHCI Host Controller
  3382  [    2.091537] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
  3383  [    2.091683] ehci-platform 1c1a000.usb: irq 28, io mem 0x01c1a000
  3384  [    2.105401] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
  3385  [    2.105770] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
  3386  [    2.105785] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  3387  [    2.105797] usb usb1: Product: EHCI Host Controller
  3388  [    2.105806] usb usb1: Manufacturer: Linux 5.15.48-sunxi64 ehci_hcd
  3389  [    2.105815] usb usb1: SerialNumber: 1c1a000.usb
  3390  [    2.106366] hub 1-0:1.0: USB hub found
  3391  [    2.106416] hub 1-0:1.0: 1 port detected
  3392  [    2.107429] ehci-platform 1c1b000.usb: EHCI Host Controller
  3393  [    2.107462] ehci-platform 1c1b000.usb: new USB bus registered, assigned bus number 2
  3394  [    2.107597] ehci-platform 1c1b000.usb: irq 30, io mem 0x01c1b000
  3395  [    2.121411] ehci-platform 1c1b000.usb: USB 2.0 started, EHCI 1.00
  3396  [    2.121744] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
  3397  [    2.121759] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  3398  [    2.121771] usb usb2: Product: EHCI Host Controller
  3399  [    2.121780] usb usb2: Manufacturer: Linux 5.15.48-sunxi64 ehci_hcd
  3400  [    2.121790] usb usb2: SerialNumber: 1c1b000.usb
  3401  [    2.122275] hub 2-0:1.0: USB hub found
  3402  [    2.122323] hub 2-0:1.0: 1 port detected
  3403  [    2.297505] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
  3404  [    2.297539] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 3
  3405  [    2.297677] ohci-platform 1c1a400.usb: irq 29, io mem 0x01c1a400
  3406  [    2.365448] usb 1-1: new high-speed USB device number 2 using ehci-platform
  3407  [    2.365749] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.15
  3408  [    2.365766] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  3409  [    2.365777] usb usb3: Product: Generic Platform OHCI controller
  3410  [    2.365787] usb usb3: Manufacturer: Linux 5.15.48-sunxi64 ohci_hcd
  3411  [    2.365797] usb usb3: SerialNumber: 1c1a400.usb
  3412  [    2.366312] hub 3-0:1.0: USB hub found
  3413  [    2.366362] hub 3-0:1.0: 1 port detected
  3414  [    2.367363] ohci-platform 1c1b400.usb: Generic Platform OHCI controller
  3415  [    2.367395] ohci-platform 1c1b400.usb: new USB bus registered, assigned bus number 4
  3416  [    2.367525] ohci-platform 1c1b400.usb: irq 31, io mem 0x01c1b400
  3417  [    2.377409] usb 2-1: new high-speed USB device number 2 using ehci-platform
  3418  [    2.433753] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.15
  3419  [    2.433768] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  3420  [    2.433780] usb usb4: Product: Generic Platform OHCI controller
  3421  [    2.433790] usb usb4: Manufacturer: Linux 5.15.48-sunxi64 ohci_hcd
  3422  [    2.433799] usb usb4: SerialNumber: 1c1b400.usb
  3423  [    2.434305] hub 4-0:1.0: USB hub found
  3424  [    2.434351] hub 4-0:1.0: 1 port detected
  3425  [    2.435414] usb_phy_generic usb_phy_generic.3.auto: supply vcc not found, using dummy regulator
  3426  [    2.435571] usb_phy_generic usb_phy_generic.3.auto: dummy supplies not allowed for exclusive requests
  3427  [    2.505675] musb-hdrc musb-hdrc.4.auto: MUSB HDRC host driver
  3428  [    2.505706] musb-hdrc musb-hdrc.4.auto: new USB bus registered, assigned bus number 5
  3429  [    2.505975] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
  3430  [    2.505990] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  3431  [    2.506002] usb usb5: Product: MUSB HDRC host driver
  3432  [    2.506011] usb usb5: Manufacturer: Linux 5.15.48-sunxi64 musb-hcd
  3433  [    2.506020] usb usb5: SerialNumber: musb-hdrc.4.auto
  3434  [    2.506564] hub 5-0:1.0: USB hub found
  3435  [    2.506619] hub 5-0:1.0: 1 port detected
  3436  [    2.510044] sun50i-a64-pinctrl 1c20800.pinctrl: supply vcc-pf not found, using dummy regulator
  3437  [    2.510109] scpi_protocol scpi: SCP Protocol 0.0 Firmware 0.0.0 version
  3438  [    2.511217] sunxi-mmc 1c10000.mmc: allocated mmc-pwrseq
  3439  [    2.511235] sunxi-mmc 1c0f000.mmc: Got CD GPIO
  3440  [    2.511391] of_cfs_init
  3441  [    2.511556] of_cfs_init: OK
  3442  [    2.511949] ALSA device list:
  3443  [    2.511956]   No soundcards found.
  3444  [    2.527356] usb 1-1: New USB device found, idVendor=1f75, idProduct=0621, bcdDevice= 0.36
  3445  [    2.527374] usb 1-1: New USB device strings: Mfr=4, Product=5, SerialNumber=6
  3446  [    2.527386] usb 1-1: SerialNumber: 20181120
  3447  [    2.528351] usb-storage 1-1:1.0: USB Mass Storage device detected
  3448  [    2.528902] scsi host0: usb-storage 1-1:1.0
  3449  [    2.534454] sunxi-mmc 1c10000.mmc: initialized, max. request size: 16384 KB, uses new timings mode
  3450  [    2.536517] usb 2-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice= 6.54
  3451  [    2.536533] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
  3452  [    2.536545] usb 2-1: Product: USB2.1 Hub
  3453  [    2.536554] usb 2-1: Manufacturer: GenesysLogic
  3454  [    2.536659] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB, uses new timings mode
  3455  [    2.537474] hub 2-1:1.0: USB hub found
  3456  [    2.537902] hub 2-1:1.0: 4 ports detected
  3457  [    2.538633] Freeing unused kernel memory: 2496K
  3458  [    2.538772] Run /init as init process
  3459  [    2.538780]   with arguments:
  3460  [    2.538787]     /init
  3461  [    2.538792]   with environment:
  3462  [    2.538797]     HOME=/
  3463  [    2.538803]     TERM=linux
  3464  [    2.538808]     ubootpart=ea5e158f-01
  3465  [    2.538814]     cgroup_enable=memory
  3466  [    2.573473] mmc0: new high speed SDHC card at address 0001
  3467  [    2.574613] mmcblk0: mmc0:0001 EB1QT 29.8 GiB
  3468  [    2.577205]  mmcblk0: p1
  3469  [    2.853441] usb 2-1.1: new high-speed USB device number 3 using ehci-platform
  3470  [    3.035518] usbcore: registered new interface driver uas
  3471  [    3.053085] sun50i-a64-pinctrl 1c20800.pinctrl: supply vcc-ph not found, using dummy regulator
  3472  [    3.060429] sun50i-a64-pinctrl 1c20800.pinctrl: supply vcc-pd not found, using dummy regulator
  3473  [    3.060745] dwmac-sun8i 1c30000.ethernet: IRQ eth_wake_irq not found
  3474  [    3.060759] dwmac-sun8i 1c30000.ethernet: IRQ eth_lpi not found
  3475  [    3.061055] dwmac-sun8i 1c30000.ethernet: supply phy-io not found, using dummy regulator
  3476  [    3.061330] dwmac-sun8i 1c30000.ethernet: PTP uses main clock
  3477  [    3.061373] dwmac-sun8i 1c30000.ethernet: Current syscon value is not the default 6 (expect 0)
  3478  [    3.062494] dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported
  3479  [    3.062526] dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported
  3480  [    3.062535] dwmac-sun8i 1c30000.ethernet: COE Type 2
  3481  [    3.062547] dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported
  3482  [    3.062556] dwmac-sun8i 1c30000.ethernet: Normal descriptors
  3483  [    3.062564] dwmac-sun8i 1c30000.ethernet: Chain mode enabled
  3484  [    3.087854] axp20x-gpio axp20x-gpio: DMA mask not set
  3485  [    3.095679] axp20x-gpio axp20x-gpio: AXP209 pinctrl and GPIO driver loaded
  3486  [    3.202316] usb 2-1.1: New USB device found, idVendor=046d, idProduct=081b, bcdDevice= 0.12
  3487  [    3.202351] usb 2-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=2
  3488  [    3.202363] usb 2-1.1: SerialNumber: AA5FCF90
  3489  [    3.562441] scsi 0:0:0:0: Direct-Access     OCZ-VERT EX2                   PQ: 0 ANSI: 6
  3490  [    3.563055] sd 0:0:0:0: Attached scsi generic sg0 type 0
  3491  [    3.563937] sd 0:0:0:0: [sda] 234441648 512-byte logical blocks: (120 GB/112 GiB)
  3492  [    3.565187] sd 0:0:0:0: [sda] Write Protect is off
  3493  [    3.565216] sd 0:0:0:0: [sda] Mode Sense: 3b 00 00 00
  3494  [    3.566698] sd 0:0:0:0: [sda] No Caching mode page found
  3495  [    3.566729] sd 0:0:0:0: [sda] Assuming drive cache: write through
  3496  [    3.572533]  sda: sda1
  3497  [    3.576019] sd 0:0:0:0: [sda] Attached SCSI disk
  3498  [    3.941793] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
  3499  [    4.534335] systemd[1]: systemd 249.11-0ubuntu3.6 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY -P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
  3500  [    4.535051] systemd[1]: Detected architecture arm64.
  3501  [    4.537814] systemd[1]: Hostname set to <pine64>.
  3502  [    4.647470] dw-apb-uart 1c28000.serial: forbid DMA for kernel console
  3503  [    5.519748] systemd[1]: Queued start job for default target Graphical Interface.
  3504  [    5.521821] random: systemd: uninitialized urandom read (16 bytes read)
  3505  [    5.561939] systemd[1]: Created slice Slice /system/modprobe.
  3506  [    5.562744] random: systemd: uninitialized urandom read (16 bytes read)
  3507  [    5.565808] systemd[1]: Created slice Slice /system/serial-getty.
  3508  [    5.566250] random: systemd: uninitialized urandom read (16 bytes read)
  3509  [    5.568563] systemd[1]: Created slice User and Session Slice.
  3510  [    5.569047] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped.
  3511  [    5.569631] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
  3512  [    5.571081] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
  3513  [    5.571652] systemd[1]: Reached target Local Encrypted Volumes.
  3514  [    5.572432] systemd[1]: Reached target Slice Units.
  3515  [    5.572777] systemd[1]: Reached target Swaps.
  3516  [    5.573074] systemd[1]: Reached target System Time Set.
  3517  [    5.573615] systemd[1]: Reached target Local Verity Protected Volumes.
  3518  [    5.595826] systemd[1]: Listening on RPCbind Server Activation Socket.
  3519  [    5.598000] systemd[1]: Listening on Syslog Socket.
  3520  [    5.599199] systemd[1]: Listening on fsck to fsckd communication Socket.
  3521  [    5.599868] systemd[1]: Listening on initctl Compatibility Named Pipe.
  3522  [    5.601548] systemd[1]: Listening on Journal Audit Socket.
  3523  [    5.602604] systemd[1]: Listening on Journal Socket (/dev/log).
  3524  [    5.603689] systemd[1]: Listening on Journal Socket.
  3525  [    5.605033] systemd[1]: Listening on udev Control Socket.
  3526  [    5.606101] systemd[1]: Listening on udev Kernel Socket.
  3527  [    5.612010] systemd[1]: Mounting Huge Pages File System...
  3528  [    5.618862] systemd[1]: Mounting POSIX Message Queue File System...
  3529  [    5.624862] systemd[1]: Mounting NFSD configuration filesystem...
  3530  [    5.631727] systemd[1]: Mounting Kernel Debug File System...
  3531  [    5.632872] systemd[1]: Condition check resulted in Kernel Trace File System being skipped.
  3532  [    5.633936] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
  3533  [    5.642680] systemd[1]: Starting Restore / save the current clock...
  3534  [    5.651075] systemd[1]: Starting Set the console keyboard layout...
  3535  [    5.651713] systemd[1]: Condition check resulted in Create List of Static Device Nodes being skipped.
  3536  [    5.658803] systemd[1]: Starting Load Kernel Module chromeos_pstore...
  3537  [    5.666580] systemd[1]: Starting Load Kernel Module configfs...
  3538  [    5.674433] systemd[1]: Starting Load Kernel Module drm...
  3539  [    5.683124] systemd[1]: Starting Load Kernel Module efi_pstore...
  3540  [    5.690801] systemd[1]: Starting Load Kernel Module fuse...
  3541  [    5.699057] systemd[1]: Starting Load Kernel Module pstore_blk...
  3542  [    5.707156] systemd[1]: Starting Load Kernel Module pstore_zone...
  3543  [    5.715305] systemd[1]: Starting Load Kernel Module ramoops...
  3544  [    5.723427] systemd[1]: Started Nameserver information manager.
  3545  [    5.725374] systemd[1]: Reached target Preparation for Network.
  3546  [    5.726945] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
  3547  [    5.740081] systemd[1]: Starting Load Kernel Modules...
  3548  [    5.748382] systemd[1]: Starting Remount Root and Kernel File Systems...
  3549  [    5.756653] systemd[1]: Starting Coldplug All udev Devices...
  3550  [    5.772040] systemd[1]: Mounted Huge Pages File System.
  3551  [    5.773571] systemd[1]: Mounted POSIX Message Queue File System.
  3552  [    5.774663] systemd[1]: proc-fs-nfsd.mount: Mount process exited, code=exited, status=32/n/a
  3553  [    5.774709] systemd[1]: proc-fs-nfsd.mount: Failed with result 'exit-code'.
  3554  [    5.776644] systemd[1]: Failed to mount NFSD configuration filesystem.
  3555  [    5.776986] systemd[1]: Dependency failed for NFS server and services.
  3556  [    5.777130] systemd[1]: Dependency failed for NFS Mount Daemon.
  3557  [    5.777289] systemd[1]: nfs-mountd.service: Job nfs-mountd.service/start failed with result 'dependency'.
  3558  [    5.777364] systemd[1]: Dependency failed for NFSv4 ID-name mapping service.
  3559  [    5.777707] systemd[1]: nfs-idmapd.service: Job nfs-idmapd.service/start failed with result 'dependency'.
  3560  [    5.777769] systemd[1]: nfs-server.service: Job nfs-server.service/start failed with result 'dependency'.
  3561  [    5.777815] systemd[1]: Dependency failed for NFSv4 Client Tracking Daemon.
  3562  [    5.777965] systemd[1]: nfsdcld.service: Job nfsdcld.service/start failed with result 'dependency'.
  3563  [    5.779146] systemd[1]: Mounted Kernel Debug File System.
  3564  [    5.782216] systemd[1]: Finished Restore / save the current clock.
  3565  [    5.784571] systemd[1]: modprobe@chromeos_pstore.service: Deactivated successfully.
  3566  [    5.786149] systemd[1]: Finished Load Kernel Module chromeos_pstore.
  3567  [    5.788554] systemd[1]: modprobe@configfs.service: Deactivated successfully.
  3568  [    5.790159] systemd[1]: Finished Load Kernel Module configfs.
  3569  [    5.792370] systemd[1]: modprobe@drm.service: Deactivated successfully.
  3570  [    5.793826] systemd[1]: Finished Load Kernel Module drm.
  3571  [    5.793936] EXT4-fs (sda1): re-mounted. Opts: commit=600,errors=remount-ro. Quota mode: none.
  3572  [    5.800680] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
  3573  [    5.802129] systemd[1]: Finished Load Kernel Module efi_pstore.
  3574  [    5.804313] systemd[1]: modprobe@fuse.service: Deactivated successfully.
  3575  [    5.805798] systemd[1]: Finished Load Kernel Module fuse.
  3576  [    5.807983] systemd[1]: modprobe@pstore_blk.service: Deactivated successfully.
  3577  [    5.809338] systemd[1]: Finished Load Kernel Module pstore_blk.
  3578  [    5.811537] systemd[1]: modprobe@pstore_zone.service: Deactivated successfully.
  3579  [    5.813044] systemd[1]: Finished Load Kernel Module pstore_zone.
  3580  [    5.815232] systemd[1]: modprobe@ramoops.service: Deactivated successfully.
  3581  [    5.816651] systemd[1]: Finished Load Kernel Module ramoops.
  3582  [    5.822188] systemd[1]: Finished Load Kernel Modules.
  3583  [    5.825012] systemd[1]: Finished Remount Root and Kernel File Systems.
  3584  [    5.828361] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
  3585  [    5.834192] systemd[1]: Mounting Kernel Configuration File System...
  3586  [    5.835047] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
  3587  [    5.841886] systemd[1]: Starting Load/Save Random Seed...
  3588  [    5.850972] systemd[1]: Starting Apply Kernel Variables...
  3589  [    5.862584] systemd[1]: Starting Create System Users...
  3590  [    5.881556] systemd[1]: Mounted Kernel Configuration File System.
  3591  [    5.953137] systemd[1]: Finished Apply Kernel Variables.
  3592  [    5.956492] systemd[1]: Finished Create System Users.
  3593  [    5.966766] systemd[1]: Starting Create Static Device Nodes in /dev...
  3594  [    6.019115] systemd[1]: Finished Create Static Device Nodes in /dev.
  3595  [    6.058919] systemd[1]: Starting Rule-based Manager for Device Events and Files...
  3596  [    6.062336] systemd[1]: Finished Set the console keyboard layout.
  3597  [    6.063631] systemd[1]: Reached target Preparation for Local File Systems.
  3598  [    6.073804] systemd[1]: Mounting /tmp...
  3599  [    6.086424] systemd[1]: Mounted /tmp.
  3600  [    6.087442] systemd[1]: Reached target Local File Systems.
  3601  [    6.094717] systemd[1]: Starting Armbian leds state...
  3602  [    6.103067] systemd[1]: Starting Armbian ZRAM config...
  3603  [    6.114026] systemd[1]: Starting Set console font and keymap...
  3604  [    6.114912] systemd[1]: Condition check resulted in RPC security service for NFS server being skipped.
  3605  [    6.115266] systemd[1]: Condition check resulted in Mark the need to relabel after reboot being skipped.
  3606  [    6.123357] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
  3607  [    6.142276] systemd[1]: Finished Set console font and keymap.
  3608  [    6.186192] systemd[1]: armbian-led-state.service: Main process exited, code=exited, status=1/FAILURE
  3609  [    6.187149] systemd[1]: armbian-led-state.service: Failed with result 'exit-code'.
  3610  [    6.188916] systemd[1]: Failed to start Armbian leds state.
  3611  [    6.295776] systemd[1]: Finished Coldplug All udev Devices.
  3612  [    6.324488] systemd[1]: Starting Helper to synchronize boot up for ifupdown...
  3613  [    6.355988] systemd[1]: Started Rule-based Manager for Device Events and Files.
  3614  [    6.444119] systemd[1]: armbian-zram-config.service: Main process exited, code=exited, status=1/FAILURE
  3615  [    6.445085] systemd[1]: armbian-zram-config.service: Failed with result 'exit-code'.
  3616  [    6.447079] systemd[1]: Failed to start Armbian ZRAM config.
  3617  [    6.487209] systemd[1]: Starting Armbian memory supported logging...
  3618  [    6.595495] urandom_read_iter: 51 callbacks suppressed
  3619  [    6.595525] random: systemd: uninitialized urandom read (16 bytes read)
  3620  [    6.686377] random: systemd: uninitialized urandom read (16 bytes read)
  3621  [    6.686491] random: systemd: uninitialized urandom read (16 bytes read)
  3622  [    6.793477] random: crng init done
  3623  [    6.793506] random: 8 urandom warning(s) missed due to ratelimiting
  3624  [    6.807282] systemd[1]: Finished Load/Save Random Seed.
  3625  [    6.809192] systemd[1]: Condition check resulted in First Boot Complete being skipped.
  3626  [    6.809622] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
  3627  [    6.809876] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
  3628  [    6.929530] systemd[1]: Found device /dev/ttyS0.
  3629  [    7.481698] systemd[1]: Found device /sys/subsystem/net/devices/eth0.
  3630  [    7.507475] systemd[1]: Started ifup for eth0.
  3631  [    7.513528] systemd[1]: Finished Helper to synchronize boot up for ifupdown.
  3632  [    7.522254] systemd[1]: Starting Raise network interfaces...
  3633  [    7.524346] systemd[1]: ifup@eth0.service: Main process exited, code=exited, status=1/FAILURE
  3634  [    7.525658] systemd[1]: ifup@eth0.service: Failed with result 'exit-code'.
  3635  [    8.061538] systemd[1]: networking.service: Main process exited, code=exited, status=1/FAILURE
  3636  [    8.062437] systemd[1]: networking.service: Failed with result 'exit-code'.
  3637  [    8.064099] systemd[1]: Failed to start Raise network interfaces.
  3638  [   10.623768] systemd[1]: Finished Armbian memory supported logging.
  3639  [   10.685675] systemd[1]: Starting Journal Service...
  3640  [   10.940110] systemd[1]: Started Journal Service.
  3641  [   10.996353] systemd-journald[586]: Received client request to flush runtime journal.
  3642
  3643  ### armbian-release:
  3644
  3645  # PLEASE DO NOT EDIT THIS FILE
  3646  BOARD=pine64
  3647  BOARD_NAME="Pine64"
  3648  BOARDFAMILY=sun50iw1
  3649  BUILD_REPOSITORY_URL=https://github.com/armbian/build
  3650  BUILD_REPOSITORY_COMMIT=84940abb
  3651  VERSION=22.11.1
  3652  LINUXFAMILY=sunxi64
  3653  ARCH=arm64
  3654  IMAGE_TYPE=stable
  3655  BOARD_TYPE=conf
  3656  INITRD_ARCH=arm64
  3657  KERNEL_IMAGE_TYPE=Image
  3658  BRANCH=current
  3659
  3660  ### boot environment:
  3661
  3662  verbosity=1
  3663  bootlogo=false
  3664  console=both
  3665  disp_mode=1920x1080p60
  3666  overlay_prefix=sun50i-a64
  3667  rootdev=UUID=1a07fccf-6922-49b1-ace2-e12d87fdb297
  3668  rootfstype=ext4
  3669  usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
  3670
  3671  ### lsusb:
  3672
  3673  Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  3674  Bus 002 Device 003: ID 046d:081b Logitech, Inc. Webcam C310
  3675  Bus 002 Device 002: ID 05e3:0610 Genesys Logic, Inc. Hub
  3676  Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  3677  Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  3678  Bus 001 Device 002: ID 1f75:0621 Innostor Technology Corporation IS621 SATA Storage Controller
  3679  Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  3680  Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  3681
  3682  ### lscpu:
  3683
  3684  Architecture:                    aarch64
  3685  CPU op-mode(s):                  32-bit, 64-bit
  3686  Byte Order:                      Little Endian
  3687  CPU(s):                          4
  3688  On-line CPU(s) list:             0-3
  3689  Vendor ID:                       ARM
  3690  Model name:                      Cortex-A53
  3691  Model:                           4
  3692  Thread(s) per core:              1
  3693  Core(s) per cluster:             4
  3694  Socket(s):                       -
  3695  Cluster(s):                      1
  3696  Stepping:                        r0p4
  3697  BogoMIPS:                        48.00
  3698  Flags:                           fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  3699  NUMA node(s):                    1
  3700  NUMA node0 CPU(s):               0-3
  3701  Vulnerability Itlb multihit:     Not affected
  3702  Vulnerability L1tf:              Not affected
  3703  Vulnerability Mds:               Not affected
  3704  Vulnerability Meltdown:          Not affected
  3705  Vulnerability Mmio stale data:   Not affected
  3706  Vulnerability Spec store bypass: Not affected
  3707  Vulnerability Spectre v1:        Mitigation; __user pointer sanitization
  3708  Vulnerability Spectre v2:        Not affected
  3709  Vulnerability Srbds:             Not affected
  3710  Vulnerability Tsx async abort:   Not affected
  3711
  3712  ### cpuinfo:
  3713
  3714  processor       : 0
  3715  BogoMIPS        : 48.00
  3716  Features        : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  3717  CPU implementer : 0x41
  3718  CPU architecture: 8
  3719  CPU variant     : 0x0
  3720  CPU part        : 0xd03
  3721  CPU revision    : 4
  3722
  3723  processor       : 1
  3724  BogoMIPS        : 48.00
  3725  Features        : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  3726  CPU implementer : 0x41
  3727  CPU architecture: 8
  3728  CPU variant     : 0x0
  3729  CPU part        : 0xd03
  3730  CPU revision    : 4
  3731
  3732  processor       : 2
  3733  BogoMIPS        : 48.00
  3734  Features        : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  3735  CPU implementer : 0x41
  3736  CPU architecture: 8
  3737  CPU variant     : 0x0
  3738  CPU part        : 0xd03
  3739  CPU revision    : 4
  3740
  3741  processor       : 3
  3742  BogoMIPS        : 48.00
  3743  Features        : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  3744  CPU implementer : 0x41
  3745  CPU architecture: 8
  3746  CPU variant     : 0x0
  3747  CPU part        : 0xd03
  3748  CPU revision    : 4
  3749
  3750
  3751  ### meminfo:
  3752
  3753  MemTotal:        2037276 kB
  3754  MemFree:         1889588 kB
  3755  MemAvailable:    1885804 kB
  3756  Buffers:           11664 kB
  3757  Cached:            56400 kB
  3758  SwapCached:            0 kB
  3759  Active:            27768 kB
  3760  Inactive:          55144 kB
  3761  Active(anon):        344 kB
  3762  Inactive(anon):    31716 kB
  3763  Active(file):      27424 kB
  3764  Inactive(file):    23428 kB
  3765  Unevictable:           0 kB
  3766  Mlocked:               0 kB
  3767  SwapTotal:             0 kB
  3768  SwapFree:              0 kB
  3769  Dirty:                16 kB
  3770  Writeback:             0 kB
  3771  AnonPages:         15624 kB
  3772  Mapped:            15984 kB
  3773  Shmem:             16716 kB
  3774  KReclaimable:       9160 kB
  3775  Slab:              31644 kB
  3776  SReclaimable:       9160 kB
  3777  SUnreclaim:        22484 kB
  3778  KernelStack:        2192 kB
  3779  PageTables:         1504 kB
  3780  NFS_Unstable:          0 kB
  3781  Bounce:                0 kB
  3782  WritebackTmp:          0 kB
  3783  CommitLimit:     1018636 kB
  3784  Committed_AS:      52328 kB
  3785  VmallocTotal:   133143592960 kB
  3786  VmallocUsed:       10116 kB
  3787  VmallocChunk:          0 kB
  3788  Percpu:             1072 kB
  3789  AnonHugePages:         0 kB
  3790  ShmemHugePages:        0 kB
  3791  ShmemPmdMapped:        0 kB
  3792  FileHugePages:         0 kB
  3793  FilePmdMapped:         0 kB
  3794  CmaTotal:         131072 kB
  3795  CmaFree:          130304 kB
  3796  HugePages_Total:       0
  3797  HugePages_Free:        0
  3798  HugePages_Rsvd:        0
  3799  HugePages_Surp:        0
  3800  Hugepagesize:       2048 kB
  3801  Hugetlb:               0 kB
  3802
  3803  ### virtual memory:
  3804
  3805  vm.admin_reserve_kbytes = 8192
  3806  vm.compaction_proactiveness = 20
  3807  vm.compact_unevictable_allowed = 1
  3808  vm.dirty_background_bytes = 0
  3809  vm.dirty_background_ratio = 10
  3810  vm.dirty_bytes = 0
  3811  vm.dirty_expire_centisecs = 3000
  3812  vm.dirty_ratio = 20
  3813  vm.dirtytime_expire_seconds = 43200
  3814  vm.dirty_writeback_centisecs = 500
  3815  vm.extfrag_threshold = 500
  3816  vm.hugetlb_shm_group = 0
  3817  vm.laptop_mode = 0
  3818  vm.legacy_va_layout = 0
  3819  vm.lowmem_reserve_ratio = 256   256     32      0
  3820  vm.max_map_count = 65530
  3821  vm.min_free_kbytes = 22528
  3822  vm.min_slab_ratio = 5
  3823  vm.min_unmapped_ratio = 1
  3824  vm.mmap_min_addr = 32768
  3825  vm.mmap_rnd_bits = 18
  3826  vm.mmap_rnd_compat_bits = 11
  3827  vm.nr_hugepages = 0
  3828  vm.nr_hugepages_mempolicy = 0
  3829  vm.nr_overcommit_hugepages = 0
  3830  vm.numa_stat = 1
  3831  vm.numa_zonelist_order = Node
  3832  vm.oom_dump_tasks = 1
  3833  vm.oom_kill_allocating_task = 0
  3834  vm.overcommit_kbytes = 0
  3835  vm.overcommit_memory = 0
  3836  vm.overcommit_ratio = 50
  3837  vm.page-cluster = 3
  3838  vm.page_lock_unfairness = 5
  3839  vm.panic_on_oom = 0
  3840  vm.percpu_pagelist_high_fraction = 0
  3841  vm.stat_interval = 1
  3842  vm.swappiness = 100
  3843  vm.user_reserve_kbytes = 63000
  3844  vm.vfs_cache_pressure = 100
  3845  vm.watermark_boost_factor = 15000
  3846  vm.watermark_scale_factor = 10
  3847  vm.zone_reclaim_mode = 0
  3848
  3849  ### ip addr:
  3850
  3851  1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
  3852      link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
  3853      inet XXX.XXX.0.1/8 scope host lo
  3854         valid_lft forever preferred_lft forever
  3855      inet6 ::1/128 scope host
  3856         valid_lft forever preferred_lft forever
  3857  2: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
  3858      link/ether 02:ba:85:77:17:e9 brd ff:ff:ff:ff:ff:ff
  3859
  3860  ### partitions:
  3861
  3862  major minor  #blocks  name
  3863
  3864   179        0   31260672 mmcblk0
  3865   179        1   30928896 mmcblk0p1
  3866     8        0  117220824 sda
  3867     8        1  117218304 sda1
  3868
  3869  ### df:
  3870
  3871  tmpfs           199M  3.1M  196M   2% /run
  3872  /dev/sda1       110G   29G   76G  28% /
  3873  tmpfs           995M     0  995M   0% /dev/shm
  3874  tmpfs           5.0M     0  5.0M   0% /run/lock
  3875  tmpfs           995M  4.0K  995M   1% /tmp
  3876
  3877  ### lsblk:
  3878
  3879  NAME        FSTYPE   SIZE MOUNTPOINT UUID
  3880  sda                111.8G
  3881  └─sda1      ext4   111.8G /          933d6d44-0352-46aa-8100-fd703056ae3d
  3882  mmcblk0             29.8G
  3883  └─mmcblk0p1 ext4    29.5G            1a07fccf-6922-49b1-ace2-e12d87fdb297
  3884
  3885  ### zramctl:
  3886
  3887
  3888
  3889  ### mtab:
  3890
  3891  /dev/sda1 / ext4 rw,noatime,errors=remount-ro,commit=600 0 0
  3892  /dev/sda1 /var/log.hdd ext4 rw,noatime,errors=remount-ro,commit=600 0 0
  3893
  3894  ### mmc0:0001 info:
  3895
  3896                 fwrev: 0x0
  3897                uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=EB1QT MODALIAS=mmc:block
  3898                   cid: 1b534d454231515430bc836120012941
  3899                   rca: 0x0001
  3900                   csd: 400e00325b590000ee7f7f800a404055
  3901                manfid: 0x00001b
  3902                   ocr: 0x00200000
  3903  preferred_erase_size: 4194304
  3904                  type: SD
  3905                 hwrev: 0x3
  3906                  date: 09/2018
  3907                   dsr: 0x404
  3908            erase_size: 512
  3909                 oemid: 0x534d
  3910                serial: 0xbc836120
  3911                   ssr: 0000000005000000040090000f051c00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
  3912                   scr: 02b5800200000000
  3913                  name: EB1QT
  3914
  3915  ### Boot system health:
  3916
  3917  Time      CPU n/a    load %cpu %sys %usr %nice %io %irq   CPU
  3918  23:10:54:   ---      0.30  54%  29%  20%   0%   4%   0% 38.8 °C
  3919  23:10:55:   ---      0.30  82%  13%  20%   0%  45%   2% 38.8 °C
  3920  23:10:55:   ---      0.84  82%  20%  23%   0%  37%   0% 37.2 °C
  3921  23:10:55:   ---      0.84  53%  10%  12%   0%  28%   2% 37.2 °C
  3922  23:10:56:   ---      0.84  23%   7%   2%   0%  11%   1% 35.0 °C
  3923
  3924  ### No more available zram devices ()
  3925
  3926  Sat Dec 10 05:37:11 PM CET 2022 | Pine64 | 22.11.1 | arm64 | aarch64 | 5.15.48-sunxi64
  3927
  3928  ### dmesg:
  3929
  3930  [    0.000968] pid_max: default: 32768 minimum: 301
  3931  [    0.001054] LSM: Security Framework initializing
  3932  [    0.001083] Yama: becoming mindful.
  3933  [    0.001180] AppArmor: AppArmor initialized
  3934  [    0.001293] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
  3935  [    0.001322] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
  3936  [    0.003389] rcu: Hierarchical SRCU implementation.
  3937  [    0.004901] smp: Bringing up secondary CPUs ...
  3938  [    0.006147] Detected VIPT I-cache on CPU1
  3939  [    0.006215] arch_timer: CPU1: Trapping CNTVCT access
  3940  [    0.006233] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
  3941  [    0.007043] Detected VIPT I-cache on CPU2
  3942  [    0.007078] arch_timer: CPU2: Trapping CNTVCT access
  3943  [    0.007089] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
  3944  [    0.007815] Detected VIPT I-cache on CPU3
  3945  [    0.007848] arch_timer: CPU3: Trapping CNTVCT access
  3946  [    0.007859] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
  3947  [    0.007961] smp: Brought up 1 node, 4 CPUs
  3948  [    0.007977] SMP: Total of 4 processors activated.
  3949  [    0.007984] CPU features: detected: 32-bit EL0 Support
  3950  [    0.007990] CPU features: detected: CRC32 instructions
  3951  [    0.022845] CPU: All CPU(s) started at EL2
  3952  [    0.022878] alternatives: patching kernel code
  3953  [    0.024694] devtmpfs: initialized
  3954  [    0.032744] Registered cp15_barrier emulation handler
  3955  [    0.032777] Registered setend emulation handler
  3956  [    0.032961] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
  3957  [    0.032985] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
  3958  [    0.038435] pinctrl core: initialized pinctrl subsystem
  3959  [    0.040112] NET: Registered PF_NETLINK/PF_ROUTE protocol family
  3960  [    0.041898] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
  3961  [    0.042075] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
  3962  [    0.042252] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
  3963  [    0.042363] audit: initializing netlink subsys (disabled)
  3964  [    0.042577] audit: type=2000 audit(0.040:1): state=initialized audit_enabled=0 res=1
  3965  [    0.043188] thermal_sys: Registered thermal governor 'fair_share'
  3966  [    0.043196] thermal_sys: Registered thermal governor 'bang_bang'
  3967  [    0.043202] thermal_sys: Registered thermal governor 'step_wise'
  3968  [    0.043207] thermal_sys: Registered thermal governor 'user_space'
  3969  [    0.043671] cpuidle: using governor menu
  3970  [    0.043930] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
  3971  [    0.044037] ASID allocator initialised with 65536 entries
  3972  [    0.044233] Serial: AMBA PL011 UART driver
  3973  [    0.060227] platform 1ee0000.hdmi: Fixing up cyclic dependency with 1c0d000.lcd-controller
  3974  [    0.061746] platform hdmi-connector: Fixing up cyclic dependency with 1ee0000.hdmi
  3975  [    0.069833] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
  3976  [    0.069856] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
  3977  [    0.069864] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
  3978  [    0.069872] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
  3979  [    0.072081] cryptd: max_cpu_qlen set to 1000
  3980  [    0.140238] raid6: neonx8   gen()  1457 MB/s
  3981  [    0.208316] raid6: neonx8   xor()  1091 MB/s
  3982  [    0.276404] raid6: neonx4   gen()  1494 MB/s
  3983  [    0.344481] raid6: neonx4   xor()  1082 MB/s
  3984  [    0.412557] raid6: neonx2   gen()  1412 MB/s
  3985  [    0.480637] raid6: neonx2   xor()   990 MB/s
  3986  [    0.548715] raid6: neonx1   gen()  1231 MB/s
  3987  [    0.616793] raid6: neonx1   xor()   848 MB/s
  3988  [    0.684884] raid6: int64x8  gen()  1014 MB/s
  3989  [    0.752954] raid6: int64x8  xor()   533 MB/s
  3990  [    0.821049] raid6: int64x4  gen()  1127 MB/s
  3991  [    0.889123] raid6: int64x4  xor()   572 MB/s
  3992  [    0.957211] raid6: int64x2  gen()   962 MB/s
  3993  [    1.025288] raid6: int64x2  xor()   509 MB/s
  3994  [    1.093390] raid6: int64x1  gen()   716 MB/s
  3995  [    1.161483] raid6: int64x1  xor()   373 MB/s
  3996  [    1.161490] raid6: using algorithm neonx4 gen() 1494 MB/s
  3997  [    1.161497] raid6: .... xor() 1082 MB/s, rmw enabled
  3998  [    1.161502] raid6: using neon recovery algorithm
  3999  [    1.162153] iommu: Default domain type: Translated
  4000  [    1.162162] iommu: DMA domain TLB invalidation policy: strict mode
  4001  [    1.162486] SCSI subsystem initialized
  4002  [    1.162711] usbcore: registered new interface driver usbfs
  4003  [    1.162762] usbcore: registered new interface driver hub
  4004  [    1.162799] usbcore: registered new device driver usb
  4005  [    1.163132] pps_core: LinuxPPS API ver. 1 registered
  4006  [    1.163140] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
  4007  [    1.163159] PTP clock support registered
  4008  [    1.163630] ARM FF-A: FFA_VERSION returned not supported
  4009  [    1.164022] Advanced Linux Sound Architecture Driver Initialized.
  4010  [    1.164800] NetLabel: Initializing
  4011  [    1.164806] NetLabel:  domain hash size = 128
  4012  [    1.164812] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
  4013  [    1.164889] NetLabel:  unlabeled traffic allowed by default
  4014  [    1.165390] clocksource: Switched to clocksource arch_sys_counter
  4015  [    1.165681] VFS: Disk quotas dquot_6.6.0
  4016  [    1.165750] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
  4017  [    1.166413] AppArmor: AppArmor Filesystem Enabled
  4018  [    1.173634] NET: Registered PF_INET protocol family
  4019  [    1.173921] IP idents hash table entries: 32768 (order: 6, 262144 bytes, linear)
  4020  [    1.175317] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
  4021  [    1.175360] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
  4022  [    1.175378] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
  4023  [    1.175539] TCP bind hash table entries: 16384 (order: 6, 262144 bytes, linear)
  4024  [    1.175865] TCP: Hash tables configured (established 16384 bind 16384)
  4025  [    1.176029] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
  4026  [    1.176098] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
  4027  [    1.176311] NET: Registered PF_UNIX/PF_LOCAL protocol family
  4028  [    1.176960] Trying to unpack rootfs image as initramfs...
  4029  [    1.186133] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
  4030  [    1.193488] Initialise system trusted keyrings
  4031  [    1.193594] Key type blacklist registered
  4032  [    1.193805] workingset: timestamp_bits=44 max_order=19 bucket_order=0
  4033  [    1.200226] zbud: loaded
  4034  [    1.202015] squashfs: version 4.0 (2009/01/31) Phillip Lougher
  4035  [    1.204510] integrity: Platform Keyring initialized
  4036  [    1.257825] xor: automatically using best checksumming function   32regs
  4037  [    1.257855] async_tx: api initialized (async)
  4038  [    1.257866] Key type asymmetric registered
  4039  [    1.257873] Asymmetric key parser 'x509' registered
  4040  [    1.258040] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
  4041  [    1.258234] io scheduler mq-deadline registered
  4042  [    1.258243] io scheduler kyber registered
  4043  [    1.258457] io scheduler bfq registered
  4044  [    1.262137] sun50i-a64-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver
  4045  [    1.272169] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
  4046  [    1.284000] loop: module loaded
  4047  [    1.286584] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
  4048  [    1.286619] ehci-platform: EHCI generic platform driver
  4049  [    1.286778] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
  4050  [    1.286793] ohci-platform: OHCI generic platform driver
  4051  [    1.287289] usbcore: registered new interface driver usb-storage
  4052  [    1.287846] mousedev: PS/2 mouse device common for all mice
  4053  [    1.288942] sun6i-rtc 1f00000.rtc: registered as rtc0
  4054  [    1.288983] sun6i-rtc 1f00000.rtc: setting system clock to 2022-12-10T16:37:01 UTC (1670690221)
  4055  [    1.289111] sun6i-rtc 1f00000.rtc: RTC enabled
  4056  [    1.289220] i2c_dev: i2c /dev entries driver
  4057  [    1.290083] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
  4058  [    1.292200] sun50i-a64-r-pinctrl 1f02c00.pinctrl: supply vcc-pl not found, using dummy regulator
  4059  [    1.292701] sdhci: Secure Digital Host Controller Interface driver
  4060  [    1.292710] sdhci: Copyright(c) Pierre Ossman
  4061  [    1.292738] Synopsys Designware Multimedia Card Interface Driver
  4062  [    1.293553] sdhci-pltfm: SDHCI platform and OF driver helper
  4063  [    1.294593] ledtrig-cpu: registered to indicate activity on CPUs
  4064  [    1.295105] SMCCC: SOC_ID: ID = jep106:091e:1689 Revision = 0x00000001
  4065  [    1.295419] sun8i-ce 1c15000.crypto: Set mod clock to 300000000 (300 Mhz) from 24000000 (24 Mhz)
  4066  [    1.295728] sun8i-ce 1c15000.crypto: will run requests pump with realtime priority
  4067  [    1.295876] sun8i-ce 1c15000.crypto: will run requests pump with realtime priority
  4068  [    1.295989] sun8i-ce 1c15000.crypto: will run requests pump with realtime priority
  4069  [    1.296117] sun8i-ce 1c15000.crypto: will run requests pump with realtime priority
  4070  [    1.296215] sun8i-ce 1c15000.crypto: Register cbc(aes)
  4071  [    1.296403] sun8i-ce 1c15000.crypto: Register ecb(aes)
  4072  [    1.296540] sun8i-ce 1c15000.crypto: Register cbc(des3_ede)
  4073  [    1.296686] sun8i-ce 1c15000.crypto: Register ecb(des3_ede)
  4074  [    1.296804] sun8i-ce 1c15000.crypto: Register md5
  4075  [    1.296931] sun8i-ce 1c15000.crypto: Register sha1
  4076  [    1.297058] sun8i-ce 1c15000.crypto: Register sha224
  4077  [    1.297182] sun8i-ce 1c15000.crypto: Register sha256
  4078  [    1.297305] sun8i-ce 1c15000.crypto: DEBUG: Algo of sha384 not supported
  4079  [    1.297315] sun8i-ce 1c15000.crypto: DEBUG: Algo of sha512 not supported
  4080  [    1.297324] sun8i-ce 1c15000.crypto: Register stdrng
  4081  [    1.297520] sun8i-ce 1c15000.crypto: TRNG not supported
  4082  [    1.297531] sun8i-ce 1c15000.crypto: CryptoEngine Die ID 0
  4083  [    1.298131] hid: raw HID events driver (C) Jiri Kosina
  4084  [    1.298311] usbcore: registered new interface driver usbhid
  4085  [    1.298319] usbhid: USB HID core driver
  4086  [    1.304440] NET: Registered PF_INET6 protocol family
  4087  [    1.956867] Freeing initrd memory: 12684K
  4088  [    1.990455] Segment Routing with IPv6
  4089  [    1.990549] In-situ OAM (IOAM) with IPv6
  4090  [    1.990648] NET: Registered PF_PACKET protocol family
  4091  [    1.990785] 8021q: 802.1Q VLAN Support v1.8
  4092  [    1.990961] 9pnet: Installing 9P2000 support
  4093  [    1.991095] Key type dns_resolver registered
  4094  [    1.991631] registered taskstats version 1
  4095  [    1.991650] Loading compiled-in X.509 certificates
  4096  [    1.995895] Loaded X.509 cert 'Build time autogenerated kernel key: 32330adefd2da02e444296fafd37464380789679'
  4097  [    2.000372] zswap: loaded using pool zstd/z3fold
  4098  [    2.001199] Key type ._fscrypt registered
  4099  [    2.001208] Key type .fscrypt registered
  4100  [    2.001213] Key type fscrypt-provisioning registered
  4101  [    2.002405] Btrfs loaded, crc32c=crc32c-generic, zoned=yes, fsverity=no
  4102  [    2.018331] Key type encrypted registered
  4103  [    2.018369] AppArmor: AppArmor sha1 policy hashing enabled
  4104  [    2.018414] ima: No TPM chip found, activating TPM-bypass!
  4105  [    2.018451] ima: Allocated hash algorithm: sha1
  4106  [    2.018490] ima: No architecture policies found
  4107  [    2.018576] evm: Initialising EVM extended attributes:
  4108  [    2.018581] evm: security.selinux
  4109  [    2.018587] evm: security.SMACK64
  4110  [    2.018591] evm: security.SMACK64EXEC
  4111  [    2.018596] evm: security.SMACK64TRANSMUTE
  4112  [    2.018600] evm: security.SMACK64MMAP
  4113  [    2.018605] evm: security.apparmor
  4114  [    2.018610] evm: security.ima
  4115  [    2.018615] evm: security.capability
  4116  [    2.018619] evm: HMAC attrs: 0x1
  4117  [    2.031490] platform 1100000.mixer: Fixing up cyclic dependency with 1c0d000.lcd-controller
  4118  [    2.031575] platform 1100000.mixer: Fixing up cyclic dependency with 1c0c000.lcd-controller
  4119  [    2.032330] platform 1200000.mixer: Fixing up cyclic dependency with 1c0d000.lcd-controller
  4120  [    2.032405] platform 1200000.mixer: Fixing up cyclic dependency with 1c0c000.lcd-controller
  4121  [    2.033239] sunxi-rsb 1f03400.rsb: RSB running at 3000000 Hz
  4122  [    2.033693] axp20x-rsb sunxi-rsb-3a3: AXP20x variant AXP803 found
  4123  [    2.035666] input: axp20x-pek as /devices/platform/soc/1f03400.rsb/sunxi-rsb-3a3/axp221-pek/input/input0
  4124  [    2.038746] vcc-3v3: supplied by regulator-dummy
  4125  [    2.039253] vdd-cpux: supplied by regulator-dummy
  4126  [    2.039936] dcdc4: supplied by regulator-dummy
  4127  [    2.040125] vcc-dram: supplied by regulator-dummy
  4128  [    2.040592] vdd-sys: supplied by regulator-dummy
  4129  [    2.041149] vcc-phy: supplied by regulator-dummy
  4130  [    2.041524] aldo1: supplied by regulator-dummy
  4131  [    2.041708] vcc-pl: supplied by regulator-dummy
  4132  [    2.042174] vcc-pll-avcc: supplied by regulator-dummy
  4133  [    2.042781] vcc-hdmi: supplied by regulator-dummy
  4134  [    2.043162] vcc-mipi: supplied by regulator-dummy
  4135  [    2.043527] dldo3: supplied by regulator-dummy
  4136  [    2.043894] vcc-wifi: supplied by regulator-dummy
  4137  [    2.044317] cpvdd: supplied by regulator-dummy
  4138  [    2.044680] eldo2: supplied by regulator-dummy
  4139  [    2.045041] eldo3: supplied by regulator-dummy
  4140  [    2.045472] vcc-1v2-hsic: supplied by regulator-dummy
  4141  [    2.045671] vdd-cpus: supplied by regulator-dummy
  4142  [    2.046104] vcc-rtc: supplied by regulator-dummy
  4143  [    2.046548] ldo-io0: supplied by regulator-dummy
  4144  [    2.046879] ldo-io1: supplied by regulator-dummy
  4145  [    2.047001] axp20x-rsb sunxi-rsb-3a3: AXP20X driver loaded
  4146  [    2.051925] sun50i-a64-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
  4147  [    2.052343] sun50i-a64-pinctrl 1c20800.pinctrl: supply vcc-pb not found, using dummy regulator
  4148  [    2.052902] printk: console [ttyS0] disabled
  4149  [    2.052988] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 41, base_baud = 1500000) is a 16550A
  4150  [    2.053198] printk: console [ttyS0] enabled
  4151  [    2.053947] sun50i-a64-pinctrl 1c20800.pinctrl: supply vcc-pg not found, using dummy regulator
  4152  [    2.054421] 1c28400.serial: ttyS1 at MMIO 0x1c28400 (irq = 42, base_baud = 1500000) is a 16550A
  4153  [    2.054571] serial serial0: tty port ttyS1 registered
  4154  [    2.085122] sun4i-drm display-engine: bound 1100000.mixer (ops 0xffff800008e16990)
  4155  [    2.086991] sun4i-drm display-engine: bound 1200000.mixer (ops 0xffff800008e16990)
  4156  [    2.087485] sun4i-drm display-engine: No panel or bridge found... RGB output disabled
  4157  [    2.087504] sun4i-drm display-engine: bound 1c0c000.lcd-controller (ops 0xffff800008e11ba0)
  4158  [    2.087767] sun4i-drm display-engine: bound 1c0d000.lcd-controller (ops 0xffff800008e11ba0)
  4159  [    2.088941] sun8i-dw-hdmi 1ee0000.hdmi: Detected HDMI TX controller v1.32a with HDCP (sun8i_dw_hdmi_phy)
  4160  [    2.089629] sun8i-dw-hdmi 1ee0000.hdmi: registered DesignWare HDMI I2C bus driver
  4161  [    2.090014] sun4i-drm display-engine: bound 1ee0000.hdmi (ops 0xffff800008e15cc8)
  4162  [    2.090703] [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on minor 0
  4163  [    2.090788] sun4i-drm display-engine: [drm] Cannot find any crtc or sizes
  4164  [    2.091482] sun50i-a64-pinctrl 1c20800.pinctrl: supply vcc-pc not found, using dummy regulator
  4165  [    2.092055] sun4i-drm display-engine: [drm] Cannot find any crtc or sizes
  4166  [    2.092794] ehci-platform 1c1a000.usb: EHCI Host Controller
  4167  [    2.092828] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
  4168  [    2.092964] ehci-platform 1c1a000.usb: irq 28, io mem 0x01c1a000
  4169  [    2.105399] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
  4170  [    2.105791] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
  4171  [    2.105807] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  4172  [    2.105819] usb usb1: Product: EHCI Host Controller
  4173  [    2.105829] usb usb1: Manufacturer: Linux 5.15.48-sunxi64 ehci_hcd
  4174  [    2.105838] usb usb1: SerialNumber: 1c1a000.usb
  4175  [    2.106397] hub 1-0:1.0: USB hub found
  4176  [    2.106446] hub 1-0:1.0: 1 port detected
  4177  [    2.107474] ehci-platform 1c1b000.usb: EHCI Host Controller
  4178  [    2.107501] ehci-platform 1c1b000.usb: new USB bus registered, assigned bus number 2
  4179  [    2.107635] ehci-platform 1c1b000.usb: irq 30, io mem 0x01c1b000
  4180  [    2.121401] ehci-platform 1c1b000.usb: USB 2.0 started, EHCI 1.00
  4181  [    2.121729] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
  4182  [    2.121744] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  4183  [    2.121755] usb usb2: Product: EHCI Host Controller
  4184  [    2.121764] usb usb2: Manufacturer: Linux 5.15.48-sunxi64 ehci_hcd
  4185  [    2.121774] usb usb2: SerialNumber: 1c1b000.usb
  4186  [    2.122261] hub 2-0:1.0: USB hub found
  4187  [    2.122309] hub 2-0:1.0: 1 port detected
  4188  [    2.297491] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
  4189  [    2.297525] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 3
  4190  [    2.297665] ohci-platform 1c1a400.usb: irq 29, io mem 0x01c1a400
  4191  [    2.361441] usb 1-1: new high-speed USB device number 2 using ehci-platform
  4192  [    2.361792] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.15
  4193  [    2.361807] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  4194  [    2.361819] usb usb3: Product: Generic Platform OHCI controller
  4195  [    2.361828] usb usb3: Manufacturer: Linux 5.15.48-sunxi64 ohci_hcd
  4196  [    2.361838] usb usb3: SerialNumber: 1c1a400.usb
  4197  [    2.362354] hub 3-0:1.0: USB hub found
  4198  [    2.362408] hub 3-0:1.0: 1 port detected
  4199  [    2.363427] ohci-platform 1c1b400.usb: Generic Platform OHCI controller
  4200  [    2.363454] ohci-platform 1c1b400.usb: new USB bus registered, assigned bus number 4
  4201  [    2.363578] ohci-platform 1c1b400.usb: irq 31, io mem 0x01c1b400
  4202  [    2.377404] usb 2-1: new high-speed USB device number 2 using ehci-platform
  4203  [    2.425658] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.15
  4204  [    2.425674] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  4205  [    2.425685] usb usb4: Product: Generic Platform OHCI controller
  4206  [    2.425695] usb usb4: Manufacturer: Linux 5.15.48-sunxi64 ohci_hcd
  4207  [    2.425704] usb usb4: SerialNumber: 1c1b400.usb
  4208  [    2.426224] hub 4-0:1.0: USB hub found
  4209  [    2.426277] hub 4-0:1.0: 1 port detected
  4210  [    2.427337] usb_phy_generic usb_phy_generic.3.auto: supply vcc not found, using dummy regulator
  4211  [    2.427517] usb_phy_generic usb_phy_generic.3.auto: dummy supplies not allowed for exclusive requests
  4212  [    2.505663] musb-hdrc musb-hdrc.4.auto: MUSB HDRC host driver
  4213  [    2.505695] musb-hdrc musb-hdrc.4.auto: new USB bus registered, assigned bus number 5
  4214  [    2.505957] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
  4215  [    2.505973] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  4216  [    2.505985] usb usb5: Product: MUSB HDRC host driver
  4217  [    2.505995] usb usb5: Manufacturer: Linux 5.15.48-sunxi64 musb-hcd
  4218  [    2.506005] usb usb5: SerialNumber: musb-hdrc.4.auto
  4219  [    2.506527] hub 5-0:1.0: USB hub found
  4220  [    2.506578] hub 5-0:1.0: 1 port detected
  4221  [    2.509984] sun50i-a64-pinctrl 1c20800.pinctrl: supply vcc-pf not found, using dummy regulator
  4222  [    2.510034] scpi_protocol scpi: SCP Protocol 0.0 Firmware 0.0.0 version
  4223  [    2.511064] sunxi-mmc 1c0f000.mmc: Got CD GPIO
  4224  [    2.511079] sunxi-mmc 1c10000.mmc: allocated mmc-pwrseq
  4225  [    2.511280] of_cfs_init
  4226  [    2.511411] of_cfs_init: OK
  4227  [    2.511772] ALSA device list:
  4228  [    2.511780]   No soundcards found.
  4229  [    2.519395] usb 1-1: New USB device found, idVendor=1f75, idProduct=0621, bcdDevice= 0.36
  4230  [    2.519413] usb 1-1: New USB device strings: Mfr=4, Product=5, SerialNumber=6
  4231  [    2.519425] usb 1-1: SerialNumber: 20181120
  4232  [    2.520389] usb-storage 1-1:1.0: USB Mass Storage device detected
  4233  [    2.520914] scsi host0: usb-storage 1-1:1.0
  4234  [    2.534507] sunxi-mmc 1c10000.mmc: initialized, max. request size: 16384 KB, uses new timings mode
  4235  [    2.536429] usb 2-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice= 6.54
  4236  [    2.536445] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
  4237  [    2.536457] usb 2-1: Product: USB2.1 Hub
  4238  [    2.536478] usb 2-1: Manufacturer: GenesysLogic
  4239  [    2.536507] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB, uses new timings mode
  4240  [    2.537330] hub 2-1:1.0: USB hub found
  4241  [    2.537686] hub 2-1:1.0: 4 ports detected
  4242  [    2.538207] Freeing unused kernel memory: 2496K
  4243  [    2.538343] Run /init as init process
  4244  [    2.538351]   with arguments:
  4245  [    2.538357]     /init
  4246  [    2.538363]   with environment:
  4247  [    2.538368]     HOME=/
  4248  [    2.538373]     TERM=linux
  4249  [    2.538379]     ubootpart=ea5e158f-01
  4250  [    2.538385]     cgroup_enable=memory
  4251  [    2.573167] mmc0: new high speed SDHC card at address 0001
  4252  [    2.574258] mmcblk0: mmc0:0001 EB1QT 29.8 GiB
  4253  [    2.576671]  mmcblk0: p1
  4254  [    2.849433] usb 2-1.1: new high-speed USB device number 3 using ehci-platform
  4255  [    3.061854] sun50i-a64-pinctrl 1c20800.pinctrl: supply vcc-ph not found, using dummy regulator
  4256  [    3.062739] usbcore: registered new interface driver uas
  4257  [    3.076942] sun50i-a64-pinctrl 1c20800.pinctrl: supply vcc-pd not found, using dummy regulator
  4258  [    3.077214] dwmac-sun8i 1c30000.ethernet: IRQ eth_wake_irq not found
  4259  [    3.077227] dwmac-sun8i 1c30000.ethernet: IRQ eth_lpi not found
  4260  [    3.077612] dwmac-sun8i 1c30000.ethernet: supply phy-io not found, using dummy regulator
  4261  [    3.077889] dwmac-sun8i 1c30000.ethernet: PTP uses main clock
  4262  [    3.077938] dwmac-sun8i 1c30000.ethernet: Current syscon value is not the default 6 (expect 0)
  4263  [    3.078417] dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported
  4264  [    3.078436] dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported
  4265  [    3.078445] dwmac-sun8i 1c30000.ethernet: COE Type 2
  4266  [    3.078457] dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported
  4267  [    3.078465] dwmac-sun8i 1c30000.ethernet: Normal descriptors
  4268  [    3.078473] dwmac-sun8i 1c30000.ethernet: Chain mode enabled
  4269  [    3.098353] axp20x-gpio axp20x-gpio: DMA mask not set
  4270  [    3.100011] axp20x-gpio axp20x-gpio: AXP209 pinctrl and GPIO driver loaded
  4271  [    3.199063] usb 2-1.1: New USB device found, idVendor=046d, idProduct=081b, bcdDevice= 0.12
  4272  [    3.199103] usb 2-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=2
  4273  [    3.199115] usb 2-1.1: SerialNumber: AA5FCF90
  4274  [    3.526482] scsi 0:0:0:0: Direct-Access     OCZ-VERT EX2                   PQ: 0 ANSI: 6
  4275  [    3.527236] sd 0:0:0:0: Attached scsi generic sg0 type 0
  4276  [    3.528214] sd 0:0:0:0: [sda] 234441648 512-byte logical blocks: (120 GB/112 GiB)
  4277  [    3.529529] sd 0:0:0:0: [sda] Write Protect is off
  4278  [    3.529559] sd 0:0:0:0: [sda] Mode Sense: 3b 00 00 00
  4279  [    3.531475] sd 0:0:0:0: [sda] No Caching mode page found
  4280  [    3.531505] sd 0:0:0:0: [sda] Assuming drive cache: write through
  4281  [    3.537462]  sda: sda1
  4282  [    3.541056] sd 0:0:0:0: [sda] Attached SCSI disk
  4283  [    3.895680] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
  4284  [    4.489896] systemd[1]: systemd 249.11-0ubuntu3.6 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY -P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
  4285  [    4.490608] systemd[1]: Detected architecture arm64.
  4286  [    4.493606] systemd[1]: Hostname set to <pine64>.
  4287  [    4.599592] dw-apb-uart 1c28000.serial: forbid DMA for kernel console
  4288  [    5.436125] systemd[1]: Queued start job for default target Graphical Interface.
  4289  [    5.438233] random: systemd: uninitialized urandom read (16 bytes read)
  4290  [    5.474009] systemd[1]: Created slice Slice /system/modprobe.
  4291  [    5.474766] random: systemd: uninitialized urandom read (16 bytes read)
  4292  [    5.477825] systemd[1]: Created slice Slice /system/serial-getty.
  4293  [    5.478258] random: systemd: uninitialized urandom read (16 bytes read)
  4294  [    5.480558] systemd[1]: Created slice User and Session Slice.
  4295  [    5.481041] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped.
  4296  [    5.481625] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
  4297  [    5.483133] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
  4298  [    5.483703] systemd[1]: Reached target Local Encrypted Volumes.
  4299  [    5.484470] systemd[1]: Reached target Slice Units.
  4300  [    5.484799] systemd[1]: Reached target Swaps.
  4301  [    5.485093] systemd[1]: Reached target System Time Set.
  4302  [    5.485651] systemd[1]: Reached target Local Verity Protected Volumes.
  4303  [    5.507761] systemd[1]: Listening on RPCbind Server Activation Socket.
  4304  [    5.509967] systemd[1]: Listening on Syslog Socket.
  4305  [    5.511095] systemd[1]: Listening on fsck to fsckd communication Socket.
  4306  [    5.511745] systemd[1]: Listening on initctl Compatibility Named Pipe.
  4307  [    5.513245] systemd[1]: Listening on Journal Audit Socket.
  4308  [    5.514270] systemd[1]: Listening on Journal Socket (/dev/log).
  4309  [    5.515346] systemd[1]: Listening on Journal Socket.
  4310  [    5.516728] systemd[1]: Listening on udev Control Socket.
  4311  [    5.517792] systemd[1]: Listening on udev Kernel Socket.
  4312  [    5.523638] systemd[1]: Mounting Huge Pages File System...
  4313  [    5.530252] systemd[1]: Mounting POSIX Message Queue File System...
  4314  [    5.536431] systemd[1]: Mounting NFSD configuration filesystem...
  4315  [    5.543426] systemd[1]: Mounting Kernel Debug File System...
  4316  [    5.544609] systemd[1]: Condition check resulted in Kernel Trace File System being skipped.
  4317  [    5.545716] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
  4318  [    5.554688] systemd[1]: Starting Restore / save the current clock...
  4319  [    5.562976] systemd[1]: Starting Set the console keyboard layout...
  4320  [    5.563623] systemd[1]: Condition check resulted in Create List of Static Device Nodes being skipped.
  4321  [    5.570777] systemd[1]: Starting Load Kernel Module chromeos_pstore...
  4322  [    5.578534] systemd[1]: Starting Load Kernel Module configfs...
  4323  [    5.586367] systemd[1]: Starting Load Kernel Module drm...
  4324  [    5.597439] systemd[1]: Starting Load Kernel Module efi_pstore...
  4325  [    5.608279] systemd[1]: Starting Load Kernel Module fuse...
  4326  [    5.616212] systemd[1]: Starting Load Kernel Module pstore_blk...
  4327  [    5.624780] systemd[1]: Starting Load Kernel Module pstore_zone...
  4328  [    5.632873] systemd[1]: Starting Load Kernel Module ramoops...
  4329  [    5.641828] systemd[1]: Started Nameserver information manager.
  4330  [    5.643270] systemd[1]: Reached target Preparation for Network.
  4331  [    5.644665] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
  4332  [    5.655105] systemd[1]: Starting Load Kernel Modules...
  4333  [    5.663362] systemd[1]: Starting Remount Root and Kernel File Systems...
  4334  [    5.672013] systemd[1]: Starting Coldplug All udev Devices...
  4335  [    5.687246] systemd[1]: Mounted Huge Pages File System.
  4336  [    5.688390] systemd[1]: Mounted POSIX Message Queue File System.
  4337  [    5.689688] systemd[1]: proc-fs-nfsd.mount: Mount process exited, code=exited, status=32/n/a
  4338  [    5.689738] systemd[1]: proc-fs-nfsd.mount: Failed with result 'exit-code'.
  4339  [    5.691946] systemd[1]: Failed to mount NFSD configuration filesystem.
  4340  [    5.692336] systemd[1]: Dependency failed for NFSv4 Client Tracking Daemon.
  4341  [    5.692499] systemd[1]: nfsdcld.service: Job nfsdcld.service/start failed with result 'dependency'.
  4342  [    5.692558] systemd[1]: Dependency failed for NFS server and services.
  4343  [    5.692686] systemd[1]: Dependency failed for NFS Mount Daemon.
  4344  [    5.692812] systemd[1]: nfs-mountd.service: Job nfs-mountd.service/start failed with result 'dependency'.
  4345  [    5.692867] systemd[1]: Dependency failed for NFSv4 ID-name mapping service.
  4346  [    5.692993] systemd[1]: nfs-idmapd.service: Job nfs-idmapd.service/start failed with result 'dependency'.
  4347  [    5.693030] systemd[1]: nfs-server.service: Job nfs-server.service/start failed with result 'dependency'.
  4348  [    5.694191] systemd[1]: Mounted Kernel Debug File System.
  4349  [    5.696991] systemd[1]: Finished Restore / save the current clock.
  4350  [    5.699539] systemd[1]: modprobe@chromeos_pstore.service: Deactivated successfully.
  4351  [    5.700952] systemd[1]: Finished Load Kernel Module chromeos_pstore.
  4352  [    5.701756] EXT4-fs (sda1): re-mounted. Opts: commit=600,errors=remount-ro. Quota mode: none.
  4353  [    5.708101] systemd[1]: modprobe@configfs.service: Deactivated successfully.
  4354  [    5.709490] systemd[1]: Finished Load Kernel Module configfs.
  4355  [    5.711668] systemd[1]: modprobe@drm.service: Deactivated successfully.
  4356  [    5.712954] systemd[1]: Finished Load Kernel Module drm.
  4357  [    5.715243] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
  4358  [    5.716565] systemd[1]: Finished Load Kernel Module efi_pstore.
  4359  [    5.718937] systemd[1]: modprobe@fuse.service: Deactivated successfully.
  4360  [    5.720423] systemd[1]: Finished Load Kernel Module fuse.
  4361  [    5.770991] systemd[1]: modprobe@pstore_blk.service: Deactivated successfully.
  4362  [    5.772462] systemd[1]: Finished Load Kernel Module pstore_blk.
  4363  [    5.774690] systemd[1]: modprobe@pstore_zone.service: Deactivated successfully.
  4364  [    5.776199] systemd[1]: Finished Load Kernel Module pstore_zone.
  4365  [    5.778312] systemd[1]: modprobe@ramoops.service: Deactivated successfully.
  4366  [    5.779751] systemd[1]: Finished Load Kernel Module ramoops.
  4367  [    5.784883] systemd[1]: Finished Load Kernel Modules.
  4368  [    5.787871] systemd[1]: Finished Remount Root and Kernel File Systems.
  4369  [    5.790567] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
  4370  [    5.795903] systemd[1]: Mounting Kernel Configuration File System...
  4371  [    5.796814] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
  4372  [    5.806394] systemd[1]: Starting Load/Save Random Seed...
  4373  [    5.816255] systemd[1]: Starting Apply Kernel Variables...
  4374  [    5.823671] systemd[1]: Starting Create System Users...
  4375  [    5.863161] systemd[1]: Mounted Kernel Configuration File System.
  4376  [    5.880178] systemd[1]: Finished Create System Users.
  4377  [    5.890098] systemd[1]: Starting Create Static Device Nodes in /dev...
  4378  [    5.893181] systemd[1]: Finished Apply Kernel Variables.
  4379  [    5.950915] systemd[1]: Finished Create Static Device Nodes in /dev.
  4380  [    5.966116] systemd[1]: Starting Rule-based Manager for Device Events and Files...
  4381  [    5.969558] systemd[1]: Finished Set the console keyboard layout.
  4382  [    5.970817] systemd[1]: Reached target Preparation for Local File Systems.
  4383  [    5.978368] systemd[1]: Mounting /tmp...
  4384  [    5.995592] systemd[1]: Mounted /tmp.
  4385  [    5.996657] systemd[1]: Reached target Local File Systems.
  4386  [    6.003863] systemd[1]: Starting Armbian leds state...
  4387  [    6.013532] systemd[1]: Starting Armbian ZRAM config...
  4388  [    6.022012] systemd[1]: Starting Set console font and keymap...
  4389  [    6.022904] systemd[1]: Condition check resulted in RPC security service for NFS server being skipped.
  4390  [    6.023283] systemd[1]: Condition check resulted in Mark the need to relabel after reboot being skipped.
  4391  [    6.030891] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
  4392  [    6.050050] systemd[1]: Finished Set console font and keymap.
  4393  [    6.099364] systemd[1]: armbian-led-state.service: Main process exited, code=exited, status=1/FAILURE
  4394  [    6.100313] systemd[1]: armbian-led-state.service: Failed with result 'exit-code'.
  4395  [    6.102367] systemd[1]: Failed to start Armbian leds state.
  4396  [    6.226360] systemd[1]: Finished Coldplug All udev Devices.
  4397  [    6.251853] systemd[1]: Starting Helper to synchronize boot up for ifupdown...
  4398  [    6.258264] systemd[1]: Started Rule-based Manager for Device Events and Files.
  4399  [    6.368491] systemd[1]: armbian-zram-config.service: Main process exited, code=exited, status=1/FAILURE
  4400  [    6.369557] systemd[1]: armbian-zram-config.service: Failed with result 'exit-code'.
  4401  [    6.372617] systemd[1]: Failed to start Armbian ZRAM config.
  4402  [    6.406822] systemd[1]: Starting Armbian memory supported logging...
  4403  [    6.487579] urandom_read_iter: 51 callbacks suppressed
  4404  [    6.487608] random: systemd: uninitialized urandom read (16 bytes read)
  4405  [    6.579458] random: systemd: uninitialized urandom read (16 bytes read)
  4406  [    6.579604] random: systemd: uninitialized urandom read (16 bytes read)
  4407  [    6.726347] random: crng init done
  4408  [    6.726376] random: 8 urandom warning(s) missed due to ratelimiting
  4409  [    6.749762] systemd[1]: Finished Load/Save Random Seed.
  4410  [    6.751582] systemd[1]: Condition check resulted in First Boot Complete being skipped.
  4411  [    6.751830] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
  4412  [    6.752051] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
  4413  [    6.842318] systemd[1]: Found device /dev/ttyS0.
  4414  [    7.402050] systemd[1]: Found device /sys/subsystem/net/devices/eth0.
  4415  [    7.423452] systemd[1]: Started ifup for eth0.
  4416  [    7.427735] systemd[1]: Finished Helper to synchronize boot up for ifupdown.
  4417  [    7.435714] systemd[1]: Starting Raise network interfaces...
  4418  [    7.441059] systemd[1]: ifup@eth0.service: Main process exited, code=exited, status=1/FAILURE
  4419  [    7.442566] systemd[1]: ifup@eth0.service: Failed with result 'exit-code'.
  4420  [    8.004404] systemd[1]: networking.service: Main process exited, code=exited, status=1/FAILURE
  4421  [    8.005291] systemd[1]: networking.service: Failed with result 'exit-code'.
  4422  [    8.007020] systemd[1]: Failed to start Raise network interfaces.
  4423  [   10.579844] systemd[1]: Finished Armbian memory supported logging.
  4424  [   10.625691] systemd[1]: Starting Journal Service...
  4425  [   10.883893] systemd[1]: Started Journal Service.
  4426  [   10.935071] systemd-journald[586]: Received client request to flush runtime journal.
  4427
  4428  ### armbian-release:
  4429
  4430  # PLEASE DO NOT EDIT THIS FILE
  4431  BOARD=pine64
  4432  BOARD_NAME="Pine64"
  4433  BOARDFAMILY=sun50iw1
  4434  BUILD_REPOSITORY_URL=https://github.com/armbian/build
  4435  BUILD_REPOSITORY_COMMIT=84940abb
  4436  VERSION=22.11.1
  4437  LINUXFAMILY=sunxi64
  4438  ARCH=arm64
  4439  IMAGE_TYPE=stable
  4440  BOARD_TYPE=conf
  4441  INITRD_ARCH=arm64
  4442  KERNEL_IMAGE_TYPE=Image
  4443  BRANCH=current
  4444
  4445  ### boot environment:
  4446
  4447  verbosity=1
  4448  bootlogo=false
  4449  console=both
  4450  disp_mode=1920x1080p60
  4451  overlay_prefix=sun50i-a64
  4452  rootdev=UUID=1a07fccf-6922-49b1-ace2-e12d87fdb297
  4453  rootfstype=ext4
  4454  usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
  4455
  4456  ### lsusb:
  4457
  4458  Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  4459  Bus 002 Device 003: ID 046d:081b Logitech, Inc. Webcam C310
  4460  Bus 002 Device 002: ID 05e3:0610 Genesys Logic, Inc. Hub
  4461  Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  4462  Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  4463  Bus 001 Device 002: ID 1f75:0621 Innostor Technology Corporation IS621 SATA Storage Controller
  4464  Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  4465  Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  4466
  4467  ### lscpu:
  4468
  4469  Architecture:                    aarch64
  4470  CPU op-mode(s):                  32-bit, 64-bit
  4471  Byte Order:                      Little Endian
  4472  CPU(s):                          4
  4473  On-line CPU(s) list:             0-3
  4474  Vendor ID:                       ARM
  4475  Model name:                      Cortex-A53
  4476  Model:                           4
  4477  Thread(s) per core:              1
  4478  Core(s) per cluster:             4
  4479  Socket(s):                       -
  4480  Cluster(s):                      1
  4481  Stepping:                        r0p4
  4482  BogoMIPS:                        48.00
  4483  Flags:                           fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  4484  NUMA node(s):                    1
  4485  NUMA node0 CPU(s):               0-3
  4486  Vulnerability Itlb multihit:     Not affected
  4487  Vulnerability L1tf:              Not affected
  4488  Vulnerability Mds:               Not affected
  4489  Vulnerability Meltdown:          Not affected
  4490  Vulnerability Mmio stale data:   Not affected
  4491  Vulnerability Spec store bypass: Not affected
  4492  Vulnerability Spectre v1:        Mitigation; __user pointer sanitization
  4493  Vulnerability Spectre v2:        Not affected
  4494  Vulnerability Srbds:             Not affected
  4495  Vulnerability Tsx async abort:   Not affected
  4496
  4497  ### cpuinfo:
  4498
  4499  processor       : 0
  4500  BogoMIPS        : 48.00
  4501  Features        : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  4502  CPU implementer : 0x41
  4503  CPU architecture: 8
  4504  CPU variant     : 0x0
  4505  CPU part        : 0xd03
  4506  CPU revision    : 4
  4507
  4508  processor       : 1
  4509  BogoMIPS        : 48.00
  4510  Features        : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  4511  CPU implementer : 0x41
  4512  CPU architecture: 8
  4513  CPU variant     : 0x0
  4514  CPU part        : 0xd03
  4515  CPU revision    : 4
  4516
  4517  processor       : 2
  4518  BogoMIPS        : 48.00
  4519  Features        : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  4520  CPU implementer : 0x41
  4521  CPU architecture: 8
  4522  CPU variant     : 0x0
  4523  CPU part        : 0xd03
  4524  CPU revision    : 4
  4525
  4526  processor       : 3
  4527  BogoMIPS        : 48.00
  4528  Features        : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
  4529  CPU implementer : 0x41
  4530  CPU architecture: 8
  4531  CPU variant     : 0x0
  4532  CPU part        : 0xd03
  4533  CPU revision    : 4
  4534
  4535
  4536  ### meminfo:
  4537
  4538  MemTotal:        2037276 kB
  4539  MemFree:         1892844 kB
  4540  MemAvailable:    1887688 kB
  4541  Buffers:           12164 kB
  4542  Cached:            53360 kB
  4543  SwapCached:            0 kB
  4544  Active:            28920 kB
  4545  Inactive:          49032 kB
  4546  Active(anon):        596 kB
  4547  Inactive(anon):    29352 kB
  4548  Active(file):      28324 kB
  4549  Inactive(file):    19680 kB
  4550  Unevictable:           0 kB
  4551  Mlocked:               0 kB
  4552  SwapTotal:             0 kB
  4553  SwapFree:              0 kB
  4554  Dirty:                 8 kB
  4555  Writeback:             0 kB
  4556  AnonPages:         12760 kB
  4557  Mapped:            13392 kB
  4558  Shmem:             17252 kB
  4559  KReclaimable:       9260 kB
  4560  Slab:              30880 kB
  4561  SReclaimable:       9260 kB
  4562  SUnreclaim:        21620 kB
  4563  KernelStack:        2112 kB
  4564  PageTables:         1156 kB
  4565  NFS_Unstable:          0 kB
  4566  Bounce:                0 kB
  4567  WritebackTmp:          0 kB
  4568  CommitLimit:     1018636 kB
  4569  Committed_AS:      46016 kB
  4570  VmallocTotal:   133143592960 kB
  4571  VmallocUsed:       10212 kB
  4572  VmallocChunk:          0 kB
  4573  Percpu:             1072 kB
  4574  AnonHugePages:         0 kB
  4575  ShmemHugePages:        0 kB
  4576  ShmemPmdMapped:        0 kB
  4577  FileHugePages:         0 kB
  4578  FilePmdMapped:         0 kB
  4579  CmaTotal:         131072 kB
  4580  CmaFree:          130304 kB
  4581  HugePages_Total:       0
  4582  HugePages_Free:        0
  4583  HugePages_Rsvd:        0
  4584  HugePages_Surp:        0
  4585  Hugepagesize:       2048 kB
  4586  Hugetlb:               0 kB
  4587
  4588  ### virtual memory:
  4589
  4590  vm.admin_reserve_kbytes = 8192
  4591  vm.compaction_proactiveness = 20
  4592  vm.compact_unevictable_allowed = 1
  4593  vm.dirty_background_bytes = 0
  4594  vm.dirty_background_ratio = 10
  4595  vm.dirty_bytes = 0
  4596  vm.dirty_expire_centisecs = 3000
  4597  vm.dirty_ratio = 20
  4598  vm.dirtytime_expire_seconds = 43200
  4599  vm.dirty_writeback_centisecs = 500
  4600  vm.extfrag_threshold = 500
  4601  vm.hugetlb_shm_group = 0
  4602  vm.laptop_mode = 0
  4603  vm.legacy_va_layout = 0
  4604  vm.lowmem_reserve_ratio = 256   256     32      0
  4605  vm.max_map_count = 65530
  4606  vm.min_free_kbytes = 22528
  4607  vm.min_slab_ratio = 5
  4608  vm.min_unmapped_ratio = 1
  4609  vm.mmap_min_addr = 32768
  4610  vm.mmap_rnd_bits = 18
  4611  vm.mmap_rnd_compat_bits = 11
  4612  vm.nr_hugepages = 0
  4613  vm.nr_hugepages_mempolicy = 0
  4614  vm.nr_overcommit_hugepages = 0
  4615  vm.numa_stat = 1
  4616  vm.numa_zonelist_order = Node
  4617  vm.oom_dump_tasks = 1
  4618  vm.oom_kill_allocating_task = 0
  4619  vm.overcommit_kbytes = 0
  4620  vm.overcommit_memory = 0
  4621  vm.overcommit_ratio = 50
  4622  vm.page-cluster = 3
  4623  vm.page_lock_unfairness = 5
  4624  vm.panic_on_oom = 0
  4625  vm.percpu_pagelist_high_fraction = 0
  4626  vm.stat_interval = 1
  4627  vm.swappiness = 100
  4628  vm.user_reserve_kbytes = 63000
  4629  vm.vfs_cache_pressure = 100
  4630  vm.watermark_boost_factor = 15000
  4631  vm.watermark_scale_factor = 10
  4632  vm.zone_reclaim_mode = 0
  4633
  4634  ### ip addr:
  4635
  4636  1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
  4637      link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
  4638      inet XXX.XXX.0.1/8 scope host lo
  4639         valid_lft forever preferred_lft forever
  4640      inet6 ::1/128 scope host
  4641         valid_lft forever preferred_lft forever
  4642  2: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
  4643      link/ether 02:ba:85:77:17:e9 brd ff:ff:ff:ff:ff:ff
  4644
  4645  ### partitions:
  4646
  4647  major minor  #blocks  name
  4648
  4649   179        0   31260672 mmcblk0
  4650   179        1   30928896 mmcblk0p1
  4651     8        0  117220824 sda
  4652     8        1  117218304 sda1
  4653
  4654  ### df:
  4655
  4656  tmpfs           199M  3.1M  196M   2% /run
  4657  /dev/sda1       110G   29G   76G  28% /
  4658  tmpfs           995M     0  995M   0% /dev/shm
  4659  tmpfs           5.0M     0  5.0M   0% /run/lock
  4660  tmpfs           995M  4.0K  995M   1% /tmp
  4661
  4662  ### lsblk:
  4663
  4664  NAME        FSTYPE   SIZE MOUNTPOINT UUID
  4665  sda                111.8G
  4666  └─sda1      ext4   111.8G /          933d6d44-0352-46aa-8100-fd703056ae3d
  4667  mmcblk0             29.8G
  4668  └─mmcblk0p1 ext4    29.5G            1a07fccf-6922-49b1-ace2-e12d87fdb297
  4669
  4670  ### zramctl:
  4671
  4672
  4673
  4674  ### mtab:
  4675
  4676  /dev/sda1 / ext4 rw,noatime,errors=remount-ro,commit=600 0 0
  4677  /dev/sda1 /var/log.hdd ext4 rw,noatime,errors=remount-ro,commit=600 0 0
  4678
  4679  ### mmc0:0001 info:
  4680
  4681                 fwrev: 0x0
  4682                uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=EB1QT MODALIAS=mmc:block
  4683                   cid: 1b534d454231515430bc836120012941
  4684                   rca: 0x0001
  4685                   csd: 400e00325b590000ee7f7f800a404055
  4686                manfid: 0x00001b
  4687                   ocr: 0x00200000
  4688  preferred_erase_size: 4194304
  4689                  type: SD
  4690                 hwrev: 0x3
  4691                  date: 09/2018
  4692                   dsr: 0x404
  4693            erase_size: 512
  4694                 oemid: 0x534d
  4695                serial: 0xbc836120
  4696                   ssr: 0000000005000000040090000f051c00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
  4697                   scr: 02b5800200000000
  4698                  name: EB1QT
  4699
  4700  ### Boot system health:
  4701
  4702  Time      CPU n/a    load %cpu %sys %usr %nice %io %irq   CPU
  4703  17:37:14:   ---      0.23  54%  27%  20%   0%   5%   0% 39.1 °C
  4704  17:37:15:   ---      0.93  85%  18%  21%   0%  44%   1% 39.1 °C
  4705  17:37:15:   ---      0.93  80%  21%  25%   0%  31%   0% 36.2 °C
  4706  17:37:16:   ---      0.93  54%   9%   7%   1%  34%   0% 36.2 °C
  4707  17:37:16:   ---      0.93  39%   7%   2%   0%  29%   0% 34.1 °C
  4708
  4709  ### lsusb:
  4710
  4711  Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  4712  Bus 002 Device 003: ID 046d:081b Logitech, Inc. Webcam C310
  4713  Bus 002 Device 002: ID 05e3:0610 Genesys Logic, Inc. Hub
  4714  Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  4715  Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  4716  Bus 001 Device 002: ID 1f75:0621 Innostor Technology Corporation IS621 SATA Storage Controller
  4717  Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  4718  Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  4719
  4720  /:  Bus 05.Port 1: Dev 1, Class=root_hub, Driver=musb-hdrc/1p, 480M
  4721  /:  Bus 04.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M
  4722  /:  Bus 03.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M
  4723  /:  Bus 02.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M
  4724      |__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 480M
  4725          |__ Port 1: Dev 3, If 0, Class=Video, Driver=, 480M
  4726          |__ Port 1: Dev 3, If 1, Class=Video, Driver=, 480M
  4727          |__ Port 1: Dev 3, If 2, Class=Audio, Driver=, 480M
  4728          |__ Port 1: Dev 3, If 3, Class=Audio, Driver=, 480M
  4729  /:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M
  4730      |__ Port 1: Dev 2, If 0, Class=Mass Storage, Driver=usb-storage, 480M
  4731
  4732  ### Userland:
  4733
  4734  PRETTY_NAME="Armbian 22.11.1 Jammy"
  4735
  4736  ### Installed packages:
  4737
  4738  ii  armbian-bsp-cli-pine64            22.11.1                                 arm64        Armbian board support files for pine64
  4739  ii  armbian-config                    22.11.1                                 all          Armbian configuration utility
  4740  ii  armbian-firmware                  22.11.1                                 all          Linux firmware
  4741  ii  armbian-zsh                       22.11.1                                 all          Armbian improved ZShell
  4742  ii  hostapd                           3:2.10-6~armbian22.02.3+1               arm64        IEEE 802.11 AP and IEEE 802.1X/WPA/WPA2/EAP Authenticator
  4743  ii  linux-base                        4.5ubuntu9                              all          Linux image base package
  4744  ic  linux-image-current-sunxi64       21.05.1                                 arm64        Linux kernel, version 5.10.34-sunxi64
  4745  ii  linux-image-edge-sunxi64          22.11.1                                 arm64        Linux kernel, armbian version 6.0.10-sunxi64 edge
  4746  ii  linux-libc-dev:arm64              22.11.1                                 arm64        Armbian Linux support headers for userspace development
  4747  ii  linux-u-boot-pine64-edge          22.08.6                                 arm64        Uboot loader 2022.07
  4748
  4749  ### Loaded modules:
  4750
  4751  Module                  Size  Used by
  4752  realtek                32768  1
  4753  pinctrl_axp209         16384  0
  4754  dwmac_sun8i            28672  0
  4755  mdio_mux               16384  1 dwmac_sun8i
  4756  i2c_mv64xxx            24576  0
  4757  uas                    28672  0
  4758
  4759  ### Current system health:
  4760
  4761  Time      CPU n/a    load %cpu %sys %usr %nice %io %irq   CPU
  4762  22:20:16:   ---      0.02   1%   0%   0%   0%   0%   0% 41.0 °C
  4763  22:20:16:   ---      0.02   2%   2%   0%   0%   0%   0% 39.4 °C
  4764  22:20:16:   ---      0.02   4%   3%   0%   0%   0%   0% 39.4 °C
  4765  22:20:17:   ---      0.02   2%   2%   0%   0%   0%   0% 38.9 °C
  4766  22:20:17:   ---      0.02   2%   2%   0%   0%   0%   0% 38.9 °C
  4767  22:20:20:   ---      0.42   1%   0%   0%   0%   0%   0% 42.0 °C
  4768  22:20:21:   ---      0.42  76%   0%  75%   0%   0%   0% 41.5 °C
  4769  22:20:21:   ---      0.42   2%   2%   0%   0%   0%   0% 40.3 °C
  4770  22:20:21:   ---      0.42   2%   1%   0%   1%   0%   0% 40.3 °C
  4771  22:20:22:   ---      0.42   2%   2%   0%   0%   0%   0% 40.3 °C
  4772
  4773  ### resolv.conf
  4774
  4775  lrwxrwxrwx 1 root root 32 Aug 25 00:31 /etc/resolv.conf -> /run/systemd/resolve/resolv.conf
  4776  # This is /run/systemd/resolve/resolv.conf managed by man:systemd-resolved(8).
  4777  # Do not edit.
  4778  #
  4779  # This file might be symlinked as /etc/resolv.conf. If you're looking at
  4780  # /etc/resolv.conf and seeing this text, you have followed the symlink.
  4781  #
  4782  # This is a dynamic resolv.conf file for connecting local clients directly to
  4783  # all known uplink DNS servers. This file lists all configured search domains.
  4784  #
  4785  # Third party programs should typically not access this file directly, but only
  4786  # through the symlink at /etc/resolv.conf. To manage man:resolv.conf(5) in a
  4787  # different way, replace this symlink by a static file or a different symlink.
  4788  #
  4789  # See man:systemd-resolved.service(8) for details about the supported modes of
  4790  # operation for /etc/resolv.conf.
  4791
  4792  nameserver XXX.XXX.0.1
  4793  search .
  4794
  4795  ### Current sysinfo:
  4796
  4797  Linux 5.15.48-sunxi64 (pine64)  12/10/2022      _aarch64_       (4 CPU)
  4798
  4799  avg-cpu:  %user   %nice %system %iowait  %steal   %idle
  4800             0.99    0.00    0.22    0.04    0.00   98.75
  4801
  4802  Device             tps    kB_read/s    kB_wrtn/s    kB_dscd/s    kB_read    kB_wrtn    kB_dscd
  4803  mmcblk0           0.01         0.43         0.00         0.00       7312          0          0
  4804  mmcblk0p1         0.01         0.31         0.00         0.00       5200          0          0
  4805  sda               1.96        35.05        86.56         0.00     596141    1472096          0
  4806  sda1              1.95        34.93        86.56         0.00     593973    1472096          0
  4807
  4808  --procs-- -----------------------memory---------------------- ---swap-- -----io---- -system-- --------cpu--------
  4809     r    b         swpd         free         buff        cache   si   so    bi    bo   in   cs  us  sy  id  wa  st
  4810     0    0            0       966728        32904       898212    0    0     9    22   49   29   1   0  99   0   0
  4811
  4812                 total        used        free      shared  buff/cache   available
  4813  Mem:           1.9Gi       136Mi       944Mi        19Mi       909Mi       1.7Gi
  4814  Swap:             0B          0B          0B
  4815
  4816
  4817
  4818   22:20:26 up  4:43,  1 user,  load average: 0.39, 0.19, 0.10
  4819
  4820  [    2.297491] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
  4821  [    2.297525] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 3
  4822  [    2.297665] ohci-platform 1c1a400.usb: irq 29, io mem 0x01c1a400
  4823  [    2.361441] usb 1-1: new high-speed USB device number 2 using ehci-platform
  4824  [    2.361792] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.15
  4825  [    2.361807] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  4826  [    2.361819] usb usb3: Product: Generic Platform OHCI controller
  4827  [    2.361828] usb usb3: Manufacturer: Linux 5.15.48-sunxi64 ohci_hcd
  4828  [    2.361838] usb usb3: SerialNumber: 1c1a400.usb
  4829  [    2.362354] hub 3-0:1.0: USB hub found
  4830  [    2.362408] hub 3-0:1.0: 1 port detected
  4831  [    2.363427] ohci-platform 1c1b400.usb: Generic Platform OHCI controller
  4832  [    2.363454] ohci-platform 1c1b400.usb: new USB bus registered, assigned bus number 4
  4833  [    2.363578] ohci-platform 1c1b400.usb: irq 31, io mem 0x01c1b400
  4834  [    2.377404] usb 2-1: new high-speed USB device number 2 using ehci-platform
  4835  [    2.425658] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.15
  4836  [    2.425674] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  4837  [    2.425685] usb usb4: Product: Generic Platform OHCI controller
  4838  [    2.425695] usb usb4: Manufacturer: Linux 5.15.48-sunxi64 ohci_hcd
  4839  [    2.425704] usb usb4: SerialNumber: 1c1b400.usb
  4840  [    2.426224] hub 4-0:1.0: USB hub found
  4841  [    2.426277] hub 4-0:1.0: 1 port detected
  4842  [    2.427337] usb_phy_generic usb_phy_generic.3.auto: supply vcc not found, using dummy regulator
  4843  [    2.427517] usb_phy_generic usb_phy_generic.3.auto: dummy supplies not allowed for exclusive requests
  4844  [    2.505663] musb-hdrc musb-hdrc.4.auto: MUSB HDRC host driver
  4845  [    2.505695] musb-hdrc musb-hdrc.4.auto: new USB bus registered, assigned bus number 5
  4846  [    2.505957] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
  4847  [    2.505973] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  4848  [    2.505985] usb usb5: Product: MUSB HDRC host driver
  4849  [    2.505995] usb usb5: Manufacturer: Linux 5.15.48-sunxi64 musb-hcd
  4850  [    2.506005] usb usb5: SerialNumber: musb-hdrc.4.auto
  4851  [    2.506527] hub 5-0:1.0: USB hub found
  4852  [    2.506578] hub 5-0:1.0: 1 port detected
  4853  [    2.509984] sun50i-a64-pinctrl 1c20800.pinctrl: supply vcc-pf not found, using dummy regulator
  4854  [    2.510034] scpi_protocol scpi: SCP Protocol 0.0 Firmware 0.0.0 version
  4855  [    2.511064] sunxi-mmc 1c0f000.mmc: Got CD GPIO
  4856  [    2.511079] sunxi-mmc 1c10000.mmc: allocated mmc-pwrseq
  4857  [    2.511280] of_cfs_init
  4858  [    2.511411] of_cfs_init: OK
  4859  [    2.511772] ALSA device list:
  4860  [    2.511780]   No soundcards found.
  4861  [    2.519395] usb 1-1: New USB device found, idVendor=1f75, idProduct=0621, bcdDevice= 0.36
  4862  [    2.519413] usb 1-1: New USB device strings: Mfr=4, Product=5, SerialNumber=6
  4863  [    2.519425] usb 1-1: SerialNumber: 20181120
  4864  [    2.520389] usb-storage 1-1:1.0: USB Mass Storage device detected
  4865  [    2.520914] scsi host0: usb-storage 1-1:1.0
  4866  [    2.534507] sunxi-mmc 1c10000.mmc: initialized, max. request size: 16384 KB, uses new timings mode
  4867  [    2.536429] usb 2-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice= 6.54
  4868  [    2.536445] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
  4869  [    2.536457] usb 2-1: Product: USB2.1 Hub
  4870  [    2.536478] usb 2-1: Manufacturer: GenesysLogic
  4871  [    2.536507] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB, uses new timings mode
  4872  [    2.537330] hub 2-1:1.0: USB hub found
  4873  [    2.537686] hub 2-1:1.0: 4 ports detected
  4874  [    2.538207] Freeing unused kernel memory: 2496K
  4875  [    2.538343] Run /init as init process
  4876  [    2.538351]   with arguments:
  4877  [    2.538357]     /init
  4878  [    2.538363]   with environment:
  4879  [    2.538368]     HOME=/
  4880  [    2.538373]     TERM=linux
  4881  [    2.538379]     ubootpart=ea5e158f-01
  4882  [    2.538385]     cgroup_enable=memory
  4883  [    2.573167] mmc0: new high speed SDHC card at address 0001
  4884  [    2.574258] mmcblk0: mmc0:0001 EB1QT 29.8 GiB
  4885  [    2.576671]  mmcblk0: p1
  4886  [    2.849433] usb 2-1.1: new high-speed USB device number 3 using ehci-platform
  4887  [    3.061854] sun50i-a64-pinctrl 1c20800.pinctrl: supply vcc-ph not found, using dummy regulator
  4888  [    3.062739] usbcore: registered new interface driver uas
  4889  [    3.076942] sun50i-a64-pinctrl 1c20800.pinctrl: supply vcc-pd not found, using dummy regulator
  4890  [    3.077214] dwmac-sun8i 1c30000.ethernet: IRQ eth_wake_irq not found
  4891  [    3.077227] dwmac-sun8i 1c30000.ethernet: IRQ eth_lpi not found
  4892  [    3.077612] dwmac-sun8i 1c30000.ethernet: supply phy-io not found, using dummy regulator
  4893  [    3.077889] dwmac-sun8i 1c30000.ethernet: PTP uses main clock
  4894  [    3.077938] dwmac-sun8i 1c30000.ethernet: Current syscon value is not the default 6 (expect 0)
  4895  [    3.078417] dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported
  4896  [    3.078436] dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported
  4897  [    3.078445] dwmac-sun8i 1c30000.ethernet: COE Type 2
  4898  [    3.078457] dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported
  4899  [    3.078465] dwmac-sun8i 1c30000.ethernet: Normal descriptors
  4900  [    3.078473] dwmac-sun8i 1c30000.ethernet: Chain mode enabled
  4901  [    3.098353] axp20x-gpio axp20x-gpio: DMA mask not set
  4902  [    3.100011] axp20x-gpio axp20x-gpio: AXP209 pinctrl and GPIO driver loaded
  4903  [    3.199063] usb 2-1.1: New USB device found, idVendor=046d, idProduct=081b, bcdDevice= 0.12
  4904  [    3.199103] usb 2-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=2
  4905  [    3.199115] usb 2-1.1: SerialNumber: AA5FCF90
  4906  [    3.526482] scsi 0:0:0:0: Direct-Access     OCZ-VERT EX2                   PQ: 0 ANSI: 6
  4907  [    3.527236] sd 0:0:0:0: Attached scsi generic sg0 type 0
  4908  [    3.528214] sd 0:0:0:0: [sda] 234441648 512-byte logical blocks: (120 GB/112 GiB)
  4909  [    3.529529] sd 0:0:0:0: [sda] Write Protect is off
  4910  [    3.529559] sd 0:0:0:0: [sda] Mode Sense: 3b 00 00 00
  4911  [    3.531475] sd 0:0:0:0: [sda] No Caching mode page found
  4912  [    3.531505] sd 0:0:0:0: [sda] Assuming drive cache: write through
  4913  [    3.537462]  sda: sda1
  4914  [    3.541056] sd 0:0:0:0: [sda] Attached SCSI disk
  4915  [    3.895680] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
  4916  [    4.489896] systemd[1]: systemd 249.11-0ubuntu3.6 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY -P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
  4917  [    4.490608] systemd[1]: Detected architecture arm64.
  4918  [    4.493606] systemd[1]: Hostname set to <pine64>.
  4919  [    4.599592] dw-apb-uart 1c28000.serial: forbid DMA for kernel console
  4920  [    5.436125] systemd[1]: Queued start job for default target Graphical Interface.
  4921  [    5.438233] random: systemd: uninitialized urandom read (16 bytes read)
  4922  [    5.474009] systemd[1]: Created slice Slice /system/modprobe.
  4923  [    5.474766] random: systemd: uninitialized urandom read (16 bytes read)
  4924  [    5.477825] systemd[1]: Created slice Slice /system/serial-getty.
  4925  [    5.478258] random: systemd: uninitialized urandom read (16 bytes read)
  4926  [    5.480558] systemd[1]: Created slice User and Session Slice.
  4927  [    5.481041] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped.
  4928  [    5.481625] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
  4929  [    5.483133] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
  4930  [    5.483703] systemd[1]: Reached target Local Encrypted Volumes.
  4931  [    5.484470] systemd[1]: Reached target Slice Units.
  4932  [    5.484799] systemd[1]: Reached target Swaps.
  4933  [    5.485093] systemd[1]: Reached target System Time Set.
  4934  [    5.485651] systemd[1]: Reached target Local Verity Protected Volumes.
  4935  [    5.507761] systemd[1]: Listening on RPCbind Server Activation Socket.
  4936  [    5.509967] systemd[1]: Listening on Syslog Socket.
  4937  [    5.511095] systemd[1]: Listening on fsck to fsckd communication Socket.
  4938  [    5.511745] systemd[1]: Listening on initctl Compatibility Named Pipe.
  4939  [    5.513245] systemd[1]: Listening on Journal Audit Socket.
  4940  [    5.514270] systemd[1]: Listening on Journal Socket (/dev/log).
  4941  [    5.515346] systemd[1]: Listening on Journal Socket.
  4942  [    5.516728] systemd[1]: Listening on udev Control Socket.
  4943  [    5.517792] systemd[1]: Listening on udev Kernel Socket.
  4944  [    5.523638] systemd[1]: Mounting Huge Pages File System...
  4945  [    5.530252] systemd[1]: Mounting POSIX Message Queue File System...
  4946  [    5.536431] systemd[1]: Mounting NFSD configuration filesystem...
  4947  [    5.543426] systemd[1]: Mounting Kernel Debug File System...
  4948  [    5.544609] systemd[1]: Condition check resulted in Kernel Trace File System being skipped.
  4949  [    5.545716] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
  4950  [    5.554688] systemd[1]: Starting Restore / save the current clock...
  4951  [    5.562976] systemd[1]: Starting Set the console keyboard layout...
  4952  [    5.563623] systemd[1]: Condition check resulted in Create List of Static Device Nodes being skipped.
  4953  [    5.570777] systemd[1]: Starting Load Kernel Module chromeos_pstore...
  4954  [    5.578534] systemd[1]: Starting Load Kernel Module configfs...
  4955  [    5.586367] systemd[1]: Starting Load Kernel Module drm...
  4956  [    5.597439] systemd[1]: Starting Load Kernel Module efi_pstore...
  4957  [    5.608279] systemd[1]: Starting Load Kernel Module fuse...
  4958  [    5.616212] systemd[1]: Starting Load Kernel Module pstore_blk...
  4959  [    5.624780] systemd[1]: Starting Load Kernel Module pstore_zone...
  4960  [    5.632873] systemd[1]: Starting Load Kernel Module ramoops...
  4961  [    5.641828] systemd[1]: Started Nameserver information manager.
  4962  [    5.643270] systemd[1]: Reached target Preparation for Network.
  4963  [    5.644665] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
  4964  [    5.655105] systemd[1]: Starting Load Kernel Modules...
  4965  [    5.663362] systemd[1]: Starting Remount Root and Kernel File Systems...
  4966  [    5.672013] systemd[1]: Starting Coldplug All udev Devices...
  4967  [    5.687246] systemd[1]: Mounted Huge Pages File System.
  4968  [    5.688390] systemd[1]: Mounted POSIX Message Queue File System.
  4969  [    5.689688] systemd[1]: proc-fs-nfsd.mount: Mount process exited, code=exited, status=32/n/a
  4970  [    5.689738] systemd[1]: proc-fs-nfsd.mount: Failed with result 'exit-code'.
  4971  [    5.691946] systemd[1]: Failed to mount NFSD configuration filesystem.
  4972  [    5.692336] systemd[1]: Dependency failed for NFSv4 Client Tracking Daemon.
  4973  [    5.692499] systemd[1]: nfsdcld.service: Job nfsdcld.service/start failed with result 'dependency'.
  4974  [    5.692558] systemd[1]: Dependency failed for NFS server and services.
  4975  [    5.692686] systemd[1]: Dependency failed for NFS Mount Daemon.
  4976  [    5.692812] systemd[1]: nfs-mountd.service: Job nfs-mountd.service/start failed with result 'dependency'.
  4977  [    5.692867] systemd[1]: Dependency failed for NFSv4 ID-name mapping service.
  4978  [    5.692993] systemd[1]: nfs-idmapd.service: Job nfs-idmapd.service/start failed with result 'dependency'.
  4979  [    5.693030] systemd[1]: nfs-server.service: Job nfs-server.service/start failed with result 'dependency'.
  4980  [    5.694191] systemd[1]: Mounted Kernel Debug File System.
  4981  [    5.696991] systemd[1]: Finished Restore / save the current clock.
  4982  [    5.699539] systemd[1]: modprobe@chromeos_pstore.service: Deactivated successfully.
  4983  [    5.700952] systemd[1]: Finished Load Kernel Module chromeos_pstore.
  4984  [    5.701756] EXT4-fs (sda1): re-mounted. Opts: commit=600,errors=remount-ro. Quota mode: none.
  4985  [    5.708101] systemd[1]: modprobe@configfs.service: Deactivated successfully.
  4986  [    5.709490] systemd[1]: Finished Load Kernel Module configfs.
  4987  [    5.711668] systemd[1]: modprobe@drm.service: Deactivated successfully.
  4988  [    5.712954] systemd[1]: Finished Load Kernel Module drm.
  4989  [    5.715243] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
  4990  [    5.716565] systemd[1]: Finished Load Kernel Module efi_pstore.
  4991  [    5.718937] systemd[1]: modprobe@fuse.service: Deactivated successfully.
  4992  [    5.720423] systemd[1]: Finished Load Kernel Module fuse.
  4993  [    5.770991] systemd[1]: modprobe@pstore_blk.service: Deactivated successfully.
  4994  [    5.772462] systemd[1]: Finished Load Kernel Module pstore_blk.
  4995  [    5.774690] systemd[1]: modprobe@pstore_zone.service: Deactivated successfully.
  4996  [    5.776199] systemd[1]: Finished Load Kernel Module pstore_zone.
  4997  [    5.778312] systemd[1]: modprobe@ramoops.service: Deactivated successfully.
  4998  [    5.779751] systemd[1]: Finished Load Kernel Module ramoops.
  4999  [    5.784883] systemd[1]: Finished Load Kernel Modules.
  5000  [    5.787871] systemd[1]: Finished Remount Root and Kernel File Systems.
  5001  [    5.790567] systemd[1]: Condition check resulted in FUSE Control File System being skipped.
  5002  [    5.795903] systemd[1]: Mounting Kernel Configuration File System...
  5003  [    5.796814] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
  5004  [    5.806394] systemd[1]: Starting Load/Save Random Seed...
  5005  [    5.816255] systemd[1]: Starting Apply Kernel Variables...
  5006  [    5.823671] systemd[1]: Starting Create System Users...
  5007  [    5.863161] systemd[1]: Mounted Kernel Configuration File System.
  5008  [    5.880178] systemd[1]: Finished Create System Users.
  5009  [    5.890098] systemd[1]: Starting Create Static Device Nodes in /dev...
  5010  [    5.893181] systemd[1]: Finished Apply Kernel Variables.
  5011  [    5.950915] systemd[1]: Finished Create Static Device Nodes in /dev.
  5012  [    5.966116] systemd[1]: Starting Rule-based Manager for Device Events and Files...
  5013  [    5.969558] systemd[1]: Finished Set the console keyboard layout.
  5014  [    5.970817] systemd[1]: Reached target Preparation for Local File Systems.
  5015  [    5.978368] systemd[1]: Mounting /tmp...
  5016  [    5.995592] systemd[1]: Mounted /tmp.
  5017  [    5.996657] systemd[1]: Reached target Local File Systems.
  5018  [    6.003863] systemd[1]: Starting Armbian leds state...
  5019  [    6.013532] systemd[1]: Starting Armbian ZRAM config...
  5020  [    6.022012] systemd[1]: Starting Set console font and keymap...
  5021  [    6.022904] systemd[1]: Condition check resulted in RPC security service for NFS server being skipped.
  5022  [    6.023283] systemd[1]: Condition check resulted in Mark the need to relabel after reboot being skipped.
  5023  [    6.030891] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
  5024  [    6.050050] systemd[1]: Finished Set console font and keymap.
  5025  [    6.099364] systemd[1]: armbian-led-state.service: Main process exited, code=exited, status=1/FAILURE
  5026  [    6.100313] systemd[1]: armbian-led-state.service: Failed with result 'exit-code'.
  5027  [    6.102367] systemd[1]: Failed to start Armbian leds state.
  5028  [    6.226360] systemd[1]: Finished Coldplug All udev Devices.
  5029  [    6.251853] systemd[1]: Starting Helper to synchronize boot up for ifupdown...
  5030  [    6.258264] systemd[1]: Started Rule-based Manager for Device Events and Files.
  5031  [    6.368491] systemd[1]: armbian-zram-config.service: Main process exited, code=exited, status=1/FAILURE
  5032  [    6.369557] systemd[1]: armbian-zram-config.service: Failed with result 'exit-code'.
  5033  [    6.372617] systemd[1]: Failed to start Armbian ZRAM config.
  5034  [    6.406822] systemd[1]: Starting Armbian memory supported logging...
  5035  [    6.487579] urandom_read_iter: 51 callbacks suppressed
  5036  [    6.487608] random: systemd: uninitialized urandom read (16 bytes read)
  5037  [    6.579458] random: systemd: uninitialized urandom read (16 bytes read)
  5038  [    6.579604] random: systemd: uninitialized urandom read (16 bytes read)
  5039  [    6.726347] random: crng init done
  5040  [    6.726376] random: 8 urandom warning(s) missed due to ratelimiting
  5041  [    6.749762] systemd[1]: Finished Load/Save Random Seed.
  5042  [    6.751582] systemd[1]: Condition check resulted in First Boot Complete being skipped.
  5043  [    6.751830] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
  5044  [    6.752051] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
  5045  [    6.842318] systemd[1]: Found device /dev/ttyS0.
  5046  [    7.402050] systemd[1]: Found device /sys/subsystem/net/devices/eth0.
  5047  [    7.423452] systemd[1]: Started ifup for eth0.
  5048  [    7.427735] systemd[1]: Finished Helper to synchronize boot up for ifupdown.
  5049  [    7.435714] systemd[1]: Starting Raise network interfaces...
  5050  [    7.441059] systemd[1]: ifup@eth0.service: Main process exited, code=exited, status=1/FAILURE
  5051  [    7.442566] systemd[1]: ifup@eth0.service: Failed with result 'exit-code'.
  5052  [    8.004404] systemd[1]: networking.service: Main process exited, code=exited, status=1/FAILURE
  5053  [    8.005291] systemd[1]: networking.service: Failed with result 'exit-code'.
  5054  [    8.007020] systemd[1]: Failed to start Raise network interfaces.
  5055  [   10.579844] systemd[1]: Finished Armbian memory supported logging.
  5056  [   10.625691] systemd[1]: Starting Journal Service...
  5057  [   10.883893] systemd[1]: Started Journal Service.
  5058  [   10.935071] systemd-journald[586]: Received client request to flush runtime journal.
  5059  [   15.133231] phy_rtl8211e_led_fixup in
  5060  [   15.137038] dwmac-sun8i 1c30000.ethernet eth0: PHY [stmmac-0:01] driver [RTL8211E Gigabit Ethernet] (irq=POLL)
  5061  [   15.138465] dwmac-sun8i 1c30000.ethernet eth0: Register MEM_TYPE_PAGE_POOL RxQ-0
  5062  [   15.139409] dwmac-sun8i 1c30000.ethernet eth0: No Safety Features support found
  5063  [   15.139434] dwmac-sun8i 1c30000.ethernet eth0: No MAC Management Counters available
  5064  [   15.139445] dwmac-sun8i 1c30000.ethernet eth0: PTP not supported by HW
  5065  [   15.140270] dwmac-sun8i 1c30000.ethernet eth0: configuring for phy/rgmii-txid link mode
  5066  [   17.194174] dwmac-sun8i 1c30000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
  5067  [   17.194245] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
  5068  [   34.037165] vcc-mipi: disabling
  5069  [   34.037456] vcc-1v2-hsic: disabling
  5070
  5071
  5072
  5073  ### interrupts:
  5074             CPU0       CPU1       CPU2       CPU3
  5075   11:     464566     236186     253247     178562     GICv2  30 Level     arch_timer
  5076   14:     339196          0          0          0     GICv2  50 Level     timer@1c20c00
  5077   15:          0          0          0          0     GICv2 148 Level     arm-pmu
  5078   16:          0          0          0          0     GICv2 149 Level     arm-pmu
  5079   17:          0          0          0          0     GICv2 150 Level     arm-pmu
  5080   18:          0          0          0          0     GICv2 151 Level     arm-pmu
  5081   19:          0          0          0          0     GICv2  82 Level     1c02000.dma-controller
  5082   20:          0          0          0          0     GICv2 118 Level     1c0c000.lcd-controller
  5083   21:          0          0          0          0     GICv2 119 Level     1c0d000.lcd-controller
  5084   23:        230          0          0      16654     GICv2  92 Level     sunxi-mmc
  5085   24:         25          0          0          0     GICv2  93 Level     sunxi-mmc
  5086   25:          0          0          0          0     GICv2 126 Level     sun8i-ce-ns
  5087   26:          0          0          0          0     GICv2  81 Level     1c17000.mailbox
  5088   27:          0          0          0          0     GICv2 103 Level     musb-hdrc.4.auto
  5089   28:       7961      96518          0          0     GICv2 104 Level     ehci_hcd:usb1
  5090   29:          0          0          0          0     GICv2 105 Level     ohci_hcd:usb3
  5091   30:         65          0          0          0     GICv2 106 Level     ehci_hcd:usb2
  5092   31:          0          0          0          0     GICv2 107 Level     ohci_hcd:usb4
  5093   39:          0          0          0          0     GICv2  60 Level     1c22e00.codec
  5094   40:      68052          0          0          0     GICv2  63 Level     ths
  5095   41:          4          0          0          0     GICv2  32 Level     ttyS0
  5096   43:          0          0          0          0     GICv2  39 Level     mv64xxx_i2c
  5097   44:          0          0          0          0     GICv2  97 Level     sun6i-spi
  5098   45:     660564          0          0          0     GICv2 114 Level     eth0
  5099   55:          0          0          0          0     GICv2 120 Level     1ee0000.hdmi
  5100   56:          0          0          0          0  sun6i-r-intc  40 Level     1f00000.rtc
  5101   59:        168          0          0          0     GICv2  71 Level     sunxi-rsb
  5102   93:          0          0          0          0  sun6i-r-intc  32 Level     axp803
  5103  120:          0          0          0          0    axp803  26 Edge      axp20x-pek-dbr
  5104  121:          0          0          0          0    axp803  27 Edge      axp20x-pek-dbf
  5105  IPI0:     75981     144466     135009     123221       Rescheduling interrupts
  5106  IPI1:     15470     186070     177926       3412       Function call interrupts
  5107  IPI2:         0          0          0          0       CPU stop interrupts
  5108  IPI3:         0          0          0          0       CPU stop (for crash dump) interrupts
  5109  IPI4:         0      48234      34466      36387       Timer broadcast interrupts
  5110  IPI5:         0          0          0          0       IRQ work interrupts
  5111  IPI6:         0          0          0          0       CPU wake-up interrupts
  5112  Err:          0
Turns out there was an issue with a kernel update, i found out after uname -a witch pointed at a different kernel than installed. After reinstalling a preveous kernel docker started emediately... :) not shure this is a fix but hey it worked.
