Hello, using mk_format_patch and for <LOCAL GIT URL> am getting bad url its NOT git
git config [remote "origin"] physical look up or and any of git remote show origin - git remote -v etc will give the url if you dont know it already.
Any suggestions configuring the url for mk_format_patch
15 часов назад, ALIGMSTEN сказал:
Hello Alistair.
leo@localhost:/1.8T/gituser/armbian-build> url="cache/sources/linux-mainline/6.1"
leo@localhost:/1.8T/gituser/armbian-build> mkdir -p ~/tmp/test/patches.test
leo@localhost:/1.8T/gituser/armbian-build> tdir="/home/leo/tmp/test/patches.test"
leo@localhost:/1.8T/gituser/armbian-build> tools/mk_format_patch $url mego-6.1..HEAD "$tdir"
LOCAL GIT URL =: [/1.8T/gituser/armbian-build/cache/sources/linux-mainline/6.1]
revision range =: [mego-6.1..HEAD]
target folder for patches =: [/home/leo/tmp/test/patches.test]
prefix =: []
numbered =: [false]
    It's generate format-patch:
    In tmp folder: /tmp/format_patch_lD9TFyE
                All generated patches: [7]
                Good patches: [7]
leo@localhost:/1.8T/gituser/armbian-build> tree /home/leo/tmp/test/
/home/leo/tmp/test/
├── patches.test
│   ├── Doc-dt-bindings-usb-add-binding-for-DWC3-controller-on-Allwinne.patch
│   ├── drv-bluetooth-btrtl-Add-rtl8822cs-hci-ver-0008.patch
│   ├── drv-mfd-Add-support-for-AC200.patch
│   ├── drv-net-phy-Add-support-for-AC200-EPHY.patch
│   ├── drv-pinctrl-pinctrl-sun50i-a64-disable_strict_mode.patch
│   ├── drv-rtc-sun6i-support-RTCs-without-external-LOSCs.patch
│   └── Revert-net-Remove-net-ipx.h-and-uapi-linux-ipx.h-header-files.patch
└── series.test
1 directory, 8 files
After I applied all the "megous" patches, at the top of the story I made the tag "mego-6.1".
Now you can see at what stage my work is today.
Specify the full, absolute paths and everything will work.
