Hello, dear members! I built the mainline kernel 6.0.8 using the config-5.15.80-sunxi64 config, but when I try to boot the system hangs on Starting the kernel.
Boot log:
U-Boot 2023.01-rc3-00069-g93685d0dcb-dirty (Dec 19 2022 - 11:31:13 +0300) Allwinner Technology
CPU:   Allwinner H6 (SUN50I)
Model: OrangePi 3 LTS
DRAM:  2 GiB
Core:  50 devices, 14 uclasses, devicetree: separate
WDT:   Not starting watchdog@7020400
MMC:   mmc@4020000: 0, mmc@4022000: 1
Loading Environment from FAT... Unable to use mmc 0:1...
In:    serial@5000000
Out:   serial@5000000
Err:   serial@5000000
Net:   No ethernet found.
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
3259 bytes read in 2 ms (1.6 MiB/s)
## Executing script at 4fc00000
U-boot loaded from SD
Boot script loaded from mmc
203 bytes read in 2 ms (98.6 KiB/s)
37640 bytes read in 6 ms (6 MiB/s)
Working FDT set to 4fa00000
3844 bytes read in 5 ms (750 KiB/s)
Applying kernel provided DT fixup script (sun50i-h6-fixup.scr)
## Executing script at 45000000
19076290 bytes read in 940 ms (19.4 MiB/s)
22224904 bytes read in 1094 ms (19.4 MiB/s)
Moving Image from 0x40080000 to 0x40200000, end=417a0000
## Loading init Ramdisk from Legacy Image at 4ff00000 ...
   Image Name:   uInitrd
   Data Size:    19076226 Bytes = 18.2 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 4fa00000
   Booting using the fdt blob at 0x4fa00000
   Loading Ramdisk to 48dce000, end 49fff482 ... OK
   Loading Device Tree to 0000000048d5c000, end 0000000048dcdfff ... OK
Working FDT set to 48d5c000
Starting kernel ...
Sorry, IM use google-translate
