RX/TX stats on welcome banner (motd script): Refine RegEx to match real network interfaces only but ignore virtual interfaces by Docker & Co
Go to solution Solved by atone,
Environment:
Armbian on an Odroid-HC2 (Homecloud 2) which uses the odroid-xu4 firmware.
Reproduction:
  1. After initial installation on the welcome banner "RX today:" always shows a nice value.
  2. Install and run some docker containers. This changes /sys/class/net/ . AFAIK it adds so called "virtual network interfaces".
  3. From then on the Armbian welcome screen displays like this:
  • Error: Interface "veth•••••••" not found in database.
  • Note: • redacted by me.
Analysis:
/etc/default/armbian-motd
PRIMARY_INTERFACE="$(ls -1 /sys/class/net/ | grep -v lo | egrep "enp|eth" | head -1)"
The current regular expression falsely matches veth••••••• (created by Docker).
$ ls -1 /sys/class/net/
br-••••••••••••
docker0
enx••••••••••••
lo
veth•••••••
I fixed it for myself by changing PRIMARY_INTERFACE to this:
"$(ls -1 /sys/class/net/ | grep -v lo | egrep "^en" | head -1)"
Fix Proposal:
A developer with proper knowhow of the network interface naming conventions changes the default regular expression / pipe for PRIMARY_INTERFACE so that it safely only matches a real hardware interface for all typical systems, also working fine when using docker or other software which may create virtual network interfaces or other stub like entries there.
Notes:
  • This bug was already discussed in a forum thread in a "how to help yourself" manner.
  • This here now is a formal bug report with the inquiry to please fix it.
Edited by porg
Added note that this is a bug report
