martin-by Posted October 22, 2016 Posted October 22, 2016 Hello, now my system is running well on my Cubietruck: (ARMBIAN Ubuntu 16.04.1 LTS 4.8.1-sunxi) Booting from SDCard rootfs on SSD (installed via nand-sata-install script) Whereas a image backup of SDCard is easy, how to backup my rootfs on SSD for system fallback Szenario: Is there any good script to backup rootfs of SSD with shrinking function to get small backup files? simply TAR of "/" of SSD? Use of webmin backup functionality (howto store this backup on network drive outside my Cubietruck)? Best Regards, Martin
hanjo Posted October 23, 2016 Posted October 23, 2016 Hi Martin, I wouldn't say the following is the "best" backup strategy, but I'm using it for quite some time already and it has not failed me (yet). I'm using the following script to create a dump of my NAND. You will probably need to adapt the script, but it could serve you as a good starting point. Note that the script below is prepared for a second device and also for compressing the backup, but both is not done in the version below. It should be easy enough to enable it if required: #!/bin/bash NETWORKPATH="//server/share" # some CIFS share NETWORKUSER="username" NETWORKPASS="password" MOUNTPATH="/mnt/backup" # Setting up directories SUBDIR=cubie_backups DIR=$MOUNTPATH/$SUBDIR echo "Starting backup process!" # First check if pv package is installed, if not, install it first PACKAGESTATUS=$(dpkg -s pv | grep Status); if [[ $PACKAGESTATUS == S* ]] then echo "Package 'pv' is installed." else echo "Package 'pv' is NOT installed." echo "Installing package 'pv'. Please wait..." apt-get -y install pv fi # Mount network share mount -t cifs $NETWORKPATH $MOUNTPATH -o user=$NETWORKUSER,password=$NETWORKPASS if [ $? != 0 ]; then echo "Could not mount network share"; exit; fi # Check if backup directory exists if [ ! -d "$DIR" ]; then echo "Backup directory $DIR doesn't exist, creating it now!" mkdir $DIR fi # Create a filename with datestamp for our current backup (without .img suffix) OFILE="$DIR/backup_$(date +%Y%m%d_%H%M%S)" OFILE2="$DIR/backup_mmc_$(date +%Y%m%d_%H%M%S)" # Create final filename, with suffix OFILEFINAL=$OFILE.img OFILEFINAL2=$OFILE2.img # First sync disks sync; sync # Shut down some services before starting backup process #echo "Stopping some services before backup." #service apache2 stop #service mysql stop #service cron stop # Begin the backup process, should take about 1 hour from 8Gb SD card to HDD echo "Backing up internal NAND to fileserver" echo "This will take some time depending on your SD card size and read performance. Please wait..." SDSIZE=$(blockdev --getsize64 /dev/nand); pv -tpreba /dev/nand -s $SDSIZE | dd of=$OFILE bs=1M conv=sync,noerror iflag=fullblock # Wait for DD to finish and catch result RESULT=$? #SDSIZE2=$(blockdev --getsize64 /dev/mmcblk0); #pv -tpreba /dev/mmcblk0 -s $SDSIZE2 | dd of=$OFILE2 bs=1M conv=sync,noerror iflag=fullblock # Wait for DD to finish and catch result #RESULT=$(( $? | $RESULT )) # Start services again that where shutdown before backup process #echo "Start the stopped services again." #service apache2 start #service mysql start #service cron start # If command has completed successfully, delete previous backups and exit if [ $RESULT = 0 ]; then echo "Successful backup." #echo "Successful backup, previous backup files will be deleted." #rm -f $DIR/backup_*.tar.gz mv $OFILE $OFILEFINAL #mv $OFILE2 $OFILEFINAL2 #echo "Backup is being tarred. Please wait..." #tar zcf $OFILEFINAL.tar.gz $OFILEFINAL #rm -rf $OFILEFINAL echo "Backup process completed! FILE: $OFILEFINAL.tar.gz" umount $MOUNTPATH exit 0 # Else remove attempted backup file else echo "Backup failed! Previous backup files untouched." echo "Please check there is sufficient space on the HDD." rm -f $OFILE #rm -f $OFILE2 echo "Backup process failed!" umount $MOUNTPATH exit 1 fi I can't take all the credit for the above, since I have started from someone else's backup script. I cannot recall who it was though. Greetings Hanjo
