Hello armbianers !
Armbian 22.11.1 Bullseye with Linux 5.15.80-sunxi on a banana pi m1
I've connected a lipo battery to my bpi m1, and now when I try to shutdown -h 0, it ends up in a kernel panic and instead of shutting down it remains powered up. Is there anything I can do to fix that? I'd know how to shut it down talking to the axp209 via i2c, but I'm not sure how/where to put that, or if that would be or not the proper way to go.
Thanks,
George.
Ok, never mind. I went in a loop to [ armbian-config/switch to other kernels, chose the next newer kernel, apt update && upgrade ], and after a few rounds I got to:
Armbian 22.11.1 Bullseye with bleeding edge Linux 6.0.10-sunxi
In which everything works as it should ! :-)
shutdown -h 0 is now turning it off.
Cheers,
George
Hello!
Lemaker Banana Pi M1
The problem with the kernel 6.0.10 is that /sys/power/axp_pmu/ is no longer there... nor anywhere else as far I know.
tree /sys/power/axp_pmu/battery/
├── amperage
├── capacity
├── charge
├── charging
├── connected
├── power
├── ts_voltage
└── voltage
Any ideas why? Can I fix that? How?
Thanks,
George.
Edited by seif
