not sure if this problem is related to Armbian, but in my case it occurs only on an Armian system.
I have mainline kernel (4.7.x) running on a Banana Pro. wlan is configured as access point and works without any problems. eth0 is configured as client with static IP. The Banana is running 24/7, but the ethernet port is used only sporadically. The switch where eth0 is connected to is powered down most time. The problem is that eth0 forgets its IP configuration after a while, ifconfig then reports no IP address for eth0. I have to login via wlan and then ifdown/ifup eth0, then it works again. After a couple of hours (I dont know exactly how long), the IP is lost again. What is going wrong here?
Sorry, I forgot to mention two things.
First, a snippet from dmesg:
[146505.927251] sun7i-dwmac 1c50000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[158802.546876] sun7i-dwmac 1c50000.ethernet eth0: Link is Down
[231079.235691]  RX IPC Checksum Offload disabled
[231079.235726]  No MAC Management Counters available
[231578.280995] sun7i-dwmac 1c50000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
Second, this behavior did not occur with legacy kernel.
What about removing eth0 from /etc/network/interfaces and then as root
apt-get --no-install-recommends install network-manager
systemctl start network-manager
nmcli con add con-name Ethernet ifname eth0 type eth autoconnect yes ip4 192.168.1.101/24 gw4 192.168.1.1
You can then immediately change settings in an intuitive way using 'nmtui'. Network-manager should react on link state changes correctly otherwise what happens is non-deterministic (kernel dependant)
Thanks tkaiser,
I will try your suggestion. Can I be sure that network-manager does not interfere with the AP configuration of wlan0?
Network-manager doesn't touch any interfaces defined in /etc/network/interfaces or blacklisted in /etc/NetworkManager/NetworkManager.conf (unmanaged-devices=). Simply check using 'nmcli device show' and please report back. :)
Hm, there is no systemctl on my system. Did you mean sysctl?
But 'sudo sysctl start network-manager' reports
sysctl: cannot stat /proc/sys/start: No such file or directory
sysctl: cannot stat /proc/sys/network-manager: No such file or directory
Ok, I used 'sudo service start network-manager' and network-manager is up now.
However, 'nmcli con add con-name..' complains
Error: 'con' command 'add' is not valid.
Ok, you're using either Wheezy or Trusty (I'm testing only with Jessie or Xenial any more). Does setting up the Ethernet connection with 'nmtui' work?
