Opi zero 2 failed to boot uimage
Go to solution Solved by shyeline,
From the posts that I've read i think i have made the terrible mistake of updating the software via command. It was kinda slow so I did reboot command and the board since than won't start.
I've bought the uart adapter and the boot process is as follows:
https://pastebin.com/Pz1xb5jc
Can i get support?
13 часов назад, shyeline сказал:
Scanning mmc 0:1...
2669 bytes read in 2 ms (1.3 MiB/s)
## Executing script at 4fc00000
U-boot loaded from SD
Boot script loaded from mmc
180 bytes read in 2 ms (87.9 KiB/s)
No FDT memory address configured. Please configure
the FDT address via "fdt addr <address>" command.
Aborting!
Aborting!
It looks like you updated the kernel and the dtb, but interrupted the process and the installation did not finish its work. There are no necessary files.
Two options:
1) Download a new one and burn the whole image to the sd card.
2) Use an adapter for SD cards. Attach it to a running Linux computer and mount the root partition in /mnt. Then use the chroot command and reinstall the kernel and dtb packages.
