GPIO setup?
Go to solution Solved by mrkev,
10 hours ago, Efe Çetin said:
Which branch did you try? You should compile from next branch
I did compile the master branch. I suspect the GPIO constants come from additional custom files from OrangePI custom kernel... I haven't figured out where they have their source code but was going to dig more into the issue. Is there any repo I could just pull the most recent kernel packages from CI pipeline?
Edited by OttawaHacker
48 minutes ago, Efe Çetin said:
You shouldn't compile from master, it won't work with opi5. I compiled from next and it works without any problem
Hold on want to make sure I understand - are you referring to the branch armbian-next in the git repo? That branch is quite a bit behind the master branch - or what is that 'next' you are referring to?
