garfius Posted January 25, 2023 Share Posted January 25, 2023 (edited) Hello, i have an Orange Pi One H3 512Mb, running Hass(docker) pretty well for years. System Specifications: USB - 1Tb TF card (micro SD), via usb adapter, bought as fat32, formatted as exFat. - Arduino Nano-CH340 GPIO - Arduino Pro mini as binary sensor TF card (micro SD) - SanDisk 16Gb Kernel - Linux armbianKickAss 5.15.72-sunxi #22.08.4 SMP Fri Oct 7 16:45:35 UTC 2022 armv7l GNU/Linux PROBLEM: Commands 'mv' and 'cp' to 1Tb card results in the loss of files. Beheaviour: -shows the files for some time -Detected corruption when folder listed as follows: d????????? ? ? ? ? ? myFolder -fsck.exfat detects a LOT of errors, and removes most of the files TF card details Disk /dev/sda: 1000 GiB, 1073742872576 bytes, 2097154048 sectors Disk model: STORAGE DEVICE Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: dos Disk identifier: 0xff629fb5 Device Boot Start End Sectors Size Id Type /dev/sda1 32 2097154047 2097154016 1000G 7 HPFS/NTFS/exFAT Destruction of data root@armbianKickAss:/mnt# fsck.exfat -a /dev/sda1 exfatfsck 1.3.0 Checking file system on /dev/sda1. File system version 1.0 Sector size 512 bytes Cluster size 256 KB Volume size 1000 GB Used space 110 GB Available space 890 GB ERROR: unknown entry type 0xb0. Fix (Y/N)? Y ERROR: too long label (215 chars). ERROR: unknown entry type 0xf4. Fix (Y/N)? Y ----------------a lot of repeating lines----------- ERROR: unknown entry type 0x9f. Fix (Y/N)? Y Totally 13 directories and 19 files. File system checking finished. ERRORS FOUND: 77, FIXED: 76. Edited January 25, 2023 by garfius 0 Quote Link to comment Share on other sites More sharing options...
YF Chong Posted January 27, 2023 Share Posted January 27, 2023 Maybe you buy a fake 1TB Card 0 Quote Link to comment Share on other sites More sharing options...
