drush99 Posted October 22, 2016 Posted October 22, 2016 Greetings all. Today I tried updating my Odroid C2 to image 5.22 posted on Oct 22, 2016. And I got the following error during apt-get upgrade: Setting up linux-u-boot-odroidc2-default (5.22) ... /var/lib/dpkg/info/linux-u-boot-odroidc2-default.postinst: line 5: conditional binary operator expected /var/lib/dpkg/info/linux-u-boot-odroidc2-default.postinst: line 5: syntax error near `function' /var/lib/dpkg/info/linux-u-boot-odroidc2-default.postinst: line 5: `[[ == function ]] && setup_write_uboot_platform' I peaked at the code in /var/lib/dpkg/info/linux-u-boot-odroidc2-default.postinst contains #!/bin/bash source /usr/lib/u-boot/platform_install.sh [[ $DEVICE == /dev/null ]] && exit 0 [[ -z $DEVICE ]] && DEVICE="/dev/mmcblk0" [[ == function ]] && setup_write_uboot_platform write_uboot_platform $DIR $DEVICE exit 0 Which appears broken, so I updated it to: #!/bin/bash source /usr/lib/u-boot/platform_install.sh [[ $DEVICE == /dev/null ]] && exit 0 [[ -z $DEVICE ]] && DEVICE="/dev/mmcblk0" [[ $(type -t setup_write_uboot_platform) == function ]] && setup_write_uboot_platform write_uboot_platform $DIR $DEVICE exit 0 And the upgrade succeeded. Dunno where else to post this information. Hope it helps someone 1
