ZephyrNet Posted February 2, 2023 Posted February 2, 2023 Hi all, I am trying to recover after a failed NVMe install. I have a working install on an SDCard, but I think my board no longer boots to SDCard, since I flashed the bootloader via armbian-install. I am not sure if my NVMe install is good or not, and I can't currently reflash it. So I think my best bet is to wipe the SPI, which I hope means the board will go back to booting from SDCard. That's question 1 - is that actually a valid solution? If I wipe the SPI will I be able to again boot to SDCard? I am able to get the board into Maskrom mode, and I can see it using the Windows tool. However, I believe that I need a "loader image" that I "download" into the tool before I can wipe the bootloader. The Rock5 SPI wipe guide posted elsewhere in this forum refers to rk3588_spl_loader_v1.08.111.bin, which I don't have, and I'm not sure that's the right loader for the OPi5. That's question 2 - is there a loader for the OPi5 and/or can the Rock5 loader be used here? The OPi5 Manual is very sparse about Maskrom info, it says how to get into that mode, but only gives instructions for flashing the board to Android. The Android download is not working right now (Google Drive quota) so I am not able to get that package, in case it happens to have a suitable loader image. Thanks for any replies in advance. 0 Quote
Efe Çetin Posted February 2, 2023 Posted February 2, 2023 You can use rk3588_spl_loader_v1.08.111.bin. Check here https://github.com/rockchip-linux/rkbin 0 Quote
ZephyrNet Posted February 3, 2023 Author Posted February 3, 2023 Update: I was able to borrow an NVMe enclosure, I flashed the SSD with a fresh image on a different computer, and my board booted it just fine. I am still interested in knowing if zero'ing the SPI is a valid way to go back to SDCard booting. Thanks again for your help. 0 Quote
Efe Çetin Posted February 4, 2023 Posted February 4, 2023 I'm also able to boot from SD card with spi loader 0 Quote
pazzoide Posted February 5, 2023 Posted February 5, 2023 What if in the bootloader there could be an option to set the boot order, like in BIOS/uefi? Eg. 1St option is SSD 2nd is SD card (in case of 1St option fails) And so on Do you think this is this possible? 0 Quote
Jaybyrd Posted November 12, 2023 Posted November 12, 2023 Recover OrangePi 5 Plus Download: https://drive.google.com/drive/folders/19SMZHj1Y8l_Vvr6_SMDHYdJHi41hMgsI Press and hold the MASKROM button, then plug in USB power and release the MASKROM button Open a terminal in Linux and install "rkdeveloptool" *Note, I saved all the files in that URL to /home/$USER/opi5plus then "cd opi5plus" | use "sudo rkdeveloptool ld" to see if your device can be seen (plug in USB cable from PC to the USB-C connector opposite the power). opi5plus$ sudo rkdeveloptool db MiniLoaderAll.bin Downloading bootloader succeeded. opi5plus$ sudo rkdeveloptool ul MiniLoaderAll.bin Upgrading loader succeeded. opi5plus$ sudo rkdeveloptool td Test Device OK. opi5plus$ sudo rkdeveloptool rd Reset Device OK. Make sure you have a freshly baked SD card installed with your Linux flavor of choice then power off, install the SD card and boot up! 2 Quote
Paulkkl Posted December 29, 2024 Posted December 29, 2024 (edited) Hi Jaybyrd Good post, but i have a question that I have orange pi 5 Pro not plus. Are those file are same for all or difference for op 5 pro? It gives only red led on. Not booting. You may please contact on paulkkl0@gmail.com. Thanks in advance Paul Edited December 29, 2024 by Paulkkl 0 Quote
drewcephus Posted January 18 Posted January 18 How can you tell when you've actually entered maskrom mode? Does the redlight blink or anything. I have one that is flashed the spi on with the command line configuration tool, not rkdevelop. It's a brick until I figure out how to get it to maskrom mode. 0 Quote
Jacob Olness Posted January 30 Posted January 30 @drewcephus hold down the maskrom button, plug in the power, then plug in the data cable to your computer. I am running the cli tool so it is rkdeveloptool ld DevNo=1 Vid=0x2207,Pid=0x350b,LocationID=201 Maskrom The light doesn't blink or anything but itll show up as a device there (and when plugged in to the machine initially even) 0 Quote
nexusguy59 Posted September 2 Posted September 2 Hey Guys, I know this post is old but I have some questions. I was following @Jaybyrd's instructions and I have a question pertaining to the Plugin USB-C to the power on the device "I am assuming that is on The OPi5 device." Am I supposed to plug in something else? Because it says to open a terminal "what terminal? On what device?" Thank you for your time, Michael 0 Quote
SuperKali Posted September 21 Posted September 21 On 9/2/2025 at 2:09 PM, nexusguy59 said: open a terminal "what terminal? On what device?" You need to install rkdeveloptool on your PC. Connect the board to your PC using a USB-C to USB-A cable. Before powering the board, press and hold the mask button, then plug in the power cable. Once this is done, your PC should detect the device, and you can verify it with: rkdeveloptool ld You can follow this guide: https://docs.armbian.com/User-Guide_Getting-Started/#rockchip 0 Quote
