dochawk Posted February 6, 2023 Posted February 6, 2023 I was happy to find the Orange pi 4 armbian; it ignores raspbian an ubuntu images on sd and boots into android from its EMMC instead. The pi is an orange 4 LTS with 3gb RAM and 16gb EMMC. I have a 2tb crucial SSD attached through the usbc port. It is powered by a 4A supply through the DC port. it's purpose is to be a dedicated mythtv back end; it is wired by ethernet but also has wifi active. armbian-hardware-monitor.log is at https://paste.armbian.com/axayequliz it isn't showing up as a disk, as near as I can tell: Quote mythbackend:~:% ls /dev/disk/by-id mmc-AJTD4R_0x81704fbd mmc-SC16G_0x9345afab mmc-SC16G_0x9345afab-part1 the first is the EMMC, I believe, and the second my sandisk card. I haven't used linux since the late 90s when I switched to FreeBSD, and so much has changed . . . 0 Quote
dochawk Posted February 11, 2023 Author Posted February 11, 2023 (edited) The answer seems to be that the usbc connector either isn't really usbc, or that it won't supply power to a connected device. . I connected it to the type A usbc, and it was instantly found and appeared as /dev/sda Edited February 11, 2023 by dochawk 0 Quote
