Hey there,
I just joined the ARM universe & to be honest I lost all my skills with Linux.
First I tried some official images  Armbian_22.11.1_Rockpi-4cplus_jammy_current_5.15.80_xfce_desktop.img & with all of them I got a Blackscreen after the Logo. (all settings were made)
Then I a tried a pre-release so I could finally get into armbian.
Wifi :
I couldn't connect via. wifi, "wifi network could not be found"
But it was listed with a good signal strength.
BT:
no adapter was found. ( I used armconfig to enable BT)
USB:
just 3 of 4 usb ports were working.  ( I guess it was 1x usb 3.0 &  2x usb 2.0)
The Rock Pi ist connected via usbc and I tried different Power sources, Monitor (supercharging enabled), PC & and a seperate power supply with 3,5 A.
Then I tried librelec,(LibreELEC-RK3399.arm-10.0.4-rock-pi-4) there wasnt even a Wifi or a BT adapter listed.
And only 1 usb port were working.
And then I tried Debian and I finally got all USB ports working.
Also my BT adapter showed up the first time.
But I still wasnt able to connect to my wifi network, my network was listed but I got again: "wifi network could not be found"
With BT was nearly the same..., it listed my BT device but it couldn't connect.
I guess I'll give armbian another chance & also use another sd card (because the were some situations were it told me....path not found)
But the Issues with wifi & BT is everywhere present..., any tipps how to solve this ?
Any version recommendation ?
meanwhile I found out with the debian 11 beta from Radxa  Wifi & BT is working.  https://github.com/radxa-build/rock-4c-plus/releases/download/20230207-0209/rock-4c-plus_debian_bullseye_kde_2023-02-07T0210+0000_gpt.img.xz
But it isnt a stable version at all.
Would rather like find a solution get my board to work in armbian.
I also tried the latest  armbian minimal version for my board and it was booting properly, could also install the gui, but how to start ?
