krankes_etwas Posted February 9, 2023 Posted February 9, 2023 Hey there, I just joined the ARM universe & to be honest I lost all my skills with Linux. First I tried some official images Armbian_22.11.1_Rockpi-4cplus_jammy_current_5.15.80_xfce_desktop.img & with all of them I got a Blackscreen after the Logo. (all settings were made) Then I a tried a pre-release so I could finally get into armbian. Wifi : I couldn't connect via. wifi, "wifi network could not be found" But it was listed with a good signal strength. BT: no adapter was found. ( I used armconfig to enable BT) USB: just 3 of 4 usb ports were working. ( I guess it was 1x usb 3.0 & 2x usb 2.0) The Rock Pi ist connected via usbc and I tried different Power sources, Monitor (supercharging enabled), PC & and a seperate power supply with 3,5 A. Then I tried librelec,(LibreELEC-RK3399.arm-10.0.4-rock-pi-4) there wasnt even a Wifi or a BT adapter listed. And only 1 usb port were working. And then I tried Debian and I finally got all USB ports working. Also my BT adapter showed up the first time. But I still wasnt able to connect to my wifi network, my network was listed but I got again: "wifi network could not be found" With BT was nearly the same..., it listed my BT device but it couldn't connect. I guess I'll give armbian another chance & also use another sd card (because the were some situations were it told me....path not found) But the Issues with wifi & BT is everywhere present..., any tipps how to solve this ? Any version recommendation ? 0 Quote
krankes_etwas Posted February 10, 2023 Author Posted February 10, 2023 meanwhile I found out with the debian 11 beta from Radxa Wifi & BT is working. https://github.com/radxa-build/rock-4c-plus/releases/download/20230207-0209/rock-4c-plus_debian_bullseye_kde_2023-02-07T0210+0000_gpt.img.xz But it isnt a stable version at all. Would rather like find a solution get my board to work in armbian. I also tried the latest armbian minimal version for my board and it was booting properly, could also install the gui, but how to start ? 0 Quote
