Building Armbian on CI
bappelt
I would like to use a CI service to build Armbian images, ideally BitBucket pipelines since that is where most of my projects are. Has anyone had any success doing something similar?
I thought it would be easy since docker based builds are supported, but it seems the supported technique is to run a command on the host that starts a separate docker container. Most CI build now are already running in a container and while I think running docker inside docker is possible, I have not been able to get that to work well in the past.
Link to comment
Share on other sites
