robnielsen Posted March 8, 2023 Posted March 8, 2023 (edited) I'm struggling to get my Orange Pi 5 to boot to NVMe with Armbian 23.02 Bullseye CLI. With armbian-install I picked: 4 Boot from MTD Flash - system on SATA, USB or NVMe then install to /dev/nvme0n1p1, followed by updating the bootloader on mtdbblock0, and then powering off. When I remove the SD drive, and reboot. The console remains blank. When I insert the SD drive, and reboot again, the system comes up, and I can mount /dev/nvme0n1p1: $ df -h Filesystem Size Used Avail Use% Mounted on udev 7.7G 0 7.7G 0% /dev tmpfs 1.6G 9.6M 1.6G 1% /run /dev/mmcblk1p2 30G 2.0G 27G 7% / tmpfs 7.7G 0 7.7G 0% /dev/shm tmpfs 5.0M 4.0K 5.0M 1% /run/lock tmpfs 7.7G 0 7.7G 0% /tmp /dev/mmcblk1p1 256M 150M 106M 59% /boot /dev/zram1 49M 4.1M 41M 10% /var/log tmpfs 1.6G 0 1.6G 0% /run/user/1000 /dev/nvme0n1p1 234G 1.7G 221G 1% /mnt /dev/nvme0n1p1 looks like it's a clone of / Any ideas/suggestions? Edited March 8, 2023 by robnielsen more details 0 Quote
robnielsen Posted March 8, 2023 Author Posted March 8, 2023 I was able to get my Orange Pi 5 to boot to NVMe. I used https://jamesachambers.com/orange-pi-5-ssd-boot-guide/ as an example. Deleted partition on NVMe gdisk /dev/nvme0n1 Copied SD card to NVMD cat /dev/mmcblk1 > /dev/nvme0n1 Powered off the Orange Pi 5, removed the SD card and then powered it back on and it booted from the NVMe. I then resized the filesystem /usr/lib/armbian/armbian-resize-filesystem start Now I have: $ df -H Filesystem Size Used Avail Use% Mounted on udev 8.3G 0 8.3G 0% /dev tmpfs 1.7G 10M 1.7G 1% /run /dev/nvme0n1p2 254G 5.7G 245G 3% / tmpfs 8.3G 0 8.3G 0% /dev/shm tmpfs 5.3M 4.1k 5.3M 1% /run/lock tmpfs 8.3G 0 8.3G 0% /tmp /dev/nvme0n1p1 269M 158M 111M 59% /boot /dev/zram1 51M 4.8M 43M 11% /var/log tmpfs 1.7G 0 1.7G 0% /run/user/1000 $ mount | grep /dev/n /dev/nvme0n1p2 on / type ext4 (rw,noatime,errors=remount-ro,commit=600) /dev/nvme0n1p1 on /boot type vfat (rw,relatime,fmask=0022,dmask=0022,codepage=936,iocharset=utf8,shortname=mixed,errors=remount-ro) /dev/nvme0n1p2 on /var/log.hdd type ext4 (rw,noatime,errors=remount-ro,commit=600) 0 Quote
stk Posted March 8, 2023 Posted March 8, 2023 I have used the simple way( prompted by etho201): 1. Using the balenaetcher write the same armbian image to a microSd and to a nvme m.2 SSD too. 2. Put the microSd and the nvme SSD into your orange pi 5. 3. Turn on, load from microSd, start armbian-config, install updates and after that defreeze kernel upgrades. 4. At the same place (armbian-config) write the bootloader on spi MTD, shutdown and remove microSd. 5. Turn on again and load from nvme SSD. 0 Quote
