Hey guys,
First of all I would like to let you know that the default DTB has an issue, the GPU status is disabled by default.
I've changed this & now my GPU is detected & working fine so far.
(Armbian Jammy current)
But I'm also facing some other Issues....
  • not all USB Ports are working, just 2-3 & the working ports sometime are randomly switching after a reboot.
  • Bluetooth isn't working at all
I guess these Issues are also related to the dtb file because I didn't find any entries for BT in the DTB.
I also tried the other DTB file:  rk3399-rock-4c-plus but I dont have any video output with it but there I found some entries related to BT (default is rk3399-rock-pi-4c-plus)
I also noticed I didn't get any Video output from the latest sid & edge, but Kernel was loaded.
Then I forced the Resolution in the Armbian.env to 1080p, with that settings I got vidio ouput during the boot time & CLI.
But as soon the Xserver has started I got no more Video output or I got a weird/broken video output.
Probably its an gpu driver Issue....
I should also mention that my  GPU isn't working & detected in Debian too (all kernels)
But as I understood  right the gpu isn't deactivated in the DTB file from Debian, but except the gpu everythings is working.
Here are the Logs & DTS files
Any ideas how to solve this ?
Edited by krankes_etwas
