I am trying to use my NanoPi neo Plus 2 rev 1.2 board as KVM with help of (kvmd-armbian) and USB-HDMI capture card and USB-A to USB-A cable as OTG for emulation of Keyboard and mouse as HID.
I discoverred that If I install "Armbian 23.02 Jammy with Kernel 5.15.y" like the install script from srepac/kvmd-armbian recommends, updated it and installed the srepac/kvmd-armbian piKVM, it installed properly and it is working BUT
to my OTG USB HID connection to work I had to convert sun50i-h5-nanopi-neo-plus2.dtb to sun50i-h5-nanopi-neo-plus2.dts and in there find "dr_mode" and change it to peripheral (or otg) to get my HID OTG input to work  which is working BUT my USB-HDMI Capture card (ID 534d:2109 MacroSilicon) is not working BECAUSE i discoverred that If i plug the capture card into my NanoPi neo Plus 2`s USB port (Closer to ethernet port because further from the ethernet port that is OTG as USB-A (OTG is not Micro-USB as many sources claims on the web)) I have USB 1.1 speeds but the card is detected as USB 2.0 (which it is).
in lsusb there it is as 12M the Macrosilicon HDMI to USB capture card.
lsusb -t -v
/:  Bus 09.Port 1: Dev 1, Class=root_hub, Driver=musb-hdrc/1p, 480M
    ID 1d6b:0002 Linux Foundation 2.0 root hub
/:  Bus 08.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M
    ID 1d6b:0001 Linux Foundation 1.1 root hub
    |__ Port 1: Dev 3, If 0, Class=Video, Driver=uvcvideo, 12M
    |__ Port 1: Dev 3, If 1, Class=Video, Driver=uvcvideo, 12M
/:  Bus 07.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M
/:  Bus 06.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M
/:  Bus 05.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M
/:  Bus 04.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M
/:  Bus 03.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M
/:  Bus 02.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M
/:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M
If I list lshw the the USB hubs are shown and usbhost:7 is where under it is my USB Video HDMI Capture card and it shows 1.1 speed for the host but 2.0 speed for the card:
  *-usbhost:0
       product: EHCI Host Controller
       vendor: Linux 5.15.93-sunxi64 ehci_hcd
       physical id: 2
       bus info: usb@1
       logical name: usb1
       version: 5.15
       capabilities: usb-2.00
       configuration: driver=hub slots=1 speed=480Mbit/s
  *-usbhost:1
       physical id: 3
       bus info: usb@2
       logical name: usb2
       version: 5.15
  *-usbhost:2
       physical id: 4
       bus info: usb@3
       logical name: usb3
       version: 5.15
  *-usbhost:3
       physical id: 5
       bus info: usb@4
       logical name: usb4
       version: 5.15
  *-usbhost:4
       product: Generic Platform OHCI controller
       vendor: Linux 5.15.93-sunxi64 ohci_hcd
       physical id: 6
       bus info: usb@5
       logical name: usb5
       version: 5.15
       capabilities: usb-1.10
       configuration: driver=hub slots=1 speed=12Mbit/s
  *-usbhost:5
       physical id: 7
       bus info: usb@6
       logical name: usb6
       version: 5.15
  *-usbhost:6
       physical id: 8
       bus info: usb@7
       logical name: usb7
       version: 5.15
  *-usbhost:7
       physical id: 9
       bus info: usb@8
       logical name: usb8
       version: 5.15
     *-usb
          description: Video
          product: USB Video
          vendor: MACROSILICON
          physical id: 1
          bus info: usb@8:1
          version: 21.00
          configuration: driver=uvcvideo maxpower=500mA speed=12Mbit/s
  *-usbhost:8
       product: MUSB HDRC host driver
       vendor: Linux 5.15.93-sunxi64 musb-hcd
       physical id: 1
       bus info: usb@9
       logical name: usb9
       version: 5.15
No power issue, tried it with powered USB Hub and the result is same.
No Hardware issue because The whole setup is working on different (outdated) Arch image from https://github.com/Yura80/os/releases (v2-hdmiusb-generic-aarch64-nanopi-neo2.img)
I am connecting my system diagnosis information via armbianmonitor -u
https://paste.armbian.com/acoxifotik
I am uploaded my .dts file, I assuming this is somehow wrong bacuse it should not be possible to USB host worked on USB1.1 speed and registerring that the USB-HDMI capture card is USB2.0, and it is working on one Image and not working on other.
My Question is What shoul I edit, install / uninstall / reinstall, to be able to properly use my NanoPi neo Plus 2 USB with USB2.0 speeds and use my USB-HDMI Capture card without any issue ????
Sincerely, thank you for help.
Edited by Peterkal
added my question.
OK, so I made a workaround.
I installed Armbian_21.02.1_Nanopineoplus2_focal_current_5.10.12_minimal.img
Installed it to eMMC and then Updated and Upgraded it to 23.02.2 and 5.15.93-sunxi64. I used this instructions: Manually upgrading Armbian Focal -> Jammy on ODroid N2+
umane -a
Linux nanopineoplus2 5.15.93-sunxi64 #23.02.2 SMP Fri Feb 17 23:48:38 UTC 2023 aarch64 aarch64 aarch64 GNU/Linux
 lsusb -t
    |__ Port 1: Dev 2, If 0, Class=Video, Driver=uvcvideo, 480M
    |__ Port 1: Dev 2, If 1, Class=Video, Driver=uvcvideo, 480M
    |__ Port 1: Dev 2, If 2, Class=Audio, Driver=snd-usb-audio, 480M
    |__ Port 1: Dev 2, If 3, Class=Audio, Driver=snd-usb-audio, 480M
    |__ Port 1: Dev 2, If 4, Class=Human Interface Device, Driver=usbhid, 480M
Finally My USB HDMI capture card is operating with USB2.0 speeds.
I am connecting armbianmonitor -u
http://ix.io/4qJO
apt list --installed
Listing... Done
adduser/jammy,jammy,now 3.118ubuntu5 all [installed]
apt-transport-https/jammy-updates,jammy-updates,now 2.4.8 all [installed]
apt-utils/jammy-updates,now 2.4.8 arm64 [installed]
apt/jammy-updates,now 2.4.8 arm64 [installed]
armbian-config/jammy,jammy,jammy,now 23.02.2 all [installed]
armbian-firmware/jammy,jammy,jammy,now 23.02.2 all [installed]
base-files/jammy-updates,now 12ubuntu4.3 arm64 [installed]
base-passwd/jammy,now 3.5.52build1 arm64 [installed]
bash/jammy,now 5.1-6ubuntu1 arm64 [installed]
bc/jammy,now 1.07.1-3build1 arm64 [installed]
binutils-aarch64-linux-gnu/jammy-security,jammy-updates,now 2.38-4ubuntu2.1 arm64 [installed,automatic]
binutils-common/jammy-security,jammy-updates,now 2.38-4ubuntu2.1 arm64 [installed,automatic]
binutils/jammy-security,jammy-updates,now 2.38-4ubuntu2.1 arm64 [installed,automatic]
bsdutils/jammy,now 1:2.37.2-4ubuntu3 arm64 [installed]
build-essential/jammy,now 12.9ubuntu3 arm64 [installed]
busybox-initramfs/jammy,now 1:1.30.1-7ubuntu3 arm64 [installed]
bzip2/jammy,now 1.0.8-5build1 arm64 [installed]
ca-certificates/jammy-security,jammy-security,jammy-updates,jammy-updates,now 20211016ubuntu0.22.04.1 all [installed]
chrony/jammy,now 4.2-2ubuntu2 arm64 [installed]
console-setup-linux/jammy,jammy,now 1.205ubuntu3 all [installed]
console-setup/jammy,jammy,now 1.205ubuntu3 all [installed]
coreutils/jammy,now 8.32-4.1ubuntu1 arm64 [installed]
cpio/jammy,now 2.13+dfsg-7 arm64 [installed]
cpp-11/jammy-security,jammy-updates,now 11.3.0-1ubuntu1~22.04 arm64 [installed,automatic]
cpp/jammy,now 4:11.2.0-1ubuntu1 arm64 [installed,automatic]
cpufrequtils/jammy,now 008-2build1 arm64 [installed]
cracklib-runtime/jammy,now 2.9.6-3.4build4 arm64 [installed]
crda/now 3.18-1build1 arm64 [installed,local]
cron/jammy,now 3.0pl1-137ubuntu3 arm64 [installed]
curl/jammy-security,jammy-updates,now 7.81.0-1ubuntu1.8 arm64 [installed]
dash/jammy,now 0.5.11+git20210903+057cd650a4ed-3build1 arm64 [installed]
dbus-user-session/jammy-security,jammy-updates,now 1.12.20-2ubuntu4.1 arm64 [installed,automatic]
dbus/jammy-security,jammy-updates,now 1.12.20-2ubuntu4.1 arm64 [installed]
dconf-gsettings-backend/jammy,now 0.40.0-3 arm64 [installed,automatic]
dconf-service/jammy,now 0.40.0-3 arm64 [installed,automatic]
debconf-utils/jammy,jammy,now 1.5.79ubuntu1 all [installed]
debconf/jammy,jammy,now 1.5.79ubuntu1 all [installed]
debianutils/jammy,now 5.5-1ubuntu2 arm64 [installed]
device-tree-compiler/jammy,now 1.6.1-1 arm64 [installed]
dialog/jammy,now 1.3-20211214-1 arm64 [installed]
diffutils/jammy,now 1:3.8-0ubuntu2 arm64 [installed]
dirmngr/jammy-security,jammy-updates,now 2.2.27-3ubuntu2.1 arm64 [installed]
distro-info-data/jammy-updates,jammy-updates,now 0.52ubuntu0.2 all [installed,automatic]
dmsetup/jammy,now 2:1.02.175-2.1ubuntu4 arm64 [installed]
dnsmasq-base/jammy-security,jammy-updates,now 2.86-1.1ubuntu0.1 arm64 [installed,automatic]
dnsmasq/jammy-security,jammy-security,jammy-updates,jammy-updates,now 2.86-1.1ubuntu0.1 all [installed]
dos2unix/jammy,now 7.4.2-2 arm64 [installed]
dpkg-dev/jammy-security,jammy-security,jammy-updates,jammy-updates,now 1.21.1ubuntu2.1 all [installed,automatic]
dpkg-repack/jammy,jammy,now 1.50 all [installed]
dpkg/jammy-security,jammy-updates,now 1.21.1ubuntu2.1 arm64 [installed]
e2fsprogs/jammy-security,jammy-updates,now 1.46.5-2ubuntu1.1 arm64 [installed]
expect/jammy,now 5.45.4-2build1 arm64 [installed]
fake-hwclock/jammy,jammy,now 0.12 all [installed]
fdisk/jammy,now 2.37.2-4ubuntu3 arm64 [installed]
ffmpeg/jammy-security,jammy-updates,now 7:4.4.2-0ubuntu0.22.04.1 arm64 [installed]
figlet/jammy,now 2.2.5-3 arm64 [installed]
file/jammy,now 1:5.41-3 arm64 [installed,automatic]
findutils/jammy,now 4.8.0-1ubuntu3 arm64 [installed]
fontconfig-config/jammy,jammy,now 2.13.1-4.2ubuntu5 all [installed,automatic]
fontconfig/jammy,now 2.13.1-4.2ubuntu5 arm64 [installed,automatic]
fonts-dejavu-core/jammy,jammy,now 2.37-2build1 all [installed,automatic]
fping/jammy,now 5.1-1 arm64 [installed]
g++-11/jammy-security,jammy-updates,now 11.3.0-1ubuntu1~22.04 arm64 [installed,automatic]
g++/jammy,now 4:11.2.0-1ubuntu1 arm64 [installed,automatic]
gcc-10-base/jammy-security,jammy-updates,now 10.4.0-4ubuntu1~22.04 arm64 [installed]
gcc-11-base/jammy-security,jammy-updates,now 11.3.0-1ubuntu1~22.04 arm64 [installed,automatic]
gcc-11/jammy-security,jammy-updates,now 11.3.0-1ubuntu1~22.04 arm64 [installed,automatic]
gcc-12-base/jammy-security,jammy-updates,now 12.1.0-2ubuntu1~22.04 arm64 [installed,automatic]
gcc/jammy,now 4:11.2.0-1ubuntu1 arm64 [installed]
gir1.2-freedesktop/jammy,now 1.72.0-1 arm64 [installed,automatic]
gir1.2-glib-2.0/jammy,now 1.72.0-1 arm64 [installed,automatic]
gir1.2-gssdp-1.2/jammy,now 1.4.0.1-2build1 arm64 [installed,automatic]
gir1.2-gupnp-1.2/jammy,now 1.4.3-1 arm64 [installed,automatic]
gir1.2-gupnpigd-1.0/jammy,now 1.2.0-1build1 arm64 [installed,automatic]
gir1.2-nice-0.1/jammy,now 0.1.18-2 arm64 [installed,automatic]
gir1.2-packagekitglib-1.0/jammy,now 1.2.5-2ubuntu2 arm64 [installed,automatic]
gir1.2-soup-2.4/jammy,now 2.74.2-3 arm64 [installed,automatic]
git-man/jammy-security,jammy-security,jammy-updates,jammy-updates,now 1:2.34.1-1ubuntu1.8 all [installed,automatic]
git/jammy-security,jammy-updates,now 1:2.34.1-1ubuntu1.8 arm64 [installed]
glib-networking-common/jammy,jammy,now 2.72.0-1 all [installed,automatic]
glib-networking-services/jammy,now 2.72.0-1 arm64 [installed,automatic]
glib-networking/jammy,now 2.72.0-1 arm64 [installed,automatic]
gnupg-l10n/jammy-security,jammy-security,jammy-updates,jammy-updates,now 2.2.27-3ubuntu2.1 all [installed]
gnupg-utils/jammy-security,jammy-updates,now 2.2.27-3ubuntu2.1 arm64 [installed]
gnupg/jammy-security,jammy-security,jammy-updates,jammy-updates,now 2.2.27-3ubuntu2.1 all [installed]
gpg-agent/jammy-security,jammy-updates,now 2.2.27-3ubuntu2.1 arm64 [installed]
gpg-wks-client/jammy-security,jammy-updates,now 2.2.27-3ubuntu2.1 arm64 [installed]
gpg-wks-server/jammy-security,jammy-updates,now 2.2.27-3ubuntu2.1 arm64 [installed]
gpg/jammy-security,jammy-updates,now 2.2.27-3ubuntu2.1 arm64 [installed]
gpgconf/jammy-security,jammy-updates,now 2.2.27-3ubuntu2.1 arm64 [installed]
gpgsm/jammy-security,jammy-updates,now 2.2.27-3ubuntu2.1 arm64 [installed]
gpgv/jammy-security,jammy-updates,now 2.2.27-3ubuntu2.1 arm64 [installed]
gpiod/jammy,now 1.6.3-1build1 arm64 [installed]
grep/jammy,now 3.7-1build1 arm64 [installed]
gsettings-desktop-schemas/jammy,jammy,now 42.0-1ubuntu1 all [installed,automatic]
gzip/jammy-updates,now 1.10-4ubuntu4.1 arm64 [installed]
hostapd/jammy,now 3:2.10-6~armbian22.02.3+1 arm64 [installed]
hostname/jammy,now 3.23ubuntu2 arm64 [installed]
html2text/jammy,now 1.3.2a-28 arm64 [installed,automatic]
htop/now 3.1.0-0~armbian20.08.2+1 arm64 [installed,local]
icu-devtools/jammy,now 70.1-2 arm64 [installed,automatic]
iftop/jammy,now 1.0~pre4-7 arm64 [installed]
ifupdown/jammy,now 0.8.36+nmu1ubuntu3 arm64 [installed]
init-system-helpers/jammy,jammy,now 1.62 all [installed]
init/jammy,now 1.62 arm64 [installed]
initramfs-tools-bin/jammy-updates,now 0.140ubuntu13.1 arm64 [installed]
initramfs-tools-core/jammy-updates,jammy-updates,now 0.140ubuntu13.1 all [installed]
initramfs-tools/jammy-updates,jammy-updates,now 0.140ubuntu13.1 all [installed]
iozone3/jammy,now 489-1 arm64 [installed]
iperf3/jammy,now 3.9-1build1 arm64 [installed,automatic]
iproute2/jammy,now 5.15.0-1ubuntu2 arm64 [installed]
iptables/jammy,now 1.8.7-1ubuntu5 arm64 [installed]
iputils-ping/jammy,now 3:20211215-1 arm64 [installed]
isc-dhcp-client/jammy-updates,now 4.4.1-2.3ubuntu2.4 arm64 [installed]
iso-codes/jammy,jammy,now 4.9.0-1 all [installed,automatic]
iw/jammy,now 5.16-1build1 arm64 [installed]
janus-dev/jammy,now 0.11.8-3 arm64 [installed]
janus/jammy,now 0.11.8-3 arm64 [installed]
jq/jammy,now 1.6-2.1ubuntu3 arm64 [installed]
kbd/jammy-updates,now 2.3.0-3ubuntu4.22.04 arm64 [installed]
keyboard-configuration/jammy,jammy,now 1.205ubuntu3 all [installed]
keyutils/jammy,now 1.6.1-2ubuntu3 arm64 [installed,automatic]
klibc-utils/jammy,now 2.0.10-4 arm64 [installed]
kmod/jammy,now 29-1ubuntu1 arm64 [installed]
less/jammy-security,jammy-updates,now 590-1ubuntu0.22.04.1 arm64 [installed]
libacl1/jammy,now 2.3.1-1 arm64 [installed]
libaom3/jammy,now 3.3.0-1 arm64 [installed,automatic]
libapparmor1/jammy-updates,now 3.0.4-2ubuntu2.1 arm64 [installed]
libappstream4/jammy,now 0.15.2-2 arm64 [installed,automatic]
libapt-pkg6.0/jammy-updates,now 2.4.8 arm64 [installed]
libarchive13/jammy,now 3.6.0-1ubuntu1 arm64 [installed,automatic]
libargon2-1/jammy,now 0~20171227-0.3 arm64 [installed]
libasan6/jammy-security,jammy-updates,now 11.3.0-1ubuntu1~22.04 arm64 [installed,automatic]
libasn1-8-heimdal/jammy,now 7.7.0+dfsg-3ubuntu1 arm64 [installed]
libasound2-data/jammy,jammy,now 1.2.6.1-1ubuntu1 all [installed,automatic]
libasound2/jammy,now 1.2.6.1-1ubuntu1 arm64 [installed,automatic]
libass9/jammy,now 1:0.15.2-1 arm64 [installed,automatic]
libassuan0/jammy,now 2.5.5-1build1 arm64 [installed]
libasyncns0/jammy,now 0.8-6build2 arm64 [installed,automatic]
libatomic1/jammy-security,jammy-updates,now 12.1.0-2ubuntu1~22.04 arm64 [installed,automatic]
libattr1/jammy,now 1:2.5.1-1build1 arm64 [installed]
libaudit-common/jammy,jammy,now 1:3.0.7-1build1 all [installed]
libaudit1/jammy,now 1:3.0.7-1build1 arm64 [installed]
libavc1394-0/jammy,now 0.5.4-5build2 arm64 [installed,automatic]
libavcodec58/jammy-security,jammy-updates,now 7:4.4.2-0ubuntu0.22.04.1 arm64 [installed,automatic]
libavdevice58/jammy-security,jammy-updates,now 7:4.4.2-0ubuntu0.22.04.1 arm64 [installed,automatic]
libavfilter7/jammy-security,jammy-updates,now 7:4.4.2-0ubuntu0.22.04.1 arm64 [installed,automatic]
libavformat58/jammy-security,jammy-updates,now 7:4.4.2-0ubuntu0.22.04.1 arm64 [installed,automatic]
libavutil56/jammy-security,jammy-updates,now 7:4.4.2-0ubuntu0.22.04.1 arm64 [installed,automatic]
libbinutils/jammy-security,jammy-updates,now 2.38-4ubuntu2.1 arm64 [installed,automatic]
libblas3/jammy,now 3.10.0-2ubuntu1 arm64 [installed,automatic]
libblkid-dev/jammy,now 2.37.2-4ubuntu3 arm64 [installed,automatic]
libblkid1/jammy,now 2.37.2-4ubuntu3 arm64 [installed]
libbluetooth3/jammy,now 5.64-0ubuntu1 arm64 [installed,automatic]
libbluray2/jammy,now 1:1.3.1-1 arm64 [installed,automatic]
libbpf0/jammy-security,jammy-updates,now 1:0.5.0-1ubuntu22.04.1 arm64 [installed,automatic]
libbrotli-dev/jammy,now 1.0.9-2build6 arm64 [installed,automatic]
libbrotli1/jammy,now 1.0.9-2build6 arm64 [installed,automatic]
libbs2b0/jammy,now 3.1.0+dfsg-2.2build1 arm64 [installed,automatic]
libbsd-dev/jammy,now 0.11.5-1 arm64 [installed]
libbsd0/jammy,now 0.11.5-1 arm64 [installed]
libbz2-1.0/jammy,now 1.0.8-5build1 arm64 [installed]
libc-bin/jammy-updates,now 2.35-0ubuntu3.1 arm64 [installed]
libc-dev-bin/jammy-updates,now 2.35-0ubuntu3.1 arm64 [installed,automatic]
libc6-dev/jammy-updates,now 2.35-0ubuntu3.1 arm64 [installed,automatic]
libc6/jammy-updates,now 2.35-0ubuntu3.1 arm64 [installed]
libcaca0/jammy,now 0.99.beta19-2.2ubuntu4 arm64 [installed,automatic]
libcairo-gobject2/jammy,now 1.16.0-5ubuntu2 arm64 [installed,automatic]
libcairo2/jammy,now 1.16.0-5ubuntu2 arm64 [installed,automatic]
libcap-ng0/jammy,now 0.7.9-2.2build3 arm64 [installed]
libcap2-bin/jammy,now 1:2.44-1build3 arm64 [installed]
libcap2/jammy,now 1:2.44-1build3 arm64 [installed]
libcbor0.8/jammy,now 0.8.0-2ubuntu1 arm64 [installed,automatic]
libcc1-0/jammy-security,jammy-updates,now 12.1.0-2ubuntu1~22.04 arm64 [installed,automatic]
libcdio-cdda2/jammy,now 10.2+2.0.0-1build3 arm64 [installed,automatic]
libcdio-paranoia2/jammy,now 10.2+2.0.0-1build3 arm64 [installed,automatic]
libcdio19/jammy,now 2.1.0-3build1 arm64 [installed,automatic]
libchromaprint1/jammy,now 1.5.1-2 arm64 [installed,automatic]
libcodec2-1.0/jammy,now 1.0.1-3 arm64 [installed,automatic]
libcom-err2/jammy-security,jammy-updates,now 1.46.5-2ubuntu1.1 arm64 [installed]
libconfig9/jammy,now 1.5-0.4build1 arm64 [installed,automatic]
libcpufreq0/jammy,now 008-2build1 arm64 [installed,automatic]
libcrack2/jammy,now 2.9.6-3.4build4 arm64 [installed]
libcrypt-dev/jammy,now 1:4.4.27-1 arm64 [installed,automatic]
libcrypt1/jammy,now 1:4.4.27-1 arm64 [installed]
libcryptsetup12/jammy-updates,now 2:2.4.3-1ubuntu1.1 arm64 [installed]
libctf-nobfd0/jammy-security,jammy-updates,now 2.38-4ubuntu2.1 arm64 [installed,automatic]
libctf0/jammy-security,jammy-updates,now 2.38-4ubuntu2.1 arm64 [installed,automatic]
libcurl3-gnutls/jammy-security,jammy-updates,now 7.81.0-1ubuntu1.8 arm64 [installed,automatic]
libcurl4-openssl-dev/jammy-security,jammy-updates,now 7.81.0-1ubuntu1.8 arm64 [installed,automatic]
libcurl4/jammy-security,jammy-updates,now 7.81.0-1ubuntu1.8 arm64 [installed,automatic]
libdatrie1/jammy,now 0.2.13-2 arm64 [installed,automatic]
libdav1d5/jammy,now 0.9.2-1 arm64 [installed,automatic]
libdb5.3/jammy,now 5.3.28+dfsg1-0.8ubuntu3 arm64 [installed]
libdbus-1-3/jammy-security,jammy-updates,now 1.12.20-2ubuntu4.1 arm64 [installed]
libdc1394-25/jammy,now 2.2.6-4 arm64 [installed,automatic]
libdconf1/jammy,now 0.40.0-3 arm64 [installed,automatic]
libdebconfclient0/jammy,now 0.261ubuntu1 arm64 [installed]
libdecor-0-0/jammy,now 0.1.0-3build1 arm64 [installed,automatic]
libdeflate0/jammy,now 1.10-2 arm64 [installed,automatic]
libdevmapper1.02.1/jammy,now 2:1.02.175-2.1ubuntu4 arm64 [installed]
libdns-export1109/now 1:9.11.16+dfsg-3~ubuntu1 arm64 [installed,local]
libdns-export1110/jammy,now 1:9.11.19+dfsg-2.1ubuntu3 arm64 [installed,automatic]
libdpkg-perl/jammy-security,jammy-security,jammy-updates,jammy-updates,now 1.21.1ubuntu2.1 all [installed,automatic]
libdrm-amdgpu1/jammy-updates,now 2.4.113-2~ubuntu0.22.04.1 arm64 [installed,automatic]
libdrm-common/jammy-updates,jammy-updates,now 2.4.113-2~ubuntu0.22.04.1 all [installed,automatic]
libdrm-nouveau2/jammy-updates,now 2.4.113-2~ubuntu0.22.04.1 arm64 [installed,automatic]
libdrm-radeon1/jammy-updates,now 2.4.113-2~ubuntu0.22.04.1 arm64 [installed,automatic]
libdrm2/jammy-updates,now 2.4.113-2~ubuntu0.22.04.1 arm64 [installed,automatic]
libdw1/jammy,now 0.186-1build1 arm64 [installed,automatic]
libedit2/jammy,now 3.1-20210910-1build1 arm64 [installed,automatic]
libelf1/jammy,now 0.186-1build1 arm64 [installed]
liberror-perl/jammy,jammy,now 0.17029-1 all [installed,automatic]
libestr0/jammy,now 0.1.10-2.1build3 arm64 [installed]
libev4/jammy,now 1:4.33-1 arm64 [installed,automatic]
libevent-2.1-7/jammy,now 2.1.12-stable-1build3 arm64 [installed]
libevent-core-2.1-7/jammy,now 2.1.12-stable-1build3 arm64 [installed]
libevent-dev/jammy,now 2.1.12-stable-1build3 arm64 [installed]
libevent-extra-2.1-7/jammy,now 2.1.12-stable-1build3 arm64 [installed,automatic]
libevent-openssl-2.1-7/jammy,now 2.1.12-stable-1build3 arm64 [installed,automatic]
libevent-pthreads-2.1-7/jammy,now 2.1.12-stable-1build3 arm64 [installed]
libexpat1-dev/jammy-security,jammy-updates,now 2.4.7-1ubuntu0.2 arm64 [installed,automatic]
libexpat1/jammy-security,jammy-updates,now 2.4.7-1ubuntu0.2 arm64 [installed]
libext2fs2/jammy-security,jammy-updates,now 1.46.5-2ubuntu1.1 arm64 [installed]
libfastjson4/jammy,now 0.99.9-1build2 arm64 [installed]
libfdisk1/jammy,now 2.37.2-4ubuntu3 arm64 [installed]
libfdt1/jammy,now 1.6.1-1 arm64 [installed,automatic]
libffi-dev/jammy,now 3.4.2-4 arm64 [installed,automatic]
libffi7/jammy,now 3.3-5ubuntu1 arm64 [installed]
libffi8/jammy,now 3.4.2-4 arm64 [installed,automatic]
libfido2-1/jammy,now 1.10.0-1 arm64 [installed,automatic]
libflac8/jammy-security,jammy-updates,now 1.3.3-2ubuntu0.1 arm64 [installed,automatic]
libflite1/jammy,now 2.2-3 arm64 [installed,automatic]
libfontconfig1/jammy,now 2.13.1-4.2ubuntu5 arm64 [installed,automatic]
libfreetype6/jammy-security,jammy-updates,now 2.11.1+dfsg-1ubuntu0.1 arm64 [installed,automatic]
libfribidi0/jammy-security,jammy-updates,now 1.0.8-2ubuntu3.1 arm64 [installed,automatic]
libgbm1/jammy-updates,now 22.2.5-0ubuntu0.1~22.04.1 arm64 [installed,automatic]
libgcc-11-dev/jammy-security,jammy-updates,now 11.3.0-1ubuntu1~22.04 arm64 [installed,automatic]
libgcc-s1/jammy-security,jammy-updates,now 12.1.0-2ubuntu1~22.04 arm64 [installed]
libgcrypt20/jammy,now 1.9.4-3ubuntu3 arm64 [installed]
libgd3/jammy,now 2.3.0-2ubuntu2 arm64 [installed,automatic]
libgdbm-compat4/jammy,now 1.23-1 arm64 [installed,automatic]
libgdbm6/jammy,now 1.23-1 arm64 [installed,automatic]
libgdk-pixbuf-2.0-0/jammy-updates,now 2.42.8+dfsg-1ubuntu0.2 arm64 [installed,automatic]
libgdk-pixbuf2.0-common/jammy-updates,jammy-updates,now 2.42.8+dfsg-1ubuntu0.2 all [installed,automatic]
libgfortran5/jammy-security,jammy-updates,now 12.1.0-2ubuntu1~22.04 arm64 [installed,automatic]
libgif7/jammy,now 5.1.9-2build2 arm64 [installed,automatic]
libgirepository-1.0-1/jammy,now 1.72.0-1 arm64 [installed,automatic]
libgl1-mesa-dri/jammy-updates,now 22.2.5-0ubuntu0.1~22.04.1 arm64 [installed,automatic]
libgl1/jammy,now 1.4.0-1 arm64 [installed,automatic]
libglapi-mesa/jammy-updates,now 22.2.5-0ubuntu0.1~22.04.1 arm64 [installed,automatic]
libglib2.0-0/jammy-updates,now 2.72.4-0ubuntu1 arm64 [installed,automatic]
libglib2.0-bin/jammy-updates,now 2.72.4-0ubuntu1 arm64 [installed,automatic]
libglib2.0-data/jammy-updates,jammy-updates,now 2.72.4-0ubuntu1 all [installed,automatic]
libglib2.0-dev-bin/jammy-updates,now 2.72.4-0ubuntu1 arm64 [installed,automatic]
libglib2.0-dev/jammy-updates,now 2.72.4-0ubuntu1 arm64 [installed,automatic]
libglvnd0/jammy,now 1.4.0-1 arm64 [installed,automatic]
libglx-mesa0/jammy-updates,now 22.2.5-0ubuntu0.1~22.04.1 arm64 [installed,automatic]
libglx0/jammy,now 1.4.0-1 arm64 [installed,automatic]
libgme0/jammy,now 0.6.3-2 arm64 [installed,automatic]
libgmp-dev/jammy,now 2:6.2.1+dfsg-3ubuntu1 arm64 [installed,automatic]
libgmp10/jammy,now 2:6.2.1+dfsg-3ubuntu1 arm64 [installed]
libgmpxx4ldbl/jammy,now 2:6.2.1+dfsg-3ubuntu1 arm64 [installed,automatic]
libgnutls-dane0/jammy-security,jammy-updates,now 3.7.3-4ubuntu1.2 arm64 [installed,automatic]
libgnutls-openssl27/jammy-security,jammy-updates,now 3.7.3-4ubuntu1.2 arm64 [installed,automatic]
libgnutls28-dev/jammy-security,jammy-updates,now 3.7.3-4ubuntu1.2 arm64 [installed,automatic]
libgnutls30/jammy-security,jammy-updates,now 3.7.3-4ubuntu1.2 arm64 [installed]
libgnutlsxx28/jammy-security,jammy-updates,now 3.7.3-4ubuntu1.2 arm64 [installed,automatic]
libgomp1/jammy-security,jammy-updates,now 12.1.0-2ubuntu1~22.04 arm64 [installed,automatic]
libgpg-error0/jammy,now 1.43-3 arm64 [installed]
libgpiod-dev/jammy,now 1.6.3-1build1 arm64 [installed]
libgpiod2/jammy,now 1.6.3-1build1 arm64 [installed,automatic]
libgpm2/jammy,now 1.20.7-10build1 arm64 [installed,automatic]
libgraphite2-3/jammy,now 1.3.14-1build2 arm64 [installed,automatic]
libgsm1/jammy,now 1.0.19-1 arm64 [installed,automatic]
libgssapi-krb5-2/jammy-security,jammy-updates,now 1.19.2-2ubuntu0.1 arm64 [installed,automatic]
libgssapi3-heimdal/jammy,now 7.7.0+dfsg-3ubuntu1 arm64 [installed]
libgssdp-1.2-0/jammy,now 1.4.0.1-2build1 arm64 [installed,automatic]
libgssdp-1.2-dev/jammy,now 1.4.0.1-2build1 arm64 [installed,automatic]
libgstreamer1.0-0/jammy-updates,now 1.20.3-0ubuntu1 arm64 [installed,automatic]
libgupnp-1.2-1/jammy,now 1.4.3-1 arm64 [installed,automatic]
libgupnp-1.2-dev/jammy,now 1.4.3-1 arm64 [installed,automatic]
libgupnp-igd-1.0-4/jammy,now 1.2.0-1build1 arm64 [installed,automatic]
libgupnp-igd-1.0-dev/jammy,now 1.2.0-1build1 arm64 [installed,automatic]
libharfbuzz0b/jammy-security,jammy-updates,now 2.7.4-1ubuntu3.1 arm64 [installed,automatic]
libhcrypto4-heimdal/jammy,now 7.7.0+dfsg-3ubuntu1 arm64 [installed]
libheimbase1-heimdal/jammy,now 7.7.0+dfsg-3ubuntu1 arm64 [installed]
libheimntlm0-heimdal/jammy,now 7.7.0+dfsg-3ubuntu1 arm64 [installed]
libhidapi-hidraw0/jammy,now 0.11.2-1 arm64 [installed,automatic]
libhogweed5/now 3.5.1+really3.5.1-2ubuntu0.2 arm64 [installed,local]
libhogweed6/jammy,now 3.7.3-1build2 arm64 [installed,automatic]
libhwasan0/jammy-security,jammy-updates,now 12.1.0-2ubuntu1~22.04 arm64 [installed,automatic]
libhx509-5-heimdal/jammy,now 7.7.0+dfsg-3ubuntu1 arm64 [installed]
libicu-dev/jammy,now 70.1-2 arm64 [installed,automatic]
libicu70/jammy,now 70.1-2 arm64 [installed,automatic]
libidn2-0/jammy,now 2.3.2-2build1 arm64 [installed]
libidn2-dev/jammy,now 2.3.2-2build1 arm64 [installed,automatic]
libiec61883-0/jammy,now 1.2.0-4build3 arm64 [installed,automatic]
libimagequant0/jammy,now 2.17.0-1 arm64 [installed,automatic]
libip4tc2/jammy,now 1.8.7-1ubuntu5 arm64 [installed]
libip6tc2/jammy,now 1.8.7-1ubuntu5 arm64 [installed,automatic]
libiperf0/jammy,now 3.9-1build1 arm64 [installed,automatic]
libisc-export1105/jammy,now 1:9.11.19+dfsg-2.1ubuntu3 arm64 [installed]
libisl23/jammy,now 0.24-2build1 arm64 [installed,automatic]
libitm1/jammy-security,jammy-updates,now 12.1.0-2ubuntu1~22.04 arm64 [installed,automatic]
libiw30/jammy,now 30~pre9-13.1ubuntu4 arm64 [installed,automatic]
libjack-jackd2-0/jammy,now 1.9.20~dfsg-1 arm64 [installed,automatic]
libjansson-dev/jammy,now 2.13.1-1.1build3 arm64 [installed,automatic]
libjansson4/jammy,now 2.13.1-1.1build3 arm64 [installed,automatic]
libjbig0/jammy-security,jammy-updates,now 2.1-3.1ubuntu0.22.04.1 arm64 [installed,automatic]
libjpeg-dev/jammy,now 8c-2ubuntu10 arm64 [installed]
libjpeg-turbo8-dev/jammy,now 2.1.2-0ubuntu1 arm64 [installed,automatic]
libjpeg-turbo8/jammy,now 2.1.2-0ubuntu1 arm64 [installed,automatic]
libjpeg8-dev/jammy,now 8c-2ubuntu10 arm64 [installed,automatic]
libjpeg8/jammy,now 8c-2ubuntu10 arm64 [installed,automatic]
libjq1/jammy,now 1.6-2.1ubuntu3 arm64 [installed,automatic]
libjs-jquery/jammy,jammy,now 3.6.0+dfsg+~3.5.13-1 all [installed,automatic]
libjs-sphinxdoc/jammy,jammy,now 4.3.2-1 all [installed,automatic]
libjs-underscore/jammy,jammy,now 1.13.2~dfsg-2 all [installed,automatic]
libjson-c4/now 0.13.1+dfsg-7ubuntu0.3 arm64 [installed,local]
libjson-c5/jammy-updates,now 0.15-3~ubuntu1.22.04.1 arm64 [installed,automatic]
libk5crypto3/jammy-security,jammy-updates,now 1.19.2-2ubuntu0.1 arm64 [installed,automatic]
libkeyutils1/jammy,now 1.6.1-2ubuntu3 arm64 [installed,automatic]
libklibc/jammy,now 2.0.10-4 arm64 [installed]
libkmod2/jammy,now 29-1ubuntu1 arm64 [installed]
libkrb5-26-heimdal/jammy,now 7.7.0+dfsg-3ubuntu1 arm64 [installed]
libkrb5-3/jammy-security,jammy-updates,now 1.19.2-2ubuntu0.1 arm64 [installed,automatic]
libkrb5support0/jammy-security,jammy-updates,now 1.19.2-2ubuntu0.1 arm64 [installed,automatic]
libksba8/jammy-security,jammy-updates,now 1.6.0-2ubuntu0.2 arm64 [installed]
liblapack3/jammy,now 3.10.0-2ubuntu1 arm64 [installed,automatic]
liblcms2-2/jammy,now 2.12~rc1-2build2 arm64 [installed,automatic]
libldap-2.4-2/now 2.4.49+dfsg-2ubuntu1.9 arm64 [installed,local]
libldap-2.5-0/jammy-updates,now 2.5.13+dfsg-0ubuntu0.22.04.1 arm64 [installed,automatic]
libldap-common/jammy-updates,jammy-updates,now 2.5.13+dfsg-0ubuntu0.22.04.1 all [installed]
liblept5/jammy,now 1.82.0-3build1 arm64 [installed,automatic]
liblilv-0-0/jammy,now 0.24.12-2 arm64 [installed,automatic]
libllvm15/jammy-updates,now 1:15.0.6-3~ubuntu0.22.04.2 arm64 [installed,automatic]
liblocale-gettext-perl/jammy,now 1.07-4build3 arm64 [installed]
liblsan0/jammy-security,jammy-updates,now 12.1.0-2ubuntu1~22.04 arm64 [installed,automatic]
liblua5.3-0/jammy,now 5.3.6-1build1 arm64 [installed,automatic]
liblz4-1/jammy,now 1.9.3-2build2 arm64 [installed]
liblzma5/jammy,now 5.2.5-2ubuntu1 arm64 [installed]
libmagic-mgc/jammy,now 1:5.41-3 arm64 [installed,automatic]
libmagic1/jammy,now 1:5.41-3 arm64 [installed,automatic]
libmaxminddb0/jammy,now 1.5.2-1build2 arm64 [installed,automatic]
libmd-dev/jammy,now 1.0.4-1build1 arm64 [installed,automatic]
libmd0/jammy,now 1.0.4-1build1 arm64 [installed,automatic]
libmicrohttpd12/jammy,now 0.9.75-3ubuntu1 arm64 [installed,automatic]
libmm-glib0/jammy-updates,now 1.20.0-1~ubuntu22.04.1 arm64 [installed,automatic]
libmnl0/jammy,now 1.0.4-3build2 arm64 [installed]
libmount-dev/jammy,now 2.37.2-4ubuntu3 arm64 [installed,automatic]
libmount1/jammy,now 2.37.2-4ubuntu3 arm64 [installed]
libmp3lame0/jammy,now 3.100-3build2 arm64 [installed,automatic]
libmpc3/jammy,now 1.2.1-2build1 arm64 [installed,automatic]
libmpdec3/jammy,now 2.5.1-2build2 arm64 [installed,automatic]
libmpfr6/jammy,now 4.1.0-3build3 arm64 [installed,automatic]
libmpg123-0/jammy,now 1.29.3-1build1 arm64 [installed,automatic]
libmsgpackc2/jammy,now 3.3.0-4 arm64 [installed,automatic]
libmysofa1/jammy,now 1.2.1~dfsg0-1 arm64 [installed,automatic]
libnanomsg5/jammy,now 1.1.5+dfsg-1 arm64 [installed,automatic]
libncurses6/jammy,now 6.3-2 arm64 [installed]
libncursesw6/jammy,now 6.3-2 arm64 [installed]
libndp0/jammy,now 1.8-0ubuntu3 arm64 [installed,automatic]
libnetfilter-conntrack3/jammy,now 1.0.9-1 arm64 [installed,automatic]
libnettle7/now 3.5.1+really3.5.1-2ubuntu0.2 arm64 [installed,local]
libnettle8/jammy,now 3.7.3-1build2 arm64 [installed,automatic]
libnewt0.52/jammy,now 0.52.21-5ubuntu2 arm64 [installed]
libnfnetlink0/jammy,now 1.0.1-3build3 arm64 [installed,automatic]
libnfsidmap1/jammy-updates,now 1:2.6.1-1ubuntu1.2 arm64 [installed,automatic]
libnftnl11/jammy,now 1.2.1-1build1 arm64 [installed,automatic]
libnghttp2-14/jammy,now 1.43.0-1build3 arm64 [installed,automatic]
libnginx-mod-http-geoip2/jammy-security,jammy-updates,now 1.18.0-6ubuntu14.3 arm64 [installed,automatic]
libnginx-mod-http-image-filter/jammy-security,jammy-updates,now 1.18.0-6ubuntu14.3 arm64 [installed,automatic]
libnginx-mod-http-xslt-filter/jammy-security,jammy-updates,now 1.18.0-6ubuntu14.3 arm64 [installed,automatic]
libnginx-mod-mail/jammy-security,jammy-updates,now 1.18.0-6ubuntu14.3 arm64 [installed,automatic]
libnginx-mod-stream-geoip2/jammy-security,jammy-updates,now 1.18.0-6ubuntu14.3 arm64 [installed,automatic]
libnginx-mod-stream/jammy-security,jammy-updates,now 1.18.0-6ubuntu14.3 arm64 [installed,automatic]
libnice-dev/jammy,now 0.1.18-2 arm64 [installed,automatic]
libnice10/jammy,now 0.1.18-2 arm64 [installed,automatic]
libnl-3-200/jammy,now 3.5.0-0.1 arm64 [installed]
libnl-genl-3-200/jammy,now 3.5.0-0.1 arm64 [installed]
libnl-route-3-200/jammy,now 3.5.0-0.1 arm64 [installed,automatic]
libnm0/jammy-updates,now 1.36.6-0ubuntu2 arm64 [installed,automatic]
libnorm1/jammy,now 1.5.9+dfsg-2 arm64 [installed,automatic]
libnpth0/jammy,now 1.6-3build2 arm64 [installed]
libnsl-dev/jammy,now 1.3.0-2build2 arm64 [installed,automatic]
libnsl2/jammy,now 1.3.0-2build2 arm64 [installed,automatic]
libnspr4-dev/jammy,now 2:4.32-3build1 arm64 [installed,automatic]
libnspr4/jammy,now 2:4.32-3build1 arm64 [installed,automatic]
libnss3-dev/jammy-security,jammy-updates,now 2:3.68.2-0ubuntu1.2 arm64 [installed,automatic]
libnss3/jammy-security,jammy-updates,now 2:3.68.2-0ubuntu1.2 arm64 [installed,automatic]
libnuma1/jammy,now 2.0.14-3ubuntu2 arm64 [installed,automatic]
libogg0/jammy,now 1.3.5-0ubuntu3 arm64 [installed,automatic]
libonig5/jammy,now 6.9.7.1-2build1 arm64 [installed,automatic]
libopenal-data/jammy,jammy,now 1:1.19.1-2build3 all [installed,automatic]
libopenal1/jammy,now 1:1.19.1-2build3 arm64 [installed,automatic]
libopenjp2-7/jammy,now 2.4.0-6 arm64 [installed,automatic]
libopenmpt0/jammy,now 0.6.1-1 arm64 [installed,automatic]
libopus0/jammy,now 1.3.1-0.1build2 arm64 [installed,automatic]
libp11-kit-dev/jammy,now 0.24.0-6build1 arm64 [installed,automatic]
libp11-kit0/jammy,now 0.24.0-6build1 arm64 [installed]
libpackagekit-glib2-18/jammy,now 1.2.5-2ubuntu2 arm64 [installed,automatic]
libpaho-mqtt1.3/jammy,now 1.3.9-1build1 arm64 [installed,automatic]
libpam-modules-bin/jammy-security,jammy-updates,now 1.4.0-11ubuntu2.3 arm64 [installed]
libpam-modules/jammy-security,jammy-updates,now 1.4.0-11ubuntu2.3 arm64 [installed]
libpam-runtime/jammy-security,jammy-security,jammy-updates,jammy-updates,now 1.4.0-11ubuntu2.3 all [installed]
libpam-systemd/jammy-security,jammy-updates,now 249.11-0ubuntu3.7 arm64 [installed]
libpam0g/jammy-security,jammy-updates,now 1.4.0-11ubuntu2.3 arm64 [installed]
libpango-1.0-0/jammy-updates,now 1.50.6+ds-2ubuntu1 arm64 [installed,automatic]
libpangocairo-1.0-0/jammy-updates,now 1.50.6+ds-2ubuntu1 arm64 [installed,automatic]
libpangoft2-1.0-0/jammy-updates,now 1.50.6+ds-2ubuntu1 arm64 [installed,automatic]
libparted2/jammy,now 3.4-2build1 arm64 [installed,automatic]
libpcap0.8/jammy,now 1.10.1-4build1 arm64 [installed,automatic]
libpcre16-3/jammy-security,jammy-updates,now 2:8.39-13ubuntu0.22.04.1 arm64 [installed,automatic]
libpcre2-16-0/jammy-security,jammy-updates,now 10.39-3ubuntu0.1 arm64 [installed,automatic]
libpcre2-32-0/jammy-security,jammy-updates,now 10.39-3ubuntu0.1 arm64 [installed,automatic]
libpcre2-8-0/jammy-security,jammy-updates,now 10.39-3ubuntu0.1 arm64 [installed]
libpcre2-dev/jammy-security,jammy-updates,now 10.39-3ubuntu0.1 arm64 [installed,automatic]
libpcre2-posix3/jammy-security,jammy-updates,now 10.39-3ubuntu0.1 arm64 [installed,automatic]
libpcre3-dev/jammy-security,jammy-updates,now 2:8.39-13ubuntu0.22.04.1 arm64 [installed,automatic]
libpcre32-3/jammy-security,jammy-updates,now 2:8.39-13ubuntu0.22.04.1 arm64 [installed,automatic]
libpcre3/jammy-security,jammy-updates,now 2:8.39-13ubuntu0.22.04.1 arm64 [installed]
libpcrecpp0v5/jammy-security,jammy-updates,now 2:8.39-13ubuntu0.22.04.1 arm64 [installed,automatic]
libpcsclite1/jammy,now 1.9.5-3 arm64 [installed,automatic]
libperl5.34/jammy-security,jammy-updates,now 5.34.0-3ubuntu1.1 arm64 [installed,automatic]
libpgm-5.3-0/jammy,now 5.3.128~dfsg-2 arm64 [installed,automatic]
libpixman-1-0/jammy-security,jammy-updates,now 0.40.0-1ubuntu0.22.04.1 arm64 [installed,automatic]
libpng16-16/jammy,now 1.6.37-3build5 arm64 [installed,automatic]
libpocketsphinx3/jammy,now 0.8.0+real5prealpha+1-14ubuntu1 arm64 [installed,automatic]
libpolkit-agent-1-0/jammy,now 0.105-33 arm64 [installed,automatic]
libpolkit-gobject-1-0/jammy,now 0.105-33 arm64 [installed,automatic]
libpopt0/jammy,now 1.18-3build1 arm64 [installed]
libpostproc55/jammy-security,jammy-updates,now 7:4.4.2-0ubuntu0.22.04.1 arm64 [installed,automatic]
libprocps8/jammy,now 2:3.3.17-6ubuntu2 arm64 [installed]
libproxy1v5/jammy,now 0.4.17-2 arm64 [installed,automatic]
libpsl-dev/jammy,now 0.21.0-1.2build2 arm64 [installed,automatic]
libpsl5/jammy,now 0.21.0-1.2build2 arm64 [installed,automatic]
libpulse0/jammy-updates,now 1:15.99.1+dfsg1-1ubuntu2 arm64 [installed,automatic]
libpython3-dev/jammy-updates,now 3.10.6-1~22.04 arm64 [installed,automatic]
libpython3-stdlib/jammy-updates,now 3.10.6-1~22.04 arm64 [installed,automatic]
libpython3.10-dev/jammy-security,jammy-updates,now 3.10.6-1~22.04.2 arm64 [installed,automatic]
libpython3.10-minimal/jammy-security,jammy-updates,now 3.10.6-1~22.04.2 arm64 [installed,automatic]
libpython3.10-stdlib/jammy-security,jammy-updates,now 3.10.6-1~22.04.2 arm64 [installed,automatic]
libpython3.10/jammy-security,jammy-updates,now 3.10.6-1~22.04.2 arm64 [installed,automatic]
librabbitmq4/jammy,now 0.10.0-1ubuntu2 arm64 [installed,automatic]
libraqm0/jammy,now 0.7.0-4ubuntu1 arm64 [installed,automatic]
libraw1394-11/jammy,now 2.1.2-2build2 arm64 [installed,automatic]
libreadline8/jammy,now 8.1.2-1 arm64 [installed]
libroken18-heimdal/jammy,now 7.7.0+dfsg-3ubuntu1 arm64 [installed]
librsvg2-2/jammy,now 2.52.5+dfsg-3 arm64 [installed,automatic]
librtmp1/jammy,now 2.4+20151223.gitfa8646d.1-2build4 arm64 [installed,automatic]
librubberband2/jammy,now 2.0.0-2 arm64 [installed,automatic]
libsamplerate0/jammy,now 0.2.2-1build1 arm64 [installed,automatic]
libsasl2-2/jammy-updates,now 2.1.27+dfsg2-3ubuntu1.2 arm64 [installed]
libsasl2-modules-db/jammy-updates,now 2.1.27+dfsg2-3ubuntu1.2 arm64 [installed]
libsctp1/jammy,now 1.0.19+dfsg-1build1 arm64 [installed,automatic]
libsdl2-2.0-0/jammy-updates,now 2.0.20+dfsg-2ubuntu1.22.04.1 arm64 [installed,automatic]
libseccomp2/jammy,now 2.5.3-2ubuntu2 arm64 [installed]
libselinux1-dev/jammy,now 3.3-1build2 arm64 [installed,automatic]
libselinux1/jammy,now 3.3-1build2 arm64 [installed]
libsemanage-common/jammy,jammy,now 3.3-1build2 all [installed]
libsemanage2/jammy,now 3.3-1build2 arm64 [installed,automatic]
libsensors-config/jammy,jammy,now 1:3.6.0-7ubuntu1 all [installed,automatic]
libsensors5/jammy,now 1:3.6.0-7ubuntu1 arm64 [installed,automatic]
libsepol-dev/jammy,now 3.3-1build1 arm64 [installed,automatic]
libsepol1/now 3.0-1ubuntu0.1 arm64 [installed,local]
libsepol2/jammy,now 3.3-1build1 arm64 [installed,automatic]
libserd-0-0/jammy,now 0.30.10-2 arm64 [installed,automatic]
libshine3/jammy,now 3.1.1-2 arm64 [installed,automatic]
libslang2/jammy,now 2.3.2-5build4 arm64 [installed]
libsmartcols1/jammy,now 2.37.2-4ubuntu3 arm64 [installed]
libsnappy1v5/jammy,now 1.1.8-1build3 arm64 [installed,automatic]
libsndfile1/jammy,now 1.0.31-2build1 arm64 [installed,automatic]
libsndio7.0/jammy,now 1.8.1-1.1 arm64 [installed,automatic]
libsodium23/jammy,now 1.0.18-1build2 arm64 [installed,automatic]
libsofia-sip-ua0/jammy-security,jammy-updates,now 1.12.11+20110422.1-2.1+deb10u3ubuntu0.22.04.1 arm64 [installed,automatic]
libsord-0-0/jammy,now 0.16.8-2 arm64 [installed,automatic]
libsoup-gnome2.4-1/jammy,now 2.74.2-3 arm64 [installed,automatic]
libsoup2.4-1/jammy,now 2.74.2-3 arm64 [installed,automatic]
libsoup2.4-common/jammy,jammy,now 2.74.2-3 all [installed,automatic]
libsoup2.4-dev/jammy,now 2.74.2-3 arm64 [installed,automatic]
libsoxr0/jammy,now 0.1.3-4build2 arm64 [installed,automatic]
libspeex1/jammy,now 1.2~rc1.2-1.1ubuntu3 arm64 [installed,automatic]
libsphinxbase3/jammy,now 0.8+5prealpha+1-13build1 arm64 [installed,automatic]
libsqlite3-0/jammy-security,jammy-updates,now 3.37.2-2ubuntu0.1 arm64 [installed]
libsqlite3-dev/jammy-security,jammy-updates,now 3.37.2-2ubuntu0.1 arm64 [installed,automatic]
libsratom-0-0/jammy,now 0.6.8-1 arm64 [installed,automatic]
libsrt1.4-gnutls/jammy,now 1.4.4-4 arm64 [installed,automatic]
libsrtp2-1/jammy,now 2.4.2-2 arm64 [installed,automatic]
libsrtp2-dev/jammy,now 2.4.2-2 arm64 [installed,automatic]
libss2/jammy-security,jammy-updates,now 1.46.5-2ubuntu1.1 arm64 [installed]
libssh-4/jammy,now 0.9.6-2build1 arm64 [installed,automatic]
libssh-gcrypt-4/jammy,now 0.9.6-2build1 arm64 [installed,automatic]
libssh2-1/jammy,now 1.10.0-3 arm64 [installed,automatic]
libssl1.1/now 1.1.1f-1ubuntu2.17 arm64 [installed,local]
libssl3/jammy-security,jammy-updates,now 3.0.2-0ubuntu1.8 arm64 [installed,automatic]
libstdc++-11-dev/jammy-security,jammy-updates,now 11.3.0-1ubuntu1~22.04 arm64 [installed,automatic]
libstdc++6/jammy-security,jammy-updates,now 12.1.0-2ubuntu1~22.04 arm64 [installed]
libstemmer0d/jammy,now 2.2.0-1build1 arm64 [installed,automatic]
libswresample3/jammy-security,jammy-updates,now 7:4.4.2-0ubuntu0.22.04.1 arm64 [installed,automatic]
libswscale5/jammy-security,jammy-updates,now 7:4.4.2-0ubuntu0.22.04.1 arm64 [installed,automatic]
libsysfs2/jammy,now 2.1.1-1build1 arm64 [installed,automatic]
libsystemd-dev/jammy-security,jammy-updates,now 249.11-0ubuntu3.7 arm64 [installed]
libsystemd0/jammy-security,jammy-updates,now 249.11-0ubuntu3.7 arm64 [installed]
libtasn1-6-dev/jammy,now 4.18.0-4build1 arm64 [installed,automatic]
libtasn1-6/jammy,now 4.18.0-4build1 arm64 [installed]
libtcl8.6/jammy,now 8.6.12+dfsg-1build1 arm64 [installed,automatic]
libteamdctl0/jammy,now 1.31-1build2 arm64 [installed,automatic]
libtesseract4/jammy,now 4.1.1-2.1build1 arm64 [installed,automatic]
libthai-data/jammy,jammy,now 0.1.29-1build1 all [installed,automatic]
libthai0/jammy,now 0.1.29-1build1 arm64 [installed,automatic]
libtheora0/jammy,now 1.1.1+dfsg.1-15ubuntu4 arm64 [installed,automatic]
libtiff5/jammy-security,jammy-updates,now 4.3.0-6ubuntu0.4 arm64 [installed,automatic]
libtinfo6/jammy,now 6.3-2 arm64 [installed]
libtirpc-common/jammy-security,jammy-security,jammy-updates,jammy-updates,now 1.3.2-2ubuntu0.1 all [installed,automatic]
libtirpc-dev/jammy-security,jammy-updates,now 1.3.2-2ubuntu0.1 arm64 [installed,automatic]
libtirpc3/jammy-security,jammy-updates,now 1.3.2-2ubuntu0.1 arm64 [installed,automatic]
libtsan0/jammy-security,jammy-updates,now 11.3.0-1ubuntu1~22.04 arm64 [installed,automatic]
libtwolame0/jammy,now 0.4.0-2build2 arm64 [installed,automatic]
libubsan1/jammy-security,jammy-updates,now 12.1.0-2ubuntu1~22.04 arm64 [installed,automatic]
libudev1/jammy-security,jammy-updates,now 249.11-0ubuntu3.7 arm64 [installed]
libudfread0/jammy,now 1.1.2-1 arm64 [installed,automatic]
libunbound8/jammy-security,jammy-updates,now 1.13.1-1ubuntu5.3 arm64 [installed,automatic]
libunistring2/jammy,now 1.0-1 arm64 [installed]
libunwind8/jammy,now 1.3.2-2build2 arm64 [installed,automatic]
libusb-1.0-0/jammy-updates,now 2:1.0.25-1ubuntu2 arm64 [installed,automatic]
libusrsctp2/jammy,now 0.9.5.0-2 arm64 [installed,automatic]
libutempter0/jammy,now 1.2.1-2build2 arm64 [installed,automatic]
libuuid1/jammy,now 2.37.2-4ubuntu3 arm64 [installed]
libuv1/jammy,now 1.43.0-1 arm64 [installed,automatic]
libv4l-0/jammy,now 1.22.1-2build1 arm64 [installed,automatic]
libv4l2rds0/jammy,now 1.22.1-2build1 arm64 [installed,automatic]
libv4lconvert0/jammy,now 1.22.1-2build1 arm64 [installed,automatic]
libva-drm2/jammy,now 2.14.0-1 arm64 [installed,automatic]
libva-x11-2/jammy,now 2.14.0-1 arm64 [installed,automatic]
libva2/jammy,now 2.14.0-1 arm64 [installed,automatic]
libvdpau1/jammy,now 1.4-3build2 arm64 [installed,automatic]
libvidstab1.1/jammy,now 1.1.0-2 arm64 [installed,automatic]
libvorbis0a/jammy,now 1.3.7-1build2 arm64 [installed,automatic]
libvorbisenc2/jammy,now 1.3.7-1build2 arm64 [installed,automatic]
libvorbisfile3/jammy,now 1.3.7-1build2 arm64 [installed,automatic]
libvpx7/jammy,now 1.11.0-2ubuntu2 arm64 [installed,automatic]
libwayland-client0/jammy-security,jammy-updates,now 1.20.0-1ubuntu0.1 arm64 [installed,automatic]
libwayland-cursor0/jammy-security,jammy-updates,now 1.20.0-1ubuntu0.1 arm64 [installed,automatic]
libwayland-egl1/jammy-security,jammy-updates,now 1.20.0-1ubuntu0.1 arm64 [installed,automatic]
libwayland-server0/jammy-security,jammy-updates,now 1.20.0-1ubuntu0.1 arm64 [installed,automatic]
libwebp7/jammy,now 1.2.2-2 arm64 [installed,automatic]
libwebpdemux2/jammy,now 1.2.2-2 arm64 [installed,automatic]
libwebpmux3/jammy,now 1.2.2-2 arm64 [installed,automatic]
libwebsockets16/jammy,now 4.0.20-2ubuntu1 arm64 [installed,automatic]
libwind0-heimdal/jammy,now 7.7.0+dfsg-3ubuntu1 arm64 [installed]
libwrap0/jammy,now 7.6.q-31build2 arm64 [installed,automatic]
libx11-6/jammy,now 2:1.7.5-1 arm64 [installed,automatic]
libx11-data/jammy,jammy,now 2:1.7.5-1 all [installed,automatic]
libx11-xcb1/jammy,now 2:1.7.5-1 arm64 [installed,automatic]
libx264-163/jammy,now 2:0.163.3060+git5db6aa6-2build1 arm64 [installed,automatic]
libx265-199/jammy,now 3.5-2 arm64 [installed,automatic]
libxau6/jammy,now 1:1.0.9-1build5 arm64 [installed,automatic]
libxcb-dri2-0/jammy,now 1.14-3ubuntu3 arm64 [installed,automatic]
libxcb-dri3-0/jammy,now 1.14-3ubuntu3 arm64 [installed,automatic]
libxcb-glx0/jammy,now 1.14-3ubuntu3 arm64 [installed,automatic]
libxcb-present0/jammy,now 1.14-3ubuntu3 arm64 [installed,automatic]
libxcb-render0/jammy,now 1.14-3ubuntu3 arm64 [installed,automatic]
libxcb-shape0/jammy,now 1.14-3ubuntu3 arm64 [installed,automatic]
libxcb-shm0/jammy,now 1.14-3ubuntu3 arm64 [installed,automatic]
libxcb-sync1/jammy,now 1.14-3ubuntu3 arm64 [installed,automatic]
libxcb-xfixes0/jammy,now 1.14-3ubuntu3 arm64 [installed,automatic]
libxcb1/jammy,now 1.14-3ubuntu3 arm64 [installed,automatic]
libxcursor1/jammy,now 1:1.2.0-2build4 arm64 [installed,automatic]
libxdmcp6/jammy,now 1:1.1.3-0ubuntu5 arm64 [installed,automatic]
libxext6/jammy,now 2:1.3.4-1build1 arm64 [installed,automatic]
libxfixes3/jammy,now 1:6.0.0-1 arm64 [installed,automatic]
libxi6/jammy,now 2:1.8-1build1 arm64 [installed,automatic]
libxinerama1/jammy,now 2:1.1.4-3 arm64 [installed,automatic]
libxkbcommon0/jammy,now 1.4.0-1 arm64 [installed,automatic]
libxml2-dev/jammy-security,jammy-updates,now 2.9.13+dfsg-1ubuntu0.2 arm64 [installed,automatic]
libxml2/jammy-security,jammy-updates,now 2.9.13+dfsg-1ubuntu0.2 arm64 [installed,automatic]
libxmlb2/jammy,now 0.3.6-2build1 arm64 [installed,automatic]
libxpm4/jammy-security,jammy-updates,now 1:3.5.12-1ubuntu0.22.04.1 arm64 [installed,automatic]
libxrandr2/jammy,now 2:1.5.2-1build1 arm64 [installed,automatic]
libxrender1/jammy,now 1:0.9.10-1build4 arm64 [installed,automatic]
libxshmfence1/jammy,now 1.3-1build4 arm64 [installed,automatic]
libxslt1.1/jammy-security,jammy-updates,now 1.1.34-4ubuntu0.22.04.1 arm64 [installed,automatic]
libxss1/jammy,now 1:1.2.3-1build2 arm64 [installed,automatic]
libxtables12/jammy,now 1.8.7-1ubuntu5 arm64 [installed]
libxv1/jammy,now 2:1.0.11-1build2 arm64 [installed,automatic]
libxvidcore4/jammy,now 2:1.3.7-1 arm64 [installed,automatic]
libxxf86vm1/jammy,now 1:1.1.4-1build3 arm64 [installed,automatic]
libxxhash0/jammy,now 0.8.1-1 arm64 [installed,automatic]
libyaml-0-2/jammy,now 0.2.2-1build2 arm64 [installed,automatic]
libzimg2/jammy,now 3.0.3+ds1-1 arm64 [installed,automatic]
libzmq5/jammy,now 4.3.4-2 arm64 [installed,automatic]
libzstd1/jammy,now 1.4.8+dfsg-3build1 arm64 [installed]
libzvbi-common/jammy,jammy,now 0.2.35-19 all [installed,automatic]
libzvbi0/jammy,now 0.2.35-19 arm64 [installed,automatic]
linux-base/jammy,jammy,now 4.5ubuntu9 all [installed]
linux-dtb-current-sunxi64/jammy,now 23.02.2 arm64 [installed]
linux-focal-root-current-nanopineoplus2/now 21.02.1 arm64 [installed,local]
linux-image-current-sunxi64/jammy,now 23.02.2 arm64 [installed]
linux-libc-dev/jammy,now 23.02.2 arm64 [installed,automatic]
linux-u-boot-nanopineoplus2-current/jammy,now 23.02.2 arm64 [installed]
locales/jammy-updates,jammy-updates,now 2.35-0ubuntu3.1 all [installed]
login/jammy-security,jammy-updates,now 1:4.8.1-2ubuntu2.1 arm64 [installed]
logrotate/jammy-security,jammy-updates,now 3.19.0-1ubuntu1.1 arm64 [installed]
logsave/jammy-security,jammy-updates,now 1.46.5-2ubuntu1.1 arm64 [installed]
lsb-base/jammy,jammy,now 11.1.0ubuntu4 all [installed]
lsb-release/jammy,jammy,now 11.1.0ubuntu4 all [installed,automatic]
lsof/jammy,now 4.93.2+dfsg-1.1build2 arm64 [installed]
lto-disabled-list/jammy,jammy,now 24 all [installed,automatic]
lz4/jammy,now 1.9.3-2build2 arm64 [installed]
mailcap/jammy,jammy,now 3.70+nmu1ubuntu1 all [installed,automatic]
make/jammy,now 4.3-4.1build1 arm64 [installed]
mawk/jammy,now 1.3.4.20200120-3 arm64 [installed]
mc-data/jammy,jammy,now 3:4.8.27-1 all [installed,automatic]
mc/jammy,now 3:4.8.27-1 arm64 [installed]
media-types/jammy,jammy,now 7.0.0 all [installed,automatic]
mime-support/jammy,jammy,now 3.66 all [installed,automatic]
mmc-utils/jammy,now 0+git20191004.73d6c59-2 arm64 [installed]
mount/jammy,now 2.37.2-4ubuntu3 arm64 [installed]
nano/jammy,now 6.2-1 arm64 [installed]
ncurses-base/jammy,jammy,now 6.3-2 all [installed]
ncurses-bin/jammy,now 6.3-2 arm64 [installed]
ncurses-term/jammy,jammy,now 6.3-2 all [installed]
neofetch/jammy,jammy,now 7.1.0-3 all [installed]
net-tools/jammy,now 1.60+git20181103.0eebece-1ubuntu5 arm64 [installed]
netbase/jammy,jammy,now 6.3 all [installed]
netcat-openbsd/jammy,now 1.218-4ubuntu1 arm64 [installed]
nettle-dev/jammy,now 3.7.3-1build2 arm64 [installed,automatic]
network-manager/jammy-updates,now 1.36.6-0ubuntu2 arm64 [installed]
nfs-common/jammy-updates,now 1:2.6.1-1ubuntu1.2 arm64 [installed]
nginx-common/jammy-security,jammy-security,jammy-updates,jammy-updates,now 1.18.0-6ubuntu14.3 all [installed,automatic]
nginx-core/jammy-security,jammy-updates,now 1.18.0-6ubuntu14.3 arm64 [installed,automatic]
nginx/jammy-security,jammy-updates,now 1.18.0-6ubuntu14.3 arm64 [installed]
nload/jammy,now 0.7.4-2build3 arm64 [installed]
nocache/jammy,now 1.1-1 arm64 [installed]
ocl-icd-libopencl1/jammy,now 2.2.14-3 arm64 [installed,automatic]
openssh-client/jammy-updates,now 1:8.9p1-3ubuntu0.1 arm64 [installed,automatic]
openssh-server/jammy-updates,now 1:8.9p1-3ubuntu0.1 arm64 [installed]
openssh-sftp-server/jammy-updates,now 1:8.9p1-3ubuntu0.1 arm64 [installed,automatic]
openssl/jammy-security,jammy-updates,now 3.0.2-0ubuntu1.8 arm64 [installed]
packagekit/jammy,now 1.2.5-2ubuntu2 arm64 [installed,automatic]
parted/jammy,now 3.4-2build1 arm64 [installed]
passwd/jammy-security,jammy-updates,now 1:4.8.1-2ubuntu2.1 arm64 [installed]
patch/jammy,now 2.7.6-7build2 arm64 [installed,automatic]
pci.ids/jammy,jammy,now 0.0~2022.01.22-1 all [installed,automatic]
perl-base/jammy-security,jammy-updates,now 5.34.0-3ubuntu1.1 arm64 [installed]
perl-modules-5.34/jammy-security,jammy-security,jammy-updates,jammy-updates,now 5.34.0-3ubuntu1.1 all [installed,automatic]
perl/jammy-security,jammy-updates,now 5.34.0-3ubuntu1.1 arm64 [installed,automatic]
pinentry-curses/jammy,now 1.1.1-1build2 arm64 [installed]
pkexec/jammy,now 0.105-33 arm64 [installed,automatic]
pkg-config/jammy,now 0.29.2-1ubuntu3 arm64 [installed,automatic]
policykit-1/jammy,now 0.105-33 arm64 [installed,automatic]
polkitd/jammy,now 0.105-33 arm64 [installed,automatic]
procps/jammy,now 2:3.3.17-6ubuntu2 arm64 [installed]
psmisc/jammy,now 23.4-2build3 arm64 [installed]
pv/jammy,now 1.6.6-1build2 arm64 [installed,automatic]
python-apt-common/jammy-updates,jammy-updates,now 2.4.0ubuntu1 all [installed,automatic]
python3-aiofiles/jammy,jammy,now 0.8.0-2ubuntu1 all [installed]
python3-aiohttp/jammy,now 3.8.1-4build1 arm64 [installed]
python3-aiosignal/jammy,jammy,now 1.2.0-2 all [installed,automatic]
python3-appdirs/jammy,jammy,now 1.4.4-2 all [installed]
python3-apt/jammy-updates,now 2.4.0ubuntu1 arm64 [installed]
python3-asn1crypto/jammy,jammy,now 1.4.0-1 all [installed]
python3-async-timeout/jammy,jammy,now 4.0.1-1 all [installed]
python3-attr/jammy,jammy,now 21.2.0-1 all [installed,automatic]
python3-blinker/jammy,jammy,now 1.4+dfsg1-0.4 all [installed,automatic]
python3-bottle/jammy-security,jammy-security,jammy-updates,jammy-updates,now 0.12.19-1+deb11u1build0.22.04.1 all [installed]
python3-certifi/jammy,jammy,now 2020.6.20-1 all [installed,automatic]
python3-cffi-backend/jammy,now 1.15.0-1build2 arm64 [installed,automatic]
python3-cffi/jammy,jammy,now 1.15.0-1build2 all [installed]
python3-chardet/jammy,jammy,now 4.0.0-1 all [installed]
python3-charset-normalizer/jammy,jammy,now 2.0.6-2 all [installed,automatic]
python3-click/jammy,jammy,now 8.0.3-1 all [installed]
python3-colorama/jammy,jammy,now 0.4.4-1 all [installed]
python3-cryptography/jammy,now 3.4.8-1ubuntu2 arm64 [installed]
python3-dateutil/jammy,jammy,now 2.8.1-6 all [installed]
python3-dbus/jammy,now 1.2.18-3build1 arm64 [installed]
python3-dev/jammy-updates,now 3.10.6-1~22.04 arm64 [installed]
python3-distro/jammy,jammy,now 1.7.0-1 all [installed,automatic]
python3-distutils/jammy-updates,jammy-updates,now 3.10.6-1~22.04 all [installed,automatic]
python3-frozenlist/jammy,now 1.2.0-1build1 arm64 [installed,automatic]
python3-gi/jammy-updates,now 3.42.1-0ubuntu1 arm64 [installed,automatic]
python3-hidapi/jammy,now 0.2.2-1.1build2 arm64 [installed]
python3-httplib2/jammy,jammy,now 0.20.2-2 all [installed,automatic]
python3-idna/jammy,jammy,now 3.3-1 all [installed]
python3-importlib-metadata/jammy,jammy,now 4.6.4-1 all [installed,automatic]
python3-jeepney/jammy,jammy,now 0.7.1-3 all [installed,automatic]
python3-jwt/jammy-security,jammy-security,jammy-updates,jammy-updates,now 2.3.0-1ubuntu0.2 all [installed,automatic]
python3-keyring/jammy,jammy,now 23.5.0-1 all [installed,automatic]
python3-launchpadlib/jammy,jammy,now 1.10.16-1 all [installed,automatic]
python3-lazr.restfulclient/jammy,jammy,now 0.14.4-1 all [installed,automatic]
python3-lazr.uri/jammy,jammy,now 1.0.6-2 all [installed,automatic]
python3-lib2to3/jammy-updates,jammy-updates,now 3.10.6-1~22.04 all [installed,automatic]
python3-libgpiod/jammy,now 1.6.3-1build1 arm64 [installed]
python3-marshmallow/jammy,jammy,now 3.13.0-1 all [installed]
python3-minimal/jammy-updates,now 3.10.6-1~22.04 arm64 [installed,automatic]
python3-more-itertools/jammy,jammy,now 8.10.0-2 all [installed]
python3-multidict/jammy,now 5.1.0-1build2 arm64 [installed]
python3-netifaces/jammy,now 0.11.0-1build2 arm64 [installed]
python3-oauthlib/jammy-security,jammy-security,jammy-updates,jammy-updates,now 3.2.0-1ubuntu0.1 all [installed,automatic]
python3-packaging/jammy,jammy,now 21.3-1 all [installed]
python3-passlib/jammy,jammy,now 1.7.4-1 all [installed]
python3-pbr/jammy,jammy,now 5.8.0-0ubuntu1 all [installed,automatic]
python3-pil/jammy-security,jammy-updates,now 9.0.1-1ubuntu0.1 arm64 [installed]
python3-pip/jammy-security,jammy-security,jammy-updates,jammy-updates,now 22.0.2+dfsg-1ubuntu0.2 all [installed]
python3-pkg-resources/jammy-security,jammy-security,jammy-updates,jammy-updates,now 59.6.0-1.2ubuntu0.22.04.1 all [installed,automatic]
python3-ply/jammy,jammy,now 3.11-5 all [installed]
python3-psutil/jammy,now 5.9.0-1build1 arm64 [installed]
python3-pycparser/jammy,jammy,now 2.21-1 all [installed]
python3-pyelftools/jammy,jammy,now 0.27-1 all [installed]
python3-pyghmi/jammy,jammy,now 1.5.29-2 all [installed]
python3-pygments/jammy,jammy,now 2.11.2+dfsg-2 all [installed]
python3-pyotp/jammy,jammy,now 2.3.0-1 all [installed]
python3-pyparsing/jammy,jammy,now 2.4.7-1 all [installed]
python3-qrcode/jammy,jammy,now 7.3.1-1 all [installed]
python3-requests/jammy,jammy,now 2.25.1+dfsg-2 all [installed]
python3-secretstorage/jammy,jammy,now 3.3.1-1 all [installed,automatic]
python3-semantic-version/jammy,jammy,now 2.8.5-1 all [installed]
python3-setproctitle/jammy,now 1.2.2-2build1 arm64 [installed]
python3-setuptools/jammy-security,jammy-security,jammy-updates,jammy-updates,now 59.6.0-1.2ubuntu0.22.04.1 all [installed]
python3-six/jammy,jammy,now 1.16.0-3ubuntu1 all [installed]
python3-software-properties/jammy-updates,jammy-updates,now 0.99.22.6 all [installed,automatic]
python3-spidev/jammy,now 3.5-3build1 arm64 [installed]
python3-systemd/jammy,now 234-3ubuntu2 arm64 [installed]
python3-tabulate/jammy,jammy,now 0.8.9-0ubuntu1 all [installed]
python3-typing-extensions/jammy,jammy,now 3.10.0.2-1 all [installed,automatic]
python3-urllib3/jammy,jammy,now 1.26.5-1~exp1 all [installed]
python3-wadllib/jammy,jammy,now 1.3.6-1 all [installed,automatic]
python3-wheel/jammy-security,jammy-security,jammy-updates,jammy-updates,now 0.37.1-2ubuntu0.22.04.1 all [installed,automatic]
python3-wrapt/jammy,now 1.13.3-1build1 arm64 [installed]
python3-xlib/jammy,jammy,now 0.29-1 all [installed]
python3-yaml/jammy,now 5.4.1-1ubuntu1 arm64 [installed]
python3-yarl/jammy,now 1.7.2-1build1 arm64 [installed]
python3-zipp/jammy,jammy,now 1.0.0-3 all [installed,automatic]
python3/jammy-updates,now 3.10.6-1~22.04 arm64 [installed]
readline-common/jammy,jammy,now 8.1.2-1 all [installed]
resolvconf/jammy,jammy,now 1.84ubuntu1 all [installed]
rng-tools/now 5-1ubuntu2 arm64 [installed,local]
rpcbind/jammy,now 1.2.6-2build1 arm64 [installed,automatic]
rpcsvc-proto/jammy,now 1.4.2-0ubuntu6 arm64 [installed,automatic]
rsync/jammy-security,jammy-updates,now 3.2.7-0ubuntu0.22.04.2 arm64 [installed]
rsyslog/jammy-security,jammy-updates,now 8.2112.0-2ubuntu2.2 arm64 [installed]
screen/jammy,now 4.9.0-1 arm64 [installed]
sed/jammy,now 4.8-1ubuntu2 arm64 [installed]
sensible-utils/jammy,jammy,now 0.0.17 all [installed]
session-migration/jammy,now 0.3.6 arm64 [installed,automatic]
shared-mime-info/jammy,now 2.1-2 arm64 [installed,automatic]
software-properties-common/jammy-updates,jammy-updates,now 0.99.22.6 all [installed,automatic]
sudo/jammy-security,jammy-updates,now 1.9.9-1ubuntu2.3 arm64 [installed]
sunxi-tools/jammy,now 1.4.2+git20220212.08e209-1 arm64 [installed]
sysfsutils/jammy,now 2.1.1-1build1 arm64 [installed]
sysstat/jammy-security,jammy-updates,now 12.5.2-2ubuntu0.1 arm64 [installed]
systemd-sysv/jammy-security,jammy-updates,now 249.11-0ubuntu3.7 arm64 [installed]
sysvinit-utils/jammy,now 3.01-1ubuntu1 arm64 [installed]
tar/jammy-security,jammy-updates,now 1.34+dfsg-1ubuntu0.1.22.04.1 arm64 [installed]
tcl-expect/jammy,now 5.45.4-2build1 arm64 [installed,automatic]
tesseract-ocr-eng/jammy,jammy,now 1:4.00~git30-7274cfa-1.1 all [installed]
tesseract-ocr-osd/jammy,jammy,now 1:4.00~git30-7274cfa-1.1 all [installed,automatic]
tesseract-ocr/jammy,now 4.1.1-2.1build1 arm64 [installed]
tmate/jammy,now 2.4.0-2 arm64 [installed]
toilet-fonts/jammy,jammy,now 0.3-1.4 all [installed,automatic]
toilet/jammy,now 0.3-1.4 arm64 [installed]
ttyd/jammy,now 1.6.3+20210924-1build1 arm64 [installed]
tzdata/jammy-security,jammy-security,jammy-updates,jammy-updates,now 2022g-0ubuntu0.22.04.1 all [installed]
u-boot-tools/jammy-security,jammy-updates,now 2022.01+dfsg-2ubuntu2.3 arm64 [installed]
ubuntu-keyring/jammy,jammy,now 2021.03.26 all [installed]
ucf/jammy,jammy,now 3.0043 all [installed]
udev/jammy-security,jammy-updates,now 249.11-0ubuntu3.7 arm64 [installed]
unzip/jammy-security,jammy-updates,now 6.0-26ubuntu3.1 arm64 [installed,automatic]
usbutils/jammy,now 1:014-1build1 arm64 [installed]
util-linux/jammy,now 2.37.2-4ubuntu3 arm64 [installed]
uuid-dev/jammy,now 2.37.2-4ubuntu3 arm64 [installed,automatic]
v4l-utils/jammy,now 1.22.1-2build1 arm64 [installed]
vim-common/jammy-security,jammy-security,jammy-updates,jammy-updates,now 2:8.2.3995-1ubuntu2.3 all [installed,automatic]
vim-runtime/jammy-security,jammy-security,jammy-updates,jammy-updates,now 2:8.2.3995-1ubuntu2.3 all [installed,automatic]
vim/jammy-security,jammy-updates,now 2:8.2.3995-1ubuntu2.3 arm64 [installed]
wget/jammy,now 1.21.2-2ubuntu1 arm64 [installed]
whiptail/jammy,now 0.52.21-5ubuntu2 arm64 [installed]
wireguard-tools/jammy,now 1.0.20210914-1ubuntu2 arm64 [installed]
wireless-regdb/jammy-security,jammy-security,jammy-updates,jammy-updates,now 2022.06.06-0ubuntu1~22.04.1 all [installed]
wireless-tools/jammy,now 30~pre9-13.1ubuntu4 arm64 [installed]
wpasupplicant/jammy-updates,now 2:2.10-6ubuntu2 arm64 [installed,automatic]
x11-common/jammy,jammy,now 1:7.7+23ubuntu2 all [installed,automatic]
xkb-data/jammy,jammy,now 2.33-1 all [installed]
xxd/jammy-security,jammy-updates,now 2:8.2.3995-1ubuntu2.3 arm64 [installed,automatic]
xz-utils/jammy,now 5.2.5-2ubuntu1 arm64 [installed,automatic]
zip/jammy,now 3.0-12build2 arm64 [installed,automatic]
zlib1g-dev/jammy-security,jammy-updates,now 1:1.2.11.dfsg-2ubuntu9.2 arm64 [installed,automatic]
zlib1g/jammy-security,jammy-updates,now 1:1.2.11.dfsg-2ubuntu9.2 arm64 [installed]
zstd/jammy,now 1.4.8+dfsg-3build1 arm64 [installed,automatic]
No idea why It is working this way but I am sure that If I install the newest image "https://fi.mirror.armbian.de/dl/nanopineoplus2/archive/Armbian_23.02.2_Nanopineoplus2_jammy_current_5.15.93.img.xz"
Or any other Bullseye, buster, even focal, sid, any other image any other version then my USB ports does not giving me USB2.0 speeds but only USB1.1 on Nanopi Neo Plus 2 v1.2.
obviously I am running the newest kernel, and it is working.
This is very strange issue.
Can anybody Help me to resolve this to USB ports working straight from newest image ?
