Does not save selected sound card
Vidor
Hi, I have the board connected by HDMI to a TV but when I start I have no sound, I have to go to the speaker icon, configuration and the option is always selected "Speakers - internal audio" but if I want to have sound I have to choose the output option "Analogic ouput- internal audio" and if I restart I have to do the process again. According to the fine adjustment guide of ARMBIAN I must execute the command pacmd list-sinks | less And should be marked with * the selected card but none appears with that symbol. I attach the terminal output after selecting the right output on the desktop to have sound to see if someone is so kind to help me solve my problem.
Thanks a lot.
2 sink(s) available.
    index: 1
        driver: <module-alsa-card.c>
        flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY
        state: SUSPENDED
        suspend cause: IDLE
        priority: 9000
        volume: front-left: 33482 /  51% / -17.50 dB,   front-right: 33482 /  51% / -17.50 dB
                balance 0.00
        base volume: 65536 / 100% / 0.00 dB
        volume steps: 65537
        muted: no
        current latency: 0.00 ms
        max request: 0 KiB
        max rewind: 0 KiB
        monitor source: 1
        sample spec: s16le 2ch 44100Hz
        channel map: front-left,front-right
                     Estéreo
        used by: 0
        linked by: 0
        fixed latency: 99.95 ms
        card: 1 <alsa_card.platform-es8388-sound>
        module: 8
        properties:
                alsa.resolution_bits = "16"
                device.api = "alsa"
                device.class = "sound"
                alsa.class = "generic"
                alsa.subclass = "generic-mix"
                alsa.name = "dailink-multicodecs ES8323.6-0010-0"
                alsa.id = "dailink-multicodecs ES8323.6-0010-0"
                alsa.subdevice = "0"
                alsa.subdevice_name = "subdevice #0"
                alsa.device = "0"
                alsa.card = "2"
                alsa.card_name = "rockchip-es8388"
                alsa.long_card_name = "rockchip-es8388"
                device.bus_path = "platform-es8388-sound"
                sysfs.path = "/devices/platform/es8388-sound/sound/card2"
                device.form_factor = "internal"
                device.string = "hw:2"
                device.buffering.buffer_size = "17632"
                device.buffering.fragment_size = "4408"
                device.access_mode = "mmap"
                device.profile.name = "stereo-fallback"
Link to comment
Share on other sites
Armbian & Khadas are rewarding contributors
